Choppy audio in DaVinci Resolve is one of the most disruptive problems you can hit mid-project. The stuttering, skipping, or sync drift feels random, but it almost always traces back to one of a few specific causes: a sample rate conflict, an overwhelmed decoder, or a misconfigured cache. This guide walks through seven targeted fixes in order of simplicity, so you can stop the stutter and get back to editing.
Why DaVinci Resolve Audio Goes Choppy (And How to Diagnose It Fast)
Before applying any fix, spend 60 seconds narrowing down the cause. DaVinci Resolve audio choppiness falls into three main categories:
Project settings mismatch – your project’s audio sample rate, timeline frame rate, or output settings conflict with the source file.
System performance under codec load – your CPU or GPU cannot decode compressed formats like H.264 or HEVC fast enough for real-time playback.
Cache misconfiguration – caching is disabled, pointed to a slow drive, or corrupted, forcing DaVinci Resolve to decode everything live.
Use the table below to match your symptom to the most likely cause and jump directly to the relevant fix.
Symptom |
Likely Cause |
Start With |
Choppy audio on all clips, from the first play |
Fix 1 |
Choppy audio only on H.264 or HEVC clips |
Codec decoding load |
Fix 3 |
Starts smooth, then degrades after a few minutes |
Playback cache not building |
Fix 2 |
Choppy on playback only, clean on export |
Playback resolution or cache issue |
Fix 2 or Fix 4 |
Choppy on export and playback |
Sample rate or corrupted source file |
Fix 1 or Fix 7 |
Stuttering started after changing headphones or audio device |
Output device mismatch |
Fix 6 |
Fix 1 – Match Your Project and Audio Sample Rate
This is the single most common cause of choppy or distorted audio in DaVinci Resolve. A sample rate mismatch between your project and source clips can contribute to audio issues. Most cameras and pro recorders use 48 kHz; phones and some music apps record at 44.1 kHz. Resolve resamples on import, but a clean match from the start avoids any conversion artifacts.
How to fix it:
Open File → Project Settings.
Select the Fairlight tab.
Under General, set the Audio Sample Rate to match your source (48000 Hz for most video, 44100 Hz for music/podcast sources).
Check individual clip sample rates as well:
Go to the Media page and select the target clip. Its attributes will show in the Metadata panel, usually located in the right part of the screen.
Fix 2 – Enable and Configure the Playback Cache
Many users never activate DaVinci Resolve’s background caching system, which means every clip is decoded from scratch on every playback pass. Enabling the cache lets Resolve pre-render frames to disk so playback reads from fast cache files instead of running live decoding.
How to enable and configure the playback cache:
Go to Playback → Render Cache and select Smart. Smart mode caches only clips that require processing, which is the best default for most workflows.
Open Project Settings and go to Master Settings.
Scroll down to find the Working Folders section.
Under Cache files location, confirm the path points to a fast SSD rather than an external or spinning hard drive. A slow cache drive defeats the purpose of caching.
Return to your timeline. A red bar above clips means they are flagged for caching. Once caching begins in the background, those bars turn blue, indicating cached and ready for smooth playback.
Callout: If your cache drive is nearly full, DaVinci Resolve will stop caching silently without any warning. If your timeline bars are staying red, check your available cache drive space first and delete old cache files before continuing.
Fix 3 – Generate Optimized Media or Use Proxy Clips
H.264 and HEVC are long-GOP, high-compression formats designed for delivery, not editing. Decoding them in real time places a heavy load on your CPU and GPU, and mid-range systems frequently cannot sustain that load across a full timeline. The solution is to transcode your clips to an editing-friendly format before you edit.
DaVinci Resolve offers two approaches: Optimized Media and Proxy clips.
How to generate Optimized Media:
In Project Settings → Master Settings, scroll to Optimized Media and Render Cache.
Set the Optimized Media format to DNxHR SQ (Windows/cross-platform) or ProRes 422 (macOS).
In the Media Pool, select all clips you want to optimize, right-click, and choose Generate Optimized Media.
Resolve transcodes the clips in the background. Once complete, playback uses the new files automatically.
Optimized Media |
Proxy Clips |
Quality |
Full resolution, high quality |
Reduced resolution |
File size |
Large |
Small |
Best for |
Desktop editing workstations |
Laptops, lower-spec hardware |
Affects export? |
No – original files used at export |
Use Optimized Media when your system has storage to spare and you want full-quality previews. Use Proxies when you are on a laptop or a system with limited storage, and you need light files to get through the edit. Neither approach affects your final export, which always uses the original source files.
Fix 4 – Lower Playback Quality During Editing
If you need a quick fix while waiting for Optimized Media to generate, reducing the preview resolution is the fastest non-destructive option available.
How to lower playback quality:
Go to Playback → Timeline Playback Resolution.
