Your laptop microphone picked the worst possible time to stop working. Whether it went silent before a Zoom call, stopped recording mid-session, or simply disappeared from your sound settings, the fix is almost always easy to find. This guide explains each cause and solution step by step. It starts with quick two-minute checks first. Then moves into driver-level repair methods on Windows and macOS. It also explains what to do if the hardware fails completely.
Why Your Laptop Microphone Stops Working?
Most laptop microphone failures trace back to one of five causes:
OS privacy settings blocking mic access: Windows and macOS both require explicit app-level permission to use the microphone, and an update can silently reset this.
Wrong default recording device: Another audio input, such as a recently disconnected headset or USB device, has claimed the default input slot.
Outdated or corrupted audio driver: Driver conflicts are especially common after Windows feature updates.
App-level permission override: Zoom, Teams, or a browser may be set to use a different input device than the OS default.
Physical hardware failure: A damaged or dead microphone capsule that no software fix will resolve.
Check These Things First Before You Dig In
These checks take under two minutes and resolve a surprising number of cases. Complete these steps first before going into OS-specific sections.
Check for a physical mute switch: Many laptops, particularly business models, have a dedicated microphone mute button on the keyboard or chassis. Confirm it is not engaged. A small LED indicator near the key or a red light on the lid is a common sign.
Check the microphone volume level: On Windows, open Sound Settings > Input and verify the input volume slider is not set to zero.
On Mac, go to System Settings > Sound > Input and confirm the Input Volume slider is above 50%.
Check the mic selected inside the failing app: Open the app’s own audio settings:
Zoom: Settings > Audio > Microphone — confirm the correct input device is listed.
Microsoft Teams: Settings > Devices > Microphone — select the correct input.
Google Meet: Click the three-dot menu > Settings > Audio > Microphone.
Test with a second app to isolate the scope: If the mic appears broken in Zoom, test it in a neutral app first:
Windows: Open Voice Recorder (search in the Start menu) and record a short clip.
Mac: Open QuickTime Player > File > New Audio Recording and click the record button.
If the second app records sound properly, only that app is causing trouble. The system itself is not the source of the issue. When neither app records audio, proceed to the fixes for the operating system next.
How to Fix a Laptop Microphone Not Working on Windows?
Go through each fix one by one in order. Every step targets a deeper possible cause than the previous one.
Enable Microphone Access in Privacy Settings
This is the single most common cause of a broken mic after a Windows 11 update, and it takes 30 seconds to check.
Open the Start menu and click Settings.
Go to Privacy & Security > Microphone.
Confirm the toggle “Allow apps to access your microphone” is switched ON.
Scroll down the same page to the list of individual apps. Find the app that is failing — Zoom, Microsoft Teams, your browser — and confirm its toggle is also ON.
Restart the failing app and test the microphone.
Note: Desktop apps and Microsoft Store apps appear in separate lists on this page. If your app does not appear under “Let desktop apps access your microphone,” scroll further down to find it.
Set the Microphone as the Default Recording Device
If the mic appears in settings but still produces no audio in calls or recordings, another device may have claimed the default input slot.
Right-click the speaker icon in the Windows taskbar (bottom-right corner).
Select Sound Settings / Open sound settings.
Scroll down and click More sound settings to open the classic Sound control panel. If you have Windows 10, click the “Sound Control Panel” option on the left panel under the Related Settings section.
Click the Recording tab.
Locate your laptop’s internal microphone in the list. Right-click it and select Set as Default Device.
Speak into the microphone and watch the green bar next to the device — it should animate in response to your voice.
Click OK to save.
Note: If no microphone appears in the Recording tab at all, right-click the empty list area and check “Show Disabled Devices” and “Show Disconnected Devices.” If it still does not appear, move on to the driver fix below.
Update or Reinstall the Audio Driver
A corrupted or incompatible audio driver can make the microphone invisible to Windows entirely.
To update the driver:
Right-click the Start menu and select Device Manager.
Expand Sound, Video and Game Controllers.
Right-click your audio device — usually listed as Realtek HD Audio, Realtek(R) Audio, or Intel Smart Sound Technology.
Select Update driver > Search automatically for drivers.
If Windows finds an update, install it and restart.
To fully reinstall the driver (use this if the update finds nothing, or the mic still fails):
Repeat steps 1–3 above.
Right-click the audio device and select Uninstall device.
Check the box labeled “Delete the driver software for this device” if it appears.
Click Uninstall, then restart your laptop.
