How to Convert Long Videos to Shorts in CapCut (AI + Manual Methods)
CapCut gives you two reliable ways to turn long videos into short-form clips: an AI-powered tool that automatically identifies highlight moments, and a manual split-and-trim method for full creative control. Whether you’re repurposing a 30-minute vlog or trimming down a podcast recording, this guide walks through both workflows and covers the exact export settings you need for TikTok, YouTube Shorts, and Instagram Reels.
What Does CapCut’s Long to Short Feature Actually Do?
CapCut’s Long to Short feature uses AI to scan your video and identify the most engaging segments based on signals like face detection, speech energy, and scene changes. Rather than making you scrub through an entire recording manually, the tool surfaces a set of pre-trimmed clips already sized for vertical platforms. Think of it as a first-pass editor, not a finished product.
The AI does not simply chop a video at fixed intervals. It analyzes the content, prioritizing moments where someone is speaking clearly, showing emotion, or where audio energy spikes. The result is a selection of clips that tend to hold more viewer attention than random cuts would. That said, AI accuracy depends heavily on source footage quality. Noisy audio, shaky camera work, or scenes without a clear subject will produce weaker results.
One important distinction: the feature appears under different names depending on where you use it. On mobile, look for “Smart Highlights” or “Long Video to Shorts” inside the editing menu. On CapCut desktop, the same functionality is typically labeled “Long to Short” in the AI tools panel. The underlying process is the same either way.
Where to Find the Feature - Mobile (iOS/Android): Open your project, tap the clip, then scroll the bottom toolbar to find “Smart Highlights” or navigate to AI Tools. - Desktop: Open your project, click “AI Tools” in the top toolbar, then select “Long to Short.”
Method 1 — Using CapCut’s AI to Automatically Generate Shorts
This is the fastest route and the one worth trying first. The AI workflow imports your video, analyzes it, and delivers a set of ready-to-review clips, usually within a minute or two depending on video length.
Step-by-Step on Mobile (iOS / Android)
  1. Open CapCut and tap New Video.
  2. Select your long video from your camera roll or local storage, then tap Add.
  3. On the editing timeline, tap the clip to select it.
  4. Scroll the bottom toolbar and tap Smart Highlights, or go to AI Tools and select Long Video to Shorts on some app versions.
  5. Wait for CapCut to analyze the video. A progress bar will appear during processing.
  6. Review the clips CapCut has selected. Each clip appears as a preview card showing its duration and start/end point.
  7. Tap any clip to preview it. Use the trim handles to adjust the start and end points if the selection feels off.
  8. Deselect any clips you do not want to keep.
  9. Tap Export on each clip individually, or use Export All if that option is available.
  10. Confirm your export settings (covered in the export section below) and tap Export to save.
Practical note: If the AI consistently misses the best moments, check whether the original video contains clear, audible speech segments. Dialogue with strong audio energy produces the most accurate highlight detection.
Step-by-Step on CapCut Desktop
  1. Open CapCut Desktop and click Long Video to Shorts from the home screen.
  2. Click Drag and Drop (or select a file manually) and import your long video.
  3. Wait for the video to upload and process. Once the upload is complete, the Long Video to Shorts settings screen will open automatically.
  4. Select the portion of the video you want to convert into shorts. Drag the handles on the timeline at the top to choose the desired section.
  5. Choose a caption template from the available styles under Select Caption Template.
  6. Set the desired short duration:
  • Auto
  • Less than 30 seconds
  • 30–60 seconds
  • 60–90 seconds
  • 90 seconds–3 minutes
  1. Use the Include Specific Moments field to tell CapCut what type of highlights to look for (for example: “Find the best tips” or “Find the most engaging moments”).
  2. Review the estimated processing time shown at the bottom of the window.
  3. Click Convert to start generating AI-powered short clips.
  4. Wait for CapCut to analyze the video and generate the shorts automatically.
  5. Review the generated clips and make any necessary edits before exporting.
  6. Export the final short clips using your preferred resolution and format.
Practical note: Desktop gives you more precise control over clip boundaries. If you need frame-accurate cuts, zoom into the timeline before dragging the trim handles.
Method 2 — Manually Cutting Long Videos Into Shorts in CapCut
If your video is b-roll heavy, music-driven, or lacks clear speech cues, the AI tool may not select useful segments. Manual trimming gives you full control and works on both mobile and desktop with similar steps.
  1. Import your long video into a new CapCut project and add it to the timeline.
  2. Play through the video and identify the moments you want to keep. Use the playhead to navigate efficiently.
  3. Position the playhead at the start of your target segment and tap or click Split.
  4. Move the playhead to the end of the segment and tap or click Split again.
  5. Select the clip segments before and after your target section and delete them.
  6. Drag the remaining clip’s edges to fine-tune the in and out points as needed.
  7. To pull multiple short clips from one long video, reimport the original clip or duplicate it on a new track, then repeat the split process for each additional segment.
