A clean audio fade-out can mean the difference between an edit that feels polished and one that cuts off abruptly. Whether you are wrapping a music bed, ending a scene, or smoothing a transition between clips, DaVinci Resolve gives you multiple ways to pull it off. This guide walks through three reliable methods so you can pick the one that fits your workflow and timeline.
Why Audio Fades Matter in Video Editing
An audio fade-out gradually reduces a clip’s volume to silence, preventing jarring cuts and giving your edit a professional finish. Editors use them at the end of scenes, under dialogue, and at transition points between music tracks. Starting with clean source audio, such as a recording captured on a low-noise wireless mic like the Hollyland LARK MAX 2, means your fades will sound smooth rather than fading out unwanted hiss or noise alongside the signal.
Method 1 — Use Fade Handles (Fastest Method)
Fade handles are built directly into the Edit page timeline and require no menus or panels. This is the go-to method when you need a quick fade at the end of a clip.
Open your project on the Edit page. Locate the audio clip you want to fade out in the timeline.
Hover your cursor over the top-right corner of the audio clip. A small white triangle will appear. This is the fade handle.
Click and drag the handle to the left. The further left you drag, the longer your fade-out duration. A shaded region will appear over the clip showing the fade range.
Release the mouse and press Play to preview. The volume will ramp smoothly down to silence over the length of the shaded region.
For linked A/V clips, the fade applies only to the audio portion. If you want video and audio fades together, apply separate handles to each, or unlink the clip first by right-clicking and selecting “Link Clips” to toggle it off.
Note: If your clip is very short, the fade handle may overlap the start of the clip. Trim your clip longer or shorten the fade duration to avoid this.
Adjusting Fade Curve Shape
Right-clicking the fade handle opens a small curve menu with the following options:
Linear — volume drops at a constant rate; can sound abrupt on longer fades
Ease In — fade starts gradually and drops faster at the end; works well for natural music endings
Ease Out — drops quickly at first, then tapers slowly; useful for dramatic effect
Method 2 — Use Volume Keyframes (Most Precise Method)
Volume keyframes give you exact control over when the fade begins, how long it lasts, and the shape of the volume ramp. This method is ideal for scoring music under dialogue or any situation where you need multi-point volume automation.
Select your audio clip in the timeline. Make sure you are on the Edit page.
Enable the Clip volume overlay. Right-click the clip and choose “Show Curve Editor,” or look for the thin white line running horizontally through the clip — this is the volume line.
Add a keyframe at the point where you want the fade to begin. Hold Option (Mac) or Alt (Windows) and click directly on the volume line. A small diamond marker will appear.
Add a second keyframe at the very end of the clip using the same method.
Click and drag the second (end) keyframe downward until the dB value reaches the minimum or displays as negative infinity. The volume line will now slope downward between the two keyframes.
Adjust the handles on each keyframe by clicking and dragging to create a curved ramp instead of a straight linear drop, giving the fade a more natural, musical feel.
Preview the clip and fine-tune keyframe positions until the timing feels right.
Pro Tip: If you need to fade out across multiple clips on the same track, volume keyframes in the timeline let you draw a single continuous ramp across clip boundaries without needing to treat each clip separately.
Method 3 — Apply a Fade Out Transition (Quickest for Cut Points)
DaVinci Resolve includes a dedicated Fade Out audio transition in its Effects Library. This method works best when you need a clean fade right at the end of a clip where it meets a cut or the end of the timeline.
Open the Effects Library from the top-left panel in the Edit page.
Navigate to Audio Transitions. you will find Cross Fade options such as Cross Fade +3 dB, Cross Fade -3 dB, and Cross Fade 0 dB.
Click and drag Cross Fade -3 dB (or any Cross Fade option) and drop it onto the end of your audio clip. It will automatically snap to the clip’s tail.
Trim the transition by clicking and dragging its edge to shorten or extend the fade duration. You can also click the transition and adjust its duration in the Inspector panel.
Note: This method applies
only to the clip endpoint. It is not suitable for fades that need to start mid-clip or animate across multiple volume points.
Which Method Should You Use?
Scenario |
Best Method |
Quick fade at clip end |
Fade Handles |
Music bed with gradual taper |
Volume Keyframes |
Fade exactly on a cut or transition |
Audio Transition (Effects Library) |
Need to animate multiple volume points |
Volume Keyframes |
Why can’t I see the fade handles on my audio clip?
The fade handles only appear when the audio track is tall enough in the timeline to display them. Try dragging the track header downward to increase the track height. Also confirm your cursor is hovering at the very top corner of the clip, not the left or right edge. If the clip is too short, the handle may not be visible until you zoom in.
How do I fade out background music without affecting dialogue?
Place your music and dialogue on separate audio tracks in the timeline. Apply fade handles or keyframes only to the music track, leaving the dialogue track untouched. If your clips are linked A/V pairs, right-click and unlink them first so audio and video adjustments stay independent from each other.
Can I fade audio in the Fairlight page?
Yes. The Fairlight page supports automation lanes that let you draw volume curves with fine control across an entire track. This approach is better suited to advanced mixing sessions rather than simple clip-level fades. For a full walkthrough of Fairlight automation, refer to the official DaVinci Resolve documentation or Blackmagic Design’s Fairlight user guide.
Wrapping Up
Fade handles are the fastest option for a quick clip-end fade, volume keyframes give you the most control for music and complex automation, and the Effects Library’s Fade Out transition is the simplest drag-and-drop solution for cut points. Once you are comfortable with these methods, consider exploring audio normalization and crossfade transitions in DaVinci Resolve to take your audio polish even further.
