How to Record a Video Interview: Equipment, Setup, and Technique
Recording a professional-looking video interview does not require a broadcast studio. What it does require is the right gear, applied in the right order. Most failed recordings trace back to a handful of preventable mistakes, such as poor audio, flat lighting, or a camera angle that makes a subject look uncomfortable on screen. This guide walks through the full workflow, from assembling your kit to hitting record with confidence.
What You’ll Need to Record a Video Interview
Use this list to confirm what you have and identify any gaps before recording day.
Camera
  • DSLR or mirrorless camera (Sony, Canon, Nikon) - recommended for image quality and control
  • Dedicated video camera or camcorder - reliable for long-form sessions
  • Smartphone (iPhone or Android) - viable with the right accessories
  • Webcam (Logitech Brio, etc.) - appropriate for remote-only or internal content
Audio
  • Wireless lavalier microphone system (e.g., Hollyland LARK MAX 2)
  • Shotgun microphone with camera mount (e.g., Rode VideoMic)
  • USB condenser microphone for remote desk setups only
  • Headphones for monitoring
Lighting
  • Key light: LED panel or large ring light
  • Fill light: second LED panel or reflector
  • Backlight (optional): small LED for subject-to-background separation
  • Natural window light is free but carries limitations (see setup notes below)
  • Sturdy tripod or camera stabilizer
  • Extra SD cards and fully charged batteries
  • Lavalier clip and cable management tape - Backdrop or background stand with fabric
Software / Recording Platforms
  • OBS Studio: Local or in-person capture
  • Riverside or SquadCast: Remote interviews with local track recording
  • Zoom: Remote fallback option
  • Descript: Combined recording and transcription
Choosing Your Camera and Recording Format
The camera is the piece of gear most people overthink. Image quality matters, but audio and lighting outweigh it. That said, your camera choice sets the ceiling for what post-production can achieve.
Camera Type
Best For
Key Limitation
DSLR / Mirrorless
YouTube, documentary, professional content
Requires lens investment; record time limits without a dummy battery
Long-form interviews, event recording
Less background blur; bulkier form factor
Smartphone / Webcam
Remote interviews, internal content, quick turnarounds
Limited low-light performance; less manual control
Resolution and frame rate: Shoot at a minimum of 1080p. If storage and workflow permit, record in 4K and downscale in post for extra reframing flexibility. For frame rate, 24fps produces a cinematic look; 30fps reads as cleaner and more corporate. Choose one and stay consistent throughout the session.
Why camera type matters beyond image quality: A DSLR or mirrorless camera paired with a fast prime lens, such as a 35mm or 50mm at f/1.8, creates natural background blur that separates the subject visually even in a plain room. This visual separation makes budget setups look significantly more polished.
Smartphone and Webcam Recording
Both are fully viable options when used with the right accessories:
  • Disable portrait mode and lock the orientation to landscape before you start
  • Mount the phone at eye level using a small tripod or phone grip; never hold it
  • Connect an external wireless microphone; built-in phone audio is too thin for interview use
  • Position the subject facing a large window or a ring light to compensate for smaller sensors in low light
  • For webcams, ensure the subject is well lit before trusting the camera’s auto-exposure to handle it
Setting Up Your Recording Environment
The environment affects your audio, your lighting options, and how comfortable your subject feels on camera. It deserves more attention than it typically gets.
Background: A clean, uncluttered wall is the easiest starting point. Neutral grays, off-whites, and muted blues photograph well. Environmental backgrounds (bookshelves, offices, outdoor locations) work when you create distance between the subject and the background and allow depth of field to blur the details naturally. Avoid backgrounds with moving elements; even a ceiling fan becomes distracting on playback.
A branded fabric backdrop on a stand is a reliable middle ground for anyone recording interviews regularly. It is portable, consistent, and removes the environmental variable entirely.
Acoustics: Most audio problems trace back to the room, not the microphone. Hard parallel walls create flutter echo. Tile floors, glass windows, and bare concrete amplify this effect. Soft furnishings such as rugs, sofas, curtains, and bookshelves absorb sound reflections. Empty rooms can create unwanted echoes during an interview recording. Hanging thick blankets nearby can reduce those reflections. It may not look great, but it can help. Stay away from bathrooms and parking garages when recording. Rooms with strong echoes can make voices sound unclear.
