How to Put Audio Over an Image (4 Easy Methods for Any Device)
Need to combine a still image with an audio track? Whether you’re creating a podcast cover video, a lyric clip, or a simple YouTube upload with a static visual, the process is straightforward once you know the right tool. This guide covers four methods: CapCut, browser-based tools, built-in OS apps, and professional software. Pick the one that fits your device and get it done in minutes.
What Does “Putting Audio Over an Image” Actually Create?
The output is a standard video file (MP4 or MOV) where a still image fills the entire visual layer while your audio plays underneath it. Think of it as a video where nothing on screen moves: just your photo or artwork paired with music, a voiceover, or any audio track. Common use cases include YouTube uploads, Instagram Reels, TikTok posts, podcast cover videos, and lyric clips. If that’s what you’re trying to make, you’re in the right place.
Quick Comparison — Which Tool Should You Use?
Tool
Platform
Free?
Best For
CapCut
Mobile (iOS/Android) + Desktop
Yes
Fast results, social media exports
Kapwing / Canva / Clideo
Web (any browser)
Free tier available
No-install, browser-only workflow
iMovie
Mac + iPhone
Yes (built-in)
Apple users, no download needed
Clipchamp
Windows 10/11
Yes (built-in)
Windows users, no download needed
Adobe Premiere / DaVinci Resolve
Desktop (Mac + Windows)
DaVinci is free
Professional output, advanced specs
Method 1 — CapCut (Best for Mobile and Desktop)
CapCut is the most widely used free option for this task. It runs on iOS, Android, and desktop, and no account is required for basic exports. The steps below cover the mobile version; the desktop app follows the same structure with a larger interface.
Steps (Mobile — iOS and Android):
  1. Open CapCut and tap New Video.
  2. Select your image from the gallery and tap Add.
  3. Tap the image clip in the timeline and drag the right edge to extend its duration to match your audio length.
  4. Tap Add Audio at the bottom of the screen, then choose Sounds, My Music, or Import to bring in your audio file (MP3 or WAV both work).
  5. Tap the audio clip to trim or adjust its start point so it aligns with the image clip.
  6. Tap the back arrow to return to the main editing view, then tap Export in the top-right corner.
  7. Select your resolution and frame rate, then save the file as MP4.
Steps (Desktop App):
  1. Open CapCut Desktop and click New Project.
  2. Import your image and drag it to the video timeline.
  3. Import your audio file and drag it to the audio track below the video track.
  4. Drag the right edge of the image clip to extend it until it matches the audio length.
  5. Click Export, choose your resolution and format, and save.
Note: Before exporting, check the aspect ratio in canvas settings. Use 9:16 for TikTok and Instagram Reels, 1:1 for feed posts, or 16:9 for YouTube.
Tips for CapCut Export Quality
  • Set resolution to 1080p for the best balance of quality and file size.
  • Sign in to a free CapCut account to remove the watermark from your export.
  • Use an MP3 or WAV source file; CapCut handles both cleanly and preserves audio quality on export.
Method 2 — Online Tools (No Download Required)
If you’d rather skip any installation, browser-based tools get the job done well. Kapwing is the strongest free option: it supports a wide range of file formats, lets you export without a watermark for smaller projects, and works on any browser without an account to start.
Steps with Kapwing:
  1. Go to kapwing.com and click New Project.
  2. Click Upload and import your image file (JPG or PNG).
  3. Click Upload and import your Audio, and upload your audio file (MP3 or WAV).
  4. Drag the right edge of the image clip in the timeline to match the length of your audio track.
  5. Set your canvas size using the presets for the platform you’re targeting.
  6. Click Export Project and download the finished MP4.
Free plan note: Kapwing adds a small watermark on free-tier exports for longer projects. Signing in with a Google account removes the watermark for most standard-length videos.
Alternative browser tools:
  • Canva: Create a new video project, upload your image as the background, add your audio file via the Audio tab, and export as MP4. A good fit for creators already using Canva for graphics.
  • Clideo: Upload your image and audio at clideo.com, set the duration, and export. The feature set is minimal but the process is very fast for a single-clip project. Free tier includes a watermark.
Method 3 — iMovie (Mac and iPhone)
iMovie is included on every Mac and is available as a free download for iPhone. It produces clean MP4 and MOV exports and is the obvious choice if you’re already in the Apple ecosystem and don’t want to install anything new.
