Recording audio in iMovie is pretty easy once you know where to start. You can add voiceovers, comments, or any spoken audio right on your video timeline. Maybe you're editing a school project on your MacBook or putting travel clips together on your iPhone. This guide shows every step without making things feel confusing. You will also pick up a few simple tips for better audio. Plus, you will see how to add audio you already recorded somewhere else.
What “Recording Audio” in iMovie Actually Means
“Recording audio” in iMovie covers two different actions depending on what you need:
Recording a voiceover or narration directly inside iMovie while watching your timeline play back. This is the native, in-app recording path and the main focus of this guide.
Importing audio you recorded in another app (such as Voice Memos or GarageBand) and placing it onto the iMovie timeline.
Both options get the job done, so pick what feels right. This guide starts with recording audio in the iMovie app on Mac. After that, it covers the same process on iPhone and iPad. At the end, you'll also see how to import audio you already recorded.
How to Record a Voiceover in iMovie on Mac
The Mac version of iMovie includes a dedicated voiceover tool that lets you record narration in sync with video playback. Here is the complete workflow.
Before You Start: Check Your Microphone Input
Before you open iMovie, confirm the correct microphone is selected. Go to System Preferences (or System Settings on macOS Ventura and later) > Sound > Input and choose your preferred device. The built-in mic works for casual use, but an external USB or 3.5mm condenser microphone delivers noticeably cleaner results. Whatever mic you use, position it roughly 6 to 10 inches from your mouth to capture clear speech without excessive room reverb.
Tip: If you connect an external mic after iMovie is already open, quit and relaunch the app so it registers the new input device correctly.
Using the Voiceover Tool (Step-by-Step)
Open your project. Double-click the project in the iMovie library to open it in the editing timeline.
Position the playhead. Click the exact point in the timeline where you want your voiceover to begin. The playhead (the vertical white line) will snap to that position.
Open the Voiceover tool. Click the microphone icon in the toolbar above the Viewer window. If you cannot find the icon, go to Window > Record Voiceover in the menu bar. A voiceover panel will appear below the Viewer.
Select your input source. In the voiceover panel, click the adjustment icon, and use the Input source dropdown to confirm which microphone iMovie is using.
Set your microphone volume level using the volume slider. Speak a few test sentences and watch the level meter. Aim for consistent green with brief touches of yellow, and keep it out of the red entirely.
Mute original clip audio if needed. Select the clip for which you want to mute the audio. Hover your cursor on the white horizontal volume line until the cursor changes its shape. Click on the white volume line and drag it downwards until the volume reaches 0.
Click the red Record button. iMovie counts down from three before recording starts, giving you a beat to get ready.
Speak your narration. The voiceover records in real time as the video plays through the Viewer. Speak clearly and at a steady pace.
Click Stop (or press the Space bar) when finished. The recorded clip appears as a green audio clip on the timeline, starting from the playhead position. Trim the edges or drag the clip to fine-tune its placement.
How to Record Audio in iMovie on iPhone and iPad
The iPhone and iPad version keeps everything in a different layout. Relax! It still feels easy after a minute. You will tap your way through every recording step on screen. There are no floating windows like the Mac version.
Step-by-Step for iOS
Open your project. Tap the project in the Projects screen, then tap the project thumbnail to open it in the editor.
Position the playhead. Scroll the timeline and tap the spot where you want the audio recording to start. The playhead should sit at the exact frame you want.
Access the Voiceover. Tap the Add Media button (+), and select the Voiceover option.
Allow Microphone Access: If the microphone access prompt shows up, tap Settings and toggle on the microphone option.
Once done, go back to the Add Media option and select the Voiceover option.
Tap the red Record button. A short countdown appears before recording begins.
Speak your narration. The timeline scrolls as you record, so you can watch your footage and match your words to the visuals.
Tap Stop when finished. A preview of the recorded clip appears on screen.