Space: You need enough room to place the camera at a comfortable shooting distance, typically 5 to 8 feet from the subject for a medium shot, plus clearance on both sides for lighting positioning.
Pro Tip: Record a 10-second audio clip in your chosen room before interview day and listen back with headphones. If you hear noticeable reverb or echo, address it before the subject arrives.
Lighting Your Interview Subject
Good lighting is the fastest visual upgrade available to any video interview setup. Most unprofessional-looking recordings are lit by an overhead ceiling fixture, which creates harsh shadows under the eyes and chin. Correct this before adjusting anything else.
Standard three-point lighting setup:
  1. Key light: Place your main light source 45 degrees to the side of the subject and slightly above eye level (roughly the 10 o’clock or 2 o’clock position). This is the primary light shaping the subject’s face.
  2. Fill light: Place a softer, lower-intensity light on the opposite side to reduce the harsh shadows created by the key light. A reflector at the same level can substitute for a second fixture.
  3. Backlight (optional): A small LED placed behind and above the subject, aimed at hair and shoulders, creates separation from the background. Especially useful against dark or neutral backdrops.
Practical light types:
  • LED panel lights are versatile, dimmable, and available in adjustable color temperatures. Best for controlled environments.
  • Ring lights are an accessible single-source option that creates a distinctive catch-light in the eyes. Position directly in front of the subject for best results.
  • Natural window light is soft and flattering when the subject faces it directly. The limitation is consistency: window light changes throughout the day and disappears at night or on heavily overcast days.
Avoid mixing light sources with different color temperatures. Warm tungsten and cool daylight LEDs in the same frame produce color casts that are difficult to correct in post.
Framing and Camera Placement
Even good interviews can suffer from an awkward camera position. A low camera often points upward toward the speaker. This angle can make the person appear less flattering. It can also make the frame feel visually unbalanced.
The fundamental rule: Place the camera lens at the subject’s eye line. Not chin level. Not desktop level. Directly at eye level. This applies whether you are using a DSLR on a full-size tripod or a laptop webcam. Raise or lower the camera until the lens aligns with the subject’s eyes.
Framing basics:
  • Rule of thirds: Position the subject’s eyes on the upper horizontal line of an imaginary 3x3 grid, not dead center in the frame. Their body should sit to one side, with open space in the direction they are facing.
  • Headroom: Leave a small, consistent gap between the top of the subject’s head and the top of the frame. Too much headroom makes subjects appear small; too little feels claustrophobic.
  • Shot size: A medium shot frames the subject from roughly the waist up. A medium close-up shows from mid-chest to just above the head. Medium close-ups work well for single-subject documentary and podcast video interviews; medium shots suit in-person two-person conversations where both subjects share the frame.
Camera distance and compression: Placing the camera further back and using a longer focal length (zooming in) flattens facial features slightly and blurs the background more effectively than shooting close with a wide lens. This is generally more flattering for interview subjects.
Two-camera setups: Camera A covers the main speaker or a two-shot. Camera B provides a tighter shot of the second subject or a reverse angle. Sync both cameras with a clap or a clapperboard at the start of each take, and ensure both are shooting with identical exposure and color settings.
Recording Audio for a Video Interview
Audio is the highest-impact technical decision in video interview recording. Viewers will tolerate slightly imperfect video. They will stop watching within 30 seconds of poor audio. Camera microphones are usually too far from the person speaking. Because of that distance, they pick up surrounding room sounds. They also cannot fix problems caused by poor room acoustics. For professional interviews, an external microphone is a much better choice.
The three realistic microphone options:
Wireless lavalier microphone: The standard choice for most interview recording. The transmitter clips near the subject’s mouth, maintaining consistent audio quality regardless of subject movement or camera distance. Practical for both single and multi-subject setups.
Shotgun microphone: Mounts on the camera’s hot shoe or a boom stand. Effective in controlled environments where the subject stays relatively still. Range is limited, and shotgun mics pick up more room noise than a close-mounted lav. Better used as a secondary mic or when a lav is impractical.
