Microphone Popping: Why It Happens and How to Fix It
Microphone popping is not a single problem, and there is no single fix. The word “popping” covers at least four distinct issues with different causes and different solutions. Applying the wrong fix wastes time and leaves the problem unsolved. This guide helps you first identify the pop type. After that, you can apply the right fix directly.
What Kind of Popping Does Your Microphone Have?
Before attempting any fix, match your symptom to one of the four types below.
  • Plosive thump: A low, heavy thud that appears specifically when you say words containing P, B, or T sounds. The pop is tied directly to speech.
  • Random electronic crackling: An unpredictable pop or crackle that appears whether or not you are speaking, and is not tied to any specific word or vocal action.
  • Clipping pop: A sharp, harsh, distorted burst that happens when your voice gets loud. Often described as a “crunch” or “crack” at high volume.
  • Wireless dropout pop: A sudden crackle, click, or brief silence that occurs on a wireless microphone system, sometimes mid-sentence or during movement.
Once you have matched your symptom, jump to the corresponding fix section below.
Fix 1 — Plosive Pops From P, B, and T Sounds
When you pronounce hard consonants like P, B, and T, your mouth releases a short, concentrated burst of air. That burst travels directly into the microphone capsule and strikes the diaphragm with more force than the surrounding sound waves. The diaphragm briefly gets overloaded during sound capture. This creates a low-frequency thump in the recording. This is called a plosive pop. It is a physical acoustic issue. No software adjustment will prevent it.
Cardioid microphones are more likely to pick this up. Their directional sensitivity makes them more exposed. The proximity effect also increases this impact. A capsule aimed at your mouth catches every breath strongly. Omnidirectional microphones are slightly less vulnerable because they do not boost bass frequencies at close range, but they are not immune.
Fix these pops in the following order:
  1. Add a pop filter or foam windscreen: Place a mesh pop filter between your mouth and the capsule, or fit the microphone with a foam windscreen that sits directly over the capsule. Both options work by dispersing the air blast before it reaches the diaphragm. A mesh pop filter generally provides stronger attenuation than foam alone when positioned correctly.
  2. Reposition the microphone off-axis: Angle the capsule slightly above or to the side of your mouth rather than pointing it directly at your lips. The burst of air from plosive consonants travels forward in a narrow cone, so moving the capsule even a few degrees out of that path reduces impact significantly.
  3. Increase mic-to-mouth distance to 15–20 cm: Air velocity drops off quickly with distance. Moving the microphone further from your mouth allows the blast to disperse before reaching the capsule. Pair this adjustment with a small gain increase to compensate for the reduced signal level.
Using all three fixes together produces the cleanest result. If you can only choose one approach, off-axis positioning combined with a pop filter is the most consistent combination.
Fix 2 — Crackling or Random Popping From Software and Driver Issues
Random pops that are not tied to your speech are almost always generated inside the signal chain rather than at the microphone capsule itself. Four specific causes account for the majority of cases.
If the pops appear in your recordings but you cannot hear them during real-time monitoring, the cause is likely in the buffer or driver layer. If the pops are audible live through your headphones or speakers, the cause is more likely a power or hardware instability issue.
Cause
Symptom Pattern
Fix
Outdated or corrupt audio driver
Crackling appears inconsistently, often after a system update or new device installation
Open Device Manager (Windows) or System Settings (macOS), locate the audio device, and update the driver. If updating fails, uninstall and reinstall from the manufacturer’s website.
Sample rate mismatch between mic and DAW or OS
Pops occur at regular intervals or whenever audio processing begins
Set the sample rate in your DAW, operating system sound settings, and microphone driver to the same value. 48 kHz is the broadcast standard and the safest match for most USB microphones and interfaces.
Audio buffer size set too low
Pops appear only in recordings, not in live monitoring, and worsen under CPU load
Increase the buffer size in your DAW audio settings. A setting of 256 to 512 samples is a practical starting point for most recording situations.
USB power instability on bus-powered mics
Intermittent crackling that changes when you move the cable or swap ports
Disconnect the microphone from any USB hub and connect it directly to a port on the computer itself. If a hub is required, switch to a powered hub with its own external power supply.
