DaVinci Resolve is far more than a color grading tool. Its Fairlight audio page gives you a full recording environment capable of capturing, editing, and mixing professional voiceover audio without leaving the software. Whether you are recording narration directly inside the program or dropping in externally recorded audio, this guide covers the complete workflow from input configuration to final mix.
Before using the Fairlight page, confirm you have the following in place:
DaVinci Resolve 21 recommended or at least version 17 or later (free or Studio version; all core voiceover features covered here are available in the free version)
A microphone connected to your system via USB or an audio interface
A project already created with a timeline open in the Edit page
Headphones or studio monitors for monitoring during recording
Basic familiarity with the DaVinci Resolve interface (Edit page, Media Pool, timeline)
All voiceover recording and audio editing takes place on the Fairlight page, accessible from the bottom navigation bar. Think of it as a dedicated audio workstation built directly into your video editing environment.
For microphone choice, the quality of your capture determines how much cleanup you will need later. The Hollyland LARK MAX 2 is a strong option for voiceover work, offering 48 kHz / 32-bit Float internal recording, built-in AI Noise Cancellation, and low-latency OWS (One-Way Simultaneous) monitoring. These specs reduce the post-production workload significantly, especially in untreated recording spaces.
How to Configure Your Audio Input in DaVinci Resolve?
Skipping audio configuration is the most common reason voiceover recordings fail silently. Complete these steps before creating any tracks.
Open DaVinci Resolve Preferences by going to DaVinci Resolve > Preferences (Mac).
Click the Video and Audio I/O tab on the left panel.
Under Audio I/O, select your microphone or audio interface from the Audio Input Device dropdown.
Set the Sample Rate to 48 kHz to match the standard for video production timelines.
To do that, open the File tab and choose Project Settings.
Select the Fairlight tab from the left-side menu.
Select the audio sample rate from the dropdown menu.
Click Save and restart DaVinci Resolve if prompted.
After restarting, open your project and confirm the input device is still selected in Preferences.
Check that your operating system’s audio settings also recognize the microphone. DaVinci Resolve reads from the system-level input, so if the OS does not detect the device, Resolve will not either.
Pro Tip: If you are using a USB microphone and the device does not appear in the dropdown, try unplugging it, restarting your computer, plugging it back in, and then relaunching Resolve.
Setting Up the Fairlight Audio Page
With your input confirmed, move into the Fairlight environment and prepare a dedicated voiceover track.
Click the Fairlight icon in the page navigation bar at the bottom of the screen (it looks like a waveform).
Familiarize yourself with the three core panels: the timeline (left), the mixer (right), and the audio meters (far right). The timeline is where your clips live. The mixer controls channel levels and routing.
Right-click in the timeline’s track header area and select Add Track > Mono to create a new track. Voiceover is almost always recorded in mono; stereo doubling happens in the mix, not at capture.
Name the track “Voiceover” by double-clicking the track label.
Open the Patch Input/Output window by navigating to Fairlight > Patch Input/Output in the top menu.
In the Patch window, locate your microphone input on the left side and drag it to connect it to the corresponding input bus on the right side for your voiceover track. This tells Resolve which physical input feeds that track.
Close the Patch window and confirm the track header displays your input assignment.
Click the Arm for Record (R) button to enable it. This option not only prepares the track to receive audio input for recording but also lets you hear your mic (audio input monitoring).
How to Record a Voiceover Directly in DaVinci Resolve?
With the Fairlight page configured, you are ready to record. This is the primary workflow for narrators, YouTubers, and editors who prefer to capture voice inside Resolve rather than switching to a separate application.
Position your playhead at the timecode where you want the voiceover to begin. Click the ruler in the timeline or type the exact timecode in the timecode display at the top.
On your voiceover track header, click the Arm for Record button. Without arming the track, Resolve will not capture audio to it.
Speak into your microphone and watch the audio meters on the right side of the screen. You want peaks to land consistently between -12 and -6 dBFS. This range provides enough headroom to avoid clipping while keeping the signal clear.
If levels are too high (clipping above 0 dBFS), reduce the gain on your audio interface or lower the input level in your system audio settings before proceeding. Do not adjust this inside Resolve’s track fader, as that only affects playback volume, not the recorded signal level.