Windows will detect the missing driver and reinstall it automatically on reboot.
After restarting, test the microphone in Voice Recorder before reopening your video call app.
Run the Windows Audio Troubleshooter
The built-in troubleshooter works best as an automated first pass for non-technical users, or as a confirmation step after the manual fixes above. It will not resolve permission issues or corrupt drivers, but it can catch misconfigured default devices and audio service errors.
Go to Settings > System > Sound > Troubleshoot > Other troubleshooters.
Find Recording Audio and click Run.
Follow the on-screen prompts and accept any recommended fixes.
Restart and test the microphone.
How to Fix a Laptop Microphone Not Working on a Mac?
The steps below apply to macOS Monterey, Ventura, and Sonoma. Older macOS versions use System Preferences instead of System Settings, but the settings themselves are identical.
Grant Microphone Permission to the App
macOS requires each app to request and receive microphone access individually. This permission can be silently revoked after a system update.
Open System Settings from the Apple menu.
Find the failing app in the list and confirm its toggle is ON.
If the toggle is already on, switch it OFF, wait five seconds, then switch it back ON. This forces macOS to refresh the permission state.
Quit and fully relaunch the app before testing.
Note: Browser-based tools like Google Meet require permission in two layers. The system must allow microphone access in Privacy and Security settings. On Mac or Windows, this appears under microphone permissions. Each website also needs access inside browser settings. You must allow the microphone and camera for that specific site. Check both.
Select the Built-In Microphone as the Input Device
A recently disconnected USB device, a plugged-in headphone jack, or an AirPlay connection can silently reroute macOS audio input away from the built-in microphone with no notification.
Go to System Settings > Sound and click the Input tab.
Look for “MacBook Pro Microphone,” “MacBook Air Microphone,” or “Internal Microphone” in the list and click it to select it.
Drag the Input Volume slider to at least 75%.
Speak into the microphone and confirm that the input level bar below the slider shows movement.
If no movement appears, unplug anything connected to the audio jack or USB-C ports and re-test.
Restart Core Audio
If the microphone appears correctly in System Settings but produces no usable signal in any app, the macOS Core Audio daemon may have entered a frozen state. Restarting it takes about ten seconds and does not modify any system files or require a full reboot.
Open Terminal (Applications > Utilities > Terminal, or search with Spotlight).
Type the following command and press Return:
sudo killall coreaudiod
Enter your administrator password when prompted.
macOS restarts the Core Audio process automatically. Wait five seconds, then test the microphone in System Settings > Sound > Input.
Install Pending macOS Updates
Specific macOS releases shipped with documented microphone regression bugs — Ventura 13.0 and 13.1, and the initial Sonoma 14.0 release, all had reported audio input issues that were later patched. If your microphone stopped working shortly after a system update, go to System Settings > General > Software Update and install any available updates. This is a targeted fix for post-update mic failures, not a general suggestion to update indiscriminately.
Still Not Working? Here’s How to Tell If It’s a Hardware Problem
Before spending money on a repair, confirm whether the failure lives in hardware or in your software environment. Run through these steps in order:
Create a new user account and test. On Windows, go to Settings > Accounts > Family & other users > Add account. On Mac, go to System Settings > Users & Groups > Add User. Log into the new account and test the microphone in Voice Recorder (Windows) or QuickTime (Mac). If the mic works in the new account, the cause is a corrupted user profile or a user-specific setting — not hardware damage.
Test in Safe Mode. On Windows, go to Settings > Recovery > Advanced Startup > Restart now, then select Troubleshoot > Advanced Options > Startup Settings to boot into Safe Mode. On Mac, shut down the computer fully first. For Apple Silicon Macs, press and hold the power button. Wait until “Loading startup options” appears on screen. Choose startup volume, then hold the Shift key and Continue Safe Mode. On Intel Macs, restart and hold the Shift key right away. Keep holding until the login screen shows Safe Mode active. Test the microphone inside Safe Mode to check behavior. If it works, a third-party app causes interference.
Check BIOS/UEFI settings. Some laptops, especially enterprise models, include an internal microphone toggle inside the BIOS firmware. Restart and enter BIOS setup (commonly F2, F10, or Del at startup, depending on manufacturer). Look under Advanced > Audio or Onboard Devices for an internal microphone setting and confirm it is enabled.
Inspect for physical damage. Examine the small microphone pinhole — usually near the webcam or on the underside of the lid. Look for cracks, debris, or liquid staining around it. A recent drop or spill is a strong indicator of hardware failure.