USB desktop condenser microphone: Best reserved for remote interviews where both participants are at a desk. Not practical for traditional interview setups because it requires the subject to stay close to the microphone.
For most interview recording scenarios, a wireless lavalier system is the right call.
The Hollyland LARK MAX 2 is built for this use case. Its 32-bit float recording helps prevent common audio level mistakes. You do not need to guess the speaker's volume beforehand. This makes recording easier when speech levels change unexpectedly. With 32-bit Float, the transmitter captures the full dynamic range internally. Even if the gain is set wrong on the camera side, the audio recorded on the transmitter unit is recoverable in post. This matters in interview settings where you cannot stop and adjust mid-conversation without disrupting the flow.
The AI Noise Cancellation is designed for real-world locations. A home office with HVAC noise, a coffee shop with ambient crowd sound, an outdoor setting with wind or traffic. The system reduces these background sounds at the source before audio reaches your camera or recorder.
The OWS earphone monitoring lets you hear what the microphone is actually capturing in real time. The open-ear design means you stay aware of the room while monitoring the feed. The LARK MAX 2 records at 48 kHz, meeting broadcast and podcast distribution standards.
Lav mic placement and cable management:
  • Clip the mic 6 to 8 inches below the subject’s mouth, on the chest or lapel
  • If hiding the mic under a thin fabric layer, use a soft mount to prevent clothing friction noise
  • Route the transmitter cable beneath the clothing or along the back seam and secure it with a small clip to reduce movement noise
  • Do a 30-second test recording and play it back before the subject sits down for the interview
Monitoring Audio While You Record
Recording without monitoring is a significant risk. Clothing rustle sounds like silence until playback. Wireless signal dropout is completely invisible without a feed in your ear. A cable shift mid-interview ruins an otherwise clean take.
The Hollyland LARK MAX 2’s OWS earphone enables live monitoring from the receiver end, so the camera operator or producer hears what is being captured as it happens. This is especially useful in run-and-gun interview setups where a dedicated audio person is not available. If something sounds wrong in the earphones, you can pause and correct it rather than discovering the problem during editing hours later.
Software and Recording Platforms
For in-person or local recording: The camera stores the original video directly on its SD card. Those files keep their full resolution without online transmission compression. OBS Studio can also record another copy at the same time. You can send video through HDMI or a connected webcam. Before formatting an SD card, copy every file elsewhere.
For remote video interviews: The platform you choose determines the quality ceiling for both audio and video.
Platform
Best Use
Video Quality
Key Limitation
Riverside
Professional remote interviews, video podcasts
Up to 4K local recording per participant
Requires host subscription; guests need browser access
SquadCast
Audio-focused podcasters moving into video
HD local recording
Less video-focused feature set than Riverside
Zoom
Internal interviews, low-stakes fallback
Compressed 720p/1080p stream
Records the stream, not local tracks; degrades with poor internet
Descript
Recording, transcription, and editing in one tool
Dependent on participant’s webcam
Best for solo workflows, not broadcast output
The double-ender method: Platforms like Riverside and SquadCast record local tracks, meaning each participant’s audio and video is captured on their own device and synced afterward. Internet instability affects only the monitoring call, not the recordings themselves. If someone’s connection drops briefly, the recording is unaffected. For any interview where quality is a priority, choose a platform that records local tracks rather than the stream.
Zoom remains useful as a fallback and for low-stakes internal content. Accept the quality trade-off going in.
In-Person vs. Remote Video Interview Setup
In-person setup advantages and workflow:
  • You control every variable: lighting, background, microphone placement, camera settings
  • Audio and video sync happens in-camera automatically
  • Setup time is front-loaded, but execution is straightforward
  • Wireless lav systems operate at full performance range
  • Guest experience is generally more relaxed and natural on camera
Remote setup considerations:
  • You control only your own end; the guest’s environment is a variable you cannot fully manage
  • Use a platform that records local tracks
  • Ask the guest to silence notifications, close unnecessary applications, and plug in their device before the call
  • Run a brief tech check five minutes before the actual recording begins
  • Have a fallback plan if video quality on the guest end is unavoidably poor
Note: Sending guests a one-page setup guide as a PDF before the interview is one of the most effective things you can do for remote recording quality. Start with four simple checks before recording your interview. Keep the camera level with the speaker's eyes. Position the speaker toward the main light source. Wear headphones and choose a quiet room for recording. Most guests appreciate the guidance and deliver noticeably cleaner recordings.
