After Effects does not have an “Unlink Audio/Video” button like Premiere Pro, so users often get stuck searching for something that does not exist. The good news is that the same result is achievable in just a few steps — you just need to know where to look. This guide covers two practical methods: isolating audio and video onto separate timeline layers, and exporting audio as a standalone file through the Render Queue.
How to Separate Audio in After Effects (2 Methods That Actually Work)
Why After Effects Handles Audio Differently
In Premiere Pro, audio and video exist on separate tracks and can be unlinked with a single right-click. After Effects works differently. Audio and video are both properties of the same layer, so there is no built-in separation button to find. This surprises a lot of users who come from a Premiere workflow.
That said, you can still accomplish what you need. The two most common goals are (1) editing audio and video independently within the timeline, and (2) exporting a standalone audio file for use elsewhere. The methods below address each scenario directly.
Method 1 — Isolate Audio and Video on Separate Layers
This is the go-to approach when you need to trim, slip, keyframe, or otherwise manipulate audio and video independently inside the same composition. The technique uses a duplicate layer — one carrying only video, the other carrying only audio. Both still reference the original source file, so no re-encoding happens and sync is preserved.
Step-by-Step Walkthrough
Import your footage and drag it into your composition from the Project panel.
Select the layer in the Timeline panel by clicking on it.
Press Ctrl+D (Windows) or Cmd+D (Mac) to duplicate the layer. You now have two identical layers stacked on top of each other.
On the original layer: click the speaker icon in the layer switches column to disable its audio. This layer now carries video only.
On the duplicate layer: click the eye icon in the layer switches column to disable its video. This layer now carries audio only.
Select the audio-only layer and press L twice in quick succession to expand the Audio Waveform property. This gives you a visual reference for precise edits and keyframe placement.
Both layers will play in perfect sync because they share the same source. You can now reposition, trim, or keyframe either layer without affecting the other.
Method 2 — Export Audio Only from After Effects
If your goal is to extract a standalone audio file — to hand off to a DAW, share with a client, or use in another project — the Render Queue is how you do it. The audio-only format option is tucked inside the Output Module settings and is easy to miss the first time.
Render Queue Walkthrough
With your composition open, go to Composition > Add to Render Queue, or press Ctrl+M (Windows) / Cmd+M (Mac).
In the Render Queue panel, click the blue Output Module text link to open its settings dialog.
In the Output Module Settings window, open the Format dropdown. Select Audio Only from the list. Choose WAV for lossless quality or MP3 if you need a smaller file size.
Confirm that the Audio Output section at the bottom of the dialog is checked. There is no video output to worry about in this format mode.
Click OK, then click the output file path text to set your save destination.
Click Render to export the audio file.
The exported file will reflect whatever audio is present in your composition for the full duration of the work area.
Managing Audio Layers After Separation
Once you have an isolated audio layer, a few tools make working with it significantly easier:
Keyframe Audio Levels: Expand the layer’s Audio property group in the Timeline and keyframe the Audio Levels value to create volume fades, dips, or swells over time.
Preview audio only: Press the period key (.) on your numpad to trigger an audio-only preview. This is faster than a full RAM preview when you only need to check the sound.
Use the Solo switch: Click the Solo switch (the small circle icon) on the audio layer to mute all other layers and focus playback on that track alone.
Slip the audio layer in time: Hold Alt (Windows) or Option (Mac) and drag the layer in the timeline to slip its in/out points without moving the layer’s position. This is useful for fine-tuning sync after the layers have been separated.
When to Send Audio to Adobe Audition Instead
After Effects handles basic audio adjustments well, but it is not built for heavy audio work. If you need noise reduction, multi-track mixing, audio restoration, or spectral editing, you should move the file to Adobe Audition.
If you are on a Creative Cloud plan, go to Edit > Edit in Adobe Audition with the audio layer selected. The file opens in Audition, and when you save it there, the updated version is reflected back in your After Effects composition automatically. Use this as an exit ramp for tasks that go beyond simple level adjustments.
Q1: Why isn’t there a “Separate Audio” button in After Effects?
After Effects uses a layer-based system where audio and video are both properties of the same layer, rather than Premiere Pro’s track-based approach. Because of this architecture, there is no single unlink button. The duplicate-and-disable method covered in Method 1 gives you the same practical result.
Q2: How do I view the audio waveform in After Effects?
Select your layer in the Timeline panel and press the L key twice in quick succession. This expands the Audio Waveform property directly in the timeline, giving you a visual representation of the audio for precise editing and keyframe placement.
Q3: Will the duplicate method affect sync or quality?
No. Both the original and duplicate layers point to the same source file in the Project panel. No re-encoding takes place, and sync remains intact. It will only fall out of sync if you intentionally drag one layer to a different point in the timeline.
Q4: What audio format should I use when exporting from the Render Queue?
Choose WAV when delivering to another editor, a DAW, or any professional workflow that needs lossless audio. Choose MP3 only when file size matters for sharing or delivery, and some quality loss is acceptable.
Next Steps
Use the duplicate-and-disable method when you need audio and video to behave independently inside your composition. Use the Render Queue audio export when your deliverable is a standalone audio file. From here, good follow-up topics include keyframing audio levels in After Effects, syncing audio to video in the timeline, and using Adobe Audition for noise removal via the Edit Original roundtrip.
