Controlling which ear your audio plays in is one of those tasks that sounds simple but can be surprisingly hard to find in DaVinci Resolve. Whether you want to intentionally direct sound to the left or right channel for a creative effect, or your audio is already stuck in one ear and you need to fix it, Resolve gives you three distinct ways to handle it. This guide walks through each method step by step.
What “One Ear Only” Means in DaVinci Resolve Audio
In DaVinci Resolve, “one ear only” means the audio pan value is set to its full left (–1.00) or full right (+1.00) position, sending all sound to a single stereo channel.
It is worth noting that there are two separate situations you might be dealing with. The first is intentional: you want to creatively pan audio hard to one side. The second is a problem: your audio is already playing in only one ear because a mono clip was incorrectly mapped to a single channel during recording or import. The methods below cover both.
Method 1 — Pan Audio to One Ear Using the Edit Page Timeline
The Edit page timeline pan knob is the fastest starting point for most users. No page switching required, and the result is immediate.
Open your project and navigate to the Edit page.
Select the audio clip on the timeline that you want to pan.
Look directly above the audio track header on the left side of the timeline. You will see a small pan knob (sometimes labeled “Pan” or shown as a circular dial).
Click and drag the pan knob fully to the left for a value of –1.00 (left channel only),
or fully to the right for +1.00 (right channel only).
Press the spacebar to play back the clip and confirm the audio is routing to the correct ear.
Note: The –1.00 and +1.00 values represent the extreme ends of the stereo field. A value of 0.00 is centered, meaning audio plays equally in both ears. Any value in between creates a partial pan toward one side.
If you cannot see the pan knob, right-click the track header and make sure track controls are fully expanded.
Method 2 — Use the Inspector Panel for Precise Pan Control
When you need an exact numeric value or want to animate the pan position over time, the Inspector panel gives you clip-level control that the timeline knob alone cannot match.
On the Edit page, click to select the audio clip you want to adjust.
Open the Inspector by clicking the icon in the top-right corner of the Edit page interface (it looks like a small “i” or panel icon), or press Ctrl+Shift+I (Cmd+Shift+I on Mac).
Click the Audio tab inside the Inspector.
Locate the Pan or Balance slider. Click the numeric field and type –1.00
for full left or +1.00 for full right.
Play back to confirm the routing.
Pro Tip: To animate the pan so audio moves between ears across the duration of a clip, right-click the Pan value in the Inspector and select Add Keyframe. Move the playhead to a different point in the clip, change the Pan value, and Resolve will automatically create a smooth transition between positions. This works well for creative fly-by sound effects or dialogue positioning.
Clip-level vs. track-level: Changes made in the Inspector apply only to the selected clip, not to every clip on that track. If you want a pan setting to apply to all clips on a track at once, use Method 3 below.
Method 3 — Pan Audio in the Fairlight Mixer (Track-Level Control)
Fairlight is Resolve’s dedicated audio page, and its mixer gives you a channel strip for every track in your timeline. Panning here affects the entire track rather than individual clips, which is useful when you have many clips on a single track and want consistent routing across all of them.
Click the Fairlight tab at the bottom of the screen to switch to the Fairlight page.
In the mixer panel, locate the channel strip that corresponds to your audio track.
At the top of the channel strip, you will see a Pan knob. Click and drag it fully left for hard left, or fully right for hard right. You can also double-click the knob and type a precise value.
Return to the Edit page and play back the timeline to verify the output.
When to use Fairlight vs. the Inspector: Use the Fairlight mixer when you want a single pan setting to govern an entire track consistently. Use the Inspector when you need different pan values on individual clips within the same track.
Fix Audio That Is Already Stuck in One Ear
If your audio is playing in only one ear and you did not intentionally pan it there, the most common cause is a mono clip that was recorded or imported with its single channel mapped only to the left or right output. Here is how to correct it.
Right-click the problem clip on the timeline and select Clip Attributes.
Click the Audio tab inside the Clip Attributes window.
Look at the channel mapping grid. If the source has one mono channel mapped to only L or only R, change the mapping so that the mono source feeds both the L and R outputs.
Click OK and play back the clip to confirm audio is now present in both ears.
Alternatively, in Fairlight, you can set the track’s channel format to Mono and route it through a stereo bus, which will automatically duplicate the signal to both channels on output.
A note on prevention: The root cause of single-channel audio is often a mono lavalier or boom microphone recording to only one channel at the source. Using a dual-channel wireless microphone like the Hollyland LARK MAX 2, which records 48 kHz / 32-bit Float audio on both channels simultaneously with built-in backup recording, eliminates this problem before it ever reaches post-production.
Q: Why is my DaVinci Resolve audio only coming out of one ear after export?
The most common cause is a mono audio clip mapped to only the left or right channel in the timeline. Open Clip Attributes, go to the Audio tab, and remap the mono source to feed both the L and R outputs. Re-export after making the change and the audio should appear in both channels.
Q: Does panning to one ear in DaVinci affect the exported file?
Yes, it does. If the pan is set to full left or full right when you export as a stereo file, only that channel will contain audio in the final render. Before you export, open the Deliver page and review your audio settings to make sure the stereo output is configured as expected.
Q: Can I keyframe the pan so audio moves between ears over time?
Yes. In the Inspector panel on the Edit page, right-click the Pan value and choose Add Keyframe. Move your playhead to another point on the clip, enter a new Pan value, and Resolve will animate the position smoothly between the two keyframes across the clip duration.
Next Steps
The Edit page pan knob handles quick adjustments without leaving the timeline. The Inspector gives you clip-by-clip precision with optional keyframing. Fairlight covers the whole track in one move. Before you render anything, open the Deliver page and review your Audio tab settings to confirm the export is set to stereo and your channel routing reflects exactly what you have built in the timeline. A quick headphone check of the exported file is always worth the extra minute.
