Raw footage rarely looks cinematic straight out of the camera. It usually appears too warm, flat, and plain in look. DaVinci Resolve gives tools to change that look completely. Color grading, visual overlays, and motion effects all help shape a more styled result inside the free software. So, through this guide, you can learn techniques to transform dull clips into polished, visually striking footage with a cool, professional look.
What “Cooler” Actually Means in DaVinci Resolve?
“Cooler” means two things in this context, and this guide delivers both.
The first meaning refers to color temperature. It pushes visuals toward blue and teal tones with muted shadows. This moves away from warm amber looks that most cameras capture by default.
The second meaning refers to the overall presentation. The footage appears more cinematic and visually refined. It feels sharper, more controlled in contrast, and less like unedited camera output.
You will use three main workspaces to achieve this. The Color Page handles grading, curves, LUTs, and film grain. The Edit Page handles letterbox bars, speed ramping, and clip-level adjustments. Fusion adds motion graphics if you want to go further.
Adjust Color Temperature and Tint for Instant Cool Tones
The fastest route to cool footage is shifting the overall color balance toward blue and teal. Here is how to do it cleanly.
Open the Color Page by clicking the palette icon at the bottom of the screen.
Select a clip in the timeline. Make sure you are on the first node in the node tree.
Go to Primaries Color Wheels (or Log Wheels if your footage was shot in a LOG profile).
Find the Temperature slider under the Primaries tab and drag it to the left (toward blue). Start with a modest shift – around -150 to -300 on the scale – and judge by eye.
Shift the Tint slider slightly toward green. This pushes shadows into teal territory, which is a key part of the popular teal-and-orange cinematic grade.
Reduce overall saturation slightly (try 90 instead of 100) to give the image a more controlled, editorial feel.
Note: If your footage contains people, watch your skin tones carefully. A global cool shift will turn faces grey or greenish. Use a secondary node with the Qualifier tool to isolate and warm skin back up after applying the broad cool grade.
Using the Color Wheels to Push Shadows Cool
The color wheels give you independent control over shadows (Lift), midtones (Gamma), and highlights (Gain). This is where you build depth into the grade.
In the Lift wheel, nudge the center point toward blue or cyan. Even a small movement – just a few pixels – introduces cool shadows without destroying detail.
Leave the Gamma (midtones) wheel close to neutral, or shift it very slightly warm. This creates contrast between the cool shadows and a natural midrange.
In the Gain wheel, push slightly warm (toward orange or amber). This is the foundation of the teal-and-orange split that defines most modern cinematic looks.
The logic behind this: cool shadows and warm highlights create the impression of depth and professional lighting. Your eye reads the contrast as intentional rather than accidental, which immediately makes footage look more cinematic.
Master the Custom Curves for Cool Contrast
The Curves panel gives you surgical control over individual color channels. This is where a grade goes from decent to distinctive.
On the Color Page, click the Curves icon in the toolbar above the viewer (it looks like a diagonal line).
On the Luma (Y) channel, create a gentle S-curve: pull the lower-quarter point slightly up to lift the blacks (preserve shadow detail), and pull the upper-quarter point slightly down to compress the highlights. This adds contrast without crushing detail.
Switch to the Blue channel. Pull the bottom-left anchor point upward slightly – this adds blue to the shadows. Then pull the top-right anchor point downward slightly – this removes blue from the highlights, making them appear warmer by comparison. The result is the teal-shadow / warm-highlight split built directly into the curve.
Switch to the Red channel. Apply a very slight downward pull in the shadow region. Reducing red in the darks pushes them toward cyan, reinforcing the cool shadow feel.
Once you are satisfied, right-click on the node, select Add Flag, and label it “Cool Curves.” Then go to Color Menu → Power Grades → Save As to reuse this grade on future projects.
Pro Tip: Work in small increments on each channel. The Blue and Red curves are sensitive. A large pull creates an unnatural look fast. Aim for adjustments you can barely see individually; the combined effect will be visible and intentional.
Apply a LUT for a Cinematic Cool Look
A LUT (Look-Up Table) is a preset that remaps the colors in your footage to a specific look in a single step. Think of it as a starting point, not a finished grade.
On the Color Page, right-click your node tree and select Add Serial Node.
Right-click that new node and choose LUTs. Browse to a LUT file (.cube format) from the built-in Resolve library or one you have downloaded and installed.
For a cool cinematic look, try DaVinci Resolve’s built-in options under Film Looks – options like “Fuji 3510” or “Kodak 2383” skew cooler and have a filmic quality out of the box. Free packs from sources like Ground Control or Lutify.me also offer strong cinematic cool presets.
After applying the LUT, find the Gain slider under Key Output at the bottom of the node panel. Reduce the LUT’s intensity to around 40–70%. Full-strength LUTs often look overdone and harsh; blending them down creates a more natural result.
Keep the LUT on its own dedicated node. This lets you toggle it on and off, adjust its strength, or swap it out without disturbing the rest of the grade.
Warning: Always apply your primary color balance (fixing exposure and white balance) on a node before the LUT node. Applying a LUT directly to uncorrected LOG or flat footage will produce unpredictable, often ugly results. Correct first, then look.
Add Film Grain, Vignette, and Letterbox Bars
These three overlays are the fastest way to take a good-looking grade and make it feel genuinely cinematic.
Film Grain
Film grain removes the clinical, digital flatness that makes footage look like it was shot on a consumer camera. A subtle layer adds texture that reads as sharpness and presence.
On the Color Page, right-click your final node and add a serial node after it.
