Ever spend time editing a video, only to find a giant logo slapped on it at the very end? Too many free video editors pull that trick. If that has happened to you before, this guide helps you skip the surprises and find the right option faster. Below are the best verified free tools for adding audio to video without a watermark, organized by platform, as well as a step-by-step walkthrough using the top-ranked desktop option.
Why Free Video Tools Add Watermarks And What to Look For
Many video editing apps let you start for free but charge for extra options. Some also place a watermark on exported videos unless you pay. Other free and open-source editors save videos without adding any watermark. Every tool in this guide has been checked to confirm clean exports on its free version. Some still ask you to create a free account or limit video size and resolution. Review those limits before choosing an editor.
Best Free Desktop Software to Add Audio to Video (No Watermark)
Desktop software gives you the most control and the most predictable results. These three options are all confirmed watermark-free with no subscription required.
DaVinci Resolve: Best Overall Free Option
DaVinci Resolve is the strongest free desktop editor available, and it does not add a watermark to exports at any point. The free version is not a trial or a stripped-down lite edition. It is the same software used by professional colorists and editors worldwide, offered free by Blackmagic Design as a long-term strategy to build an industry user base.
Platform: Windows, Mac, Linux
Watermark status: Confirmed no watermark
Full timeline editor with complete multi-track audio support
Import MP3, WAV, and AAC files directly onto a dedicated audio track
Export as MP4, MOV, or other formats at full resolution with no restriction - Includes volume keyframing, audio normalization, and basic EQ tools
Large download (around 3-4 GB) and requires a capable computer
Interface has a steeper learning curve than simpler tools
Overkill if you only need a one-time quick audio merge
Best for: Anyone who wants the cleanest result and does not mind spending 30 minutes learning the basics.
Shotcut: Best Lightweight Desktop Option
Shotcut is an open-source editor that requires no registration and adds no watermark at any stage. It runs on significantly fewer system resources than DaVinci Resolve, making it the smarter choice if your computer struggles with heavier software.
Watermark status: Confirmed no watermark (open-source)
Available as a portable app on Windows — no installation required
Supports drag-and-drop audio and video import
Simple timeline for placing an audio track beneath your video clip
Actively maintained with regular updates
Interface feels dated compared to newer editors
Smaller support community than DaVinci Resolve
Fewer built-in export presets
Best for: Users with older or lower-spec computers who need a clean audio merge without the overhead.
iMovie: Best for Mac and iPhone Users
iMovie comes pre-installed on all Mac computers and iPhones at no cost. It exports at up to 4K resolution without any watermark. Apple does not restrict the export quality on the free version, and no account creation is required.
Platform: Mac and iPhone only
Already installed on your device — zero download time
Simple drag-and-drop audio placement on a visual timeline
Clean 4K export with no account or activation needed
Projects sync between iPhone and Mac via iCloud
Apple ecosystem only — no Windows or Android support
Limited advanced audio controls compared to DaVinci Resolve
Projects are not easily portable to other editing software
Best for: Mac and iPhone users who want the fastest, simplest setup with zero configuration.
Best Online Tools to Add Audio to Video Without a Watermark
Online editors let you add audio without downloading any software. They are a good choice for quick projects or shared computers. Free versions often restrict the largest file you can upload or the highest video resolution you can export.
Kapwing: Best Browser-Based Editor
Kapwing is the best-verified browser option for watermark-free exports when you get its paid version.
Platform: Browser (any device)
Watermark status: Watermark-free with a paid account
Clean, modern interface with an audio-on-video timeline that is easy to follow
Supports uploading background music, custom audio files, or sound effects
Well-suited for short social media clips (YouTube Shorts, Reels, TikTok)
No software installation required
Free tier caps exports at 720p resolution
Projects over certain file size or duration thresholds may require an upgrade
Requires a stable internet connection throughout the session
Best for: Quick browser-based audio merges for social media, especially when working on a shared or restricted device.
Clideo: An EasyAudio Merge Tool
Clideo includes a simple Add Music to Video tool. The free plan places a watermark on exports. Removing it requires upgrading to a paid plan. Kapwing also adds watermarks to its free version exports. Clideo still helps with conversion and compression tools separately.
Watermark status: Yes
No download required - it works fully in your device's browser.
Clean and beginner-friendly layout.
Supports common audio and video formats.
Affordable paid plan.
Free account includes a watermark.
Not ideal for multi-track editing.
Slow and lagging when large files are uploaded.
Best for: Users comfortable with the free-tier watermark for non-public use, or those planning to upgrade.
FlexClip: Good for Simple Edits
FlexClip allows basic audio and video merging with a clean interface. It is more transparent than many competitors about its free-tier limitations, disclosing restrictions before you begin editing rather than at the export stage. The free tier does include some branding and resolution caps, so review current export terms before starting your project.