  8. Adjust the canvas to 9:16 under Canvas settings if needed, then proceed to export.
Note: For multiple clips from the same source, split all your target segments first, then delete the unwanted sections in bulk using multi-select. This saves significant time on longer recordings.
How to Export Shorts for TikTok, YouTube Shorts, and Instagram Reels
Getting export settings right is where many creators lose quality unnecessarily. Use the table below as your reference before hitting export in CapCut.
Platform
Aspect Ratio
Resolution
Max Length
Recommended Settings
TikTok
9:16
1080 x 1920
Up to 10 min (60 min for some accounts)
1080p, 30–60 fps, H.264
YouTube Shorts
9:16
1080 x 1920
60 sec (up to 3 min for some channels)
1080p, 60 fps preferred, H.264
Instagram Reels
9:16
1080 x 1920
90 seconds
1080p, 30 fps minimum, H.264
In CapCut’s export panel: - Set Resolution to 1080p. - Set Frame Rate to 30 fps for standard talking-head or interview content; use 60 fps for action or fast-moving footage. - CapCut defaults to H.264 encoding, which is compatible with all three platforms. - Watch your final file size. TikTok accepts up to approximately 287 MB for most users; Instagram Reels allows up to 1 GB but compresses heavily above 100 MB.
CapCut’s mobile export panel also includes quick-select platform presets. After tapping Export, look for options labeled with platform names. These presets apply the correct aspect ratio and resolution automatically, which is a reliable shortcut if you are exporting frequently.
Pro Tip: Always export from the highest-quality source file you have available. If your original recording is 720p, your short will be 720p regardless of your export settings. Upscaling in CapCut does not recover resolution that was never there.
Tips to Get Better Results When Converting Long to Shorts
  • Start with well-structured source footage. The AI performs best on videos with a clear speaker, consistent framing, and a logical flow. Rambling or unstructured content produces scattered highlights.
  • Prioritize clean source audio. CapCut’s voice detection significantly improves when ambient noise is low. Creators recording talking-head content or interviews benefit from using a compact wireless mic like the Hollyland LARK M2, which reduces background noise before it ever reaches CapCut’s AI processing.
  • Target 15–60 seconds per clip. This range performs best across TikTok, Reels, and Shorts. Clips under 15 seconds often lack enough context; clips over 60 seconds see noticeably higher drop-off rates.
  • Add auto-captions after generating shorts. A large share of short-form viewing happens on silent autoplay. CapCut’s auto-captions tool takes under a minute to apply and can meaningfully improve retention.
  • Hook within the first 3 seconds. If the AI selects a clip that opens with a slow intro or dead air, manually trim the start to push the most compelling moment to the front.
  • Review every AI selection before exporting. Even well-optimized source videos will occasionally produce clips that start mid-sentence or cut off awkwardly. A quick two-minute review prevents wasted uploads.
Does CapCut Long to Short work on both mobile and desktop?
Yes. The feature is available on both platforms, though under slightly different labels. On mobile, look for “Smart Highlights” or “Long Video to Shorts” in the AI tools section. On desktop, find it under AI Tools in the top toolbar. Core functionality and output quality are comparable across both versions, though desktop offers more precise timeline control.
Can I control which moments the AI selects as highlights?
Yes. After CapCut generates its suggested clips, you can preview each one and manually adjust the start and end points using trim handles. You can also deselect any clip you do not want included. The AI selection is a starting point, not a locked output. For complete editorial control, use the manual split method described in Method 2 above.
Will converting long to short reduce video quality?
Not if your export settings match your source resolution. CapCut re-encodes the video on export, so quality is determined by the original file and the settings you select. Exporting at 1080p with H.264 encoding will match the source quality. If your original recording is lower resolution, the output will reflect that ceiling regardless of what you set in the export panel.
How long can the original video be?
Duration and file size limits vary by account tier. Free accounts typically support uploads up to around 15 minutes or 500 MB per clip for certain features. CapCut Pro accounts allow longer files. For recordings over 30 minutes, consider trimming a rough section first before running the AI tool to reduce processing time and avoid potential errors.
Does CapCut add a watermark to exported shorts?
Yes, the free plan adds a CapCut watermark to exported videos. CapCut Pro removes it automatically. On some app versions, a toggle to remove the watermark may appear in the export settings panel even on the free tier, though availability changes with app updates. Check your current version’s export options before upgrading.
Start Converting Your Long Videos Today
Use the AI Long to Short tool first for speech-heavy content like interviews, vlogs, and tutorials. Fall back to manual splitting when you need precise control over b-roll or non-dialogue segments. Open CapCut now and run the AI tool on your most recent long video to see what it surfaces. Next, learn how to add auto-captions in CapCut to maximize reach on silent-scroll platforms.
