How to Access and Configure Microphone Settings in Windows 11 (Step-by-Step)
Windows 11 reorganized the audio settings interface, splitting microphone controls across several menus that do not always connect intuitively. Whether you are configuring a wireless USB mic like the Hollyland LARK MAX 2 for the first time or troubleshooting a silent input after upgrading from Windows 10, the path to the right panel is not always obvious. This guide explains each important step in the correct order. It covers finding settings, selecting default devices, adjusting input levels, allowing app permissions, and checking for clean microphone signals.
Where to Find Microphone Settings in Windows 11?
Windows 11 keeps microphone settings in two places. Most day-to-day tasks start in the modern Settings app, but some advanced options, including Microphone Boost, still require the legacy Sound Control Panel. Knowing which panel handles which task saves time during any setup.
The modern path: Settings > System > Sound
This is the primary location for selecting a default input device, checking input volume, and running a quick mic test.
  1. Press Windows + I to open Settings. Or, click the Start button and select Settings.
  1. Select System from the left sidebar.
  1. Click Sound.
  1. Scroll to the Input section. All connected microphones appear here.
If you have a Hollyland LARK MAX 2 plugged in via USB-C, the receiver appears in this list as a labeled USB audio device. Before opening Settings, check the receiver’s LED: a solid LED confirms it is powered and paired with the transmitter, which is the clearest hardware-level signal that Windows should be able to detect the device.
The legacy path: Sound settings/Sound Control Panel > Recording tab
Some per-device settings are only accessible here.
  1. Right-click the speaker icon in the taskbar and select Sound settings. Scroll down and click More sound settings.
Alternatively, press Windows + R, type mmsys.cpl, and press Enter.
  1. Click the Recording tab.
  1. All input devices are listed here, including USB audio receivers like the LARK MAX 2.
Note: The modern Settings path and the legacy Recording tab display the same connected devices. Neither replaces the other entirely, and a complete microphone setup typically requires both.
How to Set Your Default Microphone in Windows 11?
When multiple inputs are connected simultaneously, such as a built-in laptop microphone alongside the LARK MAX 2 receiver, Windows 11 may not default to the intended device. Setting the correct default ensures every app uses the right input unless overridden individually at the app level.
Using Settings (recommended for most users):
  1. Open Settings > System > Sound.
  2. Under Input, click the dropdown labeled Choose a device for speaking or recording.
  3. Select Hollyland LARK MAX 2 (or your USB audio device name) from the list.
Using the legacy Sound Control Panel (required for some older applications):
  1. Open the Sound Control Panel using mmsys.cpl and go to the Recording tab.
  2. Right-click Hollyland LARK MAX 2 in the device list.
  3. Select Set as Default Device.
  4. Click Apply, then OK.
Important: Pressing the mute button on the LARK MAX 2 transmitter (the LED turns red when muted) cuts the audio signal at the hardware level. It does not change which device Windows has designated as the system default. The device remains set as the default input even while the transmitter is muted.
How to Adjust Microphone Volume and Input Levels in Windows 11?
Windows 11 controls microphone volume through two separate settings. One is the input volume slider inside Windows Settings. The other is Microphone Boost in the legacy Control Panel. Adjusting them in the proper order helps avoid distortion. It also reduces the chance of excessive audio processing.
Step 1: Set the hardware gain on the LARK MAX 2 transmitter first
The LARK MAX 2 has a dedicated gain control system.
Option 1: LARK MAX 2 Gain Control via HollyAudio (LarkSound) App
  1. Connect your Hollyland LARK MAX 2 with the HollyAudio app (LarkSound app).
  2. To apply auto gain, go to the "Dynamic Gain" settings and select High, Medium, or Low. Or, you can set custom gain for Mic 1 or Mic 2 by adjusting the "Set gain to" levels.
Option 2: LARK MAX 2 Gain Adjustment via Camera RX Connected to Windows 11
  1. Press the dial on the camera receiver to view options.
  1. Rotate the dial and tap on Mic Settings.
  1. Tap Mic Gain to adjust it.
Start at a mid-level gain setting before adjusting any Windows slider. Hardware gain sets the baseline signal quality at the source, before any software processing is applied.
Step 2: Adjust the Windows input volume slider
  2. Under Input, click your LARK MAX 2 device to expand its properties.
  3. Drag the Input Volume slider while speaking normally. Aim for the input level meter to peak at roughly 70 to 80 percent during typical speech.
Step 3: Use Microphone Boost only as a last resort
  1. Open the Sound Control Panel (mmsys.cpl) and go to the Recording tab.
  2. Double-click Hollyland LARK MAX 2 to open Device Properties.
  3. Click the Levels tab.
  4. If the input remains too quiet with the main slider at 100, increase Microphone Boost in small increments, typically +10 dB at a time.
How to Configure Microphone Privacy Settings in Windows 11?
If your microphone appears in Sound settings but produces no signal inside apps like Zoom, Teams, OBS, or your browser, a disabled privacy permission is the most likely cause. Windows 11 includes a master toggle and per-app toggles that block microphone access entirely at the operating system level.
