Microphone Not Picking Up Voice? Here’s How to Fix It
Your microphone is connected, your recording app is open, and yet nothing is coming through. Before you assume the hardware is broken, know that most cases of a microphone not picking up voice trace back to a setting, a permission, or a pairing state rather than a dead device. This guide walks you through every likely cause in the order you should check them, from physical connections all the way to wireless transmitter configuration.
Why Your Microphone Isn’t Picking Up Your Voice?
The problem usually comes from one of four main areas. Finding the exact area responsible helps reduce troubleshooting time a lot.
  • Physical and hardware issues: Mute buttons, loose connectors, or a damaged capsule
  • OS-level input settings: Wrong default device, zeroed input volume, or blocked privacy permissions
  • App-level audio configuration: The application has selected a different input than the OS default
  • Wireless device configuration: Pairing failure, transmitter mute state, or gain set too low on the TX unit
The sections below work through these layers in that order.
Start Here — Quick Checks Before You Dig Deeper
Run through these five checks first. A large number of “mic not working” reports are resolved at this stage.
  1. Confirm no physical mute is active: Check your microphone body, headset inline control, or audio interface for a mute button. A lit LED often signals the mute-on state.
  2. Verify the microphone is selected as the active input device: Open your OS sound settings and confirm your mic, not a built-in device or a previous input, is the chosen source.
  3. Confirm the input level is not set to zero: A mic can be selected, but it produces nothing if the input volume slider is at its lowest position.
  4. Reseat every cable connection. Pull each connector fully out, wait two seconds, and push it back until it clicks or seats firmly. This includes USB, 3.5mm, and XLR connections.
  5. Restart the application and, if needed, the computer: Driver state and app audio sessions can freeze without a visible error message.
  6. Test in a second application: Open the voice recorder built into your OS and speak. If that app picks up audio, the fault is in the first app’s settings, not the hardware.
Fix Microphone Input Settings on Windows
If the quick checks did not resolve the issue, the next layer to inspect is Windows itself. Follow each step in order.
Select the Correct Input Device in Sound Settings
  1. Open Settings and navigate to System → Sound.
  2. Scroll to the Input section and open the dropdown labeled Choose your input device (Windows 10)
Or choose a device for speaking or recording (Windows 11).
  1. Select your microphone from the list. If it does not appear, confirm the device is plugged in, then click Manage sound devices to check whether it has been disabled.
  1. Click the device name to expand its properties and confirm the channel is not set to Disabled.
Raise the Input Volume and Test the Signal
  1. Still inside Settings → System → Sound → Input, click your microphone to open its property panel.
  2. Move the Input volume slider to at least 80 percent.
  3. Use the Start Test button beneath the slider. Speak normally and watch for the green bar to move. If it responds, the OS layer is functioning correctly, and the problem is inside a specific application.
  1. If the bar does not move despite a raised volume, continue to the privacy step below.
Enable Microphone Access in Privacy and Security Settings
Windows can block all microphone access at the system level, which prevents every application from receiving a signal, even when the device appears selected.
  1. Open Settings → Privacy and Security → Microphone.
  2. Confirm the toggle labeled Microphone access is turned On.
  3. Scroll down to the Let apps access your microphone toggle and turn it On.
  1. Find the specific application in the per-app list below and confirm its individual toggle is also enabled.
  2. Return to the Sound settings test bar to confirm the signal is now registering.
Fix Microphone Input Settings on Mac
macOS Ventura and Sonoma use a unified System Settings layout. The steps below reflect the current interface.
Check Sound Input and Input Volume
  1. Open System Settings and click Sound.
  1. Select the Input tab.
  1. Click your microphone in the device list to select it as the active input.
  2. Move the Input volume slider to the right. A position below 50 percent can cause the signal to fall below the threshold that apps use to detect speech.
  3. Speak and watch the Input level meter. If the meter responds, the OS is receiving audio.
Allow Microphone Access in Privacy and Security
  1. Open System Settings → Privacy and Security → Microphone.
  1. Find the application that is not receiving audio and flip its toggle to On.
  1. If the application is already toggled on, try toggling it off, closing the app, then toggling it back on and relaunching.
