Audio crackling can be difficult to figure out because many problems cause it. The same sound may come from software, a damaged cable, or wireless interference. Before you reinstall drivers or buy new gear, you need to know which type of crackling you are dealing with. This guide explains the most common causes and the fastest path to a clean fix.
What Audio Crackling Actually Tells You
Not all crackling is the same, and the pattern you hear points directly to the source.
Continuous static crackle that persists regardless of what you are playing typically points to a physical problem. A loose connector, damaged cable, dirty contacts, or a faulty audio jack may be causing it. The problem is somewhere along the audio connection.
Intermittent pops and clicks that appear randomly or worsen under load usually trace back to software. A driver conflict, a sample rate mismatch, or the CPU failing to feed the audio pipeline fast enough.
Symptom |
Likely Source |
Constant static or crackling hiss |
Cable, connector, hardware failure, ground loop |
Random pops/clicks or crackling under load |
Audio driver, sample rate mismatch, CPU/DPC latency |
The Most Common Causes of Audio Crackling
Use this section to match your specific situation before attempting any fix.
Outdated or Corrupted Audio Drivers
Audio drivers act as the translator between your operating system and your sound hardware. When a Windows update ships with an incompatible driver version, or when a driver becomes corrupted over time, the communication breaks down and produces random pops or crackling, often only under load like gaming or video calls.
You will notice this if: The crackling started shortly after a Windows update, or if it appears inconsistently rather than constantly.
Sample Rate or Bit Depth Mismatch
Every audio device has a native sample rate (commonly 44.1 kHz or 48 kHz) and bit depth (16-bit or 24-bit). When your system and audio hardware use different settings, audio problems can happen. You may hear clicking or light crackling, especially when playback starts or stops.
You will notice this if: The crackling is most obvious at the very beginning of a sound, or it appears after plugging in a new headset or audio interface.
DPC Latency and CPU Overload
Windows processes audio in small buffers. If the CPU is too busy with other tasks, it misses the handoff and the audio pipeline underruns, creating a brief gap that registers as a pop or click. This is called Deferred Procedure Call (DPC) latency, and it worsens during heavy multitasking, gaming, or when certain drivers monopolize CPU time.
You will notice this if: Crackling increases noticeably when you open additional applications or when your CPU usage spikes.
Loose, Damaged, or Low-Quality Cables and Connectors
A 3.5mm headphone jack or XLR connector that is worn, bent, or oxidized creates intermittent physical contact with the port. Every tiny interruption in that contact produces a crackle or pop. Budget cables with thin shielding also pick up electromagnetic interference from nearby components.
You will notice this if: The crackling changes or disappears when you wiggle the cable or shift the connector in its port.
Ground Loop and Electrical Interference
When grounded devices have different voltage levels, electrical current can flow between them. This often creates a low hum or crackling around 50 or 60 Hz. This is common in desktop rigs where an audio interface, monitor, and PC are all plugged into separate outlets or power strips.
You will notice this if: The noise is always present, has a buzzy or cyclic character, and does not change with playback volume or activity level.
Bluetooth and Wireless Interference
Bluetooth audio relies on a stable 2.4 GHz radio link and real-time codec negotiation between devices. When the signal weakens, the codec drops bits to maintain the connection, producing audible artifacts. Heavy 2.4 GHz congestion from Wi-Fi routers or neighboring wireless devices compounds the problem, as does moving out of range.
You will notice this if: Crackling is only present on wireless headphones and gets worse when you move away from the source device or when many other devices are nearby.
How to Fix Audio Crackling on Windows (Step-by-Step)
Work through these steps in order. The fixes at the top resolve the majority of crackling issues on Windows PCs and laptops.
Update or roll back your audio driver.
Open Device Manager (right-click the Start button and select “Device Manager”).
Expand “Sound, video and game controllers,” right-click your audio device, and choose “Update driver.”
If crackling started after a recent update, choose “Properties,” go to the “Driver” tab, and select “Roll Back Driver” to return to the previous version.
Match sample rate and bit depth.
Go to Settings > System > Sound, select your output device.
Click “Device Properties,” then “Additional device properties.”
Under the “Advanced” tab, set the Default Format to match your hardware’s native rate. For most headphones and speakers, 24-bit at 48000 Hz is a reliable starting point.
Disable audio enhancements and Exclusive Mode.
On the same “Advanced” tab, uncheck “Enable audio enhancements.”
Note: Not all Windows versions have the Audio Enhancements option.
Uncheck “Allow applications to take exclusive control of this device.”
Windows audio enhancements can introduce processing artifacts, and Exclusive Mode can cause conflicts between applications competing for the same audio device.
Switch your power plan to High Performance.
Open Control Panel > Power Options and select High Performance.
Windows sometimes power-gates USB controllers and audio chips on balanced or power-saving plans, cutting power mid-stream and creating crackle, a problem that is especially common on laptops.
Check DPC latency.
Download a free tool such as LatencyMon and run it while the audio crackles. The tool identifies which drivers are causing latency spikes. Common offenders include GPU drivers, network adapter drivers, and USB controller drivers. Updating or disabling the flagged driver often resolves the crackle immediately.
Test a different USB port or audio jack.
Plug your headphones or speakers into a different physical port. If the crackling stops or changes, the original port has a hardware problem. This single swap isolates whether the issue is in the port itself rather than a system-wide software problem.
Note: Complete each step and test the audio before moving to the next. This keeps troubleshooting efficient and tells you exactly what resolved the issue.
