Audio that cuts in and out can quickly ruin your experience. It can interrupt games, video calls, or movies without warning. The good news is that this problem is rarely caused by bad speakers. A damaged sound card is also not the usual reason. Most of the time, choppy audio is caused by driver problems. Wrong settings or too many tasks running at once can also create issues. You can usually fix the issue without much effort. Work through the diagnostic section below first, then go directly to the fix that matches your situation.
What “Choppy Audio” Usually Means And Why It Happens
Choppy PC audio comes in a few different forms. There is constant crackling or static that never goes away, audio that cuts in and out every few seconds at regular intervals, and stuttering that only appears when the system is under heavy load. Each pattern points to a different root cause, and applying the wrong fix wastes time.
The important thing to understand is that nearly all choppy audio problems on Windows are software-side issues. Your audio signal travels through a driver layer, the Windows audio engine, and power management before it ever reaches your speakers or headset. When any part of that chain misfires, the result is audible distortion. A damaged speaker or failed sound chip is uncommon. They usually cause no sound at all instead of audio that cuts in and out.
This means the fixes below are things any Windows user can apply. No hardware tools required.
Quick Diagnostic: Find Your Likely Cause First
Scan this table before applying any fix. Matching your symptoms to the correct cause significantly reduces troubleshooting time.
Symptom Pattern |
Most Likely Cause |
Jump to Fix |
Choppy only over Bluetooth |
Codec mismatch or Wi-Fi/BT interference |
Fix 6 |
Cuts out every few seconds (regular rhythm) |
USB Selective Suspend |
Fix 4 |
Choppy only when CPU usage is high |
DPC latency or buffer starvation |
Fix 5 |
Choppy after a Windows update |
Audio driver regression |
Fix 1, Fix 7 |
Choppy across all apps |
Driver, sample rate, or power issue |
Fix 1, Fix 2, Fix 4 |
Choppy on one app only |
App buffer setting or Exclusive Mode conflict |
Fix 3, FAQ Q3 |
Crackling or static with no clear pattern |
Audio enhancements or sample rate mismatch |
Fix 2, Fix 3 |
Pro Tip: If audio only stutters during gaming or video rendering, go straight to Fix 5. If the problem started the day after a Windows Update notification, start with Fix 1 and Fix 7.
Fix 1: Update or Reinstall Your Audio Driver
An outdated, corrupted, or incompatible audio driver is the most common cause of choppy audio on Windows. This fix resolves the problem for the majority of users.
Press Windows + X and select Device Manager.
Expand Sound, video and game controllers.
Right-click your audio device (commonly labeled Realtek High Definition Audio, Intel Smart Sound Technology, or IDT High Definition Audio).
Select Update driver, then choose Search automatically for drivers.
If Windows reports the driver is already current but the problem continues, visit your PC manufacturer’s support page (Dell, HP, Lenovo) or the chipset maker’s site (realtek.com) and download the latest driver manually.
For a clean reinstall: right-click the device, select Uninstall device, check the box for Delete the driver software for this device, and click Uninstall.
Restart your PC. Windows will reinstall the default driver automatically, or you can run the installer you downloaded.
Note: If both “Realtek High Definition Audio” and “Intel Display Audio” are listed, update both. Intel Display Audio handles HDMI and DisplayPort output and can cause stuttering independently.
Fix 2: Match Audio Format and Sample Rate
When the sample rate of your audio source does not match the Windows audio engine’s output setting, Windows performs real-time conversion on every sample. Under any CPU load, this conversion process creates buffer stuttering even on capable hardware.
Right-click the speaker icon in your system tray and select Sounds (Windows 10) or Sound settings (Windows 11).
In Windows 10, go to the Playback tab, right-click your default audio device, and select Properties. In Windows 11, click More sound settings first, then follow the same path.
Click the Advanced tab.
Open the Default Format dropdown and select 24-bit, 48000 Hz (Studio Quality).
Click Test to confirm playback sounds clean.
Click Apply, then OK.
Note: 48 kHz is the standard for gaming audio, video, and most streaming content. If you primarily play music ripped from CDs, try 24-bit, 44100 Hz instead. The goal is to match the format to your most common source rather than maximizing bit depth.
Fix 3: Disable Audio Enhancements
Windows applies real-time audio processing effects including bass boost, loudness equalization, and spatial sound. These effects run continuously on the CPU and can cause crackling or choppy output when the system is under any meaningful load.
