Your microphone is connected and recognized, but everyone on the call tells you they can barely hear you. Low audio gain on Windows 10 is one of the most common and most fixable audio complaints. In the majority of cases, the issue lives entirely in software. This guide walks you through six targeted fixes, ordered from quickest to most involved, so you can isolate and resolve the problem without guesswork.
How to Fix Low Audio Gain on Windows 10 (Microphone Too Quiet? Try These Fixes)
Why Is Audio Gain Low on Windows 10?
Two root causes cover most cases. First, Windows 10 defaults to conservative microphone volume and boost settings, and these values frequently reset after OS updates or driver reinstalls. Second, many audio drivers, particularly Realtek and HD Audio variants, apply background processing such as Automatic Gain Control (AGC) or noise suppression that silently suppresses your input signal with no obvious indicator in the UI. Most users resolve the problem by Fix 1 or Fix 2.
Symptom |
Likely Cause |
Quiet in all applications |
Microphone Volume or Boost set too low in Sound Settings |
Quiet in one specific app |
App-level Volume Mixer setting or missing privacy permission |
Volume fluctuates automatically |
AGC or noise suppression active in driver or app |
Quiet after a Windows update |
Driver reinstall reset gain settings to defaults |
Fix 1 — Raise the Microphone Volume in Sound Settings
This is your baseline. Before trying anything else, confirm that Windows has not quietly dropped your microphone volume to 50% or lower, which is a common side effect of driver updates.
Right-click the speaker icon in the system tray at the bottom-right corner of the taskbar.
Select Sounds from the context menu.
Click the Recording tab to see all connected audio input devices.
Double-click your microphone to open its Properties panel.
Click the Levels tab.
Drag the Microphone volume slider all the way to 100.
Click Apply, then OK.
Test your microphone using Windows Voice Recorder or a quick live call.
Note: If you see two sliders on the Levels tab, the top one controls microphone volume and the lower one is Microphone Boost. Leave Boost untouched for now; Fix 2 covers it specifically.
Fix 2 — Enable Microphone Boost
With microphone volume at 100, many users still find the signal too quiet. Microphone Boost applies additional gain in decibel increments on top of the main volume slider.
Follow steps 1 through 5 from Fix 1 to return to the Levels tab in Microphone Properties.
Locate the Microphone Boost slider beneath the main volume slider.
Set Boost to +20 dB as a starting point. This balances a meaningful gain increase against a manageable noise floor.
Test again. If the signal is still too low, try +30 dB. If the result sounds noisy or distorted, step back down to +10 dB.
Why is the Microphone Boost slider missing?
Not all drivers expose a software Boost control. Realtek and most HD Audio drivers include it, but USB microphones and professional audio interfaces handle gain internally and do not offer a Windows-level Boost slider. If the slider is absent for your device, skip to Fix 3 and use your microphone’s physical gain knob or companion software to control input level instead.
Fix 3 — Enable Audio Enhancements for Your Microphone
The Enhancements tab holds additional signal processing options that can raise perceived loudness and correct inconsistent gain. Its contents vary by driver, so what you see may differ slightly from the steps below.
Click the Advanced tab.
Review the Exclusive Mode checkboxes, specifically “Allow applications to take exclusive control of this device.”
If Exclusive Mode is active and you notice gain inconsistency across apps, uncheck both boxes.
If the Enable Audio Enhancements checkbox is available, check it to enable Windows audio enhancements for your microphone.
Click Apply, then OK, and retest.
Note: Disabling Exclusive Mode prevents any single application from overriding Windows gain settings independently. This is particularly useful when one app sounds normal while another sounds quiet, which is a direct sign that an app has been claiming exclusive audio control.
Fix 4 — Update or Reinstall Your Audio Driver
An outdated or corrupt audio driver is a common source of capped or erratic gain behavior. Windows Update does not always deliver audio driver updates, so a manual check is worthwhile.
Press Windows + X and select Device Manager.
Expand the Sound, video and game controllers category.
Right-click your audio device, for example “Realtek High Definition Audio,” and select Update driver.
Choose Search automatically for drivers and let Windows check online.
If no update is found, visit the manufacturer’s website directly. For Realtek, download the latest HD Audio driver from the Realtek download center and install it manually.
Restart your PC after installation, then return to the Levels tab to re-apply your Volume and Boost settings, as the driver update will likely reset them.
Pro Tip: If updating the driver makes the problem worse, open Device Manager, right-click the audio device, select Properties, go to the Driver tab, and click Roll Back Driver to restore the previous version.
