The split screen interview format is one of the most engaging content styles on Instagram right now. Whether you’re chatting with brands, experts, or podcast guests, this works. Putting two faces together makes your content feel more conversational. It also gives your Reel a more professional vibe. The challenge is knowing which method to use and how to pull it off cleanly. This guide covers all three approaches from start to finish.
What Is a Split Screen Instagram Interview?
A split screen Instagram interview is a video format that places two speakers side by side in a single frame. Instagram supports this natively during a Live session when you invite a guest, creating an automatic vertical split in real time.
Alternatively, you can build the effect in post-production using a mobile editing app like CapCut or iMovie and upload it as a Reel. A third path is remote recording, where each person captures their own footage separately, and an editor combines both clips afterward.
Each method has its own disadvantages, so choosing the right one depends on your production goals.
Method 1: Use Instagram Live to Go Live with a Guest
Instagram’s native Live feature is the fastest way to get a split screen interview running. When you go live and invite a guest, Instagram automatically divides the screen into two vertical panels. Your audiences merge, both sides can comment in real time, and no editing is required. The downside is that everything happens live and unscripted. Both people also need Instagram open at once. That can make scheduling the conversation a little harder.
How to Invite a Guest to Your Instagram Live
Open the Instagram app and tap the + icon, or swipe right to open the camera.
Select Live from the bottom menu options.
Add a title for your broadcast to label the interview, then tap Go Live (Round button).
Once you are live, tap the camera icon with the plus (+) sign. This Rooms icon appears at the bottom of the screen. It opens the guest panel.
Search for your guest’s username or select them from the list of current viewers if they are already watching.
Tap Request to send your guest an invite.
Once your guest accepts, Instagram automatically splits the screen vertically and places both speakers in separate panels.
To remove the guest without ending your broadcast, tap their panel and select Remove Guest.
Note: Your guest must be on Instagram and actively watching your Live to receive the invite. Coordinate beforehand so they join the broadcast before you send the request.
Saving and Repurposing Your Instagram Live Interview
Live broadcasts disappear after they end unless you save them manually. Here is how to preserve and repurpose the content:
Tap End when finished, then select Download Video before dismissing the end screen. Instagram saves the broadcast to your camera roll.
Trim the video inside Instagram’s Reel editor or in a third-party app before sharing it as a Reel.
Clip the strongest 60 to 90 seconds from the broadcast and post it as a standalone Reel with captions.
Add lower-third name labels in CapCut after the fact to give the repurposed clip a more polished finish.
The Live collab method works best for spontaneous conversations, community Q&As, and real-time brand partnerships where authenticity matters more than production value.
Method 2: Create a Pre-Recorded Split Screen Interview for Reels
If you want full editorial control over pacing, framing, and audio quality, the pre-recorded method is the right choice. Each speaker records their own footage separately, and you combine both clips into a split screen layout before uploading as a Reel. This takes more time but delivers consistently polished results.
Step 1: Record Each Speaker Individually
Before editing anything, you need clean individual recordings from both speakers. Get these details right, and the assembly step becomes straightforward.
Record vertically in 9:16. Set your phone to portrait mode, or film in landscape and plan to crop. Each speaker’s panel will occupy half of the final 1080x1920 frame.
Consistent framing. Position each speaker at the same horizontal level in their frame with similar amounts of headroom. Mismatched framing is one of the fastest ways to make a split screen look unfinished.
Match eyeline direction. If one speaker looks slightly left, the other should look slightly right. This creates implied eye contact between the two panels and makes the conversation feel natural.
Keep backgrounds minimal. A plain wall, a tidy bookshelf, or a simple home office works well. Busy backgrounds compete for attention.
Consistent lighting. A ring light or a window with natural light facing the speaker works for most setups. Mismatched lighting between the two panels breaks visual cohesion immediately.
Record in a quiet space. Background noise compounds when you layer two audio tracks together in post.
Step 2: Build the Split Screen in CapCut (or iMovie)
CapCut is the most accessible option for this workflow and includes dedicated split screen templates. Here is how to set it up:
Open CapCut and tap New video.
Select the first speaker’s clip and tap Add.
In the timeline, tap Overlay, then tap the Add Overlay option, and import the second speaker’s clip.
Resize and reposition both clips until they sit side by side, each occupying roughly half the 9:16 canvas.
Alternatively, tap Templates, search “split screen,” and drop your clips directly into a pre-built two-panel layout.
Align both clips on the timeline so the conversation stays in sync. Use the audio waveforms as your guide, especially if the clips started recording at different moments.
Mute one audio track if needed and adjust the second track’s volume to balance both voices at a similar level.
Add a thin divider line or shape graphic between the two panels using the Sticker tool for a more intentional visual finish.
Use the Text tool and then select the Add text option to add lower-third name labels for each speaker.
For side-by-side split videos, CapCut and VN Video Editor give more control. iMovie works better for picture-in-picture videos. VN Video Editor is great when timeline control needs more precision. It also helps when your edit has multiple audio tracks.
Step 3: Export and Post as an Instagram Reel
Once your split screen is assembled and audio is balanced, export at 1080x1920 pixels (9:16 aspect ratio) at a minimum of 30 frames per second. CapCut defaults to this setting for portrait projects, so no manual adjustment is usually needed.