Steps:
  1. Open Settings > Privacy & Security > Microphone.
  2. Toggle on the Microphone access option.
  3. Confirm that Let apps access your microphone is toggled On.
  4. Scroll down to review individual app permissions and enable access for each application you use.
Apps most commonly blocked:
  • Microsoft Teams
  • Zoom
  • Google Chrome and other browsers
  • OBS Studio
  • Discord
  • Slack
Note for LARK MAX 2 users: If the privacy toggle is disabled, Windows will display a flat zero-level bar in Sound settings even though the LARK MAX 2 receiver LED confirms the transmitter is paired and actively transmitting. This is the single most common cause of a “working mic, silent PC” situation. Enabling the master toggle resolves it immediately.
The privacy setting applies identically to all connected microphones. Turning it on for the LARK MAX 2 enables microphone access for every input device on the system.
How to Test Your Microphone in Windows 11?
Windows 11 includes a built-in input test that requires no third-party software. Running it after each configuration change confirms the signal path is working before you open a recording session or video call.
Steps:
  2. Scroll down to the Input section and click on your Microphone name (such as Hollyland LARK MAX or USB Microphone).
  3. Under the Input settings section, go to the Test your microphone option, and click the Start Test button.
  4. Click Start test.
  1. Speak normally for several seconds, then click Stop test.
In the legacy Recording tab (mmsys.cpl), you can watch the green level bar next to your device animate in real time while you speak. If the bar does not move, the signal is not reaching Windows.
Before starting the test, confirm:
  • The LARK MAX 2 transmitter is not muted (the mute LED should be off, not red or flashing)
  • You are speaking directly into the transmitter capsule
  • The receiver LED is solid, confirming the transmitter is paired and within operating range
No-signal quick checks:
  • Privacy toggle is off: go to Settings > Privacy & Security > Microphone and enable the master toggle
  • Wrong default device selected: confirm LARK MAX 2 is set as the active input in both Settings and Sound Control Panel
  • Transmitter is hardware-muted: check that the mute LED is off
  • Device is disabled in Sound Control Panel: right-click it in the Recording tab and select Enable
  • USB-C cable issue: try a different port or a cable confirmed to support data transfer
Advanced quality check:
Open Device Properties > Advanced for the LARK MAX 2 and confirm the Windows audio format is set to 48000 Hz, 24-bit or 48000 Hz, 32-bit. The LARK MAX 2 outputs at 48 kHz natively, and matching this format in Windows avoids sample rate conversion artifacts that can subtly degrade recorded audio.
Microphone Not Showing Up or Not Working in Windows 11 – Quick Checks
If you have followed the steps above and the microphone is still missing from the device list or producing no signal, work through this checklist before moving to driver-level troubleshooting.
  • Privacy toggle is off: Check Settings > Privacy & Security > Microphone and confirm the master toggle is enabled.
  • Device is disabled in the Sound Control Panel: Open the Recording tab, right-click your device, and check whether it shows as “Disabled.” Select Enable if needed.
  • Driver error in Device Manager: Press Windows + X, select Device Manager, and expand Audio inputs and outputs. A yellow warning triangle next to the LARK MAX 2 USB audio entry indicates a driver problem. Right-click and choose Update driver.
  • USB-C cable is charge-only: Not all USB-C cables carry data. If the LARK MAX 2 receiver does not appear in any device list after connecting, swap to a cable confirmed to support data transfer.
  • Transmitter and receiver are not paired: A flashing receiver LED on the LARK MAX 2 means the receiver is searching for the transmitter. A solid LED confirms an active pairing. Confirm the transmitter is powered on and within range.
  • Transmitter is hardware-muted: A muted transmitter produces a flat line in the Windows Sound test even with a perfect physical connection. Verify the mute LED is off before concluding there is a connection fault.
  • Wrong default input is selected: Confirm the correct device is active as the default in both Settings > System > Sound and the legacy Recording tab, since some applications reference only one of those settings.
Why can’t I find the microphone settings in Windows 11?
Windows 11 places most audio controls inside the Settings app. This layout differs from what many Windows 10 users know. The older Recording tab is still available when needed. Open mmsys.cpl from the Run dialog to access it. You can also open Sound settings and select More sound settings. Another option is searching for it through Settings directly.
How do I set a different microphone as default for one specific app only?
To use a microphone with only one app, change it inside that app’s audio settings. Many recording and meeting apps include their own input selection menu. This includes Microsoft Teams, Zoom, and OBS Studio. The selected microphone then overrides the Windows default for that app.
Why is my microphone volume too low, even with Windows input at 100%?
Open the Sound Control Panel and select the Recording tab. Open your microphone properties and check the Levels tab. Look for the Microphone Boost slider and increase it carefully. With the Hollyland LARK MAX 2, you can raise output gain directly. Use the receiver knob or the HollyAudio app (LarkSound app). Increasing gain at the source often gives cleaner audio.
Setting up a microphone in Windows 11 involves five main steps. Find the correct settings page. And choose the proper input device. Adjust hardware gain and software volume levels carefully. Enable microphone permissions and run the built-in audio test. Once you know where each setting is located, most problems can be fixed easily without reinstalling drivers or using extra software. For less dependence on Windows audio processing, the Hollyland LARK MAX 2 manages gain and noise control through hardware. This helps provide a cleaner and more consistent audio signal.