If no update is available through either route, try uninstalling the device outright. Right-click the audio device, select Uninstall device, and restart your PC. Windows will automatically reinstall a generic High Definition Audio driver. If that generic driver produces a stronger or more consistent signal, the OEM driver was applying heavy processing that was suppressing input gain.
Fix 5 — Check Windows 10 Microphone Privacy Permissions
Windows 10 privacy controls can block or throttle application access to the microphone. An app with restricted permission does not simply stop working; it often receives a degraded, low-volume signal that closely mimics a gain problem.
Open Settings with Windows + I and click Privacy.
Select Microphone from the left sidebar.
Confirm that Allow apps to access your microphone is toggled On.
Scroll down to find your specific application (Camera, Discord, Zoom, etc.) and confirm its individual toggle is also On.
Close Settings, relaunch the affected app, and retest.
Fix 6 — Check the Volume Mixer and Third-Party Audio Software
Even with system-wide gain correctly set, a single application or piece of companion software can impose its own volume ceiling that Windows Sound Settings cannot override.
Volume Mixer: Right-click the speaker icon and select Open Volume Mixer. Confirm the slider for your active application is not set significantly lower than the system volume.
Realtek Audio Console: If installed, open it and check input gain settings. Driver-level values here can silently override what you set in Windows Sound Settings.
Gaming peripheral software: Applications such as ASUS Sonic Studio, SteelSeries GG, Logitech G HUB, and Razer Synapse include their own audio processing layers that can apply compression or gain reduction invisible to Windows. Open each one and set microphone processing to default or disable AGC and noise suppression features.
Communication apps: Teams and Skype both include internal AGC settings. In Microsoft Teams, navigate to Settings → Devices and disable automatic microphone adjustments if that option is available.
When Software Fixes Aren’t Enough — Consider Your Microphone’s Hardware Sensitivity
If you have worked through all six fixes and the signal remains unsatisfactorily quiet, the issue may not be Windows at all. Built-in laptop microphones and entry-level clip-on or headset mics often use capsules with inherently low sensitivity, and no OS-level gain setting can fully compensate for a weak transducer without pushing the noise floor to an unusable level. At that point, the practical solution is a microphone hardware upgrade. Professionals and content creators address this at the source, for example with hardware like the Hollyland LARK MAX 2, which captures audio at 48 kHz / 32-bit Float with 32-bit Float Internal Recording and AI Noise Cancellation, sidestepping Windows gain dependency entirely by delivering a clean, high-sensitivity signal before it ever reaches the PC.
Q1: Why does Windows 10 reset my microphone gain after every reboot?
Some audio drivers, particularly Realtek, re-apply default gain profiles on each restart. The fix is to configure gain inside the driver’s own control panel, such as the Realtek Audio Console, rather than relying solely on Windows Sound Settings. Driver-level settings are stored separately and persist across reboots in a way that Windows-side sliders sometimes do not.
Q2: My Microphone Boost slider is missing. Why?
USB microphones and professional audio interfaces manage gain internally, so Windows does not expose a software Boost slider for these devices. Use your microphone’s physical gain knob, its companion app, or an audio interface preamp to control input level. If none of those options are available, a dedicated USB audio interface with a preamp is the most reliable path to additional gain.
Q3: Can increasing Microphone Boost damage audio quality?
Yes, at higher settings. Boosting beyond +20 dB amplifies background noise alongside your voice, and in a noisy environment the result can be unusable. Set Boost incrementally and test in a real recording after each change, stopping at the lowest setting that gives you an acceptable signal without excessive noise.
Q4: Does Windows 10 AGC cause fluctuating or inconsistent volume?
Yes. Many drivers and communication apps, including Teams and Skype, apply Automatic Gain Control that continuously adjusts input gain, producing inconsistent loudness between quiet and loud passages. Disable AGC in the Enhancements tab of Microphone Properties or within the specific app’s audio or device settings.
Q5: Are these steps the same in Windows 11?
The core Levels and Boost controls function the same way, but the navigation path differs. In Windows 11, you access similar settings through Settings → System → Sound rather than the classic Sound Control Panel. The steps in this guide apply specifically to the Windows 10 interface.
Start with Fixes 1 and 2: set volume to 100 and apply a +20 dB Boost. If the problem persists, check Enhancements and Exclusive Mode (Fix 3), update or reinstall your driver (Fix 4), then verify privacy permissions and the Volume Mixer (Fixes 5 and 6). Use Windows Voice Recorder to test after each individual change rather than applying several at once. If all software avenues are exhausted, a hardware upgrade with a higher-sensitivity microphone is the only remaining path to consistently usable gain.