Right-click the speaker icon and select Sounds (or More sound settings on Windows 11).
On the Playback tab, double-click your active playback device.
Click the Enhancements tab.
Check Disable all enhancements.
Click Apply.
Note: The Enhancements tab may not be available on every Windows version or audio driver. If you do not see it, open your audio manufacturer's software to adjust the sound effects instead.
Switch to the Advanced tab in the same window.
Under Exclusive Mode, uncheck Allow applications to take exclusive control of this device.
Pro Tip: Exclusive Mode lets a single app bypass the Windows audio mixer entirely. This can be useful for high-end audio software but causes conflicts when multiple apps compete for the audio device, resulting in stuttering or sudden silence for one of them.
Fix 4: Disable USB Selective Suspend and Adjust Power Plan
Windows power management is designed to cut power to idle USB devices to extend battery life. For USB audio devices like headsets, DACs, and external sound cards, this shutoff creates audio dropouts that repeat every few seconds as the device powers down and back up.
Part A: Adjust the power plan and disable USB suspend
Press Windows + R, type powercfg.cpl, and press Enter.
Click Change plan settings, then Change advanced power settings.
Expand USB settings, then expand USB selective suspend setting.
Set it to Disabled.
Part B: Disable device-level power management
Open Device Manager (Windows + X).
Expand Sound, video and game controllers and right-click your audio device.
Select Properties, then click the Power Management tab.
Uncheck Allow the computer to turn off this device to save power.
Click OK.
Note: Laptop users concerned about battery life can switch back to Balanced mode when not actively using audio. Disabling USB selective suspend is the higher-priority step here since it directly controls the dropout behavior.
Fix 5: Check for CPU Overload and High-DPC Latency
When the CPU cannot service the audio buffer in time, the audio engine runs out of data to output, and you hear a stutter. This is called a buffer underrun. The cause is usually a driver running at high priority with elevated DPC (Deferred Procedure Call) latency, which blocks the audio thread from executing on time.
Step 1: Confirm CPU usage during playback
Press Ctrl + Shift + Esc to open Task Manager.
Click the Performance tab.
Play the choppy audio and watch the CPU graph in real time. If usage spikes above 80 to 90 percent during stuttering, close background apps, browser tabs, and background update processes and retest.
Step 2: Use LatencyMon to find the offending driver
Download LatencyMon (free) from resplendence.com.
Open it and click the green Play button.
Play audio for 2 to 3 minutes while LatencyMon monitors in the background.
Click the Drivers tab. Drivers with high values highlighted in red are causing latency spikes.
Note the driver file name to identify which component needs updating.
Top DPC latency offenders to look for:
ndis.sys — Network adapter driver. Update or roll back the NIC driver.
nvlddmkm.sys / atikmdag.sys — NVIDIA or AMD GPU driver. Update through GeForce Experience or AMD Software.
MsMpEng.exe — Windows Defender scanner. Schedule full scans for off-hours rather than running them mid-use.
storport.sys — Storage controller. Check for NVMe drive firmware updates from the manufacturer.
Fix 6: Fix Choppy Bluetooth Audio Specifically
Bluetooth sound problems are often different from wired audio issues. If both connections sound choppy, start by checking Windows audio settings first. If only Bluetooth has the problem, focus on fixing the wireless connection instead.
Force the A2DP stereo codec: Windows sometimes defaults to the Hands-Free Telephony (HFP) profile, which runs at lower quality and drops out more frequently. In Device Manager, expand Sound, video and game controllers, find any entry for your Bluetooth headset labeled “Hands-Free” or “Telephony,” right-click it, and select Disable device. This forces the system to use the higher-quality A2DP stereo profile.
Reduce 2.4 GHz interference: Bluetooth and Wi-Fi share the 2.4 GHz band. Switching your router to 5 GHz or moving your Bluetooth device closer to the adapter reduces interference significantly.
Update the Bluetooth driver: Open Device Manager, expand Bluetooth, right-click your adapter, and select Update driver. Check the laptop or motherboard manufacturer’s site for the latest version.
Check distance and line of sight: Bluetooth audio quality degrades past 20 to 30 feet and through solid walls. Keep the headset within a clear line of sight of the transmitter.