Right-click the new node, go to Open FX, and choose Film Grain from the Resolve FX library.
Set Grain Size between 0.3 and 0.6. Smaller sizes feel more like 35mm film; larger sizes start to look like stylized noise.
Set the Blend Mode to Overlay and reduce the overall strength to around 30–50%.
The overlay blend mode allows the grain to interact with the image’s luminance values rather than sitting uniformly on top, which looks far more organic.
Vignette
A vignette darkens the frame edges slightly, drawing the viewer’s eye toward the center of the image. It is a technique borrowed from portrait photography and used in nearly every cinematic grade.
On the Color Page, add a serial node after your grain node.
Click the Window tool (the shape icon in the left toolbar).
Select a circular or oval shape and resize it to cover most of the frame, leaving a visible border.
Click Invert so the selection applies to the edges rather than the center.
On the Gain wheel for this node, pull slightly down to darken the edges. Keep it subtle – the vignette should be felt, not seen.
Increase the Softness slider significantly so the falloff is gradual.
Letterbox / Anamorphic Bars
Black bars at the top and bottom of the frame give footage the aspect ratio of a cinema screen. It is a simple visual cue that signals “this is a film.”
Go to the Edit Page, open the Effects Library, and search for Letterbox. Drop it onto an adjustment layer above your clips, or onto a specific clip. Set the ratio to 2.35:1 or 2.39:1 for the most cinematic feel. Make sure the bars are true black with no transparency bleed.
Use Speed Ramping and Motion Blur for Dynamic Footage
Speed ramping – smoothly transitioning between normal speed and slow motion – is one of the most recognizable effects in modern video. Combined with motion blur, it adds energy and drama to any transition or action moment.
In the Edit Page, right-click your clip and select Change Clip Speed.
In the Retime controls, click Retime Curve to open the speed graph at the bottom of the timeline.
Place keyframes at the start and end of the section you want to ramp. Between those keyframes, set the speed to your desired percentage (e.g., 25% for a dramatic slow-down).
Smooth the keyframe handles to create a gradual ramp in and out rather than an abrupt cut.
Right-click the clip and go to Retime Process → Optical Flow. This tells Resolve to generate interpolated frames between existing ones, making slow-motion footage look smoother rather than choppy.
For motion blur, go to the Inspector panel → Retime and Scaling → change Motion Estimation to Enhanced. This adds a subtle natural blur during the ramp that matches how the eye perceives fast movement.
Best for: Transition moments, dramatic B-roll reveals, action sequences, and any clip where movement itself is the subject. Works significantly better when the source footage was captured at 60fps or higher.
Combine Techniques with a Node Tree Workflow
Individual techniques are powerful. Combined in the right order, they produce consistent, professional results across an entire project.
Recommended node order:
Node 1 – Primary Balance: Fix exposure, set white balance, correct any lens issues.
Node 2 – LUT: Apply your chosen LUT at reduced strength via Key Output Gain.
Node 3 – Cool Grade: Color wheels and custom curves adjustments (teal shadows, warm highlights, contrast S-curve).
Node 4 – FX: Film grain and vignette layered at the end so they sit on top of the finished grade.
Node order matters because each adjustment reads the output of the node before it. Applying a LUT before balancing means the LUT is working with flawed input. Adding grain before grading means your color work will interact with the grain texture unpredictably.
Once your node tree is complete, right-click on the clip in the Color Page thumbnail strip and select Grab Still. Save the still as a Power Grade. You can now drag that Power Grade onto any other clip in your timeline and apply the entire node tree in one click.
For applying a look across an entire sequence without touching individual clips, go to the Edit Page, create a new Adjustment Clip from the Effects Library, place it on a track above all your footage, and apply your Power Grade to that single clip. Every clip beneath it inherits the grade.
Q1: How do I make my video look cooler without changing the whole color grade?
Apply a cool LUT on its own serial node and reduce the Gain slider under the Key Output to 40–60%. This blends the LUT over your existing footage at low intensity, adding the cool tonal quality without a full regrading session. You can toggle the node on and off to compare results instantly.
Q2: Why does my cool grade look wrong on skin tones?
A global cool shift pushes skin tones toward grey or green, which reads as unnatural. Use the Qualifier tool on the Color Page to isolate skin tones by sampling with the eyedropper. Add a new parallel or serial node connected only to the qualified selection and apply a warm correction there, leaving the rest of the frame cool.
Q3: Can I make a cool grade in the free version of DaVinci Resolve?
Yes and No. You can find the basic tools, such as Color Wheels, in the free version. But some effects, like the Film Grain, are only available in the Studio version.
Q4: What is the difference between adjusting color temperature in-camera versus in DaVinci Resolve?
In-camera adjustments (especially in JPEG or H.264 formats) bake the white balance permanently into the file. In DaVinci Resolve, every adjustment is mathematical and can be modified or reset.
Q5: What LUTs give the best cool cinematic look in DaVinci Resolve?
DaVinci Resolve film emulation LUTs Fuji 3510 Kodak 2383 create a cinematic base. Creators find free LUTs on Wandering DP and FilterGrade resources. Pair LUTs with manual curve adjustments to personalize footage results.
Start with a color temperature shift for a cooler tone. Build depth using curves to shape contrast levels. Apply LUT at reduced strength for a subtle effect. Finish with grain and vignette for the final look. This sequence turns flat footage into cinematic visuals.
Apply the full node tree to one short clip first. Save it as Power Grade for reuse later. Then batch apply it across the entire timeline consistently. After the workflow feels stable, test export quality settings. Ensure the final render keeps grading intact without loss.
