You turn the volume to the highest level, yet the sound stays very low. Finding the reason is not always simple. A hidden setting, driver problem, or weak microphone could be responsible. This guide explains each step in a clear order. You will check the easiest fixes first before looking at possible hardware problems. That approach makes the real cause much easier to identify.
First, Identify What Kind of Audio Is Quiet
Start by figuring out exactly where the low audio problem happens. The right fix depends on the situation causing the low volume.
All playback audio is low (speaker or headphones): Everything on the device sounds faint, including system sounds, music, and video. Begin with the volume and system settings section below.
Your microphone sounds quiet to others (calls or recordings): Other people say you sound faint, or your recorded audio is low when you play it back. Jump to the microphone input section.
One specific app or platform sounds quiet: Everything else is fine, but Zoom, a browser tab, or a media player sounds low. The Volume Mixer and platform-specific section are your starting points.
Check Volume and System Settings First
Most quiet audio problems are resolved here. Before touching drivers or hardware, work through every layer of the volume stack.
Master Volume and System Output Level
An app may have its volume set to full internally, while the system is routing audio to the wrong device entirely. Check both.
On Windows:
Right-click the speaker icon in the taskbar and select Open Sound settings.
Under Output, confirm the correct playback device is selected (your speakers or headphones, not a monitor or Bluetooth device you are not using).
Confirm the master volume slider is at or near 100.
If a Bluetooth speaker or headset shows as connected but is not physically in use, disconnect it in Bluetooth settings. Windows will silently route audio there.
On macOS:
Open System Settings > Sound > Output.
Confirm the correct output device is selected and the output volume slider is at maximum.
Make sure the Mute checkbox is not active.
If AirPods or another Bluetooth device is connected but not being used, disconnect it from Bluetooth settings.
Volume Mixer and Per-App Volume Settings
Windows allows every application to run at its own independent volume level, completely separate from the master slider. A single app can be nearly silent while the rest of the system sounds normal.
Right-click the speaker icon and select Open Volume mixer.
Check the slider for the application that sounds quiet. It may be set to 10 or 20 even though the master is at 100.
Raise the app’s channel to 100 and retest.
Also check the application’s own internal volume control. Media players, games, and video editors each have their own volume independent of Windows.
For browser audio, look at the speaker icon on the browser tab. Right-click the tab and select Unmute Site if it is muted.
Also check whether the media player embedded in the page has its own volume slider set low.
Communication Audio Settings (Windows)
Many people don't expect this to be the problem. Windows includes a setting that automatically reduces all other audio by up to 80% when it detects a phone call or communication activity. If you notice your music, video, or system sounds becoming quiet whenever you are in a call, this is the likely cause.
To disable it:
Right-click the speaker icon and select Sounds.
Click the Communications tab.
Select Do nothing.
Click Apply, then OK.
Software and Driver Issues That Suppress Volume
If the volume stack checks out and the audio is still quiet, the problem has moved below the surface. Software conflicts and driver issues can suppress output without leaving any visible indicator.
Outdated or Corrupted Audio Drivers
A driver that is out of date, partially corrupted, or mismatched after a Windows update can cause consistently low audio output, crackling, or intermittent volume drops.
On Windows:
Press Windows + X and select Device Manager.
Expand Sound, video and game controllers.
Right-click your audio device (commonly Realtek High Definition Audio or an Intel/AMD equivalent) and select Update driver.
Choose Search automatically for drivers. If no update appears, visit the PC or motherboard manufacturer’s website and download the latest audio driver manually.
If updating does not help, right-click the device and select Uninstall device, then restart Windows. The system will reinstall a clean version of the driver.
As a first pass, go to Settings > System > Troubleshoot > Other troubleshooters and run Playing Audio. Windows will often detect and correct driver-related issues automatically.
On macOS: Audio drivers are managed by the operating system and update through macOS system updates. Keep macOS updated with the latest system version. Update third-party audio interface drivers through the manufacturer's software.
Audio Enhancements and Equalizer Settings Lowering Output
Windows applies audio enhancements at the driver level, and several of them can conflict, compress the signal, or reduce perceived loudness. Third-party EQ software compounds this.
Right-click the speaker icon and select Sounds > Playback.
Double-click your default output device to open its Properties.
Click the Enhancements tab.
Note which enhancements are active: Loudness Equalization, Bass Boost, Virtual Surround, and Noise Suppression can all interfere with clean output.
Check Disable all enhancements and click Apply, then test playback.
If that resolves the problem, re-enable enhancements one at a time to identify the specific conflict.
Also check any third-party audio software installed on the system, such as Equalizer APO, Dolby Atmos, or DTS Sound Unbound. An overcorrected EQ curve or a gain reduction setting in those apps can quietly cap your output.
Note: Some Windows computers do not show the Enhancement tab at all. This usually happens because of driver problems, hardware limits, or recent system updates. Generic or incompatible audio drivers can also make the tab disappear. Some USB and Bluetooth audio devices skip Windows audio processing, so the option is unavailable.
Sample Rate or Exclusive Mode Conflicts
A sample rate mismatch between your audio device and the application playing audio can cause volume drop, distortion, or choppy output. Exclusive mode allows an application to take full control of the audio device and can lock the volume at whatever level the app sets, bypassing the Windows slider entirely.
To fix:
Right-click the speaker icon > Sounds > Playback > double-click your device > Advanced tab.
Set the sample rate to match what your application expects. Most apps work correctly at 44100 Hz (44.1 kHz) or 48000 Hz (48 kHz).
Uncheck Allow applications to take exclusive control of this device if your volume slider appears to have no effect while a specific app is running.