Pre-Recording Checklist and Day-Of Workflow
Run through this sequence at least 30 minutes before the subject arrives, or the call begins.
Camera
1. SD card formatted and confirmed with capacity for the full session
2. Battery fully charged or dummy battery connected to power supply
3. Resolution, frame rate, and picture profile settings confirmed
4. Face-detect autofocus enabled for single-subject interviews
5. Camera mounted and locked on tripod at subject’s eye level
Audio
6. Wireless microphone transmitter fully charged
7. Gain levels tested and set on camera or external recorder
8. 30-second test recording completed and played back — confirm clean audio, no echo or signal noise
9. Backup recording method armed if available
Lighting
10. Key light positioned at 45 degrees, slightly above eye level
11. No harsh shadows on subject’s face or neck
12. No flickering from mixed light sources or aging bulbs
13. Color temperature consistent across all light sources
Room and Environment
14. Phone on silent, all notifications disabled on every device in the space
15. Door closed; a notice placed outside if others are in the building
16. Air conditioning, fans, or noisy appliances turned off or redirected away from the mic
17. Audible ticking clocks and running appliances switched off
Software (Remote Interviews)
18. Recording platform confirmed open and tested
19. Both participants have completed audio and video checks
20. Backup recording enabled within the platform
21. Secondary device recording the call as a final safety net
Quick Post-Recording Steps
Immediately after the interview ends, complete these steps before closing any software or touching any files.
  • Back up first. Copy all files to a second location, such as an external drive or cloud storage, before reformatting cards or closing recording software. Files lost at this stage are not recoverable.
  • Label your clips. Use a consistent naming format: InterviewName_CameraAngle_Date_Take. This saves significant time during editing.
  • Note sync points. If you recorded separate audio to a dedicated recorder, mark the clap or sync point in your notes before you forget.
  • Log any issues. Note timestamps where noise occurred, a take was interrupted, or a restart happened. Your editor will not need to review the entire file to locate the problems.
The next step from here is post-production: syncing audio tracks, cutting the interview, and color grading your footage.
Can I record a video interview with just a smartphone?
Yes, but a few extra tools can improve your setup. An external wireless microphone is important for cleaner interview audio. Phone microphones often pick up too much background noise. Add a ring light or face a large window. Keep your phone at eye level while recording in landscape mode. You can also blur the background with portrait video. Good audio matters more than high camera resolution here.
What’s the best microphone for recording interview videos?
A wireless lavalier microphone is the standard choice because it stays consistently close to the speaker regardless of camera distance or how much the subject moves. For professional productions, the Hollyland LARK MAX 2 adds 32-bit Float internal recording and AI Noise Cancellation, delivering reliable broadcast-quality audio in both studio and real-world environments.
How do I record a video interview with someone in a different location?
Use a platform like Riverside or SquadCast that records local audio and video tracks on each participant’s device independently. This removes internet quality from the equation. Both participants record simultaneously on their own machines, and the files are synced in post-production. Avoid relying on Zoom’s stream recording for anything beyond internal or low-stakes content.
How much storage do I need to record a video interview?
4K video at 30fps consumes roughly 10 to 12 GB per hour depending on the codec. A one-hour session in 1080p requires approximately 3 to 4 GB. Always confirm SD card capacity and battery level before the session. If storage is limited, 1080p at 30fps is a reliable format that still delivers professional results.
Should I use one camera or two for a video interview?
A single camera can cover most basic interviews. It is also enough for remote interview sessions. Two cameras give you more framing choices during recording. They can show another angle or tighter shots. Editing becomes less flexible with just one camera. With two cameras, sync both before the interview starts. A simple clap can help match their timing. Check both cameras for similar exposure and color settings.
Audio quality and environment control determine your interview quality more than any camera upgrade will. Get those two right, and moderate gear produces professional results. The pre-recording checklist puts all these steps together. You can follow it before starting every interview session.
Once your footage is backed up and organized, the next step is post-production: syncing tracks, cutting the interview, and adding titles or graphics.
