Audio Input Not Working? Here’s How to Diagnose and Fix It
Your microphone has gone silent at the worst possible moment. Whether your Sound Settings stay flat or Zoom finds nothing, we've all been there before. Maybe your computer cannot even spot the USB mic anymore. Relax! Because these fixes usually solve the problem fast. We will check simple settings first, then move toward hardware tests together. Start with the checklist below before diving into platform-specific steps.
Start Here: Quick Checks Before You Troubleshoot
Before spending time in Device Manager or Terminal, run through these five checks. A large share of audio input failures are resolved right here.
  1. Is the microphone physically connected?For USB mics, confirm the cable is seated firmly. For 3.5mm mics, make sure the plug is fully inserted. A half-seated jack often registers no signal at all.
  2. Is it set as the default input device?Your OS may have switched to a built-in mic or another connected device. Open your sound settings and confirm the correct input is selected.
  3. Is the input volume above zero?Both Windows and macOS have a dedicated input level slider that can be dragged to zero by accident. Set it to at least 50 percent.
  4. Does the app have microphone permission?If the app was never granted access in your OS privacy settings, it receives no signal regardless of how your audio is configured.
  5. Is the correct input device selected inside the app itself?Apps like Zoom, Discord, and OBS maintain their own input selectors that override the OS default for that specific application. This is the most commonly missed check.
If something looks wrong here, skip straight to that matching section. If everything seems fine, keep going with the platform-specific fixes instead.
Fix Audio Input Not Working on Windows
Most Windows mic problems usually come down to four common things. Maybe the wrong device is selected, or permissions have been blocked. An old driver or Windows update could also mess things up. Try these fixes one by one until something finally clicks.
Set the Correct Default Input Device
Windows 11:
1. Open Settings and go to System > Sound.
2. Scroll to the Input section and open the dropdown under “Choose a device for speaking or recording.”
3. Select your microphone from the list.
4. Speak into the mic and watch the Input volume bar. If it responds, the device is active and recognized.
Windows 10:
1. Right-click the speaker icon in the taskbar and select Open Sound settings.
2. Under Input, use the “Choose your input device” dropdown to select your microphone.
3. Click Device properties and confirm the Volume slider is not at zero.
Note: If your mic does not appear in either list, skip ahead to the driver fix or the hardware checks section below.
Check Microphone Privacy Settings
Windows blocks app-level microphone access by default after a fresh install or a major update. This is one of the most frequent causes of a mic that works in Sound Settings but fails inside Zoom, Discord, or Chrome.
  1. Open Settings > Privacy and Security > Microphone on Windows 11.
Or Settings > Privacy > Microphone on Windows 10.
  1. Toggle “Let apps access your microphone” to On.
  1. Scroll down and confirm that the specific app you are using is also toggled to On.
  2. Close and relaunch the app, then test your microphone.
Pro Tip: This page displays every installed app in one place. It lists desktop programs and Store apps together. The list follows alphabetical order from beginning to end.
Update or Reinstall the Audio Driver
A corrupted or outdated audio driver is the most common cause of a microphone disappearing after a Windows Update.
  1. Press Windows + X and select Device Manager.
  1. Expand the Sound, video and game controllers section.
  1. Right-click your audio device and choose Update driver > Search automatically for drivers.
  2. If no update is found, right-click the device again and choose Uninstall device. Check “Delete the driver software for this device” if that option appears.
  3. Restart your computer. Windows reinstalls the audio driver automatically on reboot.
  4. If the problem persists, visit your motherboard or laptop manufacturer’s website and download the audio driver directly from there, rather than relying on Windows Update to supply the correct version.
Note: Some USB microphones appear under Universal Serial Bus controllers in Device Manager. Others appear under Sound, video and game controllers. Check both sections to find your microphone.
Run the Windows Audio Troubleshooter
The built-in troubleshooter catches roughly 30 to 40 percent of recording failures and is worth running before a full driver reinstall.