  2. macOS may prompt you to restart the application for the permission change to take effect.
Use Audio MIDI Setup for Persistent Issues
If the microphone appears in Sound settings but the input is consistently flat or distorted, a sample rate mismatch may be the cause.
  1. Open Finder → Applications → Utilities → Audio MIDI Setup.
  2. Select your microphone in the left panel.
  3. Check the Format setting. A mismatch between the device’s native sample rate and the rate macOS has assigned (for example, 48000 Hz versus 44100 Hz) can prevent clean signal capture.
  4. Set the format to match the specification in your microphone’s documentation, then test again.
Check In-App Microphone Settings
Many applications maintain a private audio device selector that overrides whatever the OS has set as the default. If your OS test bar shows a live signal but the app still records silence, this is almost certainly the cause.
  • Zoom: Open Settings → Audio. Under Microphone, open the dropdown and select your device by name rather than leaving it on “Same as System.”
  • Microsoft Teams: Go to Settings → Devices. Under Audio devices, set the Microphone field to your specific input device.
  • OBS Studio: Open Settings → Audio and check the Mic/Auxiliary Audio device selectors. Also, confirm that the audio source inside your active scene is not muted by checking the mixer panel at the bottom of the main window.
If switching from “System Default” to the named device restores audio in one app, apply the same fix in any other application where the mic stops working.
Wireless Microphone Not Picking Up Voice — Diagnosing the Hollyland LARK MAX 2
Wireless lavalier microphones can fail in a few physical and signal stages. Modern systems also include tools like 32-bit float backup recording and app-based gain control. These help reduce or prevent many common issues before they affect sound quality. The troubleshooting steps here work for any transmitter and receiver setup. But for your ease, we have used the Hollyland LARK MAX 2 as the main example. Its buttons, screen, and LED indicators clearly match what is happening inside the device at each step..
Confirm TX-RX Pairing Status via LED Indicators
The first thing to establish is whether the transmitter (TX) and receiver (RX) are actually communicating.
  1. Power on both the TX body and the RX unit.
  2. Check the LED indicator on each unit. A solid blue LED on both TX and RX indicates a stable, paired connection actively transmitting. A blinking blue LED indicates the unit is in search mode and the pairing has dropped.
  1. If either unit shows a blinking LED, first turn off both units. Then hold the power button on the TX transmitter for 6 seconds and bring the TX within 30 cm of the RX until both LEDs stabilize to a solid state.
  2. Once both LEDs are solid, speak into the TX capsule and check the audio output before proceeding to other steps.
Check Whether the Transmitter Is Muted
A hardware mute on the TX body is one of the most frequently overlooked causes of silence, because the device appears powered on and paired.
  1. Press the power button twice on the LARK MAX 2 TX unit to mute.
  2. A red LED will turn on, indicating the mute function is active.
  1. Double-press the power button again to unmute. The LED should shift back to the active (non-red) state.
  2. Speak into the capsule and check whether the signal is now registering at the output.
Adjust Input Gain in the Hollyland App
If the TX is paired and unmuted but the signal is still weak or absent, the gain may have been reduced to a very low level through the companion app.
  1. Open the HollyAudio app (LarkSound app) on your connected smartphone or tablet.
  2. Navigate to the LARK MAX 2 device control screen.
  3. Locate the gain slider for the TX channel and raise it incrementally from its current position. Start with a midpoint setting and speak at normal conversation volume.
  1. If AI Noise Cancellation is enabled, toggle it off temporarily from the app.
Conversely, you can press the TX power button once to activate or deactivate noise cancellation. If it's activated, the LED will turn solid green. When disabled, the LED will change to solidblue.
In some environments, aggressive noise cancellation can suppress speech that the algorithm misclassifies as background noise. If disabling it restores the signal, reduce the intensity rather than leaving it fully off.
Monitor Live Audio Through OWS Earphones to Isolate the Fault
  1. Connect the OWS earphones wirelessly with the RX unit.
  1. Speak directly into the TX transmitter capsule at normal volume.
  2. If you hear your voice clearly in the earphones, the wireless link is working correctly. The fault is downstream, meaning either the cable running from the RX output to your camera or phone is faulty, or the receiving device’s audio input settings need adjustment.