Fix driver and sample rate problems first before buffer changes. A driver fix often removes crackling completely. It may work without any other adjustments needed..
Fix 3 — Clipping Pops From Gain Set Too High
Every digital audio system has a ceiling: 0 dBFS (decibels relative to full scale). When your input signal is too loud, it hits that ceiling, and the waveform gets cut off flat at the top. That cut produces a sharp, distorted pop or crackle. This is digital clipping. It sounds different from a plosive thump or crackle. It is harsher and more mechanical in tone. It usually links to loud speech, not specific consonants.
Clipping pops often happen when the gain is set too high. This can come from the transmitter or interface level. It also happens when someone suddenly speaks louder. Multiple inputs combined can also exceed available headroom.
Fix clipping pops in the following order:
  1. Reduce input gain: Lower the gain on your transmitter, audio interface, or recording software until the loudest speech peaks register well below 0 dBFS on the level meter. Targeting an average speech level of around -12 to -6 dBFS leaves enough headroom for loud peaks without sacrificing audibility.
  1. Monitor levels before recording starts: Have the speaker deliver their loudest expected line before rolling, and set gain based on that peak rather than a quiet speaking test.
  2. Use a pad switch if available: Many audio interfaces offer a -10 dB or -20 dB pad on each input. Engaging the pad reduces the incoming signal level before it reaches the converter, providing additional headroom without moving the gain knob.
32-bit float recording as a structural solution: When your recording device supports 32-bit float capture, digital clipping on the internal recording becomes physically impossible. A 32-bit float file encodes a dynamic range so wide that no real-world input level can exceed it at the converter stage. Any gain-related clipping pop simply cannot exist in a 32-bit float file. It does not affect the analog signal path, but it eliminates the digital ceiling as a failure point entirely.
Fix 4 — Wireless Microphone Popping From Signal Dropouts
Wireless microphones pop when the RF link between transmitter and receiver is interrupted. The receiver loses the incoming signal for a fraction of a second, then re-establishes the connection, and the transition produces a burst of noise or a brief silence that registers as a pop or crackle in the audio.
Common causes of wireless dropout pops:
  • Operating beyond the system’s maximum effective range
  • Physical obstructions such as walls, large equipment, or the performer’s own body blocking line of sight between transmitter and receiver
  • RF congestion from dense Wi-Fi networks, Bluetooth devices, or competing wireless microphone systems operating on nearby frequencies
  • Low battery in the transmitter, which reduces RF output power and link stability
Fixes:
  1. Stay within the manufacturer’s specified operating range, and treat that figure as a maximum under ideal conditions rather than a reliable everyday working distance.
  2. Maintain clear line of sight between transmitter and receiver wherever possible. Even an incorrect transmitter angle can partially obstruct the internal antenna.
  3. Change the RF operating channel on your wireless system if the option exists. Moving to a less congested frequency significantly reduces dropout probability in crowded RF environments.
  4. Power down nearby wireless devices that are not in active use during the recording session.
  5. Charge the transmitter fully before each session and watch battery level indicators throughout.
Diagnosing and Fixing Popping on the Hollyland LARK MAX 2
The LARK MAX 2 includes specific controls and indicators that make diagnosing dropout and clipping pops more precise than on most compact wireless systems. Work through the following steps if you are experiencing popping with this system.
  1. Check the connection LED on both transmitter and receiver. A solid blue LED on each unit confirms a stable paired link. A flashing blue LED indicates the unit is actively searching for a connection or has dropped pairing. A flashing state is a direct cause of dropout pops. If either LED is flashing, bring the transmitter and receiver closer together in open space and allow the pairing to re-establish before moving on.
  1. Inspect range and line-of-sight conditions. Reposition within the LARK MAX 2’s operating range and confirm that no large physical obstructions sit between transmitter and receiver. Clip the transmitter vertically on clothing rather than placing it in a pocket or under fabric layers, which can obstruct the capsule.