  1. Open Settings > System > Troubleshoot > Other troubleshooters.
  2. Find Recording Audio and click Run.
  3. Follow the on-screen prompts and apply any fixes it recommends.
The troubleshooter checks default device configuration, driver state, and basic hardware recognition. It will not resolve permission blocks or app-level issues, so if it reports no problems, continue through the remaining steps in this section.
Fix Audio Input Not Working on Mac
Most macOS audio input problems come from three common causes. The wrong input device may be selected. An app might not have microphone permission. The Core Audio process may have stopped responding. Check each one in this order.
Check Input Settings in Sound Preferences
macOS Ventura and Sonoma:
1. Open System Settings and click Sound in the sidebar.
2. Select the Input tab.
3. Confirm your microphone appears in the list and is selected.
4. Verify the Input volume slider is not at zero.
5. Speak into the mic and watch the input level meter for any movement.
macOS Monterey and earlier:
1. Open System Preferences > Sound and click the Input tab.
2. Select your microphone and confirm the input volume slider is above zero.
If the device appears in the list but the meter shows no movement, move on to the hardware checks. If it does not appear at all, unplug and reconnect it, then return to this screen.
Grant Microphone Permission to the App
macOS requires explicit per-app microphone authorization. An app without permission will display a completely flat input meter even when the microphone is fully functional.
  1. Open System Settings > Privacy and Security > Microphone on Ventura.
Or Sonoma, or System Preferences > Security and Privacy > Privacy > Microphone on older macOS versions.
  1. Verify that the app you are using has its toggle set to On.
  2. If the app does not appear in the list, open it and attempt to record or start a call. macOS will present a permission prompt at that point.
  3. After granting access, quit and relaunch the app.
Note: Some applications require a full system restart rather than a simple relaunch before a new microphone permission takes effect.
Reset Core Audio
If your microphone vanishes from the Sound Input list after waking from sleep or following a software crash, macOS’s Core Audio engine may have entered a locked or frozen state. Restarting it takes under ten seconds and does not require a full reboot.
  1. Open Terminal (Applications > Utilities > Terminal)
  1. Enter the following command: sudo killall coreaudiod
Enter your administrator password when prompted. Core Audio restarts automatically within a few seconds, and missing input devices typically reappear. Confirm by opening System Settings > Sound > Input and checking the device list.
Fix Audio Input Not Working in Apps and Browsers
Every major communication and recording application maintains its own internal audio input selector that operates independently of the OS default. If that selector points to the wrong device, or if the app was never granted permission, the mic will appear silent in that app even while functioning correctly in system settings.
Zoom, Microsoft Teams, and Google Meet
  • Zoom: Click your profile picture, then go to Settings > Audio. Under “Microphone,” select your input device from the dropdown and click Test Mic to confirm signal.
  • Teams: Click the three-dot menu, then go to Settings > Devices. Under “Microphone,” select the correct device.
  • Google Meet: During a call, click the three-dot menu, then Settings > Audio, and choose your microphone from the list.
All three apps can silently default to a different device after a system update or after a new audio peripheral is connected, even if your OS input is correct.
Discord
  1. Open User Settings using the gear icon at the bottom left of the window.
  1. Navigate to Voice & Video.
  1. Under the Voice section, select your Microphone from the dropdown menu.
  1. To use Push-to-Talk in Discord, first assign a key in the Voice & Video settings. If you switch from Voice Activity, your microphone will not send audio until a keybind is set.
Chrome and Other Browsers
  1. Click the View site information button (settings icon) in the address bar on the page where you need microphone access.
  1. Select  Settings.
  1. Find Microphone and switch the setting from “Block” or “Ask” to “Allow.”
  1. Reload the page. The permission change does not apply until the page is refreshed.
If Chrome’s site permission is already set to Allow but the mic still shows no signal, confirm that Chrome itself has microphone access in your OS privacy settings, as covered in the Windows and Mac sections above.
OBS and DAWs
When OBS starts, it selects your system's default input if Default is chosen. If you change the default microphone later, OBS will not switch automatically. Choose your microphone in Settings > Audio to keep it selected. You can also add an Audio Input Capture source and pick your mic from the device list. In a DAW, open the audio settings and manually select your microphone or audio interface.
