How to Change Caption Style in Premiere Pro (Step-by-Step)
Default caption styling in Premiere Pro is functional but rarely looks good out of the box. If your captions feel off-brand or hard to read, you need to know where the styling controls live and how to use them efficiently. This guide covers how to change font, color, background, and other visual properties using the Text panel, how to save those settings as a reusable Caption Style preset, and how to apply one consistent look to every caption in your project at once.
Before You Start: Check Your Caption Setup
Before changing anything, confirm you already have a caption track on your Premiere Pro timeline. If you see a track labeled “Captions” or “Subtitles” in your sequence, you are ready to proceed. This article focuses on the standard subtitle and caption track workflow, which covers the most common use cases in Premiere Pro 2026.
How to Change Caption Style in Premiere Pro — Core Method
The main workflow for styling caption track entries runs through the Text panel. Here is the full step-by-step process.
Step 1 — Open the Text Panel
Go to Window > Text to open the Text panel. Once open, click the Captions tab at the top of the panel. This tab displays all caption entries in your current sequence, listed in order.
You can also access the Text panel through Premiere Pro’s Captions workspace, which is selectable from the workspace menu at the top of the application. Before moving on, confirm that your caption entries are visible in the list.
Step 2 — Select a Caption Clip
Click any caption entry in the Text panel list, or click directly on a caption clip in the timeline. Either action selects the clip and activates the styling controls in the right-hand pane of the Text panel.
If the controls appear greyed out, click the caption clip directly in the timeline to confirm it is fully selected. The right-hand pane should populate with font, color, and layout options as soon as a valid caption clip is active.
Step 3 — Adjust Caption Style Properties
With a caption clip selected, the right-hand pane of the Text panel gives you access to the following styling properties:
  • Font family and weight: Use the font dropdown to select any font installed on your system. Weight options (regular, bold, italic) appear just below the font name field.
  • Font size: Type a value directly into the field or scrub the number to increase or decrease the size.
  • Text color and opacity: Click the color swatch to open a color picker. Adjust the opacity percentage next to the swatch to control how transparent the text appears.
  • Background color and opacity: Toggle the background checkbox to enable a color block behind the text, then set the color and opacity to control how strongly it sits over your footage.
  • Position and alignment: Use the alignment buttons for horizontal and vertical positioning. You can also drag captions manually in the Program Monitor while the clip is selected.
  • Stroke and outline: Enable a text stroke using the outline toggle, then set its color and width.
Note: Premiere Pro has reorganized its captioning interface across recent versions. In Premiere Pro 2023 and 2024, all caption styling controls live within the Text panel. In older versions, some properties may appear in the Essential Graphics panel instead.
How to Create and Save a Custom Caption Style
Styling one clip manually is straightforward, but repeating that process for every caption in a long video is not practical. Premiere Pro solves this with a Style preset system that lets you save your formatting choices and reuse them across sessions.
Follow these steps to create and save a caption style:
1. Select a caption text clip in the timeline that already has the look you want.
(This is your “base” caption that defines the style)
2. Open the Properties panel from Window > Properties.
3. In the Properties panel, build and refine your caption design:
Fill (Text Color)
  • Set the main text color. This is the core visual layer of your caption.
Stroke (Outline Effect)
  • Add an outline around the text for better readability.
  • You can choose different stroke types like outer, inner, or center stroke, and even stack multiple strokes for stronger separation from the background.
Shadow
  • Add depth by applying shadows behind the text.
  • You can adjust blur, direction, opacity, and even use multiple shadows for a layered look.
Mask with Text (Optional Creative Control)
  • Turns your text into a mask so the video or graphics beneath show through the text shape.
  • This is useful for stylized intros or creative subtitle designs, but not always needed for standard captions.
Align and Transform
  • Control positioning and layout.
  • You can align text to the left, center, or right, and also adjust its placement precisely within the frame.
Linked Style (Optional but important for consistency)
  • This keeps font and appearance settings tied together so changes stay consistent across linked captions or text layers.
4. Once your caption looks exactly how you want, go to the Track Style section inside the Properties panel.
5. Click the “+ Create Style” button.
Choose how you want to save it:
Save to Project
  • Stores the style inside your current Premiere Pro project
  • Also creates a visible style item in the Project panel
  • Best for project-specific branding or client work
Save to Local Styles
  • Stores the style on your system
  • Can be reused in future projects through the style browser
  • Best for personal presets or reusable branding kits
6. Give your style a clear name (like “Clean Subtitles” or “Bold Caption”) and save it.
7. After saving, the style appears in the Track Style dropdown with thumbnails.
8. Now, you can apply it to your project.
How to Apply a Caption Style to All Captions at Once
Editing captions one at a time is the most common frustration editors encounter when captioning longer videos. Follow these steps to update all captions with a similar style.
1. Open the Properties panel.
2. Select the caption track in your timeline.
3. Style one caption the way you want using Properties as shown in Method 2.
4. Open the Track Style dropdown in the Properties panel.
5. Select the saved Track Style you created earlier.
6. The style is instantly applied to all captions in the track.
Optional Step. For quick temporary adjustments:
  • Select multiple caption clips in the timeline
  • Modify settings in the Properties panel
  • All selected captions update together instantly
7. Now, to update the style later:
  • Adjust any caption that uses that style
  • Click “Redefine Style” in the Track Style section
  • All captions using that style will update automatically
How do I make all my captions the same style without redoing each one?
Premiere Pro Track Style lets one design affect all captions. First, style a caption in the Properties panel area. Then choose the saved Track Style from the dropdown for the whole track. For later updates, change the caption and press the Redefine Style option. Premiere Pro updates every caption linked to that Track Style.
Can I import a caption style from another Premiere Pro project?
Open the project with the caption style first. Find the text style item in the Project panel. Export it as a .prtextstyle file. In a new Premiere Pro project, import that file. Drag it into the Project panel to reuse the style. It works across captions and text layers. You can also copy a styled caption clip from the source project and paste it into the new project as a reference, then use it to create a matching style preset in that destination project.
Why does my caption style reset when I reopen the project?
This usually happens when caption formatting was changed on single caption blocks. It was not saved as a Track Style instead. To stop styles from resetting, create a Track Style first. Apply it from the Properties panel after finishing formatting.
There are a few reliable ways to change caption style in Adobe Premiere Pro. You can go to the Text panel and change the caption style. Create your own style and save it to use later from the "Track Style" dropdown menu. Also, you can modify caption style for all captions using the "Redefine Style" option. And all the captions using that similar style will be updated.
