How to Set Up a 2 Person Interview: Cameras, Audio, and Lighting Done Right
Filming one person is manageable. Filming two people well is a different challenge entirely. A two-person interview needs careful planning for every shot. Each person needs a clear eyeline and separate audio. Lighting also gets more complicated with two people. Camera settings must stay consistent between every cut. This guide shows you the full configuration, from how to physically position your subjects to how to capture clean audio from both simultaneously, in a format you can apply directly on your next shoot day.
Understanding the Core Challenge of a Two-Person Interview Setup
A single-person interview is simpler to set up. You only need to light one face and capture one voice. The camera also needs to frame one clear eyeline. Adding a second subject branches every element. You are now managing two audio channels that can bleed into each other, two faces at different angles that each need lighting attention, and a camera axis rule that is easy to break when repositioning between shots.
The complexity also shifts by format. A formal sit-down where neither subject moves is very different from a setup where the interviewer occasionally addresses the camera directly. This guide focuses on stationary or near-stationary, in-person, video-based setups, covering the most common use cases: YouTube interviews, branded content, corporate Q&As, and documentary-style conversations.
Getting it right requires treating the components as a system. The way you position subjects affects how you light them. Your lighting setup affects where you can place cameras. Camera placement also impacts how you manage the audio. Build each element with the others in mind, and the setup becomes repeatable on every shoot.
Positioning and Framing Two Subjects
Decide where the subject will sit before setting up the equipment. This choice becomes difficult to change once recording begins. A poor setup can limit camera and lighting adjustments.
1. Seat subjects at a 45 to 90-degree angle to each other, slightly angled inward toward the camera.
This creates a natural conversation posture without forcing either subject to turn their head to an uncomfortable extreme. A 45-degree formation reads as warm and open. Closer to 90 degrees creates more visual separation and suits formal interview contexts well.
2. Establish a clear eyeline for each subject and hold it.
The interviewee should look at the interviewer throughout. The interviewer can look at the interviewee or slightly off-camera toward the lens, depending on the format. Whichever you choose, keep it consistent. Eyeline shifts mid-interview read as errors in editing.
3. Keep subjects 2 to 4 feet apart.
This range gives enough physical separation for two independent lighting sources and two lavalier microphones without interference. It also keeps both faces visible in a comfortable two-shot at a standard focal length. Closer, and the setup becomes cramped; farther, and the conversation reads as disconnected on screen.
4. Establish and protect the 180-degree rule before placing any camera.
Imagine a line running between the two people. Keep every camera on one side. Crossing that line can reverse their positions on-screen. They may appear to switch sides during editing. Mark the line on the floor before placing equipment.
Visualizing the layout: Think of Subject A at the 10 o’clock position and Subject B at the 2 o’clock position, both angled toward 12 o’clock. The main camera sits at 12, and a secondary camera (if used) sits at 3 or 9, remaining on one side of the subject line.
Camera Setup: Single Camera vs. Dual Camera
The choice between one camera and two shapes how the interview is covered and edited. Here is how the approaches compare:
Factor
Single Camera
Dual Camera
Cost
Lower
Higher
Setup Time
Faster
Longer
Edit Flexibility
Limited
High
Simultaneous Reaction Coverage
No
Yes
Best For
Run-and-gun, beginner shoots
Professional or polished output
Key Limitation
Must reframe between speaker cuts
Must match camera settings carefully
Single-Camera Setup
A single camera works for budget-conscious productions, beginner videographers, or fast-turnaround shoots where simplicity matters more than editorial richness.
Position the camera slightly off-center, capturing both subjects in a clean two-shot. Because you cannot capture live reactions from both subjects at once, you will need to record B-roll reaction shots separately or accept the limitation in the edit.
Cutting between speakers requires a reframe or a subtle zoom cut, which takes skill to pull off cleanly. The limitation is real. You cannot recreate a missed reaction after the recording ends.
Dual-Camera Setup (Recommended for Interviews)
Two cameras are the professional standard for a reason. They give you continuous coverage of both subjects, edit-room flexibility, and a more dynamic final product.
  • Camera A captures a wide two-shot or an over-the-shoulder (OTS) angle from the interviewer’s side, serving as a master reference throughout the edit.
  • Camera B captures a medium close-up or OTS of the interviewee from their side.
