Splitting audio in Premiere Pro is one of those tasks that sounds simple until you accidentally cut your video clip too, or you can not figure out which tool to use. Whether you need to remove a section of audio, cut a music track at a specific beat, or isolate a spoken line, this guide covers three reliable methods and shows you exactly how to split only the audio without touching the video.
What “Splitting” Audio Means in Premiere Pro
Splitting a clip means cutting it into two separate segments at a chosen point on the timeline so each piece can be moved, trimmed, or deleted independently. The key distinction to understand before you start: splitting a linked clip will cut both the audio and video together by default. If you only want to cut the audio, you need to control which tracks are targeted first, and that is what makes method choice matter.
Method 1 — Split Audio with a Keyboard Shortcut (Fastest)
The keyboard shortcut method uses the Add Edit command, which cuts a clip at the exact position of your playhead. This is the fastest approach and gives you frame-accurate splits without switching tools.
Drag the playhead in the timeline to the point where you want to split the audio. You can also press the spacebar to play, then tap K to pause at the right moment.
Look at the track header panel on the left side of the timeline. You will see track targeting icons for your video track (V1) and your audio tracks (A1, A2, etc.).
Confirm that the audio track you want to cut is targeted (highlighted). Deactivate V1 if you only want to split audio. See the section below for exactly how to do this.
Press Ctrl+K on Windows or Cmd+K on Mac.
The audio clip splits into two segments at the playhead. The video track stays untouched if V1 was deactivated.
How to Target Only the Audio Track Before Cutting
Track targeting tells Premiere Pro which tracks to include when you press the Add Edit shortcut. All active (highlighted) tracks get cut. Here is how to isolate just the audio:
Look at the track headers on the left side of your timeline panel.
Click the V1 track header to deactivate it. The highlight will turn off, indicating the video track is no longer a target.
Click the A1 header (and A2 if needed) to confirm it is active and highlighted.
Place your playhead at the split point, then press Ctrl+K / Cmd+K.
Only the active audio tracks will be cut. Your video is completely unaffected.
Note: Reactivate V1 when you are done. Leaving video targeting off is easy to forget, and it can cause confusion when later edits do not seem to apply to your video track.
Method 2 — Split Audio Using the Razor Tool
The Razor Tool is a visual, click-to-cut approach. Many beginners prefer it because you can see precisely where the cut will land without relying on playhead placement.
Press C on your keyboard to activate the Razor Tool. Your cursor changes to a razor blade icon.
Hover over the audio clip in the timeline. A vertical guide line shows where the cut will fall.
Click on the audio clip at the point you want to split it. The clip immediately divides into two segments.
Press V to return to the Selection Tool so you do not accidentally make extra cuts while navigating the timeline.
Important: If the audio and video are still linked, clicking the audio portion of a linked clip cuts the audio visually but the two segments will still move together. Use Method 3 to unlink them first if you need to reposition the audio independently afterward.
Shift-click behavior: Holding Shift while using the Razor Tool cuts every track at that point simultaneously. This is useful when you want a single clean cut across your entire timeline at once.
Method 3 — Unlink Audio from Video, Then Split Independently
Use this method when you need to cut the audio at a different point than the video, or when you want full independence between the two after splitting.
Right-click on the linked clip in your timeline.
Select Unlink from the context menu. The audio and video portions are now separate clips.
Click somewhere on the empty timeline area to deselect everything. Skipping this step is a common mistake. If both tracks are still selected, your next action may affect both of them.
Click only the audio portion of the clip to select it.
Move your playhead to the desired split point, then press Ctrl+K / Cmd+K, or click at that position with the Razor Tool.
The audio splits at your chosen point while the video clip remains exactly as it was.
Note: Unlinking creates a risk of sync drift if you drag the independent clips around carelessly. To re-link them later, select both the audio and video clips, right-click, and choose Link. Premiere Pro will flag a warning if they have gone out of sync.
Quick Tips to Keep Your Timeline Clean After Splitting
Use Ripple Delete to close gaps: Right-click an empty space left by a deleted audio segment and select Ripple Delete. This pulls everything downstream forward and closes the gap automatically.
Rename split clips: Double-click a clip name in the timeline to rename it. Useful when you have several segments from the same source file and need to stay organized.
Enable Snap to Playhead: Press S to toggle snapping on. This ensures your Razor Tool cuts and playhead-based edits land precisely at the correct frame rather than drifting a few frames off.
Undo a bad cut immediately: Press Ctrl+Z on Windows or Cmd+Z on Mac. Premiere Pro holds a generous undo history, so recovering from an accidental split is almost always straightforward.
How do I split just the audio and not the video in Premiere Pro?
Deactivate the video track (V1) in the track header panel by clicking it so the highlight turns off. Make sure your audio tracks (A1, A2, etc.) are still active. Then press Ctrl+K on Windows or Cmd+K on Mac. Premiere Pro will cut only the targeted audio tracks and leave the video clip completely untouched.
What is the keyboard shortcut to split a clip in Premiere Pro?
The shortcut is Ctrl+K on Windows and Cmd+K on Mac. In Premiere Pro’s menu, this command is listed as “Add Edit” under Sequence > Add Edit. It cuts all currently targeted tracks at the playhead position, so make sure only the tracks you want cut are active before pressing it.
Can I split multiple audio tracks at the same time?
Yes. Click each audio track header (A1, A2, A3, etc.) in the timeline panel so all the tracks you want to cut are highlighted and active. Then press Ctrl+K / Cmd+K once. Every active track splits at the playhead simultaneously. Deactivate any tracks you want to leave uncut before pressing the shortcut.
Why does my Razor Tool cut both audio and video?
The clip is linked, meaning the audio and video tracks are tied together as one unit. Clicking a linked clip with the Razor Tool cuts both tracks at once. To cut audio only, either unlink the clip first (right-click > Unlink) or switch to the keyboard shortcut method with V1 deactivated in your track targeting.
For most situations, the keyboard shortcut (Ctrl+K / Cmd+K) with the correct track targeting active is the fastest and most precise way to split audio in Premiere Pro. Use the Razor Tool when you prefer a direct, visual approach. When your audio and video need to be cut at different points, unlink the clip first and then split each track independently. Once your audio is trimmed the way you want, a practical next step is learning how to remove background noise in Premiere Pro to clean up each split segment.
