Auto Sync Failed in DaVinci Resolve: Causes and How to Fix It
DaVinci Resolve’s Auto Sync Audio is supposed to save you time. When it fails, it usually gives you little to no explanation, leaving you to guess what went wrong. This guide breaks down every common cause behind the failure and walks you through targeted fixes in the order most likely to solve your problem. If you are working with dual-system audio and the sync is refusing to cooperate, start here.
What DaVinci Resolve’s Auto Sync Audio Actually Does
Auto Sync Audio matches your separate audio file to the video clip it belongs to. It offers three methods to accomplish this, and each method requires specific conditions to function. Knowing which method you are using – and whether those conditions are met – is the foundation of diagnosing any failure.
Sync Method
What It Requires
Best Use Case
Timecode
Matching timecode metadata on both clips
Structured dual-system setups with jam-synced devices
Waveform
Reference audio on the video clip and analyzed waveform data
Most run-and-gun or solo shooters with scratch audio
In/Out Points
Manually set In and Out markers on both clips
Situations where timecode and waveform are both unavailable
Why Auto Sync Fails – The Most Common Causes
Auto sync failures usually trace back to one of these root causes:
  • The video clip has no scratch audio – the camera microphone was muted, or no audio was recorded at all
  • Audio waveforms have not been analyzed or cached in Resolve, so the software has nothing to compare
  • Timecode metadata is missing, mismatched in frame rate, or was never recorded by the camera or audio device
  • The wrong sync method was selected for the type of footage being used
  • Only the video clip or only the audio clip was selected in the Media Pool – not both simultaneously
  • The two clips have no overlapping content or timecode range, making a match impossible
How to Fix Auto Sync Failed in DaVinci Resolve (Step-by-Step)
Fix 1: Auto Analysis and Auto Sync Audio (Waveform Method)
In DaVinci Resolve, Auto Sync Audio by waveform matches external audio with video clips automatically. It compares both audio waveforms and lines them up correctly. The process swaps weak camera audio with clearer external recordings inside the Media Pool. This method helps during dual-system recording setups or multi-camera shoots without timecode.
In newer versions of DaVinci Resolve, waveform analysis (waveform generation) usually starts automatically after importing media files. If Auto Sync Audio starts too soon, Resolve may still prepare the waveform data. Without that data, waveform-based syncing may not match the clips correctly.
  1. Import both of your recorded video clips and audio files into the Media Pool.
  1. Wait a few moments after import, especially with large files or slower drives.
  2. Once the files are imported, wait for a few moments and let Davinci Resolve do waveform analysis on its own (it does it in the background and the process isn’t visible).
  3. After that, play the video clip in the Source Viewer and play several seconds of it. During this process, confirm that its scratch audio is also audible.
  4. Next, play a few seconds of the external audio file as well.
  5. Now, select and right-click the clips and hover over Audio Sync, and select Auto Sync Audio.
  1. Choose Waveform from the "Sychronize Using" dropdown menu, and hit the Sync button.
Fix 2: Verify You Have Both Clips Selected Correctly
Auto Sync Audio requires at least one video clip and at least one corresponding audio-only clip to be selected at the same time in the Media Pool. Selecting only the video clip or only the audio file is a common mistake. This happens often with editors who usually work inside the timeline instead of the Media Pool.
  1. Click your video clip in the Media Pool.
  2. Hold Ctrl (Windows) or Cmd (Mac) and click your separate audio file so both are highlighted.
  1. Right-click and select Auto Sync Audio, then choose your sync method.
Tip: If your clips are in different bins, move them into one bin first. Do this before trying to sync. It makes selecting clips easier. It also lowers the chance of missing any clip.
Fix 3: Switch to the Right Sync Method for Your Footage
Choosing the wrong sync method for your recording setup is a reliable path to failure. Here is how to match the method to your situation.
If timecode sync is failing: Your camera and audio recorder were likely not jam-synced, or their frame rates do not match. Switch to waveform-based sync instead (See Fix 1). Waveform sync is the practical default for most solo shooters and small crews.
If waveform sync is failing: Confirm your video clip actually has audible reference audio. Go to the clip in the Media Pool, right-click, and open it in the Source Viewer. Scrub through it and check whether any audio channel is active. If the scratch audio track is flat or empty, waveform sync cannot work. You will need to use In/Out points or manual sync instead.
If In/Out point sync is failing: Confirm you have set matching In and Out markers on both clips at the same real-world moment before running the sync command.
