How to Create a Split Screen in Premiere Pro (3 Methods, Step by Step)
Split screen effects are one of those techniques that look complex but come together quickly once you know the right workflow. Whether you are editing a reaction video, a product comparison, or a multi-angle interview, Premiere Pro has at least three reliable ways to get the job done. This guide covers each method in order of complexity so you can pick the one that fits your project and start building immediately.
What Is a Split Screen — and When Should You Use It?
A split screen divides the video frame into two or more panels, each showing a different clip at the same time. It is a straightforward technique with a wide range of practical applications. This guide covers Adobe Premiere Pro CC (2020 through 2024).
Common use cases include:
  • Reaction videos — showing the reactor and the source content side by side
  • Before/after comparisons — product demos, transformations, or location changes
  • Interview setups — two subjects filmed separately, presented as a conversation
  • Sports highlights — multiple camera angles playing simultaneously for analysis or drama
Method 1 — Manual Split Screen Using Position and Scale (Fastest for 2 Clips)
This is the go-to method for a straightforward two-panel split. It uses only the Effect Controls panel and requires no additional effects or plugins. Most editors reach for this approach first because it is fast, flexible, and easy to revisit if the layout needs tweaking.
Steps:
  1. Set your sequence resolution. Go to Sequence > Sequence Settings and confirm the frame size is at least 1920x1080. A higher resolution gives you more room to reposition clips without losing quality.
  2. Stack your two clips on separate tracks. Place the first clip on V1 and the second clip on V2 in the timeline. Both clips should span the same duration.
  1. Select the clip on V1 and open Effect Controls. Under the Motion section, find the Position property. The default X value for a 1920x1080 sequence is 960. Change it to approximately 480 to push the clip to the left half of the frame.
Alternatively, hover the mouse in the position until the cursor changes. Then, click and drag to the left or right and watch the clip move in the monitor.
  1. Repeat for the clip on V2. Set the Position X value to approximately 1440 to push it to the right half.
  2. Adjust Scale for each clip. If the clips do not fill their half of the frame cleanly, reduce the Scale value until they fit. Avoid scaling above 100% — this is addressed in the troubleshooting note below.
  3. Optional: add a solid color bar as a divider. Right-click in the Project panel, select New Item > Color Matte, choose a color (white or black work well), and place it on V3. Resize it to a thin vertical strip using Position and Scale in Effect Controls.
Pro Tip: For interview-style split screens where each subject is filmed separately, audio bleed between panels is a common problem that starts at the recording stage, not the editing stage. A dual-channel wireless system like the Hollyland LARK MAX 2 — which records at 48 kHz / 32-bit Float with AI noise cancellation — gives each subject a fully isolated audio channel, making it much easier to manage levels and muting in Premiere Pro later.
Note on blurry clips: If a clip looks soft or pixelated after repositioning, the source footage resolution is likely lower than the sequence resolution. Scaling a 1080p clip inside a 4K sequence, for example, forces Premiere Pro to interpolate pixels and the result looks blurry. Use source footage that matches or exceeds your sequence resolution, or lower your sequence output resolution to match your source.
How to Add a Divider Line Between Panels
A visible border between panels makes the split look intentional and polished. There are two clean ways to add one.
Option A: Solid Color Matte (simplest)
  1. In the Project panel, right-click and select New Item > Color Matte.
  2. Choose your divider color and click OK.
  3. Place the matte on V3, above both clips in the timeline.\
  1. In Effect Controls, set Scale Width to a low value (around 0.5 to 1%) and leave Scale Height at 100%.
  2. Set Position X to 960 (center of a 1080p frame) to align it with the split.
Option B: Shape from Essential Graphics
  1. Go to Window > Essential Graphics to open the panel.
  2. Click the rectangle shape tool and draw a thin vertical bar over the split line in the Program Monitor.
  3. Adjust the fill color, width, and position directly in the Essential Graphics panel.
  4. This method makes it easy to add a label or stroke style at the same time.
Method 2 — Split Screen with the Crop Effect (Cleaner Hard Edges)
When you need pixel-precise panel edges or an unequal split (such as a 40/60 or 30/70 layout), the Crop effect gives you more control than Position and Scale alone. Cropping removes pixels from the edge of the frame rather than shrinking the entire clip, which eliminates the interpolation artifacts that can appear when you rely on Scale to fit clips into their panels.
Steps:
  1. Apply the Crop effect to your first clip. Go to Effects > Video Effects > Transform > Crop (or Legacy > Video Effects > Crop). Drag it onto the clip on V1.
  2. In Effect Controls, set the Right crop value to 50%. This removes the right half of the clip, leaving a clean left panel with no scaling distortion.
  1. Apply the Crop effect to your second clip (on V2). Set the Left crop value to 50%. This removes the left half, creating a matching right panel.
  2. For unequal splits, adjust the percentages. If you want a 40/60 layout, set the first clip’s Right crop to 60% and the second clip’s Left crop to 40%. The numbers represent how much of the frame is removed, so they should add up to 100%.
  3. Use Position only for minor alignment corrections. Because cropping handles the edge definition, Position adjustments should be small — used only to nudge a clip up, down, or sideways within its panel.
  4. Combine with Method 1 for scale control when needed. If your source clip is wider or taller than the panel, use Scale in the Motion section alongside the Crop values to fit the image correctly.
The Crop method is particularly useful when the divider between panels needs to be a sharp, clean line with no overlap or gap between the two images.
Method 3 — Multi-Camera Sequence for 3+ Clips or Synced Footage
For projects with three or more panels, or any situation where audio sync across multiple clips is critical, a multi-camera source sequence is the most reliable approach. It is more involved than Methods 1 and 2, but it handles synchronization in a way that manual positioning cannot.