Press Ctrl+Shift+Space (Windows/Linux) or Cmd+Shift+Space (Mac) to start recording. The transport will play, and your audio will be captured to the timeline.
Speak your narration naturally. Watch the meters, but do not stare at them. Focus on your delivery.
Press Space to stop recording when finished.
The recorded clip will appear on the voiceover track in the timeline. It is also automatically saved to the Media Pool under the current bin.
Review the take by disarming the track (click the Record Arm button again to deactivate) and pressing Space to play it back.
Pro Tip: Record a few seconds of silence at the start of your session before any narration begins. This gives you a clean noise print to use with Resolve’s built-in noise reduction tool later.
Using the Voiceover Tool in the Edit Page
If you need to drop in a quick narration line without moving to the full Fairlight environment, the Edit page has a lighter recording option.
Stay on the Edit page and locate the Voiceover Record button in the toolbar at the top of the timeline. It looks like a microphone icon.
Click the button to open the Voiceover Record panel. Select your file name, input device, and record track type from the panel’s dropdowns.
Assuming you have enabled track’s Arm for Record, click the record button on the same Record Voiceover panel. The recording should start from the point where you have placed the playhead.
This method is faster for simple inserts and one-off narration lines. For anything requiring precise gain control, input patching, or multi-take management, the Fairlight page workflow is the better choice.
How to Add a Pre-Recorded Voiceover File?
Many creators record voiceover in a separate application, a sound booth, or on a dedicated recorder and then bring the file into Resolve for editing. This workflow is straightforward.
Go to File > Import> Media from File (or use the keyboard shortcut Ctrl+I / Cmd+I) to open the file browser. Alternatively, drag and drop the audio file directly from your file system into the Media Pool.
Confirm the file appears in the Media Pool. Supported formats include WAV, AIFF, MP3, and AAC, though WAV at 48 kHz / 24-bit or higher is strongly recommended for quality and compatibility.
In the Edit page timeline, create a dedicated audio track for the voiceover if one does not already exist. Right-click in the track header area and select Add Track > Mono (or Stereo if your file is stereo).
Drag the audio clip from the Media Pool down to the voiceover track at roughly the correct position on the timeline.
To sync the audio precisely to your video, use one of these methods:
Manual sync: Zoom in on the timeline and align the waveform to a visual cue in the video, such as a lip movement, a clap slate, or the start of a scene cut.
Auto Align (DaVinci Resolve Studio): Select both the video clip and the audio clip, right-click, and choose Auto Align Clips if the clips share overlapping audio content.
Lock the audio clip to the timeline by right-clicking it and selecting Link Clips to prevent accidental drift when trimming nearby clips.
Editing and Cleaning Up Your Voiceover Track
A clean recording still benefits from editing and audio processing. Work through this sequence after capturing or importing your voiceover.
Step 1: Trim and cut the clip
1. Select the Blade tool (keyboard shortcut B) and cut out any long pauses, false starts, or mistakes by clicking to split the clip at those points.
2. Switch back to the Selection tool (A) and delete the unwanted segments. 3. Snap the remaining clips together so there are no unexpected gaps, unless intentional pauses are part of the pacing.
Step 2: Adjust clip volume
In the timeline, each audio clip has a thin white horizontal line running through it. Click and drag this line up or down to adjust the clip’s volume relative to the rest of the mix without touching the track fader.
Step 3: Apply audio effects in Fairlight
Switch to the Fairlight page, then click your voiceover track to select it. Use the following tools from the Effects Library panel:
Noise Removal: Go to Effects > Noise Reduction. Drag the effect onto the clip or the track. Play a section of silent room tone, click Capture Noise Print, then increase the Noise Reduction slider to a comfortable level (40 to 60 percent is usually a good starting point). Apply and compare with the original.
EQ (Equalization): Open the Clip EQ from the Fairlight mixer channel strip. Enable a High-Pass Filter and set it to roll off frequencies below 80 Hz to remove low-end rumble and HVAC noise. If the voice sounds thin, add a gentle presence boost around 2 to 5 kHz.