Both cameras must stay on the same side of the 180-degree line. Before rolling, match color profiles, shutter speed, white balance, and ISO across both cameras. Even small exposure or color temperature mismatches become obvious in the edit when cutting between angles.
Set tripod height so the lens sits at or slightly below the seated subjects’ eye level. This produces a natural, non-intimidating interview perspective and avoids the distortion of shooting up at a chin or down at a scalp.
Microphone Setup for Two People: The Most Important Element
Audio failure is the most common and most damaging problem in a two-person interview. Lighting problems can often be fixed during editing. But bad or uneven audio is much harder to repair.
Microphone Setup for Two People: The Most Critical Element
Why shared microphones fail in two-person setups:
When two people share a single boom or clip-on microphone, the system is forced to compromise. The gain setting that works for a softer speaker will clip when the louder one jumps in. A boom positioned to favor one subject captures the other at an off-axis angle, introducing coloration and uneven levels. The result is audio that is difficult to balance and sounds unpolished regardless of how much work goes into it in post.
Lavalier mic placement best practices:
  • Clip the lavalier to the subject’s lapel or shirt approximately 6 to 8 inches below the chin, centered on the chest
  • Keep the capsule away from collar edges, jacket buttons, or jewelry that can cause rubbing noise
  • When hiding a mic under clothing, leave a small cable loop behind the clip to cushion movement without pulling the capsule
  • Check that fabric is not moving against the capsule before rolling
Wireless vs. wired lavs:
Wired lavs route cables back to the camera, creating tripping hazards, limiting subject movement, and cluttering the set. For a two-person interview, wireless lavs are the practical and professional choice.
Recommended Audio Solution: Hollyland LARK MAX 2
The Hollyland LARK MAX 2 is designed specifically for multi-person recording scenarios. Its dual-transmitter system gives each subject a dedicated wireless lavalier microphone, both transmitting to a single compact receiver that connects directly to your camera. That single-receiver design eliminates the need to sync two separate systems or manage multiple inputs.
Key features for two-person interviews:
  • 32-bit Float Internal Recording: Each transmitter stores a backup recording locally. If camera gain is wrong or a wireless dropout occurs, the audio is preserved on the transmitter at full quality.
  • AI Noise Cancellation: Ambient noise is filtered independently on both channels, which matters on location where background hum or room tone can undermine the recording.
  • Real-time OWS Earphone Wireless Monitoring: Low-latency monitoring lets the videographer or producer hear both channels live during the shoot, catching problems before they compound.
  • 48 kHz / 32-bit Float output: Studio-quality audio delivered to the camera, ready for post-production without additional processing.
Boom mic as a supplement:
A boom microphone can capture ambient room tone or B-roll audio, but it should not replace dedicated lavs as the primary source for the interview itself.
Gain staging for two subjects:
Before rolling, check audio levels with both subjects speaking at normal volume simultaneously. Set gain so the loudest subject peaks around -12 dBFS on your camera meter, leaving enough headroom to handle raised voices without clipping.
Lighting a Two-Person Interview
Lighting two subjects facing different directions requires treating each person as a semi-independent subject, then finding shared solutions for fill and background.
Step 1: Place a key light for each subject at roughly 45 degrees to their face.
Place each key light on the opposite side of its subject. Light Subject A from camera-left. Light Subject B from camera-right. This adds depth without the lights interfering with each other.
Step 2: Use one diffused fill light centered between the subjects.
Rather than running separate fill lights, a broad, soft source positioned centrally handles both faces at once while keeping the overall setup practical.
Step 3: Add a background light to separate subjects from the wall.
A single background light aimed at the set behind both subjects prevents the flat look of subjects visually merging with the background. Set it to roughly 50 to 70 percent of the key light intensity.
Step 4: Match color temperatures across all sources.
All lights should be the same temperature; either daylight (5600K) or tungsten (3200K). Mismatched sources cause one subject to appear visually warmer than the other, which reads as a technical error and is difficult to fully correct in post.
Avoiding cross-shadows:
The most common mistake is placing key lights so that one subject’s key casts a hard shadow across the other subject’s face. Fix this by using softboxes or diffusion panels, positioning keys slightly farther from the center than you would in a single-subject setup, and feathering the edges of each light so that spill falls away from the frame’s center.
