Why Does OBS Audio Sound Bad? Common Causes and How to Fix Them
OBS is a powerful recording and streaming tool, but its default settings do not always produce clean audio out of the box. If your voice sounds robotic, muffled, or noticeably worse than what you hear in your headphones, the problem almost always has a specific, fixable cause. This guide walks through the five most common reasons OBS audio sounds bad and gives you exact steps to correct each one.
c? Common Causes and How to Fix Them
What “Bad OBS Audio” Usually Sounds Like
Before diving into fixes, identify your symptom. Different audio problems point to different causes:
  • Robotic or underwater effectsample rate mismatch between OBS and your OS, or noise suppression set too aggressively
  • Muffled or dull sound → low audio bitrate or the wrong input device being captured
  • Crackling or popping → driver issue, USB bandwidth congestion, or CPU overload during encoding
  • Thin or quiet with no body → poor source microphone or a missing compressor in the filter chain
Find your symptom above, then jump to the corresponding fix section.
The Five Most Common Reasons OBS Audio Sounds Bad
These causes are ordered by how often they appear in practice. Work through them in sequence before assuming the problem is hardware.
  1. Sample rate mismatch between OBS and the OS audio device
  2. Audio bitrate set too low in OBS output settings
  3. Wrong audio input device selected in OBS
  4. Audio filters misconfigured, especially noise suppression
  5. The microphone or input source itself is the problem
Fix 1 — Sample Rate Mismatch (The Most Common Culprit)
A sample rate mismatch is the single most reported cause of robotic, distorted, or underwater-sounding audio in OBS. When OBS expects audio at 48kHz but your operating system delivers a signal at 44.1kHz (or vice versa), OBS must resample the audio in real time. That conversion introduces artifacts, and when it is not handled cleanly, it turns a natural-sounding voice into something that resembles a broken phone call.
The fix requires matching the sample rate in two places: inside OBS and inside your OS audio device settings.
Setting the Correct Sample Rate in OBS
Open OBS and navigate to Settings > Audio. Find the Sample Rate dropdown and set it to 48kHz. This is the standard sample rate for video audio and is what most recording and streaming platforms expect. Save and close.
Matching the Sample Rate in Windows
  1. Right-click the speaker icon in the system tray and select Sound settings.
  1. Click More sound settings to open the classic Sound control panel.
  1. Under the Playback tab, right-click your output device and select Properties.
  1. Click the Advanced tab.
  1. In the Default Format dropdown, select 24-bit, 48000 Hz (Studio Quality) or 16-bit, 48000 Hz.
  1. Repeat this process under the Recording tab for your microphone device.
  2. Click OK and restart OBS.
Matching the Sample Rate on macOS
  1. Open Finder and navigate to Applications > Utilities > Audio MIDI Setup.
  2. Select your input device in the left column.
  3. In the Format dropdown on the right, set the sample rate to 48000 Hz.
  4. Repeat for your output device if needed.
  5. Close Audio MIDI Setup and restart OBS.
After making these changes, record a short test clip and listen back. The robotic or underwater quality should be gone.
Fix 2 — Audio Bitrate Is Too Low
Even with the sample rate set correctly, OBS can still produce thin, lifeless audio if the audio bitrate is too low. Bitrate controls how much data is used to encode your audio signal. When bitrate is insufficient, the encoder discards high-frequency content and fine detail, leaving audio that sounds compressed and dull, regardless of how good your microphone is.
OBS can default to as low as 128kbps or even 96kbps depending on version and configuration. At those levels, even a quality microphone will sound noticeably worse than it does during direct monitoring.
Where to change it: Go to Settings > Output. In Simple output mode, look for the Audio Bitrate dropdown.
In Advanced output mode, go to the Recording and Streaming tabs and adjust each independently.
Recommended values:
  • Local recording: 320kbps AAC
  • Live streaming (bandwidth-limited): 160 to 192kbps minimum
  • Avoid: anything below 128kbps, where quality degradation becomes audible to most listeners
Always record a fresh test clip after updating the bitrate. Do not rely on previous recordings to evaluate the change.
Fix 3 — Wrong Audio Input Device Selected in OBS
OBS can capture audio from multiple sources simultaneously, and it does not always select the right device by default. A common scenario: OBS is recording from a webcam’s built-in microphone instead of your dedicated USB or XLR mic. Another: your microphone and desktop audio are being routed into the same channel, creating a muddy, layered signal.
To verify and correct your audio device:
  1. Go to Settings > Audio in OBS.
  1. Under Global Audio Devices, check the Mic/Auxiliary Audio dropdown. This should show your dedicated microphone, not simply “Default” if your system default points to the wrong device.
  1. Confirm that Desktop Audio is set separately to capture system sounds (game audio, music) on its own channel.
  2. Click OK and return to the main OBS window.
  1. In the Audio Mixer, verify that your microphone and desktop audio appear as separate faders, not combined into one channel.
If you spot an unwanted source, mute it using the speaker icon on its fader rather than deleting it, then record a short test clip to confirm you are capturing from the correct device.
Note: On Windows, you may see a choice between WASAPI and DirectSound capture modes in device properties. WASAPI is the recommended option. It offers lower latency and better compatibility with modern audio hardware.
Fix 4 — Audio Filters Are Misconfigured or Missing
OBS audio filters can either improve your sound or actively damage it, depending on how they are set up. The most common mistake is applying noise suppression too aggressively, which produces a robotic or watery artifact that many users incorrectly blame on sample rate or encoding problems.