If the microphone shows no signal in Safe Mode, the issue is deeper. It also fails across all user accounts on the system. With no BIOS option available, hardware becomes the likely cause. This is after removing driver corruption and system file problems. In this case, using an external microphone is the most practical choice.
Your Laptop Mic Is Dead — Use an External Wireless Mic Instead
If hardware failure is confirmed, or if you want a microphone that simply outperforms any built-in laptop mic, a compact wireless microphone solves the problem immediately. The Hollyland LARK M2 is the practical choice for laptop users: a small clip-on transmitter worn near the mouth, a receiver that plugs directly into the laptop’s USB-C or 3.5mm port, and zero driver installation required on either Windows or macOS.
Here is how to get it running on your laptop:
Connect the receiver to your laptop. Plug the LARK M2 receiver into your laptop’s USB-C port (or 3.5mm audio input, depending on your LARK M2’s version). No drivers download automatically; the OS registers it immediately as a standard audio input device.
Power on the transmitter. Remove the transmitter from its charging case. It powers on automatically. Both the transmitter and receiver LEDs will show a solid blue light once they are paired and active. A blue flashing LED indicates the unit is still searching or completing the pairing process — wait until both LEDs display solid white before proceeding.
Confirm the pair. Once both LEDs are solid blue, the system is live and ready. No additional pairing button is required; the LARK M2 transmitter and receiver pair automatically when removed from the charging case together.
Adjust gain if needed. For the USB-C receiver, you can tweak gain from the HollyAudio (LarkSound) app. Or, if you have connected the camera receiver of LARK M2 to your laptop via USB-C cable, then the receiver includes a gain knob. You can use it to apply three (low, medium, and high) gain levels to match your speaking volume and environment. The indicator lights on the unit reflect the current gain setting. A single blue indicator represents that the gain is low. Whereas if all three indicator lights are solid blue, it means the gain is set to high.
Select LARK M2 as your input in Windows. Right-click the speaker icon in the taskbar > Sound Settings > Input. The LARK M2 receiver will appear by name in the input device list. Select it and confirm the input level bar responds when you speak.
Select LARK M2 as your input on Mac. Go to System Settings > Sound > Input. The LARK M2 receiver will appear in the list. Click it to select it and watch the input level meter respond to your voice.
The LARK M2 transmitter runs for up to 40 hours when used with the charging case, making it practical for full days of remote work, back-to-back meetings, or extended recording sessions without stopping to recharge.
For users who want the simplest possible setup at a lower price point, the Hollyland LARK A1 is worth considering. Its USB-C receiver plugs directly into any laptop port with no pairing steps required, and a single button cycles through three levels of intelligent noise cancellation. It appears immediately as an audio input device on both Windows and macOS.
Why did my laptop microphone suddenly stop working after a Windows update?
Windows updates sometimes reset microphone privacy permissions or replace manufacturer audio drivers with generic alternatives. Start by going to Settings > Privacy & Security > Microphone and confirming both the master toggle and your specific app’s toggle are switched on. If the mic is still silent, open Device Manager and check whether a driver rollback option is available for your audio device.
Why does my microphone work in one app but not another?
Each app manages its own microphone input selection independently from the OS default. Open the audio settings inside the failing app directly. In Zoom, go to Settings > Audio; in Teams, go to Settings > Devices. Confirm the correct microphone is selected there. An app update can silently switch the input to a different device without any notification.
How do I test whether my laptop microphone is working?
On Windows, open Sound Settings > Input and speak — the input level bar should animate. On Mac, go to System Settings > Sound > Input and watch the input meter respond. For a more definitive test, use Voice Memo on Windows or open QuickTime Player > File > New Audio Recording on Mac and play the clip back to confirm audio was captured.
Is an external microphone better than a built-in laptop mic?
In almost every case, yes. Built-in laptop microphones are placed inside the chassis. That keeps them away from the speaker's mouth. They capture keyboard clicks, fan noise, and room echo clearly. An external wireless microphone, like Hollyland LARK M2, positions the capsule close to the speaker. It includes noise cancellation, producing cleaner audio for call recordings and video content.
Begin with privacy settings and default device selection checks. If they do not, apply the driver fix first. Then use Safe Mode and clean user account testing. To confirm whether the issue is hardware or software. If the hardware has failed, an external microphone is a faster option. More practical than internal repair of the laptop. Hollyland LARK M2 connects in under one minute. Works immediately on any laptop and any operating system.
