Premiere Pro includes a Speech to Text tool inside the editor. It creates a full transcript from your video footage automatically. After that, you can export the transcript in different formats. These include plain text, SRT subtitle files, and caption files. You can do everything without exporting the video again. This guide explains each export option in simple steps. It also helps you pick the right format smoothly.
Before You Export: Generate Your Transcript in Premiere Pro
If you have not run Speech to Text yet, complete these steps first.
Open the Text panel. Go to Window > Text in the top menu bar. The panel opens with two tabs: Transcript and Captions.
Select the Transcript tab. Click it if it is not already active. This is where Speech to Text output lives.
Click “Transcribe Sequence / Create transcription.” A dialog box will open with transcription settings. These settings affect accuracy, so take a moment to review them before proceeding.
Choose your language. Select the spoken language of your audio from the dropdown menu.
Select your audio track. Choose the track or mix you want Premiere to analyze. A clean, mixed-down audio track produces better results than a raw multi-track send.
Enable speaker labels (optional). If your sequence includes multiple speakers, check Recognize when different speakers are talking. Premiere Pro will tag each speaker’s lines separately in the transcript, which is especially useful for interviews and panel discussions.
Click “Transcribe.” Adobe Sensei processes the audio in the background. Most sequences under 30 minutes complete within one to two minutes, depending on your system.
Once you hit the Transcribe button, Premiere Pro will start creating auto transcription. Wait for the progress bar to get complete.
When it's done, you will be able to see the transcript.
Also, the export options in the panel menu will become active. If you attempt to export before this step is complete, the export options will be greyed out.
Method 1 — Export the Transcript as a Plain Text File (.txt)
Exporting as a .txt file is the fastest path to a clean, readable document.
Confirm you are on the Transcript tab inside the Text panel (Window > Text > Transcript).
Click the options menu. Look for the three-dot icon in the top-right corner of the Transcript panel.
Select “Export as Text.” A standard system save dialog will open.
Name your file and choose a save location, then click Save. Premiere Pro writes the .txt file immediately — no additional render or processing is required.
Open and review the file. The exported document contains the full word-by-word transcript. Speaker labels are included if you enabled them during the Transcribe Sequence step.
Method 2 — Export the Transcript as an SRT Caption File
An SRT file pairs the transcript text with timecodes, making it the right choice for YouTube uploads, accessibility compliance, and social media captions.
This method works across all recent versions of Premiere Pro and gives you the most control over caption formatting before export.
Go to the Transcript tab of the Text panel. Click the “Create captions” button.
A new dialog box will appear. Checkmark the “Create from sequence transcript” option
Next, choose Caption preset (subtitle default recommended), Format, and Style. Also, set a value for Maximum length in characters, Minimum duration in seconds, Gap between captions, and Lines (whether you want captions to appear in single or double lines). Confirm your choice by clicking the “Create” button.
If it's done correctly, you should now see a Subtitle track in the timeline with captions. The same captions that appear on the video.
Go to File > Export > Captions. This opens the dedicated caption export dialog.
Select SRT from the Format dropdown.
Choose a save destination and click Export. Your .srt file is ready to upload directly to YouTube, Vimeo, LinkedIn, or any platform that accepts subtitle files.
Export Format Comparison — Which File Type Should You Choose?
Use this table as a quick reference when deciding which export format matches your next task.
Format |
Includes Timecodes |
Best For |
Platform Compatible With |
.txt |
No |
Blog posts, show notes, scripts, client deliverables |
Any text editor, word processor, or CMS |
.srt |
Yes |
YouTube subtitles, accessibility, social media |
YouTube, Vimeo, TikTok, LinkedIn, Facebook |
.mcc |
Yes |
Broadcast captioning, closed-caption compliance |
Broadcast delivery, Vimeo Pro |
How to Improve Transcript Accuracy Before You Export
If your generated transcript is full of errors, the problem almost always traces back to the source audio quality rather than anything in the export process itself. Fixing the transcript before you export saves significant cleanup time downstream.
Edit words directly in the Transcript panel: Click any word in the transcript to correct it in line. This is the most efficient fix for isolated errors in an otherwise clean transcript.
Re-run transcription on a cleaner audio mix: If your sequence uses a rough cut with heavy background noise or music bleed, apply noise reduction to a duplicate sequence, run Speech to Text on that version, and export from there.
Confirm the language setting: A mismatched language selection causes widespread errors throughout the entire transcript. Double-check this in the Transcribe Sequence dialog before re-running.
The most effective accuracy improvement happens before you open Premiere Pro. Recording with clean, low-noise source audio at 48 kHz gives Adobe Premiere Pro’s AI engine far more accurate input to work with. A wireless microphone system like the Hollyland LARK MAX 2, which records 32-bit Float audio with built-in AI Noise Cancellation, reduces transcription errors at the capture stage — meaning less manual correction work inside the Transcript panel before you export.
Q: Can I export a transcript from Premiere Pro without adding captions to my video?
Yes. Exporting from the Transcript panel creates a separate file only. If you choose TXT, your sequence stays unchanged. It also does not add visible captions to the video export. Your timeline and final exported video both stay exactly the same. Conversely, you cannot export the transcript directly as an SRT file. First, convert the transcript into captions (Create Captions) inside Premiere Pro. After the caption track appears, export it as a separate SRT file.
Q: Why is my Premiere Pro transcript export option greyed out?
The export options only activate after a transcript has been successfully generated. If the Transcribe Sequence step is incomplete, still processing, or returned an error, the export items in the options menu will stay greyed out. Re-run the Transcribe Sequence process to resolve it.
Q: What Premiere Pro version introduced transcript export?
Adobe’s Speech to Text with transcript export launched in Premiere Pro 15.4 in mid-2021. The plain text (.txt) direct export and refined SRT workflows were expanded in the 2023 and 2024 update cycles, so available menu options may vary depending on which version you are running.
SRT creates a time-coded subtitle file used in media players and YouTube. It allows captions to be turned on and off during playback. TXT exports a plain transcript that may include timecodes in some cases. It is mainly used for reading, translation, or document work instead of playback. This article shows both methods step by step so you can choose easily.