Before uploading, choose a cover frame that shows both speakers clearly, write a caption that teases the topic of the conversation, and tag your guest using Instagram’s Collab feature if you want the Reel to appear on both accounts at the same time.
Method 3: Record Remotely, Then Edit Together
When your guest is in a different location, neither an in-person shoot nor an Instagram Live may be practical. Remote recording captures each speaker’s video and audio locally on their own device, resulting in higher quality than screen-recorded video call footage.
Recommended tools for remote split screen interviews:
Riverside: Records each participant locally in up to 4K video and 48kHz audio with fully separate tracks per speaker. This is the strongest choice for professional-grade interview content.
Squadcast: Similar to Riverside, with an audio-first focus and reliable video support for podcasters.
Zoom (local recording): A workable budget option. Ask both participants to record locally rather than using Zoom’s cloud recording, which compresses quality significantly.
Once you have both video files, follow the Method 2 CapCut workflow to build the split screen layout and sync the audio tracks. Because each person’s footage is captured at the highest quality their setup allows, you have the most editing flexibility in post compared to the other two methods.
Audio Setup: The Part Most Creators Get Wrong
A polished split screen can still lose viewers with bad audio. Two audio problems often pop up during creator interviews. Built-in mics can pick up room noise and echo. Different recording spaces can also create uneven speaker volume. The same happens when speakers record at different times.
For the pre-recorded and remote methods, the most practical fix is a dedicated wireless lavalier microphone for each speaker. The Hollyland LARK MAX 2 is built for exactly this use case. Its 32-bit Float Internal Recording captures audio directly on the transmitter, so if there is any dropout during the recording session, the local backup remains clean and intact. Its AI Noise Cancellation isolates the speaker’s voice from ambient sound, even in environments you have not fully controlled, like a home office or a location shoot. For an interview format where two audio tracks need to be mixed together cleanly in post, starting with isolated, noise-free recordings from each speaker makes a meaningful difference in the final result.
For solo creators shooting interview-style content entirely on a smartphone, the Hollyland LARK M2 is a lighter option at just 9 grams, with a clip-on form factor and up to 40 hours of battery life. It connects directly to mobile without extra recording gear, keeping the setup simple for on-the-go recording.
Audio sync checklist for split screen interviews:
Have both speakers clap once on camera at the start of each recording. This creates a visible and audible sync point when aligning clips in your editor.
In CapCut, zoom into the timeline and align both audio waveforms at the shared clap point.
Set both tracks to similar volume levels and check with headphones, not just device speakers.
If you are adding background music, keep it well beneath the voice tracks.
Listen through the full edit before exporting to catch any moments where audio drifts out of sync.
Quick Tips for a Professional-Looking Split Screen Interview
Match headroom and frame height across both panels so both speakers appear at the same scale within their respective frames.
Use consistent lighting for both speakers. A ring light or window light facing the speaker works in most home setups.
Keep backgrounds minimal and uncluttered. Matching backgrounds, such as both speakers using a plain wall, feel intentional rather than accidental.
Add a divider element between the panels in CapCut using a shape or line graphic for a more finished look.
Include lower-third name labels for both speakers to add clarity and a professional format cue for first-time viewers.
Keep interview Reels between 60 and 90 seconds. That duration maintains retention for conversation-format content better than longer clips.
Use the Instagram Collab feature to post the Reel on both accounts simultaneously for expanded organic reach without extra promotion effort.
Q: Can you do a split screen on Instagram without going live?
Yes. Create a pre-recorded split screen video using a mobile editing app like CapCut or iMovie and upload it directly as a Reel. Instagram’s built-in editor does not support split screen creation for pre-recorded content, so a third-party app is necessary for any non-live split screen format.
Q: What’s the best app for split screen Instagram interviews?
CapCut is the most beginner-friendly option, with a dedicated split screen template that places your clips directly into a two-panel layout. VN Video Editor is a better choice for creators who need more precise timeline control or are managing multiple audio tracks in a complex interview edit.
Q: How do I sync audio from two different speakers in a split screen video?
Start each recording with a shared clap or countdown that appears visibly in both clips. In CapCut, zoom into the timeline and align both audio waveforms at that clap point. This makes finding the exact sync moment fast and accurate, even when the two clips were recorded separately.
Q: Does Instagram have a built-in split screen feature for pre-recorded videos?
No. Instagram’s in-app editor does not include a split screen function for pre-recorded uploads. To create a split screen Reel, build the layout in a third-party app like CapCut, iMovie, or VN Video Editor, then upload the finished video file to Instagram.
Q: What video dimensions should I use for a split screen Instagram interview?
Export at 1080x1920 pixels in a 9:16 portrait ratio for Reels. In a standard side-by-side layout, each speaker’s panel will occupy approximately 540x960 pixels of the total frame.
Want a quick collab? Instagram Live with a guest is easiest. For polished Reels, record everyone separately and edit clips. CapCut lets you combine those clips with more control. Got guests elsewhere? Riverside.fm can record cleaner source files. Pick whichever setup matches your usual content creation routine. Just make sure your audio sounds clean and clear. Good audio can make split screen interviews feel more professional. Before filming, test your CapCut split screen setup first.
