How to Connect Left and Right Audio to a PC (RCA, Line-In & USB Methods)
Connecting left and right audio to your PC is not that difficult. Once you know your setup, everything starts making way more sense. Maybe you're recording a Hi-Fi receiver, mixer, or old tapes today. You've got three simple options, and each one gets explained clearly. This guide covers adapters, settings, and clean stereo recording without confusion.
How to Connect Left and Right Audio to a PC (Step-by-Step Methods)
Understanding Left and Right Audio Connections
Left and right audio are two separate mono signals that together form a stereo pair. On most consumer and semi-pro devices, they appear as:
  • RCA connectors: White for left, red for right (common on TVs, receivers, VCRs, and mixers)
  • Dual 1/4” TS jacks: Often labeled L and R on mixers or keyboards
  • Single 3.5mm TRS jack: Carries both channels on one plug (tip = left, ring = right, sleeve = ground)
Your PC’s 3.5mm line-in port uses the TRS format, which is why a single plug can carry a full stereo signal. The challenge is converting your source’s connector format into something your PC can accept.
Before choosing a method, confirm the following:
  • Your source connector type: RCA, dual 1/4”, XLR, or 3.5mm
  • Your PC’s available ports: Dedicated line-in jack (usually blue), a headphone/mic combo jack only, or USB ports only
  • Your intended use: Recording a file or monitoring live audio
  • Driver requirements: Some USB interfaces need a driver download before first use
Knowing these first saves you from buying the wrong adapter or cable.
Method 1: Using an RCA to 3.5mm Stereo Adapter (Simplest)
This method uses a passive cable or adapter to convert dual RCA outputs into a single 3.5mm TRS plug that connects directly to your PC’s line-in port.
Method 1 — Using an RCA to 3.5mm Stereo Adapter (Simplest)
What you need: An RCA to 3.5mm TRS stereo cable (sometimes called a dual RCA to mini jack cable)
Steps:
  1. Locate the RCA output jacks on your source device. The white jack is left; the red jack is right.
  2. Connect the white RCA plug to the white end of your adapter cable and the red RCA plug to the red end.
  3. Plug the 3.5mm TRS end into your PC’s line-in port (the blue jack on most desktops or labeled “Line In” on a laptop).
Note: A lot of newer laptops skip dedicated line-in ports these days. They usually come with a headset combo jack instead. That jack isn't made for stereo line-level audio input.
  1. Do not use the pink microphone jack. Mic inputs are tuned for low-level signals and will distort or overload when receiving line-level audio.
  2. Open your recording software or OS audio settings and confirm the signal appears in both the left and right channels.
Note: A passive adapter works well for consumer line-level sources such as receivers, VCRs, and cassette decks. If your source outputs a professional or instrument-level signal, use Method 2 instead for proper gain control.
When This Method Works Best
This method is ideal for digitizing audio from consumer electronics: TVs, VCRs, cassette decks, CD players, and home stereo receivers. It requires no drivers, no power, and minimal setup. This setup isn't meant for microphone-level sources or balanced professional audio gear. Those devices usually need an audio interface, mixer, or similar hardware. That gives you the right input, impedance, and gain control. A passive adapter cable just won't cut it there.
Method 2: Using a USB Audio Interface (Best Quality)
A USB audio interface converts analog audio to digital through a dedicated, high-quality converter. It connects to your PC via USB and gives you control over input gain, which is critical for clean recordings.
Method 2 — Using a USB Audio Interface (Best Quality)
What you need: A 2-channel USB audio interface (such as a Focusrite Scarlett 2i2) and cables to bridge your source connectors to the interface inputs.
Steps:
  1. Connect your source’s left output to Channel 1 on the interface and the right output to Channel 2. Use appropriate cables for your connector type (for example, RCA to 1/4” TS).
  2. Connect the interface to your PC using the supplied USB cable.
  3. Install any required drivers. Many modern interfaces are class-compliant and load automatically, but check the manufacturer’s support page to confirm.
  1. Set the input gain knobs to a moderate starting position. Play audio from your source and watch the interface’s level meters. Aim for green peaks with occasional amber and no red.
  1. In your OS audio settings (covered in the next section), select the interface as your input device and confirm stereo input is active.
On gain staging: Setting gain too high causes clipping; setting it too low introduces noise. Start at 12 o’clock and adjust incrementally while monitoring the meters.
Recommended Interface Types for This Use Case
For connecting a stereo L/R source, a 2-channel USB interface covers everything you need. Look for:
  • Two line-level inputs on your audio interface first. These can be 1/4-inch TRS inputs or combo XLR and 1/4-inch TRS/TS inputs. Just make sure they support line-level audio signals.
  • USB bus-powered operation, so no external power supply is required
  • A reliable driver history for your operating system
Phantom power, high channel counts, and MIDI I/O are unnecessary for this use case and should not influence your purchase.