Re-pair the device from scratch: Go to Settings > Bluetooth, remove the device, and pair it fresh. Stale pairing data can cause repeated codec negotiation failures.
Fix 7: Run the Windows Audio Troubleshooter and Check for Windows Updates
If the previous fixes did not solve the problem, try the Windows troubleshooter. It can find common configuration problems on its own. Also, look for Windows updates. They may fix driver issues caused by a recent system update.
Run the audio troubleshooter:
Go to Settings > System > Sound (Windows 11) or Settings > Update & Security > Troubleshoot > Additional troubleshooters (Windows 10).
Select Playing Audio and click Run the troubleshooter.
Follow the prompts and apply any fixes it recommends, then retest.
Check for pending updates:
Go to Settings > Windows Update and click Check for updates.
Install any available audio driver or chipset updates.
If the stuttering started immediately after a recent update, go to Settings > Windows Update > Update history > Uninstall updates and remove the most recently installed cumulative update.
Note: Sometimes a Windows update can mess up Realtek or Intel audio drivers. If the sound problem began after updating, switch back to the earlier version. Hold off on new updates until Microsoft fixes the issue.
Still Choppy? Two Last Resorts (Bonus Fixes)
If every fix above has failed, you are likely dealing with either deep software corruption or a hardware fault.
A clean Windows reinstall eliminates all driver conflicts, corrupted registry entries, and software-layer issues that individual fixes cannot reach. Back up your data first and allow time to reinstall your applications. It is a real time investment, but it removes the entire software stack as a variable.
If a clean Windows install does not resolve the problem, the issue is physical. A failing onboard audio chip, a damaged USB port, or a faulty USB hub can each cause persistent audio problems that no software fix will touch. Testing with a low-cost USB audio adapter is a practical diagnostic step at this stage. If the USB adapter plays audio without any problems, your PC's built-in audio hardware is likely at fault. A repair technician can confirm the issue and recommend the right solution.
Why is my audio choppy only when gaming?
Gaming places a heavy simultaneous load on the CPU and GPU, which can spike DPC latency and starve the audio buffer. The most common cause is the GPU driver (nvlddmkm.sys for NVIDIA, atikmdag.sys for AMD) blocking audio thread execution. Update your GPU driver first. If the stuttering continues, run LatencyMon during a gaming session to identify the exact driver responsible. See Fix 5 for the full process.
Why did my audio become choppy after a Windows update?
Your audio problems may have started after a Windows update. Try switching back to the older sound driver through Device Manager. You can also remove the newest Windows update from Update History. If the issue appeared after the update, that is probably why it happened.
Why is my audio choppy only on one app?
When only one app produces choppy audio, the cause is usually inside that application. Check the app’s own audio settings for buffer size or output device options. Discord, Spotify, and web browsers each have independent audio configurations separate from Windows. It can also be an Exclusive Mode conflict where the app takes sole control of the audio device. Disabling Exclusive Mode in Fix 3 often resolves this without touching the app itself.
Why does my audio stutter every few seconds at a regular interval?
Predictable, rhythm-like stuttering every few seconds is the signature symptom of USB Selective Suspend cutting power to your audio device on a timer. This pattern is distinct from the random, load-triggered stuttering caused by CPU overload. Go directly to Fix 4 and disable USB Selective Suspend in your advanced power settings. This is especially common on laptops running USB headsets or external DACs.
Can a bad internet connection cause choppy audio?
Only for streamed content. If audio from YouTube, Spotify, or a video call stutters while locally stored files play cleanly, check your internet connection first. If both local and streaming audio are choppy, the cause is hardware or driver-side and the network is not involved. Running a quick speed test and checking Wi-Fi signal strength takes less than a minute and rules out the network before you spend time on driver fixes.
For most users, Fix 1 (driver update) or Fix 2 (sample rate matching) resolves choppy audio within a few minutes. Start with the diagnostic table to match your exact symptom to the right fix rather than applying every step in sequence. Related issues worth investigating next include microphone audio choppy during recording and no sound on Windows 11, which share some causes but follow different fix paths.
Most common fix by scenario: - Audio choppy after a Windows update: Fix 1 and Fix 7 - Audio cuts out every few seconds: Fix 4 - Choppy only while gaming: Fix 5 - Bluetooth audio stuttering: Fix 6 - Crackling with no clear trigger: Fix 2 and Fix 3