  3. If the earphones produce silence, the fault is at the TX stage or in the pairing. Return to the mute check and gain steps above, then re-examine the LED pairing status.
Check Battery Level and Operating Range
A low battery on either unit can cause intermittent signal drop or a complete loss of transmission before the device fully powers off.
  1. Check the battery LED on both the TX and RX. The LARK MAX 2 uses a multi-stage indicator; a single slow-blinking LED typically signals a low charge state. Charge both units via USB-C before continuing any diagnosis.
  2. Confirm you are operating within the LARK MAX 2’s wireless transmission range and that there are no large metal objects, walls, or active wireless devices positioned directly between the TX and RX.
  3. For vloggers using the Hollyland LARK M2 (the 9 g clip-on variant), the same LED-based diagnostic flow applies: check pairing LED, check mute state, and charge before assuming a hardware fault.
Update or Reinstall Your Audio Driver (Windows)
If your Windows computer recognizes the microphone but the input bar never moves, or the device disappears from the input list after a reboot, a corrupted or outdated audio driver may be the cause.
  1. Right-click the Start button and select Device Manager.
  2. Expand the Audio inputs and outputs section and locate your microphone.
  3. Right-click the device and select Uninstall device. Check the box to delete the driver software if the option appears.
  4. After uninstalling, click Action → Scan for hardware changes. Windows will attempt to reinstall a basic driver automatically.
  5. If the basic driver does not restore function, visit the microphone manufacturer’s website (or your audio interface manufacturer’s site for USB interfaces) and download the latest driver package for your Windows version.
Q: My microphone shows up in settings, but the input level bar doesn’t move. What does that mean?
Common causes include privacy permissions being turned off in the system settings. A physical mute switch on the microphone may also be active. The input level or gain might also be set too low or zero. Outdated audio drivers can also stop the microphone from working properly. First, check privacy and sound settings to confirm recording permission is enabled. Also, make sure the correct input device is selected. If everything looks fine, test the mic on another device to check. If the sound is still not coming, the microphone could be damaged.
Q: Why does my microphone work in one app but not another?
Each application maintains its own audio device selector that can override the OS default. Open the audio or sound settings inside the non-working application and manually choose your microphone by name. It has likely defaulted to “System Default” or a different device after a system update or a new device was connected.
Q: My wireless microphone is paired and powered on, but the camera shows no audio. Where is the fault?
Connect the OWS earphones to the RX monitoring output and speak into the TX. If you hear your voice in the earphones, the wireless link is working, and the fault is in the cable between the RX and the camera, or in the camera’s audio input settings. If you hear nothing, re-examine the TX mute state and gain level as described in the LARK MAX 2 section above.
Q: Can a dirty or damaged 3.5mm port cause a microphone to stop picking up voice?
Yes. Lint or debris in the port creates an intermittent or broken connection. Use a dry brush or a short burst of compressed air to clean the port, then reseat the cable fully. If the problem persists, test with a different cable to determine whether the fault is in the cable or the port itself.
Q: Does Windows 11 have any new settings that can block a microphone?
Yes. Windows 11 added a granular per-app microphone toggle under Settings → Privacy and Security → Microphone. Both the master toggle and the individual application toggle must be enabled. Traditional desktop apps do not show up in the per-app microphone list. Their access is controlled by a single global setting. This setting is labeled “Let desktop apps access your microphone.” Microsoft Store apps appear separately with individual permission switches.
Start with physical checks like connection and mute status first. Next, review operating system input settings. Then adjust the audio input inside each app separately. If using a wireless system, check transmitter and receiver settings last. If the microphone still produces no signal after all of these steps, test it on a second computer or phone. A confirmed failure on multiple devices points to a hardware fault rather than a settings problem, and replacement becomes the practical next step.
If you find yourself repeatedly dealing with dropped connections or silent recordings from a wired or unreliable built-in mic, the Hollyland LARK MAX 2 offers a wireless lavalier solution with onboard 32-bit float backup recording, so a gain error or connection drop never results in a lost take.