Check the Physical Connection and Hardware
If every software fix has produced no result, the issue is likely in the physical connection or the microphone itself.
  • Wrong port on a desktop PC: The pink port is for microphones. Whereas the green port is for headphones. A 3.5 mm microphone will not record if you plug it into the green port. That port cannot provide the power a standard microphone needs. As a result, your computer will not detect any audio input.
  • USB microphone not detected: Try a different USB port directly on the computer rather than through a hub. USB hubs can supply insufficient power, causing the microphone to go unrecognized or drop intermittently.
  • Test on another device: Connect the same microphone to a phone, tablet, or a second computer. If it works there, the hardware is intact, and the issue exists on the original machine. If it fails on every device, the microphone is physically defective.
  • Inspect the cable and connectors: Check if the 3.5 mm plug is bent or damaged. Look for cable wear near the connector. Also inspect the USB plug for damaged contact pins.
  • Laptop combo jacks: Most current laptops combine the headphone and microphone functions into a single TRRS jack. A standard stereo (TRS) headphone plug will not pass a microphone signal through that port. You need either a TRRS headset or a USB audio adapter.
If your hardware tests confirm the microphone is physically defective, or if you repeatedly deal with a fragile built-in mic, a plug-and-play wireless alternative is a practical solution. The Hollyland LARK A1 connects via USB-C or Lightning and is recognized as an audio input device without any driver installation, bypassing most of the driver and port compatibility issues covered in this guide. For creators who need a compact wireless setup for video work, the Hollyland LARK M2 offers a lightweight clip-on design built for on-camera recording.
Solve Audio Input Problems on iPhone or Android
Mobile audio input failures are most often caused by a blocked app permission or an obstructed microphone port.
iPhone:
1. Open Settings > Privacy and Security > Microphone.
2. Toggle the app in question to On.
3. If the app is not in the list, open it and attempt to use the mic. iOS will prompt for permission at that point.
4. Confirm that a case or debris is not covering the microphone opening at the bottom edge of the device.
Android:
1. Open Settings > Apps > [App name] > Permissions.
2. Tap Microphone and select Allow.
3. Restart the app and test.
On both platforms, check whether a connected wired headset or Bluetooth device has taken priority as the active input source. When a secondary audio device is connected, the built-in microphone can appear inactive even when it is fully functional.
Why is my audio input not working after a Windows update?
Windows updates can reset the default input device or install a generic driver that conflicts with your existing audio hardware. Open Device Manager and look for a yellow warning icon on your audio device. If available, use the “Roll Back Driver” option to revert the change, or uninstall and reinstall the driver manually. Also, re-check your microphone privacy settings, since major updates sometimes reset those toggles without notice.
My mic works in Settings but not in the app. Why?
The app maintains its own audio input selector that may be pointing to a different device than your OS default. It may also carry its own separate permission block. Open the app’s audio settings, select the correct input device from the dropdown, and confirm that the app has microphone access in your OS privacy settings.
How do I know if my microphone is broken or if it is a software issue?
Plug the microphone into a different device, such as a phone, tablet, or a second computer. If it picks up audio on that device, the hardware is functional, and the problem is specific to your original machine. If the microphone fails to produce any signal on multiple devices, it is physically defective.
Why does my audio input show up but have no signal?
Start by checking your system's microphone input level. Make sure the volume is above zero. Connect XLR mics through a compatible audio interface. Condenser microphones need 48V phantom power turned on. Without it, they may appear connected but record nothing. Dynamic microphones normally should not receive phantom power.
Can I use a wireless microphone to bypass audio input problems entirely?
Yes. Receivers such as the Hollyland LARK A1 connect via USB-C or Lightning and appear as a recognized audio input device without any driver installation required. This bypasses driver conflicts, port compatibility issues, and built-in mic hardware failures, making it a clean solution when software troubleshooting has not resolved the problem.
You usually do not need new hardware to fix microphone issues. Most problems come from software settings, permissions, or loose connections. Begin by checking your operating system settings first. Next, review microphone permissions, then drivers, and inspect the hardware last.
