How to Do a YouTube Interview: Step-by-Step from Setup to Upload
Interview-format videos are among the most watchable content on YouTube. They feel personal, transfer expertise directly to your audience, and scale well once you have a repeatable process. Most first interview videos go wrong before editing even starts. Bad audio, weird framing, or unprepared guests can ruin everything. This guide explains every stage, from gear selection to final upload, so your first interview actually holds attention.
What You Need Before You Start Filming
Before grabbing your camera, get your basic gear sorted first. Every interview setup needs a camera, microphone, and lighting. The goal is not broadcast-grade equipment but the minimum viable setup that produces a video you would watch yourself.
Camera
Any camera that shoots 1080p is sufficient for a YouTube interview. That includes a modern smartphone, an entry-level DSLR, or a mirrorless camera. Camera model matters far less than settings. Shoot in manual exposure so the image stays consistent throughout. Turn on continuous autofocus if your guest keeps moving around. On a smartphone, lock focus and exposure by tapping and holding on your subject before recording.
  • Smartphone: iPhone 12 or newer, like the iPhone 17, recent Android flagship
  • Entry-level DSLR: Canon Rebel series, Nikon D3500
  • Mirrorless: Sony ZV-E10, Fujifilm X-S10
  • Minimum spec: 1080p at 24fps or 30fps
Microphone: The Most Important Gear Decision
The built-in microphone on your camera is the single most common reason viewers stop watching an amateur interview. Camera mics pick up room echo, handling noise, and every rustle of clothing between you and your guest. In a two-person setup where both people need to be heard clearly, a dedicated microphone is not optional; it is the first piece of gear you should buy before upgrading anything else.
A wireless clip-on mic is the most practical solution for interviews. One transmitter clips to the guest’s lapel, one to yours, and a receiver connects to the camera’s audio input. The guest’s voice travels with the transmitter regardless of how much they shift in their seat or lean forward.
The Hollyland LARK MAX 2 is great for interview shoots. Its clip-on transmitters attach to each speaker within seconds. The 32-bit Float recording helps when guest energy suddenly changes. Someone might whisper, then suddenly get loud while talking. It keeps those volume changes from ruining your audio. You also get more room during post-production editing. AI Noise Cancellation helps reduce everyday background noise too. It helps control office AC, cafe, and outdoor location noises quite impressively. The OWS wireless earphone lets you monitor audio through one ear. This helps catch audio problems before they ruin your take. Plus, you can keep eye contact with your guest.
If budget is the primary constraint and you are filming on a smartphone, the Hollyland LARK A1 is a plug-and-play entry option. It connects directly to a phone without an adapter and produces clean, isolated audio that outperforms any built-in mic.
  • Professional two-person in-person interview: Hollyland LARK MAX 2
  • Smartphone-only, budget setup: Hollyland LARK A1
Lighting
Three-point lighting is a common setup for interviews. The key light sits 45 degrees from your subject. It acts as the main light for their face. A softer fill light goes on the opposite side. This helps reduce harsh shadows across their face. Finally, a backlight goes behind them for separation. It helps keep your guest separate from the background. You do not need all three to start. A large window providing soft, indirect natural light is free and consistently effective. Place your guest facing the window, not beside it. Avoid overhead fluorescents, which cast unflattering downward shadows. A single LED panel on a stand at 45 degrees above eye level is the most cost-effective upgrade when natural light is unavailable.
How to Set Up Your Interview Space
The physical arrangement of your space has a direct effect on how professional the final video looks. Follow these steps before your guest arrives.
  1. Set the camera at eye level. Position the lens at the height of your guest’s eyes, not above or below. High camera angles can make guests seem less confident. Low camera angles can make the framing feel accidental. Keep both shots steady with a tripod.
  2. Establish the eyeline. In an interview, the guest looks at the interviewer, not directly into the lens. Sit close enough to the camera that the guest’s eyeline is only slightly off-axis when looking at you. Too far off-axis and the guest will appear to be staring at empty space.
  3. Choose between one camera and two. A single camera is the right starting point for most new creators. Two cameras, one on the guest at a medium shot and one wider to capture both speakers or the interviewer’s reactions, make editing dramatically easier and give the final video a more polished feel. If you add a second camera, match the color profiles on both before you shoot.
  4. Seat your guest at an angle. The news-style interview positions the guest at roughly 30 to 45 degrees relative to the camera, not directly facing it. This removes the stiff, deposition-like quality of head-on framing and makes the conversation read as natural on screen.
  5. Choose and control your background. A blurred background achieved through a wide aperture such as f/1.8 works in almost any room. A contextual background such as a bookshelf or relevant workspace communicates a professional setting without distraction. Avoid plain white walls unless your lighting is precise enough to add depth.