Your Microphone Input Is Too Low (Recording and Calls)
This section focuses on the sound other people hear from your microphone. It does not cover the audio you hear through your speakers. Low microphone volume has different causes than low speaker volume. Each problem needs a different way to fix it.
Microphone Input Gain Is Set Too Low
The OS-level input slider controls how much signal the system accepts from the microphone. This is the first thing to check before looking at software or hardware.
On Windows:
Right-click the speaker icon and select Sounds > Recording.
Right-click your active microphone and select Properties.
Click the Levels tab.
Raise the Microphone slider to 80 to 100.
If a Microphone Boost option is present, increase it cautiously. Boost adds gain in increments (often +10 dB, +20 dB, +30 dB) but raises the noise floor at higher settings.
Click Apply and run a recording test.
On macOS:
Open System Settings > Sound > Input.
Select your microphone from the list.
Raise the Input Volume slider and speak at a normal level to watch the input level meter respond.
Understanding the Main Difference: The input volume slider controls signal acceptance from the microphone, while mic boost applies additional amplification on top. Use boost as a last resort, not a first step.
Automatic Gain Control (AGC) Is Fighting Your Levels
AGC is designed to stabilize volume automatically, but it frequently works against you. In a quiet room with little variation in signal, AGC reads the signal as already controlled and clamps it down further. In communication apps, it can actively suppress your voice in ways that no input slider adjustment can overcome.
Disable it by platform:
Zoom: Settings > Audio > uncheck Automatically adjust microphone volume.
Microsoft Teams: Settings > Devices > disable automatic mic sensitivity adjustments if available, and manage gain through Windows recording settings.
Discord: User Settings > Voice and Video > disable Automatically Adjust Input Sensitivity and set a manual input threshold instead.
Windows system-level: In the Recording tab, open microphone Properties and check the Enhancements or Custom tab for any AGC option. Disable it if present.
Microphone Placement and Physical Source
Even a capable microphone sounds faint if it is positioned incorrectly or competing against ambient noise.
Position the microphone 6 to 12 inches from your mouth for cardioid condensers. Dynamic microphones work best even closer, at 2 to 6 inches.
For side-address microphones (most USB condensers), speak into the front face, not the top of the capsule.
Aim cardioid microphones toward your voice and point the rejection side toward dominant noise sources.
Reduce background noise in the space. A high noise floor eats into the relative level of your voice even when input gain is adequate.
The Microphone Itself Lacks Sensitivity
When input gain is maxed, AGC is off, and placement is correct but audio remains quiet, the problem is the microphone’s capsule. Built-in laptop microphones and budget clip-on mics have low inherent sensitivity, meaning they capture a weak signal at the source. No amount of software amplification fully compensates for this because boosting a weak signal also boosts the noise riding along with it.
A microphone with a high-sensitivity capsule captures a stronger, cleaner signal before any software processing takes place. That translates directly to louder, cleaner recordings at every step downstream, without the noise penalty of overamplifying a weak source.
For creators and professionals dealing with this specific problem, the Hollyland LARK MAX 2 is a practical solution. It records at 48 kHz / 32-bit Float with AI Noise Cancellation built into the transmitter, so the signal reaching your computer or camera is already strong and clean. This eliminates the need to compensate for quiet audio in post-production. For vloggers or anyone needing a portable, discreet option, the Hollyland LARK M2 weighs just 9 grams, offers up to 40 hours of battery life, and delivers reliable wireless capture without the sensitivity limitations of built-in or budget microphones.
Hardware and Physical Causes
If all software and settings checks pass, the problem may be purely physical.
Loose or damaged cable: A partially seated 3.5mm cable creates resistance that cuts signal volume. Reseat the cable firmly. If the housing is cracked or the wire is kinked near the connector, replace the cable.
Dirty or oxidized headphone jack: Dust and oxidation inside the port act as a physical barrier to signal transfer. Use compressed air to clear debris, then reseat the plug.
Worn or blown speaker driver: After prolonged use or exposure to high volumes, speaker cones lose physical range of motion and cannot reproduce the full output level. If volume is consistently low across every software state and every device, the driver may need replacement.
Adapter mismatch (TRRS vs. TRS): A 4-pole TRRS plug (stereo audio plus a microphone channel) inserted into a 3-pole TRS jack (stereo only) leaves the microphone pin unconnected. The result is either no recorded audio or a very faint signal. Use the correct adapter or connect to the dedicated microphone port if your device separates headphone and mic jacks.
Q: Why is my audio quiet in one app but not in others?
Each application runs at its own independent volume level inside the Windows Volume Mixer. If system audio sounds normal everywhere except one app, open the Volume Mixer and raise that app’s channel to 100%. Also check the application’s internal volume controls, which operate separately from the Windows mixer and are easy to overlook.
Q: Why is my microphone quiet even at 100% input volume?
If your input gain is already at the highest setting, another problem is likely causing the low volume. Your communication app may be reducing the microphone level automatically. The microphone could also be too far from your mouth. Another possibility is a microphone that cannot pick up enough sound, even with maximum gain. In that case, replacing the microphone is the only real fix.
Q: Why does my recorded audio sound quiet even though I can hear myself fine during monitoring?
Monitoring volume and recorded signal level are separate. You may be hearing a boosted playback signal while the actual recording is tracked at a low input level. Check your recording software’s input meter while speaking. If it barely moves, increase microphone gain at the OS level or inside your recording application before recording again.
Check the simplest settings before trying anything more advanced. Start with the volume and audio output, then review the Windows Communications tab and Volume Mixer. Then driver updates and audio enhancements, and finally microphone input gain and AGC settings. If every software fix is exhausted and audio remains quiet, the signal source itself is the limiting factor. A low-sensitivity microphone has a ceiling that software cannot raise cleanly.
