How to Cut Audio in iMovie (Mac and iPad/iPhone Guide)
Cutting audio in iMovie is one of the most common editing tasks, and it is easier than it looks once you know where to find the right controls. Whether you need to shorten a clip, remove a distracting sound from the middle of a recording, or separate audio from video entirely, iMovie gives you a few distinct methods to get there. This guide explains each approach for both Mac and iPhone/iPad users.
How to Cut Audio in iMovie (Mac and iPhone Guide)
What Does “Cutting Audio” Mean in iMovie?
“Cutting audio” is not a single action in iMovie. It covers three related but different tasks:
  • Trimming the edges of a clip to shorten it
  • Splitting a clip at a specific point to remove a middle segment,
  • Detaching the audio track from its video so you can edit each one independently.
Knowing which method matches your goal will save you time and frustration.
How to Trim Audio in iMovie on Mac
Trimming shortens a clip from its beginning or end. It is the quickest way to remove unwanted audio at either edge of a clip, and every change is non-destructive, meaning your original file stays untouched.
  1. Open your project in iMovie and locate the clip in the timeline.
  2. Click the clip once to select it. A yellow border appears around the clip.
  3. Hover your cursor over the left or right edge of the clip until the cursor changes to a trim handle (a small arrow icon).
  1. Click and drag the edge inward to shorten the clip. Drag the left edge to the right to remove audio from the start, or drag the right edge to the left to trim the end.
  2. Release the mouse when you reach the desired cut point. The clip updates immediately.
  3. Press the spacebar to preview the result and confirm the trim sounds natural.
Note: Dragging the edge outward extends the clip back toward its original length, as long as the original media has unused content in that direction.
Trim Audio Waveform View
Enabling the audio waveform gives you a visual representation of sound levels, which makes it much easier to find the exact trim point before you drag.
  1. Click the Settings button under the preview window and select “Show Waveforms.”
  1. Look at the waveform pattern along the bottom of each clip. Flat lines indicate silence or very low audio; peaks show louder portions.
  2. Use the waveform as a visual guide when dragging your trim handles so you can snap to a natural pause rather than guessing by time code.
How to Split and Remove a Section of Audio in iMovie on Mac
Splitting is the method to use when you need to cut out a segment from the middle of a clip, such as a cough, a long pause, or an unwanted noise. The process involves creating two split points and then deleting whatever sits between them.
  1. Click the clip in the timeline to select it. Once the audio clip is selected, it will be surrounded by a bright yellow border.
  1. Move the playhead (the white vertical line) to the point where you want the first cut. Use the arrow keys to nudge it one frame at a time for precision.
  1. Split the clip by pressing Command+B on your keyboard.
Or you can right-click the audio clip and select Split Clip from the menu.
The clip divides at the playhead position.
  1. Move the playhead forward to the second cut point, the end of the section you want to remove.
  2. Press Command+B again to split the clip a second time. You now have three separate segments.
  3. Click the middle segment (the one you want to delete) to select it.
  4. Press the Delete key. The unwanted section is removed.
Note: This method works on a standard video clip (trimming both audio and video together) or on a detached audio-only track. See the next section for how to split audio independently of the video.
How to Detach Audio from Video and Cut It Independently
Sometimes you want to cut or trim the audio portion of a clip without touching the video frame. The classic use case is cutting dead-air audio or a mic bump while keeping the visual footage intact. Detaching the audio creates a separate, editable green track in the timeline.
  1. Right-click the clip in the timeline that contains the audio you want to edit.
  2. Select “Detach Audio” from the context menu. A green audio track appears directly below the original clip in the timeline.
  1. Click the green audio track to select it. It is now independent from the video above it.
  2. Apply trimming or splitting to the audio track using the same techniques described in the previous sections. Drag the edges to trim, or use Command+B to split at specific points and then delete the unwanted segment.
  3. Leave the video track untouched. The footage above continues playing normally while the audio underneath has been cut.
  4. Preview the result by pressing the spacebar. If there is an audible gap where you deleted audio, consider adding a short audio fade to smooth the transition.
How to Cut Audio in iMovie on iPhone and iPad
The iMovie iOS app uses a touch-based interface, so the controls look different from the Mac version, but the core actions, such as trimming and splitting, are both available.
To trim audio on iPhone or iPad:
  1. Tap the clip in the timeline to select it. Yellow handles appear at each end.
  1. Tap the audio icon (the speaker symbol) in the bottom toolbar to enter audio editing mode, if needed.
  2. Press and hold the yellow handle at the left or right edge of the clip.
  3. Drag the handle inward to shorten the clip from the start or end.
  1. Tap anywhere outside the clip to deselect and confirm the change.
To split a clip on iPhone or iPad:
  1. Scrub the timeline by dragging it left or right until the white playhead line sits at the point where you want to cut.
  2. Tap the clip again and then tap “Split” from the action menu that appears. The clip divides at the playhead.
  1. Repeat the process to create a second split point if you need to remove a middle section.
  2. Tap the segment you want to remove and then tap “Delete.”
Quick Tips for Cleaner Audio Cuts in iMovie
  • Use audio fade handles. After trimming or splitting, drag the small round handle at the start or end of an audio segment to add a quick fade-in or fade-out and avoid jarring hard cuts.
  • Zoom into the timeline for precision. Pinch to zoom on Mac trackpad (or use the zoom slider) to expand the timeline and see smaller intervals before placing your playhead.
  • Press Command+Z on Mac to undo immediately if a trim or split does not land where you intended. You can undo multiple steps in sequence.
  • Check audio levels after every cut. A deleted segment can cause volume inconsistencies where clips now sit next to each other; listen through and adjust levels in the clip inspector if needed.
Can I cut just the audio without cutting the video in iMovie?
Yes. Right-click the clip in your Mac timeline and choose “Detach Audio.” This separates the audio into its own green track below the video. From there, you can trim, split, or delete portions of the audio without making any changes to the video track above it.
How do I delete a section of audio in the middle of a clip?
Move the playhead to the start of the section and press Command+B to split the clip. Move the playhead to the end of the section and press Command+B again. Click the segment between the two split points to select it, then press the Delete key to remove it.
Why is my audio cut creating a gap in iMovie?
When you delete a clip segment, iMovie leaves the empty space in the timeline by default. To close the gap, manually drag the clips on either side together to fill the space.
Does cutting audio in iMovie affect the original file?
No. iMovie is a non-destructive editor, which means all edits are stored as instructions inside the project. Your original media file on disk remains completely unchanged. You can always re-extend a trimmed clip back to its full length.
Can I cut audio in iMovie on iPhone the same way as on Mac?
Both Mac and iPhone let you trim clips and split them anywhere. The iPhone version relies on touch controls instead of keyboard shortcuts. Its editing tools are also simpler than the Mac version. But options like Detach Audio and Split are available in the Actions menu.
Trimming, splitting, and separating audio from video are the main editing methods in iMovie. If you keep cutting out pops, rustling, or other unwanted sounds, the problem may have started during recording. Cleaner recordings usually need much less editing later. Therefore, a dedicated wireless microphone like the Hollyland LARK M2 can help capture cleaner sound from the beginning. After finishing your cuts, adjust your audio levels and add background music if needed.