Use this method when: - You are building a three-panel or four-panel split screen - Your clips were filmed simultaneously and need to stay in sync (sports coverage, multi-angle interviews) - You want Premiere Pro to manage clip alignment automatically based on audio waveforms or timecode
Steps:
  1. Select all the clips you want to sync in the Project panel. Right-click and choose Create Multi-Camera Source Sequence. In the dialog, choose your sync method (Audio, Timecode, or In/Out points depending on how the footage was recorded).
  2. Premiere Pro creates a new nested sequence containing all the synced clips stacked and aligned. This appears in your Project panel.
  3. Drag the multi-camera source sequence into a new main timeline. This is your working sequence where you will build the split-screen layout.
  1. Right-click the nested sequence in the timeline and select Multi-Camera > Enable. This activates the multi-camera view in the Program Monitor.
  2. Scale and position each nested instance in Effect Controls, just as you would in Method 1. For a three-panel split at 1920x1080, divide the frame into thirds: Position X values of approximately 320, 960, and 1600 work as a starting point.
Because the clips are already synced inside the nested sequence, any timing adjustments made during the edit remain accurate across all panels simultaneously.
Customizing Your Split Screen
Once the panels are in place, several customization options can significantly improve the final look of the edit.
  • Animating the split: Add keyframes to the Position property in Effect Controls to make panels slide in from off-screen. Set a keyframe at the starting position (off-frame) and a second keyframe one second later at the final position. Premiere Pro interpolates the movement automatically. Use Ease In / Ease Out on the keyframes for a smoother result.
  • Color grading individual panels: Place an adjustment layer above each video track and apply Lumetri Color to it. Because each adjustment layer sits directly above only one clip track, color corrections stay isolated to that panel. This is cleaner than applying Lumetri directly to the clips, especially if you need to revisit the grade later.
  • Adding text labels per panel: Open the Essential Graphics panel and use the text tool to place a label (such as a subject name or location) within each panel’s boundary. Pin the text layer to its corresponding video track so it moves with the clip if the timeline is rearranged.
  • Managing audio across panels: Right-click each clip and select Unlink to separate the audio from the video. Mute audio tracks you do not want to hear, or lower individual track levels in the Audio Track Mixer. For split screens with two subjects speaking, consider routing each clip’s audio to a separate submix channel so they can be balanced independently.
Common Mistakes and How to Fix Them
Problem
Cause
Fix
Clips look blurry or pixelated
Source resolution is lower than the sequence, forcing upscaling
Use source footage that matches or exceeds the sequence resolution; or lower the sequence output resolution to match the source
Black bars appear at panel edges
Sequence aspect ratio does not match the source clip aspect ratio
Check Sequence Settings and confirm the frame size and pixel aspect ratio match your source footage
Audio from both clips plays simultaneously
Both clips retain their original audio tracks, which play together by default
Unlink audio from each clip, then mute unwanted audio tracks or route each clip’s audio to a separate channel in the Audio Track Mixer
Free Split Screen Presets for Premiere Pro (Save Time)
If you want to skip the manual setup, several reputable platforms offer free split screen templates that import directly into Premiere Pro as .mogrt files (Motion Graphics Templates).
To install a .mogrt file, go to Window > Essential Graphics, click the Browse tab, and use the menu to install the file. It then appears in your Essential Graphics library and can be dragged directly into the timeline.
Reliable free sources include:
  • Motion Array (motionarray.com) — large library of free and premium Premiere Pro templates, including multi-panel split screen layouts
  • Mixkit (mixkit.co) — free .mogrt templates with no account required for download
  • Adobe Exchange (exchange.adobe.com) — official Adobe marketplace with community-submitted templates verified for compatibility
Q: Can I create a split screen in Premiere Pro without plugins?
Yes — Methods 1 and 2 (Position/Scale and the Crop effect) are fully native to Premiere Pro and require no third-party plugins or extensions. All the tools used in this guide come standard with any active Premiere Pro CC subscription.
Q: How do I make a vertical split screen for Instagram Reels or TikTok?
Before building the split, go to Sequence Settings and change the frame size to 1080x1920 (vertical). Then follow the same Position/Scale steps from Method 1, but adjust clips to the top and bottom halves of the frame instead of left and right.
Q: Why do my split screen clips look pixelated after editing?
This almost always means the source clip resolution is lower than the sequence output resolution. Scaling a low-resolution clip up to fill its panel causes interpolation and visible pixelation. Use higher-resolution source footage or reduce the sequence output resolution to match your source material.
Q: Can I have more than two panels in a Premiere Pro split screen?
Yes. Stack additional clips on V3, V4, and so on. Divide the frame into thirds or quarters using Position and Crop values, and use Method 3 (multi-camera sequence) if the clips need to stay synced. The math is straightforward: for thirds in a 1920x1080 frame, each panel is 640 pixels wide.
Q: How do I sync audio and video in a split screen?
Use Premiere Pro’s Merge Clips feature (right-click clips in the Project panel) or the Multi-Camera Source Sequence workflow from Method 3. Both options let Premiere Pro align clips automatically using audio waveform matching or timecode, which is far more accurate than manual alignment on the timeline.
For a quick two-panel layout, Method 1 (Position and Scale) is the fastest path. When you need precise, distortion-free edges or an asymmetric split, reach for Method 2 (Crop effect). For three or more panels, or any project where sync accuracy matters, Method 3 (multi-camera sequence) is worth the extra setup time. Before starting any of these methods, confirm your sequence settings first — it is the step most editors skip and the one that causes the most rework later.
To continue building your Premiere Pro workflow, explore related guides on color grading with Lumetri Color and essential Premiere Pro keyboard shortcuts.