Tap Accept to place the clip on the timeline. If the take did not go well, tap Retake and record again. The accepted clip drops into a separate audio track below your video clips.
Trim or reposition as needed. Tap the audio clip and drag the yellow handles at either end to trim, or slide the whole clip left or right to adjust timing.
By default, iMovie uses the iPhone’s built-in microphone or any connected headset mic. For better results, an external microphone connected to your Lightning or USB-C port makes a clear difference in recording quality.
How to Import Pre-Recorded Audio into iMovie
If you prefer to record audio in a dedicated app first and then bring it into iMovie, the process is quick on both platforms.
Platform |
How to Import |
Mac |
Drag an audio file directly from Finder onto the iMovie timeline, or click the Import Media button in the toolbar to browse for your file. Audio exported from GarageBand as an AIFF or M4A file imports the same way. |
iPhone / iPad |
Tap the Add Media (+) button in the timeline, select Files, and browse iCloud Drive or local storage for your audio file. Voice Memos recordings can also be shared directly into iMovie using the share sheet inside the Voice Memos app. |
Try this if you want your audio ready before editing starts. It gives you time to fix mistakes and sound more natural.
Tips to Get Better Audio Quality in iMovie
The microphone you use and how you set up your recording space matter far more than any in-app setting. These five adjustments will produce noticeably cleaner audio.
Record in a quiet, soft-furnished space. Hard walls create echo and room noise. A bedroom with carpet and curtains, a closet full of clothes, or even a blanket draped around yourself and your laptop will absorb sound and reduce reverb significantly.
Position the microphone correctly. Keep the mic 6 to 10 inches from your mouth and angle it slightly off-axis rather than directly in front of your lips. This reduces plosive sounds from hard “p” and “b” consonants.
Watch your gain levels. In the iMovie voiceover panel on Mac, run a short test and watch the level meter. Consistent green with occasional brief touches of yellow is ideal. Clipping in the red distorts the recording and is difficult to fix in post.
Mute original clip audio when recording replacement narration. If your video clips carry ambient or camera audio you no longer need, mute them before laying down the voiceover so they do not bleed into the narration recording.
Upgrade to an external microphone. Even a current MacBook or iPhone’s built-in mic picks up keyboard noise, fan hum, and room echo. For vloggers and content creators who want wireless freedom during voiceover or on-camera narration sessions, the Hollyland LARK M2 is a practical choice. It weighs just 9 grams, lasts up to 40 hours on a single charge, and moves with you whether you are at a desk or on location. If you record primarily on iPhone and want a simpler setup, the Hollyland LARK A1 plugs directly into a Lightning or USB-C port with no pairing required, making it a natural plug-and-play upgrade for iMovie on iOS. A cleaner source signal means less time trying to salvage audio after the fact.
Why is there no sound when I record audio in iMovie?
The most common causes are an incorrect microphone input selection or blocked app permissions. On Mac, go to System Settings > Sound > Input to confirm the right mic is active, then check System Settings > Security and Privacy > Microphone to make sure iMovie has access. On iPhone or iPad, go to Settings > Privacy > Microphone and toggle iMovie on.
Can I record audio and video at the same time in iMovie?
Not natively inside iMovie itself. The voiceover tool records audio only while playing back existing footage. To capture video and audio together in the same take, record the clip with your iPhone camera app first, import it into iMovie, and then use the voiceover tool to layer any additional narration on top of it.
How do I add background music and a voiceover at the same time in iMovie?
iMovie supports multiple audio layers on the same timeline. Record or import your voiceover first using the steps above, then add a background music track from the iMovie Music browser or by importing a file. Lower the music clip’s volume slider (the white horizontal line on the clip) so it sits comfortably under the narration without drowning it out.
Recording audio in iMovie is simple on both Mac and iPhone. Before exporting, adjust the volume and reduce background noise if needed. Those small changes can make your voice sound much better. A good microphone also helps your audio sound cleaner from the beginning.
