How to Separate Audio and Video in iMovie (Mac, iPhone & iPad)
Separating audio from video in iMovie is one of the most useful edits you can make. Whether you need to cut out background noise, swap in a voiceover, or keep the visuals while replacing the sound entirely, iMovie makes it possible on both Mac and iOS. So here you'll learn the steps for each supported iMovie device. It also shows what you can do after separating the audio. Common questions and simple answers are included at the end.
What It Means to “Detach” Audio in iMovie
When you detach audio in iMovie, the app unlocks the sound from its source video clip and places it as a separate green audio track on the timeline. This step does not remove any part of your project. The video and audio stay in place but become separate clips. You can then move, trim, or delete either one without changing the other.
How to Separate Audio and Video in iMovie on Mac
These steps apply to iMovie on macOS (Ventura, Sonoma, and recent versions).
  1. Open your project and locate the clip. In the iMovie timeline at the bottom of the screen, find the video clip whose audio you want to separate.
  2. Select the clip. Click it once so it has a yellow highlight border around it.
  1. Right-click (or Control-click) the clip. A context menu will appear.
  2. Choose “Detach Audio” from the menu. This option appears near the middle of the list.
  1. Confirm the result. A green audio clip will appear directly below the original video clip in the timeline. The two tracks are now independent.
You can now click the video clip or the green audio clip separately to work on each one.
Moving or Editing the Detached Audio Track on Mac
Once the audio is detached, you have several options:
  • Reposition it: Click and drag the green audio clip to a new position in the timeline.
  • Trim it: Drag the left or right edge of the green clip to shorten it.
  • Adjust volume: Select the audio clip and use the volume slider in the inspector panel above the timeline.
  • Delete only the audio: Click the green audio clip to select it, then press the Delete key. The video clip stays intact.
  • Replace it: Delete the green audio clip, then drag a new audio file (music, voiceover, or sound effect) into the timeline and align it with your video.
How to Separate Audio and Video in iMovie on iPhone or iPad
The iOS version of iMovie handles detaching audio through a slightly different workflow, but the result is the same.
Note: The steps below are demonstrated on an iPhone. iPad users can also follow these steps.
  1. Open your project in iMovie. Tap the project to enter the editing view.
  2. Tap the video clip in the timeline. A yellow selection border will appear around it.
  1. Tap the Actions button (scissor icon) at the bottom of the screen.
  2. Tap “Detach.” The audio separates from the video and appears as a distinct bar directly below the clip in the timeline.
  1. Confirm the detachment. The audio bar will be a different color from the video, indicating they are now independent tracks.
Editing or Deleting the Detached Audio on iOS
After detaching, tap the audio bar to select it and access these options:
  • Delete the audio: Tap the detached audio bar, make sure you have selected the Actions button, and then tap the delete button.
  • Mute it: Tap the audio bar and drag the volume slider all the way down.
  • Adjust volume levels: Use the volume slider in the inspector panel to fine-tune levels.
  • Replace with music: Delete the audio bar, then add a track from your Audio library or the built-in iMovie soundtracks using the “+” button. Once you click the “+” button, tap Audio, pick from Soundtracks, My Music, and Sound Effects options, and choose your file.
Common Reasons to Separate Audio and Video in iMovie
  • Remove unwanted background noise recorded on location, such as wind or ambient crowd sound.
  • Replace the original audio with a voiceover narrating the video after the fact.
  • Sync audio from an external recorder by removing the camera’s built-in audio and aligning a separate, higher-quality recording.
  • Reuse footage with different narration for multiple versions of the same video.
  • Add background music cleanly without the original ambient sound competing with it.
Pro Tip: Capture Cleaner Audio Before You Edit
The quickest way to reduce time spent detaching and replacing audio is to record better sound from the start. A compact wireless microphone like the Hollyland LARK M2 clips to clothing and connects directly to your phone or camera, delivering clear voice audio without heavy gear. Because iMovie is built for casual and prosumer creators, pairing it with a lightweight mic like the LARK M2 can eliminate most audio cleanup work before your footage ever hits the timeline.
Why is “Detach Audio” grayed out in iMovie?
The most common reason is that no clip is actively selected in the timeline. Click or tap the video clip directly until the yellow border appears, then try right-clicking again. The option also stays grayed out if the selected clip is a still image or an audio-only file, since detaching only applies to video clips that contain embedded audio.
Can I re-attach audio to video in iMovie after detaching?
iMovie does not include an option to attach separated audio again. If you detach it by accident, press Command + Z on Mac. On iPhone or iPad, tap Undo right away. If undo is no longer available, move the green audio clip back under the original video manually.
How do I delete just the audio from a video clip in iMovie?
First, detach the audio using the steps above. Once the green audio clip appears separately in the timeline, click or tap it to select it, then press Delete (Mac) or Delete (iOS). This removes the audio track only; the video clip remains in your timeline completely untouched.
Does detaching audio in iMovie reduce video quality?
No. Detaching audio is a non-destructive edit. iMovie does not re-encode or alter the original source file at any point during editing. The separation only affects how the tracks are handled within your project. Your original video file on disk stays exactly as it was when you imported it.
Editing becomes much easier after separating the audio from your video. You can mute unwanted sounds, add music, record voiceovers, or replace poor audio. iMovie makes this possible on Mac, iPhone, and iPad. After trying it once, the whole editing process feels much more flexible.
