DaVinci Resolve Audio Waveform Not Showing: 5 Fixes That Actually Work
If audio waveforms disappeared in DaVinci Resolve, you are not the only one. Many editors run into this problem while editing their timelines. Most of the time, the file is completely fine and undamaged. A small setting inside Resolve usually causes the waveform to disappear. The fixes below start with the quickest options first. Go through them one by one and check the timeline again. In many cases, the waveform returns after the first couple of fixes.
Why Audio Waveforms Disappear in DaVinci Resolve?
Most of the time, the waveform is still there but hidden. A disabled display setting often causes this problem inside the timeline. In some cases, the audio track becomes too small to show waveforms. A damaged cache or wrong channel settings can also create this issue. The original source file is rarely the reason behind missing waveforms.
Fix 1 — Enable “Show Audio Waveforms” in the Timeline Toolbar
This is the single most common cause. DaVinci Resolve has a dedicated toggle that controls whether waveforms are drawn on the timeline, and it can be turned off accidentally or reset after certain updates.
  1. Open your project and go to the Edit page.
You will notice that the imported audio clip has no waveforms in the thumbnail.
  1. Click the TimelineToolbar menu (three horizontal dots) in the top menu bar.
  2. Look for Show Audio Waveforms and confirm it is checked. If it is unchecked, click it to enable it.
  1. Your waveforms should appear on all audio clips immediately.
Fix 2 — Increase Track Height So the Waveform Is Visible
Even with the waveform toggle enabled, a track that is collapsed to its minimum height will not display the waveform. The track exists and plays back correctly, but there is simply no vertical space for the waveform to render.
  1. On the Edit page, locate the track header on the left side of the timeline (the area showing the track name and mute/solo buttons).
  1. Hover your cursor over the bottom border of the audio track header. The cursor will change to a resize icon.
  2. Click and drag downward to increase the track height until the waveform becomes visible.
  1. Alternatively, place your cursor over the timeline panel (not the track header) and use Ctrl + Scroll (Windows) or Cmd + Scroll (Mac) to zoom the track height vertically.
Pro Tip: Vertical zoom and horizontal zoom are separate controls. Ctrl/Cmd + Scroll over the timeline adjusts track height. The scroll wheel alone (without a modifier key) zooms horizontally. Make sure you are using the right modifier, or you will just change the timeline scale instead.
This is an especially common beginner mistake after switching to a smaller monitor or after importing a project from another system where track heights were saved differently.
Fix 3 — Turn On Waveform from Timeline View Options
The Show Audio Waveforms option shows sound waves directly on clips. This makes audio editing much easier and more accurate. You can spot sound peaks while cutting or syncing clips. Without it, clips only appear as simple flat boxes.
  1. Look for the Timeline View Options icon in the upper-left of Davinci Resolve's timeline.
  1. Click the Timeline View Options and from the dropdown menu, select Display Audio Waveforms.
  1. Then, check the audio file on the timeline; it should now display waveforms.
Fix 4 — Clear the Audio Cache
A stale or corrupted render cache can interfere with waveform rendering. Clearing it forces DaVinci Resolve to rebuild everything from the source files.
  1. Go to the Playback menu in the top menu bar.
  2. Select Delete Render Cache.
  3. Choose All to clear everything, or Audio if you want to limit the cache clear to audio data only.
  1. Confirm the deletion when prompted.
  1. Press Play or scrub through the timeline. DaVinci Resolve will rebuild the cache, and waveforms should reappear.
Note: Clearing the render cache does not delete your source media files or your project. It only removes temporary data that DaVinci Resolve built internally. You will not lose any work.
Fix 5 — Check Clip-Level and Track-Level Audio Settings
If the above fixes have not resolved the issue, the problem may be at the clip or track configuration level. There are two things to check here.
Check 1: Clip Attributes (channel mapping)
  • Right-click the audio clip on the timeline.
  • Select Clip Attributes.
  • Go to the Audio tab.
  • Confirm the audio channels are mapped correctly.
A clip with all channels mapped to “None” may appear silent and waveform-less even though audio data exists in the file.
  • Reassign channels as needed and click OK.
Check 2: Track audio type
  • Look at the track header for the affected audio track.
  • Confirm the track type is not set to a mode that conflicts with your clip format (for example, a stereo clip on a mono-only track can cause display issues in certain versions).
  • Check that the track is not muted at a level that bypasses normal waveform rendering.
Note: Waveforms on the Fairlight page render per-channel at a larger visual scale. If waveforms are missing only in Fairlight and display correctly on the Edit page, check the vertical zoom level and confirm channel routing within the Fairlight mixer. These are separate controls from the Edit page.
Quick Comparison — Most Likely Fix by Symptom
Symptom
Most Likely Cause
Go To Fix
Waveform missing on all clips in the timeline
Show Audio Waveforms toggle is off
Fix 1
Waveform missing, but track exists and plays
Track height too collapsed to show waveform
Fix 2
Waveform never appears on any project
Waveform generation disabled in Preferences
Fix 3
Waveform disappeared after an update or crash
Cache corrupted or preference reset
Fix 1 or Fix 4
Waveform missing on one specific clip only
Channel mapping issue in Clip Attributes
Fix 5
Q: Why does DaVinci Resolve show a flat line instead of a waveform?
A flat line means audio data is present, but the signal is silent or near-silent, or a channel mapping problem exists in the clip. This is different from a missing waveform and is not a display toggle issue. Open Clip Attributes to check channel mapping and verify your input gain or audio levels are not set to zero.
Q: Audio waveform disappeared after updating DaVinci Resolve — what happened?
Updates occasionally reset the “Show audio waveforms” preference or clear the waveform cache. To reset waveforms, you can go to the Timeline Toolbar and checkmark the Show Audio Waveform. Also, enable the Display Audio Waveforms option from the Timeline View Options.
Q: Does the waveform look different on the Fairlight page vs. the Edit page?
Yes. The Fairlight page displays per-channel waveforms at a larger, more detailed scale compared to the Edit page view. If waveforms appear on the Edit page but not in Fairlight, check the vertical zoom level within Fairlight and confirm the channel routing in the Fairlight mixer, as these settings are independent from the Edit page.
Try these fixes one at a time for better results. Start with the View option and check the track height. After that, confirm that the waveform display is turned on correctly. Then clear the cache and review the Clip Attributes settings. Before blaming the waveform display, test the clip’s actual audio first. Scrub through the clip while wearing headphones and listen carefully. If no sound plays, the source file may be damaged.