Fix 4: Check Timecode Settings (For Timecode-Based Workflows)
If you are relying on timecode sync and it is consistently failing, verify these conditions:
  • Both the camera and the audio recorder were set to the same timecode frame rate (e.g., both at 29.97, not one at 29.97 and one at 30)
  • Timecode was jammed or locked between devices before the shoot began
  • The audio recorder’s timecode metadata is being read correctly – open the clip’s metadata in the Media Pool and confirm the timecode field is populated
  • Your project settings in Resolve match the timecode frame rate of your recorded footage
Fix 5: Try Multicam Sync as an Alternative
Multicam sync uses the same underlying sync logic as Auto Sync Audio but wraps the clips into a multicam clip, which can resolve edge cases that Auto Sync Audio handles poorly. It also gives you a visual timeline to confirm the alignment before committing.
  1. In the Media Pool, select your video clip and your audio-only clip together.
  1. Right-click and choose Create New Multicam Clip Using Selected Clips.
  1. In the dialog, choose your preferred sync method (Audio, Timecode, or In/Out Points).
  2. Click Create.
  1. Open the multicam clip in the timeline and check that the audio and video are aligned. If they are, you can export the synced audio from here or continue editing with the multicam clip directly.
Manual Sync as a Reliable Fallback
When every automated method fails, manual sync is the definitive solution. It takes a few extra minutes, but it usually works.
  1. Place both your video clip and your separate audio clip on the timeline on separate tracks.
  2. Find a clear waveform peak in both tracks – a clap, a door slam, or any sharp transient sound works well. A clapperboard slate is ideal.
  1. Zoom into the waveform display until you can see the peak precisely on both tracks.
  1. Drag the audio clip left or right until the peak in the external audio aligns exactly with the matching peak in the scratch audio on the video clip.
  2. Once aligned, you can mute or delete the scratch audio track and work with the clean external audio.
Preventing Auto Sync Failures in Future Shoots
Fixing sync problems in post is slower than preventing them on set. A few consistent habits will eliminate most failures before they start.
  • Use a slate or clapper at the top of every take. The sharp transient gives waveform sync a definitive reference point and makes manual alignment fast if auto sync fails.
  • Always record scratch audio to the camera. Even a built-in camera microphone recording at low quality is sufficient for waveform sync – Resolve only needs a readable signal, not broadcast-quality audio.
  • Lock the timecode between devices before rolling if you are running a timecode workflow. Jam-sync your audio recorder to the camera and verify the frame rate matches on both devices.
  • For dual-system audio workflows, the quality and consistency of your source audio directly affect how reliably waveform sync performs. The Hollyland LARK MAX 2 records at 48 kHz / 24-bit with onboard 32-bit Float backup, producing audio files with clean, high-resolution waveform data that DaVinci Resolve can detect and match without ambiguity.
Q: Why does DaVinci Resolve auto sync say it failed with no error details?
This usually happens when DaVinci Resolve does not have enough usable data to match clips. It can occur if scratch audio is missing or the timecode does not match. It may also happen when waveform data is not fully ready after import. Newer versions generate waveforms automatically, so wait a moment before trying sync again. Also, make sure the video clip contains clear audio for comparison.
Q: Can I auto sync audio in DaVinci Resolve without timecode?
Yes. Select the waveform-based sync method, which matches audio by comparing sound patterns between the camera’s scratch audio and your separate audio file. No timecode metadata is required. You only need the audible reference audio on the video clip and the analyzed waveforms on both files.
Q: What is the difference between Auto Sync Audio and multicam sync in DaVinci Resolve?
Both use the same underlying sync logic. The difference is that multicam sync creates a dedicated multicam clip and gives you a visual confirmation of alignment before you commit. It can be more reliable for multi-clip syncing scenarios and is worth trying if Auto Sync Audio fails on the same clips.
Q: Does the DaVinci Resolve free version support Auto Sync Audio?
Yes. Auto Sync Audio is available in both the free version and DaVinci Resolve Studio. There is no paywall on this feature, so the free version is not the cause of your sync failure.
Most Auto Sync Audio failures usually happen for two reasons. One reason is incomplete waveform data after media import. Another reason is wrong clip selection during the syncing process. Start with Fix 1 and Fix 2 first. They solve the most common sync problems in many cases. If that does not fix it, adjust the sync method. Match it with your footage type and timecode settings. When nothing else works, use manual waveform sync instead. It stays available and can be used anytime.