Compression: Add the FairlightFX Compressor to the channel strip. For narration, a ratio of 3:1 to 4:1 with a medium attack and medium release will even out the dynamic range without making the voice sound pumped or unnatural. Aim for around 3 to 6 dB of gain reduction on louder peaks.
Volume Automation: Use the Fairlight timeline’s Automation mode to draw volume curves that lower the voiceover slightly during moments where another audio element takes priority, then bring it back up.
Mixing Voiceover with Music and Sound
Getting the balance between voice, music, and effects is the final creative step before export. Use these target levels as reference points:
Audio Element |
Target Peak Level |
Notes |
Voiceover |
-6 to -3 dBFS |
Sits at the front of the mix |
Background music |
-18 to -20 dBFS under voice |
Duck further during the speech |
Sound effects |
-12 to -10 dBFS |
Context-dependent |
Integrated loudness |
-14 LUFS |
Standard for YouTube and most podcast platforms |
To duck music automatically under voice sections:
Go to the Fairlight or Edit page and select your music track.
Then, click the Inspector icon on the top-right corner of the screen next to the audio meter icon.
Click the Audio tab, toggle on the Ducker option, and set the Source to your Voiceover audio track.
For more structured routing, create a Bus for your music tracks in the Fairlight Mixer and apply level adjustments to the entire bus rather than individual clips. This keeps your mix organized and easier to adjust globally during final review.
Before exporting, run a loudness check using Resolve’s built-in Loudness Meter (found in the Fairlight meters panel) to confirm your integrated loudness matches the delivery standard for your platform.
Troubleshooting Common Voiceover Issues in DaVinci Resolve
Issue |
Likely Cause |
Fix |
Microphone not detected |
Wrong device selected or driver issue |
Go to Preferences > Video and Audio I/O, reselect the device, and update drivers |
Recorded clip has no audio (silent) |
Track not armed or input not patched |
Confirm record arm is active; recheck Patch Input/Output assignments |
Voiceover is out of sync with the video |
Sample rate mismatch between the file and the project |
Match sample rate in File > Project Settings > Master Settings (usually 48 kHz) |
Audio is clipping or distorted |
Input gain too high at the interface level |
Lower gain on the interface hardware before recording; do not rely on Resolve’s fader |
Can I record voiceover in the free version of DaVinci Resolve?
Yes. The Fairlight page recording workflow and the Voiceover Record tool on the Edit page are both fully available in the free version of DaVinci Resolve. The only features limited to the Studio version are certain AI-powered tools and advanced noise reduction options, but the core recording functionality has no paywall.
What is the best audio format for voiceover in DaVinci Resolve?
WAV at 48 kHz and 24-bit is the recommended minimum for voiceover work in DaVinci Resolve. It matches the default project sample rate for video production, preserves full dynamic range for editing and processing, and avoids the quality loss associated with compressed formats like MP3.
How do I remove background noise from my voiceover in DaVinci Resolve?
In the Fairlight page, open the Effects Library and locate Noise Reduction under Resolve FX Audio. Drag the effect onto your voiceover clip. During a silent section of the recording, click Capture Noise Print, then gradually increase the reduction amount until background noise is reduced without noticeably affecting the voice itself.
Why is my voiceover track out of sync with the video?
A sample rate mismatch is the most common cause. Go to File > Project Settings > Master Settings and confirm the timeline sample rate matches the sample rate of your audio file. A 44.1 kHz audio file placed in a 48 kHz project will play back slightly faster, causing drift that gets worse over longer recordings.
Can I record multiple voiceover takes in DaVinci Resolve?
Yes. Each time you record over the same section of the timeline, Resolve places a new clip on the track. You can mute or delete unwanted takes and keep the best one. For a more organized comp workflow, record each take on a separate track, then mute and solo tracks as you evaluate which sections to use.
DaVinci Resolve provides two different options for voiceover recording. You can record directly inside Fairlight with monitoring tools. Or bring in externally recorded audio and sync the timeline. In both cases, capture quality shapes final audio results. A reliable microphone and correct input setup reduce later editing. Before exporting, check final loudness matches platform standards. YouTube uses -14 LUFS for audio levels. Podcasts often require -16 LUFS standard settings. Broadcast usually follows -24 LUFS guidelines.