  6. Place the mic correctly. Clip the lapel mic to your guest’s clothing at approximately chest height, 6 to 8 inches below the chin. Route the cable under clothing when possible and avoid necklines or lapels with loose fabric that contacts the mic capsule.
Pro Tip: Before your guest arrives, sit in their chair and check the camera framing, audio levels, and lighting on your own face. Adjustments are far faster when you are not asking a guest to wait.
How to Prepare for the Interview
Your camera quality depends heavily on your preparation beforehand. Good planning can save you from major problems later. This is where most interviews are won or lost.
Research Your Guest
Spend 20 to 30 minutes researching your guest before writing a single question. Listen to or read at least one other interview they have done. Your goal is to find an angle relevant to your specific audience, not the talking points your guest has repeated on every other platform. Familiar stories lose attention quickly. Find the gap between what your audience wants to know and what the guest has not yet said publicly.
Write Questions That Generate Quotable Answers
Question format determines answer quality. Use these principles for every interview you write.
  1. Use open-ended questions. “What made you leave your corporate job?” produces a story. “Did you enjoy your corporate job?” produces a yes or a no.
  2. Lead with “Tell me about a time when…” This question triggers narrative. People do not naturally speak in stories unless invited to, and story-driven answers are far easier to edit for pacing than fragmented explanations.
  3. Prepare two follow-ups per main question. A guest may answer more briefly than expected, or their answer may open a more interesting angle. Useful defaults: “What happened next?” and “How did that change how you approach it now?”
  4. Avoid questions that put guests on the defensive. Reframe criticism-style questions. Instead of “Why did your company fail?” try “What would you approach differently now?” Guests rarely give usable answers when they feel cornered on camera.
  5. Write 10 to 15 questions and plan to ask 6 to 8. Extra questions give you flexibility; asking fewer keeps the energy focused and the runtime manageable.
Brief Your Guest Before You Hit Record
Send your guest 4 to 6 questions 24 to 48 hours before filming. Not all of your questions, as you want room for organic follow-up moments, but enough that they are not improvising on unfamiliar topics on camera. Confirm three things before the interview starts. Ask about the interview length and any off-limits topics. Also explain the overall tone of your channel. Guests feel more comfortable when they know the show's vibe.
How to Film the Interview
Follow this sequence on shoot day to run a clean, low-stress recording session.
  1. Run your audio check before any conversation starts. Clip the LARK MAX 2 TX units to both speakers.
Confirm levels through the wireless monitoring earphones before the guest is warmed up and waiting. Solve any technical issues with no camera rolling and no time pressure.
  1. Record 10 seconds of silence. Ask your guest not to speak immediately after you hit record. This captures the room’s noise floor as a reference for noise reduction later in post.
  2. Start with a warm-up question, off the record. Ask something easy and unrelated to the interview, such as how their morning was. Getting the guest speaking naturally before the recorded session begins loosens the conversation noticeably.
  3. Remind your guest to look at you, not the lens. Say it directly before your first official question: “Talk to me, not the camera.” This single instruction prevents the glazed, presentation-mode look that makes interview subjects appear uncomfortable on screen.
  4. Let silences sit. The most common interviewer mistake is filling pauses the moment a guest stops speaking. Wait two full seconds before responding or moving to the next question. Guests frequently deliver their most interesting or honest line in that pause once they realize you are not jumping in.
  5. Flag your best moments live. When a guest says something particularly strong, clap once or tap the desk. That transient appears as a visible spike in the audio waveform when you open the file later, making strong moments fast to locate during editing.
  6. Shoot B-roll after the main interview finishes. Capture close-up shots of hands, relevant objects mentioned, and the surrounding setting. Aim for at least 5 to 8 minutes of B-roll footage. You will use more of it in the edit than you expect.
How to Edit a YouTube Interview
Interview editing is not a general editing tutorial. The goal is to compress a full conversation into a version that holds attention from start to finish. Here is the workflow in order.
  1. Lay down the full audio track first. Import your interview audio and mark sections that are unusable: long tangents, repeated stumbles, or anything with technical problems.
  2. Build a story arc. Even informational interviews need some basic structure. Start by introducing the guest and explaining why the topic matters. Then move into the main section with useful information. Finish by giving viewers a clear and useful takeaway. Select and arrange clips around that arc, not the original order of conversation.
  3. Cut aggressively. Every sentence should earn its place. If a clip does not add new information, emotion, or necessary context, remove it. Tighter edits hold attention; extended segments lose it.
  4. Use J-cuts and L-cuts between angles. A J-cut starts the audio of the next clip slightly before the visual cuts to it. An L-cut holds the current visual while the audio transitions. Both techniques make the conversation flow naturally rather than feeling choppy when cutting between the interviewer and guest.