The table below shows a recommended minimal filter chain with safe starting settings and the most common mistake for each filter:
Filter
Recommended Setting
Common Mistake
Gain
+0 to +6 dB (adjust to your level)
Excessive gain amplifies background noise
Noise Suppression (RNNoise)
Default settings; prefer RNNoise over Speex
Over-applying Speex suppression causes robotic sound
Compressor
Threshold: -18 dB, Ratio: 4:1
Ratio set too high flattens voice character
Limiter
Threshold: -2 dB
Often skipped; its absence allows clipping distortion
To access filters in OBS, right-click any audio source in the Audio Mixer and select Filters.
Why Noise Suppression Causes Robotic Audio
OBS offers two noise suppression algorithms: Speex and RNNoise. Speex is an older algorithm that becomes destructive when pushed too hard. Setting it below -30 dB, or applying it to an already clean signal, strips voice harmonics alongside the background noise, producing a garbled, robotic effect. RNNoise handles noise more cleanly without the same harmonic damage, and its default settings are generally safe. If your audio sounds robotic and you are using Speex, switch to RNNoise or disable noise suppression entirely, then record a test clip to see whether the problem disappears.
When to Use Zero Filters
If your recording environment is reasonably quiet and your microphone produces a clean signal, a minimal filter chain of just a gain filter and a limiter often sounds better than a heavily processed one. Adding compressors and noise suppression to an already clean signal can introduce more artifacts than it resolves. Start with no filters, listen to a test recording, and add filters only when a specific problem makes them necessary.
Fix 5 — The Microphone or Input Source Is the Root Problem
When sample rate, bitrate, device selection, and filters are all confirmed correct and audio still sounds poor, the problem is upstream of OBS. No combination of software settings can fully compensate for a fundamentally low-quality input signal.
How to Test Whether Your Mic Is the Real Issue
Record a short voice clip using a tool that bypasses OBS entirely. On Windows, use the built-in Voice Recorder app. On macOS, open QuickTime Player, select File > New Audio Recording, and record 15 to 30 seconds of speech at normal speaking volume. Listen to that recording carefully. If it sounds equally poor, OBS is not the problem; the issue lies with the microphone hardware or its placement. If the direct recording sounds clean but the OBS output sounds bad, return to Fixes 1 through 4 and recheck each setting.
When to Consider an Upgrade
Built-in laptop microphones, inexpensive clip-on mics, and aging condenser capsules have fundamental limitations that no filter chain can reliably overcome. For streamers and content creators who need clean audio at the source, upgrading the input device is the only lasting fix. The Hollyland LARK MAX 2 captures audio at 48kHz / 32-bit Float, which matches OBS’s recommended sample rate natively and eliminates the mismatch problem before the signal ever reaches OBS. Its onboard AI Noise Cancellation also reduces ambient noise at the hardware level, which in turn reduces the pressure on OBS filter settings that, when pushed too hard, cause the robotic artifacts described in Fix 4.
Other Factors That Can Degrade OBS Audio
If you have addressed all five fixes and quality is still not where it should be, these less common causes are worth ruling out:
  • CPU overload: When OBS’s encoder is starved for processing power, audio dropouts and crackling appear alongside video problems. Switching to a lighter encoder preset or reducing output resolution can free up enough resources to stabilize the audio.
  • Outdated or conflicting audio drivers: If all settings appear correct but quality remains poor, reinstall or roll back audio drivers through Device Manager on Windows or run a system update on macOS.
  • USB bandwidth congestion: Multiple high-bandwidth USB devices sharing a hub can cause a USB microphone to crackle or drop out. Plug the microphone directly into a port on your computer, or move it to a dedicated powered USB hub.
  • Monitoring confusion: If OBS audio monitoring is enabled, you may be hearing a delayed monitoring signal playing alongside your recording playback. The resulting echo is not a recording defect but rather the monitor output playing through your headphones at the same time.
Why does my OBS audio sound robotic?
The most likely cause is a sample rate mismatch between OBS and your Windows or macOS audio device settings. Set both to 48kHz as outlined in Fix 1. The second most common cause is Speex noise suppression applied too aggressively in the OBS Filters panel. Disable noise suppression temporarily and record a test clip to confirm whether the filter is creating the artifact.
Why does OBS audio sound muffled?
Muffled audio most often points to a low audio bitrate (128kbps or below) or an incorrect sample rate setting. It can also result from OBS capturing audio through the wrong input device, such as a webcam microphone positioned behind a monitor rather than a dedicated mic placed close to your mouth.
Why does my audio sound worse in OBS than in my headphones?
Direct monitoring lets you hear the raw, unprocessed signal from your microphone. OBS encodes and compresses that signal before writing it to a file or sending it to a stream. At low bitrates, encoding removes the high-frequency detail that is clearly audible when monitoring directly. Raising the recording bitrate to 320kbps significantly narrows that quality gap.
Does OBS have a built-in audio enhancer?
OBS does not include a one-click audio enhancer. Its Filters panel, accessed by right-clicking any audio source in the Audio Mixer, provides individual processing tools including gain, noise suppression, compressor, and limiter. When configured appropriately for your specific microphone and room, these filters collectively serve the function of audio enhancement.
What is the best OBS audio bitrate for recording?
For local recordings, 320kbps AAC is the standard recommendation and produces audio clean enough for professional post-production use. For live streaming where upload bandwidth is a constraint, 160 to 192kbps is a practical minimum. Dropping below 128kbps is where most listeners will notice audible quality loss, even without directly comparing recordings side by side.
Start With the Most Likely Fix First
Begin with the sample rate, since it is the most common cause and the simplest to correct. Then check bitrate, input device, and filters in that order. Record a short test clip after each individual change so you can hear the effect of each adjustment in isolation rather than guessing which fix helped. The underlying principle is straightforward: the cleaner the signal entering OBS, the less any setting inside OBS has to compensate, and the less room there is for filters or encoding to introduce new problems.