Method 3: Using a USB Stereo Sound Card / Audio Dongle
Most modern laptops do not include a dedicated line-in port. A USB audio dongle provides an external audio input that works around this limitation.
Method 3 — Using a USB Stereo Sound Card / Audio Dongle
What you need: A USB external sound card that includes a line-in port (not just headphone output). Pair it with an RCA to 3.5mm TRS cable as described in Method 1.
Steps:
  1. Plug the USB audio adapter into an available USB port. Windows or macOS should detect it as a new audio device within a few seconds.
  2. Connect your RCA to 3.5mm TRS cable (white plug to left RCA, red plug to right RCA) and insert the 3.5mm end into the adapter’s line-in port.
  3. In your OS audio settings, select the USB sound card as your active input device.
  4. Run a short test recording in your software to confirm both channels are active.
USB dongles are fine for casual recordings and saving older audio files. Their analog-to-digital converters usually aren't as accurate as audio interfaces. If you care about better sound quality, Method 2 makes more sense.
Configuring Your PC to Recognize the Stereo Input
Plugging everything in is only part of the whole setup. Your computer also needs stereo recording turned on correctly. This is where most people usually run into problems.
Windows Audio Input Configuration
  1. Right-click the speaker icon in the system tray and select Sound settings.
Or open Control Panel > Sound.
  1. Click the Recording tab.
  1. Locate your input device (line-in, USB interface, or USB dongle). Right-click it and select Set as Default Device.
  2. Double-click the device to open its properties. Under the Advanced tab, confirm the format is set to 2 channel (stereo), not 1 channel.
  1. Click OK and watch the level meter in the Recording tab to confirm signal appears in both channels while audio plays from your source.
  2. Open Audacity or your preferred recording software, set the input to your chosen device, and make a short test recording to verify true stereo capture.
macOS Audio Input Configuration
  1. Open System Settings > Sound > Input.
  1. Select your input device from the list.
  2. Adjust the input volume slider to a moderate level and play audio from your source. Watch the input level bar to confirm a signal is arriving.
  1. If only one channel is active or channels appear swapped, open Audio MIDI Setup (Applications > Utilities).
  2. Select your input device in the left panel and confirm the format shows 2ch at your target sample rate (44100 Hz or 48000 Hz).
  1. Record a short test clip in GarageBand or Audacity to confirm both L and R channels are captured correctly before starting a full session.
Troubleshooting Common Problems
Problem
Likely Cause
Fix
Audio only in one channel
Mono adapter or cable fault
Replace with a stereo TRS cable; check that both RCA plugs are fully seated
No signal detected
Wrong port or missing driver
Confirm you are using line-in, not the mic jack; reinstall or update the device driver
Low or very noisy signal
Level mismatch or wrong port type
Switch to line-in if using mic-in; raise interface gain if using Method 2
Stereo recorded as mono
Software channel settings
In Audacity, set input to stereo; in Windows, confirm the device is set to 2-channel in Sound properties
Q: Can I use a microphone jack instead of line-in to connect L/R audio?
It's usually not a good idea. Microphone inputs are made for low-level mic signals, not line-level audio. A receiver, mixer, or similar device can overload that input. That often causes clipping or noticeable distortion. For better results, connect your source to a line-in port instead. You can also use a USB audio interface with line-level inputs.
Q: Why is my PC only recording one channel instead of stereo?
This usually happens because of the wrong adapter or input. A mono TS adapter can record only one channel. Picking a mono input inside your recording software also causes problems. A loose or faulty cable can do the same thing. Make sure you're using a stereo TRS adapter instead. Connect everything through a line-in port or stereo-capable audio interface. Then check your recording software records in stereo mode. Finally, confirm your source device sends audio through both channels.
Q: Do I need special software to record left and right audio separately?
Not necessarily. Most DAWs and free tools like Audacity record stereo input as two discrete channels by default. Before you start, check the input settings in your software and confirm stereo is selected. No specialized software is required for basic two-channel capture.
Q: What is the difference between RCA and 3.5mm stereo connectors?
RCA stereo audio uses two separate plugs for left and right channels. The white plug carries left audio. Whereas the red carries right. A 3.5 mm TRS plug combines both channels into one connector. Its tip carries left, ring carries right, and sleeve provides ground. A passive RCA-to-3.5 mm adapter simply matches both connector types. It needs no power with compatible analog line-level audio devices.
For quick, casual digitizing, an RCA to 3.5mm adapter paired with a PC line-in port is the simplest path. For clean, reliable recordings, a 2-channel USB audio interface is the better investment. If your laptop lacks a line-in port, a USB audio dongle covers the gap. Whichever method you choose, run a short test recording first to confirm both channels are active before starting a full session.