Fixing Crackling on Mac, Mobile, or Other Devices
Mac
On macOS, the Core Audio service can sometimes stop working properly. This may cause crackling or distorted sound. Open Terminal and run:
sudo killall coreaudiod
This restarts the audio engine without requiring a full reboot. If you use an Aggregate Device to combine two audio inputs or outputs, open Audio MIDI Setup and confirm that all devices in the aggregate share the same sample rate. A mismatch here is a frequent source of persistent clicking on Mac systems.
Mobile (iOS and Android)
Bluetooth codec: On Android, enable Developer Options and check the Bluetooth audio codec setting. Switching from SBC to AAC or aptX (if your headphones support it) often reduces crackling and dropout artifacts.
Re-pair the device: Forget the Bluetooth device and re-pair from scratch. Codec negotiation can get stuck on a poor setting after an OS update.
Check for obstructions: On phones with a built-in microphone, a case that partially covers the mic port can create back-pressure that sounds like crackling during calls.
Hardware Fixes: Cables, Ports, and Speakers
If software fixes do not stop the problem, your hardware may be at fault. Check these things first before buying new equipment.
Swap the cable: Replace the audio cable with a known-good one. If crackling stops immediately, the original cable is faulty. This single test rules out or confirms the most common hardware cause.
Try a different audio port: If your PC has both a front-panel and rear-panel headphone jack, test both. Front-panel jacks often have longer unshielded runs inside the case and pick up more interference from internal components.
Inspect the 3.5mm jack for debris: Pocket lint and dust can push into the jack and create intermittent contact. Use a short burst of compressed air to clean the port first. This helps rule out dirt before blaming the hardware.
Listen for speaker cone damage: Gently press near the edge of the speaker cone while playing audio at low volume. A rattling or crackling that changes with pressure indicates physical cone damage or a loose voice coil.
Use a ground loop isolator: If you run multiple grounded devices through a desktop audio setup, an inline ground loop isolator placed on the audio cable breaks the current loop cleanly, typically for $15 to $30.
Simple decision rule: If crackling stops the moment you swap the cable, the cable is the problem. If the problem stays after changing cables and ports, check the device or system software next.
Crackling from Wireless Microphones: A Special Case
Wireless microphone crackling follows its own diagnostic logic and is distinct from headphone or speaker crackling. The most common causes include crowded wireless channels and a weak transmitter signal. Audio can also crackle when the connection drops data to stay connected.
Start with the basics:
Change the RF channel on your wireless mic system to avoid overlap with nearby Wi-Fi routers and other 2.4 GHz devices. Reduce the physical distance between transmitter and receiver, keep the receiver in line of sight where possible, and move it away from large metal surfaces that cause multipath reflections.
If changing channels and moving the devices does not help, the problem may be with the system itself. Many budget wireless microphones use compressed audio with limited error correction. In areas with heavy wireless interference, they can lose audio data. That often causes crackling or digital distortion. More reliable systems have better wireless signal control and higher-quality audio processing. Some also include backup recording when the wireless connection becomes unstable.
For creators who have worked through every RF and placement adjustment without success, the Hollyland LARK MAX 2 addresses the root cause rather than masking it. The system transmits at 48 kHz / 32-bit Float and includes 32-bit Float Internal Recording on the transmitter itself, so even in difficult RF environments, the onboard clip captures a clean, uncompressed take that is completely free of wireless-induced crackling.
Why does my audio crackle only at high volume?
This typically points to speaker driver distortion or amplifier clipping. If the sound level pushes the speaker or amplifier past its limit, the audio signal clips. That clipping creates crackling or harsh distortion. Keeping the volume below 80 percent of maximum usually eliminates it. If crackling persists at moderate volumes, the speaker itself may be physically damaged.
Why does my audio crackle only when my laptop is charging?
Your laptop’s power supply can inject noise directly into the audio circuit, particularly on machines with limited shielding between the charging circuitry and the audio output. This is a form of electrical interference. Try a different charger or use a USB audio adapter, which isolates the audio signal from the laptop’s internal circuitry and keeps it separate from power supply noise.
Why does Bluetooth audio crackle when I walk away from my device?
Moving too far from the Bluetooth device weakens the signal. Eventually, the connection cannot correct transmission errors anymore. The codec begins dropping data to maintain the connection, and those dropped packets register as crackling. Getting closer to the connected device usually fixes the problem right away. Switching to a higher-quality codec like aptX or AAC, where supported by both devices, also improves range tolerance.
Why does my microphone crackle but my speakers sound fine?
If the crackling happens while recording, check your recording setup first. Your microphone, cable, or connector could be causing the problem. Try raising the buffer size in your recording software. If moving the microphone creates popping sounds, test another cable and port. With cheaper microphones, crackling may come from a worn or damp capsule.
Will reinstalling Windows fix audio crackling?
Only if a corrupted system driver or conflicting software installation is the cause, which is possible but uncommon. Reinstalling or rolling back the audio driver through Device Manager resolves the vast majority of software-related crackling far faster. A full Windows reinstall is a last resort with significant time cost, not a practical first step.
Most audio crackling problems can be found with a few simple checks. Look at your drivers and software settings first. Then check your system settings before testing the hardware. Save wireless interference checks for the final step. If the crackling still does not stop, your audio equipment may be failing. Replacing the faulty hardware is often the better choice. If your wireless microphone is still causing problems, comparing different options can help you find a better replacement.