  1. Adjust input gain using the HollyAudio app. Connect the system to the HollyAudio App (also known as the LarkSound app). Go to the transmitter's settings and scroll down to the Dynamic Gain section. Here, you can set gain up to three levels (Low, Medium, and High). If you want to manually change the levels, you can do it from the Set gain to option. Just increase or decrease the bar for each transmitter to set gain.
Start at the lowest gain level that captures a clean, audible signal and increase only as needed. Reducing gain removes the headroom pressure that pushes loud peaks into clipping.
  1. Enable AI Noise Cancellation. Open the Hollyland app and locate the AI Noise Cancellation toggle (NC Level) in the sound settings for your connected TX.
But if you want to quickly turn on or off the noise-canceling feature, click the pairing/power button on the TX once. When the noise cancellation is activated, the LED will turn green.
  1. Enabling this suppresses breath noise and proximity-related transients, which can contribute to sharp bursts that register as pops in the recording.
  2. Verify that 32-bit Float Internal Recording is active. In the HollyAudio app or on the RX settings screen, confirm that 32-bit Float Internal Recording is enabled on the transmitter. When this mode is active, the transmitter records a backup file to its onboard storage using 32-bit float encoding. That backup file cannot contain digital clipping pops regardless of the gain level selected, giving you a clean fallback track even when the main output was running hot.
  1. Check the battery level LED. A transmitter running low on battery produces weaker RF output, which destabilizes the wireless link and is one of the most frequently overlooked causes of intermittent popping. If the TX LED shows red, charge via USB-C before diagnosing any other cause.
Quick-Reference Fix Table
Use this table to confirm your diagnosis and find your first action quickly.
Popping Type
Most Likely Root Cause
First Fix to Try
Plosive thump on P, B, or T sounds
Air blast hitting the mic capsule
Add a pop filter or windscreen; reposition mic off-axis
Outdated audio driver or buffer size too small
Update the audio driver; increase buffer size to 256–512 samples
Sharp distorted pop on loud words
Input gain causing digital clipping
Reduce transmitter or interface gain; enable 32-bit float recording
Crackle or silence burst on wireless system
RF dropout or operating range exceeded
Check LED pairing status; reduce distance and clear line-of-sight obstacles
Why does my microphone pop randomly even when I am not speaking?
Random pops without voice usually point to an electronic issue. These are not caused by physical sound problems. Common causes include unstable audio drivers or USB power changes. Wireless signal dropouts can also create these pops. Mic placement or pop filters will not fix this issue. Begin with a driver update and try another USB port.
Does a pop filter completely eliminate plosive pops?
A pop filter significantly reduces plosive thumps but rarely eliminates them entirely on its own. Combining a pop filter with off-axis mic positioning gives the most reliable control because you are both dispersing the air blast and redirecting the capsule away from the direct blast path at the same time.
Can microphone popping damage my speakers or headphones?
Occasional pops are unlikely to cause permanent damage to most modern speakers, but loud and repeated pops do stress speaker drivers over time. More immediately, sudden pops at high monitoring volume can cause hearing discomfort. The microphone capsule usually does not get damaged by plosive blasts. But the signal path can still suffer from clipping. This often happens when distortion stays strong for long periods.
Why does my wireless mic pop more in crowded spaces like conferences or events?
Many Wi-Fi networks and Bluetooth devices share limited RF space. Multiple wireless microphones also compete for the same spectrum. More nearby devices increase the chances of signal interference. This can cause short audio dropouts. Using a less crowded RF channel can help. Moving the receiver antenna away from routers also reduces this issue.
Does 32-bit float recording eliminate all microphone popping?
It eliminates digital clipping pops on internal backup recordings by encoding a dynamic range that no input level can exceed at the converter stage. But a physical air blast from a plosive consonant still affects the analog signal before capture, and RF dropout pops occur at the wireless link level before recording format becomes relevant. Proper mic technique and stable signal conditions remain necessary alongside 32-bit float recording.
Most microphone popping problems are solvable without replacing any hardware. The key is identifying the pop type first. A pop filter helps with plosive sounds. Driver and buffer changes can fix electronic crackling. Lowering gain prevents clipping and distortion. Stable connections help stop wireless audio dropouts.