Background and Set Design for a Two-Person Interview
The background behind both subjects must work as a complete visual environment, not two independent shot backings. Most rooms do not have two equally interesting sides, which makes intentional set dressing essential.
  • Symmetrical backgrounds suit formal, branded, or studio contexts well. A single backdrop, paper roll, or consistent wall color gives both subjects matching visual treatment with no additional dressing required.
  • Asymmetrical setups work if both sides contain intentional elements, such as bookshelves, plants, branded signage, or textured architectural features. Both sides should look considered, not accidental.
  • Build depth rather than flatness. Subjects placed directly against bare walls look flat. Introduce background elements at varying distances to create visual layers that read as depth on camera.
  • Dress both sides equally. A common problem is set dressing that focuses on the primary subject’s side, while the secondary subject’s background appears bare. Check both cameras before confirming the set is ready.
  • For controlled environments, portable backdrop panels or paper roll systems provide a fast, consistent solution that requires no further dressing.
Audio Monitoring and Recording Workflow
A simple workflow prevents audio problems from slipping through unnoticed until post-production.
  1. Record dual-channel audio to your camera, assigning one channel per subject, so each voice remains isolated for independent adjustment in the edit.
  2. Enable internal backup recording on your wireless mic system before the interview starts. The Hollyland LARK MAX 2 stores 32-bit Float backups on each transmitter automatically.
  3. Run a 30-second pre-roll test with both subjects speaking at normal conversational volume simultaneously. Confirm levels on both channels via the camera meter and monitoring headphones.
  4. Label your audio tracks before editing: Track 1 for the interviewer, Track 2 for the interviewee.
Quick Checklist: 2-Person Interview Setup Before You Hit Record
  • Subjects seated at a 45 to 90-degree angle, both visible in the frame
  • 180-degree line established and marked if needed
  • Camera A (wide two-shot or OTS) locked on tripod
  • Camera B (close-up or OTS of interviewee) locked on tripod
  • Both cameras matched: color profile, white balance, shutter speed, exposure
  • Lavalier mics clipped 6 to 8 inches below chin on each subject, levels checked
  • Wireless channels confirmed with no frequency interference
  • Backup recording enabled on each transmitter
  • Key lights for each subject set at 45 degrees, all color temperatures matched
  • Fill and background lights positioned and flagged if needed
  • Background dressed and checked through both camera viewfinders
  • 30-second audio and exposure test recorded and reviewed before the interview begins
Can I use one microphone for a two-person interview?
Technically possible with a centered boom or boundary microphone, but not recommended. A single-source setup has no independent volume control per subject, struggles with off-axis pickup from one speaker, and makes post-production audio balancing significantly harder. Dual wireless lavalier microphones are the professional standard for this scenario and the most reliable path to clean, usable audio.
How far apart should two interview subjects sit?
Two to four feet apart is the practical target. This keeps both subjects visible in a natural two-shot at standard focal lengths, provides enough physical space for independent lighting on each face, and reduces the chance of lavalier microphones capturing significant bleed from the adjacent subject’s channel.
Do I need two cameras for a 2-person interview setup?
Not strictly required, but dual cameras are strongly recommended. A second camera provides simultaneous coverage of both subjects’ genuine reactions, gives the editor considerably more flexibility in the cut, and is the standard for any interview intended to look polished. Single-camera setups work for tighter budgets or faster productions, but the limitations on coverage and edit options are real.
What camera angle works best for a two-person interview?
A wide two-shot at a 35 to 50mm equivalent works as the master angle. Tighter OTS angles at roughly 70 to 85mm work for individual close-ups. Keep all cameras on the same side of the 180-degree line. Avoid shooting up at subjects from below seat level, as this perspective distorts facial features and reads as unflattering on screen.
How do I prevent audio bleed between two wireless mics?
Clip lavalier capsules as far apart as the subjects’ positions naturally allow, and route each to its own independent channel. Use a wireless system with AI noise cancellation, such as the Hollyland LARK MAX 2, which filters ambient noise independently on each channel. Keep the subjects at least two feet apart for cleaner audio separation.
A strong two-person interview depends on four areas working together. These include positioning, camera placement, two-channel audio, and matched lighting. Each choice affects what you can do elsewhere. Treat the setup as one system from start to finish. This makes your results more consistent across different locations.