Select Half Resolution or Quarter Resolution depending on how much relief your system needs.
Optionally, open the Playback Quality dropdown in the viewer and switch from Automatic to Performance.
This only affects what you see in the preview monitor. Your final export is always rendered at full resolution from the original source files, so there is no quality cost to enabling this during editing. It is a useful stopgap, but not a permanent solution for systems regularly working with compressed footage.
Fix 5 – Verify Hardware Acceleration Is Enabled
DaVinci Resolve relies heavily on GPU acceleration for real-time decoding. If the software falls back to CPU-only decoding, performance drops significantly, and choppy playback across the timeline is a predictable result.
How to check and configure GPU acceleration:
Go to DaVinci Resolve → Preferences (macOS) or File → Preferences (Windows).
Select Memory and GPU.
Under GPU Processing Mode, confirm the setting is not locked to OpenCL if you have an NVIDIA card that supports CUDA. Set it to CUDA for NVIDIA GPUs, Metal for Apple Silicon and recent Intel Macs, or OpenCL for AMD GPUs on Windows.
Check GPU Memory – if your GPU’s VRAM is fully allocated by other applications, decoding will stall. Close GPU-heavy applications running alongside Resolve.
Restart DaVinci Resolve after any change here for the setting to take effect.
Note for Apple Silicon users: Metal is the correct processing mode on M1, M2, and M3 Macs. DaVinci Resolve 18 and 19 are optimized for Apple Silicon, and Metal provides the best hardware acceleration on these machines. If you see OpenCL selected after a macOS update, switch it back to Metal and restart.
On Windows, outdated GPU drivers are a documented trigger for playback degradation. If enabling CUDA does not resolve the issue, update your drivers directly from NVIDIA’s website and retest.
Fix 6 – Check Audio Output Device Settings
A mismatch between your OS audio device's sample rate and your Resolve project rate can cause stuttering during playback. Resolve doesn't expose a sample rate setting for the audio device — that's controlled at the OS level.
How to check and fix:
In Resolve: Preferences → System →Video and Audio I/O. Confirm the correct Output Device is selected.
Check your project sample rate: Project Settings → Fairlight → Audio Sample Rate (typically 48000 Hz).
Set your OS audio device to match:
macOS: Open Audio MIDI Setup, select your output device, set Format to 48000 Hz
Windows: Sound settings → right-click playback device → Properties → Advanced tab → set Default Format to 48000 Hz
Restart DaVinci Resolve.
Note: Bluetooth headphones are a common source of this issue — many operate at lower sample rates and add latency. For critical editing, use wired monitoring.
Fix 7 – Delete and Rebuild the Media Cache Database
If none of the fixes above have resolved the issue, your media cache database may be corrupted. Corrupted cache files can produce persistent choppy playback that resists all other troubleshooting.
How to delete and rebuild the cache:
Go to DaVinci Resolve → Preferences → Media Storage.
Click Delete Cache Files and confirm. This removes all existing cached renders.
While in Preferences, click Optimize Database to clear any database-level corruption.
Close Preferences, return to your timeline, and allow the cache to rebuild. Use Playback → Render Cache → Smart to restart background caching.
This is a reset step. It requires DaVinci Resolve to re-cache your entire project, so expect some temporary playback degradation until the cache rebuilds.
Why is DaVinci Resolve audio choppy only on H.264 files?
H.264 and HEVC use high-compression, long-GOP encoding that is computationally expensive to decode in real time. DaVinci Resolve was designed around editing-friendly formats like ProRes and DNxHR. When your system cannot keep up with live H.264 decoding, audio stutters. Generating Optimized Media (Fix 3) transcodes those clips to a format that Resolve handles without strain.
DaVinci Resolve audio is choppy on export – is it the same problem?
No. Choppy audio during export is usually not a performance issue. It most commonly points to a sample rate mismatch in your Deliver settings, or a corrupted source file that plays incorrectly when Resolve reads it during render. Check your Deliver page audio settings and test the source file in another player to rule out corruption.
Does upgrading DaVinci Resolve fix audio choppiness?
It can. Blackmagic Design regularly releases bug fixes for known playback issues, and a specific version may have a bug affecting your workflow. Check the release notes for your current version before upgrading, since mid-project version changes can occasionally affect project file compatibility. If you upgrade, back up your project file first.
Start With the Fast Fixes First
For most users, fixing the audio sample rate and enabling the playback cache (Fixes 1 and 2) will resolve the problem immediately. If your footage is H.264 or HEVC, generating Optimized Media (Fix 3) is the next highest-impact step. Hardware acceleration and audio output settings (Fixes 5 and 6) are worth checking if the first three do not help. Cache deletion (Fix 7) is a last resort.
For hardware-specific edge cases not covered here, the Blackmagic Design community forum is the most reliable resource for version-specific and machine-specific issues.