Steps on Mac:
  1. Open iMovie and click Create New, then select Movie.
  2. Click the Import button or drag your image file into the media browser.
  3. Drag the image to the timeline and extend its duration by dragging the right edge of the clip.
  4. Import your audio file the same way, then drag it to the audio track beneath the image in the timeline.
  5. Trim either clip so both endpoints align cleanly.
  6. Go to File > Share > File and export as MP4 or MOV at your preferred resolution.
On iPhone: The native Photos app does not support layering audio over a still image. Download the free iMovie app from the App Store instead. The workflow mirrors the Mac version: create a new project, add the image, extend the duration, and import your audio from the Files app.
Windows Alternative — Clipchamp (Built into Windows 11)
Windows users have a built-in equivalent. Clipchamp comes pre-installed on Windows 11 and is available as a free download for Windows 10.
  1. Open Clipchamp and click Create a new video.
  2. Use the Import media button to bring in your image and audio files.
  3. Drag the image to the video track and the audio to the audio track in the timeline.
  4. Extend the image clip to match the audio length, then click Export and choose 1080p MP4.
Method 4 — Adobe Premiere Pro / DaVinci Resolve (Professional)
If you already work in professional editing software, the workflow is straightforward. This is not a full tutorial: it’s a quick reference for users who just need the steps confirmed.
Adobe Premiere Pro: Create a new sequence, import your image and audio into the Project panel, drag the image onto the V1 video track, and drag the audio onto the A1 audio track. Right-click the image clip, select Speed/Duration, and enter the length of your audio. Export via File > Export > Media as H.264 MP4.
DaVinci Resolve (free): Open the Edit page, import both files into the Media Pool, drag the image to Video 1 and the audio to Audio 1. Extend the image clip to match. Use the Deliver page to output as MP4.
DaVinci Resolve is worth noting for any project that needs color grading, multi-track audio, or broadcast-spec output, and it costs nothing to download.
Start with Clean Audio — It Makes Every Method Work Better
If the audio you’re placing over the image is a recording: a voiceover, narration, or podcast segment, the final video quality depends almost entirely on the quality of that source file. Distorted, noisy, or clipped audio cannot be repaired in CapCut or Kapwing after the fact. Recording in a quiet space with a reliable microphone solves the problem before it starts. For creators recording narration or on-the-go voiceovers, a compact wireless microphone like the Hollyland LARK M2 captures clean, broadcast-ready audio without adding complexity to your setup.
Can I put audio over an image on iPhone without an app?
Not with the native Photos app, which doesn’t support audio layering over a still image. Your best no-cost option is the free iMovie app on the App Store, which handles this in a few steps. If you prefer something more social-media-focused, CapCut for iOS is an equally fast alternative and free to use.
Why does my video have no sound after export?
The most common causes are: the audio track was accidentally muted in the timeline, you exported in a format that doesn’t carry the audio codec, or the platform you uploaded to stripped the audio during processing. Confirm your export format is MP4 (H.264) with AAC audio, and check that the audio track is not muted before you export.
What’s the best format to export?
MP4 with H.264 video and AAC audio is the safest choice for universal compatibility across YouTube, Instagram, TikTok, and most other platforms. MOV works well if you’re staying within the Apple ecosystem. Avoid AVI or WMV unless a specific platform explicitly requires them.
Can I do this with FFmpeg?
Yes. If you’re comfortable with the command line, this single command handles the task:
ffmpeg -loop 1 -i image.jpg -i audio.mp3 -shortest -c:v libx264 -c:a aac output.mp4
The -loop 1 flag keeps the image static for the full duration, and -shortest ends the video when the audio finishes. The output is clean and watermark-free.
How do I make the image last exactly as long as the audio?
In most tools, drag the right edge of the image clip in the timeline until it aligns with the end of the audio clip. Zoom into the timeline for more precise control. Kapwing and Canva also offer an auto-match option that snaps the image clip length to the audio duration automatically.
CapCut is the fastest starting point for most people: free, works on mobile and desktop, and exports in minutes. Browser tools like Kapwing work well when you need zero installation. Mac users can rely on iMovie; Windows users have Clipchamp built in. For professional output, DaVinci Resolve is free and fully capable. Pick the method that matches your device and workflow. Once you’ve got your video, see our guide to recording a clean voiceover to level up your next project.