  5. Place B-roll over jump cuts. When you cut within a single person’s continuous speech, a jump cut creates a visible visual jolt. A B-roll clip placed over the cut hides the edit while the audio continues without interruption.
  6. Normalize audio levels. Target approximately -14 LUFS for YouTube. If you recorded with the LARK MAX 2’s 32-bit Float feature, you will have no clipped peaks to recover. The full dynamic range is preserved in the file, which simplifies this step considerably.
  7. Add captions or subtitles. Captions increase watch time and make the video accessible to viewers who watch without sound. Review auto-generated captions for accuracy before you export.
  8. Color grade both angles to match. If you used two cameras, grade them to a consistent look before export. Mismatched color between angles reads as amateur even to viewers who cannot explain why.
Optimizing Your YouTube Interview for Search and Click-Through
  • Title structure: Lead with the guest’s name if they are recognizable to your audience, followed by the specific outcome or topic: “[Guest Name] on [Specific Result or Claim].” Vague titles such as “Interview with Marketing Expert” give viewers no reason to click. Specific titles such as “Sarah Chen on Growing a Service Business to $1M Without Paid Ads” deliver a clear promise before the viewer decides whether to watch.
  • Thumbnail: Pick a frame where your guest shows a natural reaction. Look for curiosity, laughter, excitement, or strong emotion. Posed smiles underperform for interview-format content. Add a maximum of 2 to 3 words of text overlay and avoid repeating language from the title.
  • Description: Give viewers a quick 150-word recap of what they learned. Skip generic lines that just describe what happens in the videos. Open with one or two sentences that echo the title’s promise and include the guest’s name, role, and any links they requested.
  • Chapter timestamps: Add timestamps every 3 to 4 minutes using the format “0:00 Intro.” Timestamps reduce audience drop-off by letting viewers jump to relevant sections and improve the video’s chances of earning a featured snippet in search results.
  • Pin a comment with timestamps: Within the first 30 minutes of publishing, post a comment listing your top 3 to 5 timestamps. This lifts early engagement and provides indexable context for YouTube’s algorithm.
Tips for Remote YouTube Interviews
Many creators interview guests who are in a different city or country entirely. Remote interviews can still look great on YouTube. Just make sure everyone has their own microphone. Relying on laptop mics can seriously hurt your audio quality. Once that happens, fixing it later gets pretty tough.
For remote recording, use a platform designed to capture separate audio and video tracks locally from each participant. Riverside, SquadCast, and Zencastr all upload clean individual files rather than compressing a video call stream, which eliminates the quality degradation you get from screen-recording a Zoom session.
Remote interviews need decent audio gear on both ends. Each person should wear a clip-on wireless mic while recording. This usually sounds much cleaner than laptop or headset mics. It also keeps everyone's voice sounding more consistent throughout the session. For your end of the call, the LARK MAX 2 connected to your recording device delivers the same clean, isolated track you would capture on a physical set.
Q: What’s the minimum equipment needed to film a YouTube interview?
A smartphone or entry-level DSLR, a clip-on wireless microphone for each speaker, and a single LED panel or reliable natural light source cover everything you need to start. Prioritize audio quality over camera resolution. People may forgive average video quality sometimes. But bad audio can make them leave within a few seconds.
Q: Should both people in an interview use a microphone?
Yes. A single boom or camera mic captures both speakers unevenly and picks up ambient noise from the space between them. Each person needs their own lapel mic to produce clean, isolated audio tracks. Isolated tracks are far easier to balance, noise-reduce, and adjust independently during the edit.
Q: How long should a YouTube interview be?
Interview-format channels generally retain engaged audiences best in the 18 to 35-minute range. Shorter cuts of 8 to 15 minutes work well for highly edited highlight versions. Avoid publishing unedited full-length sessions unless your audience has specifically asked for that format. But this is not a common demand.
Q: How do I get good answers from a nervous or low-energy guest?
Ask your first big question before turning the camera on. Then ask that same question again once recording starts. The first answer helps guests get comfortable talking. Their second answer usually sounds much more natural.
Q: Can I film an interview with just one camera?
Yes, and it is the right starting point for most new creators. One camera works well when paired with a solid B-roll library to cover your edits. Two cameras make the editing process notably easier and add dynamic energy to the final video. If you start with one, shoot from a slightly angled position rather than straight on.
Good preparation eliminates most filming problems. Clean audio saves you from many editing headaches later. Strong editing also helps keep viewers watching longer. Your workflow matters much more than having fancy gear. Therefore, start with a reliable mic and simple interview preparation. Know what you want before you start filming. Then publish your first interview and improve each time.