Platform: Browser
Straightforward interface with multiple audio import options (upload, record, stock library)
Honest about limitations upfront, which saves wasted editing time
Free-tier restrictions subject to change
Not as strong as Kapwing for audio-specific merging tasks
Best for: Simple one-off edits where you want more than a basic merge tool but are not installing software.
Best Mobile Apps to Add Audio to Video Without a Watermark
Mobile apps handle audio merges quickly and intuitively, especially for creators already working entirely from their phones. These two options are the most reliable on iOS and Android.
CapCut: Best Free Mobile App (No Watermark)
CapCut is the top recommendation for mobile users. The free version may add a watermark when you use Pro templates or premium assets. You can still add background music, upload your own audio files, or record a voiceover directly inside the app.
Platform: iOS and Android
Watermark status: No watermark in most regions (verify before finalizing your export). Contrarily, there is a watermark clip added to the video when you import it into the timeline. But it can be removed by selecting that specific watermark clip and deleting it.
Large built-in library of royalty-free music and sound effects
Import any audio file from your device storage onto the timeline
Record voiceover directly within the editor
Supports multiple simultaneous audio tracks
Active updates and a large tutorial community
Watermark behavior can vary by region and TOS update
Some advanced features (AI tools, premium sound packs) require a subscription
Availability has faced regional restrictions in certain markets
Best for: Mobile-first creators who want a capable editor with a no-watermark export at no cost.
InShot: Solid Alternative
InShot is a popular mobile editor with a clean interface built specifically for social media content. The free tier is functional for basic audio overlays, but watermarks appear on some exports in the free version. Full watermark-free access requires either a one-time purchase or a subscription.
Watermark status: Free tier includes a watermark on some exports
Fast and intuitive for simple audio overlays and trimming
Good aspect ratio presets for Instagram, TikTok, and YouTube Shorts
Watermark present on free exports in many configurations
Less capable than CapCut for multi-track audio editing
Full access requires a paid plan
Best for: Users who want a backup mobile option and are comfortable purchasing the one-time upgrade.
Quick Comparison: Add Audio to Video Without a Watermark
Tool |
Platform |
Watermark-Free |
Best For |
Difficulty |
DaVinci Resolve |
Win/Mac/Linux |
Yes |
Quality edits |
Moderate |
Shotcut |
Win/Mac/Linux |
Yes |
Lightweight tasks |
Easy–Moderate |
iMovie |
Mac/iPhone |
Yes |
Apple users |
Easy |
Kapwing |
Browser |
Yes (with free account) |
Quick online edits |
Easy |
CapCut |
iOS/Android |
Yes (most regions) |
Mobile creators |
Easy |
InShot |
iOS/Android |
Limited |
Basic mobile edits |
Easy |
How to Add Audio to Video Without a Watermark: Step-by-Step (DaVinci Resolve)
DaVinci Resolve is the most reliable watermark-free desktop option. These steps apply to the free version on Windows, Mac, or Linux. The same general logic applies in CapCut for mobile: import video, import audio, place on timeline, sync, export.
Download DaVinci Resolve. Go to blackmagicdesign.com, select the free version, and complete the standard installation. No account activation or serial key is required for the free version.
Open a new project. Launch DaVinci Resolve. From the Project Manager, click “New Project,” give it a name, and click “Create.”
Import your video file. Click on the “Import” page. Choose the local directory where you have the files, and bring them to the “Master” bin (the root directory of the Media Pool).
Import your audio file. Repeat the import step for your audio file. MP3, WAV, and AAC formats all work without conversion.
Add the video to the timeline. Click the “Edit” page icon at the bottom of the screen.
Drag your video clip from the Media Pool down to the timeline. It creates a video track and automatically attaches any embedded audio.
If the video also has embedded audio, it will appear on a separate track on the timeline but will be linked to the audio.
Place the audio file on the timeline. Drag your audio file from the Media Pool to a new audio track directly below the video clip. Position it at the point where you want it to begin.
Trim and sync the audio. Press B to activate the blade tool and cut the audio clip to match your video length. Click and drag the clip left or right to align it with specific moments in the video.
Adjust the volume balance. Click on the audio clip in the timeline. Use the Inspector panel on the right to raise or lower the volume level. If your video includes existing audio you want to retain, balance the two tracks so neither overwhelms the other.
Mute or delete the original audio track if needed. If you are replacing the original audio entirely, click the Mute icon (M) on the original audio track to mute it, or right-click the track and delete it.
If the audio is linked to the video, right-click the audio file and uncheck Link Clips to unlink.
Once done, right-click the audio file and select Delete Selected.
Export your finished video. Switch to the “Deliver” page. Under Render Settings, choose the YouTube or Custom Export preset. Set Format to MP4 and Codec to H.264 for broad compatibility. Click “Add to Render Queue,” then “Render All.” DaVinci Resolve exports a clean MP4 with no watermark to your chosen folder.
Recording Your Own Audio? Make Sure It’s Clean Before You Import
If you are adding a voiceover or live commentary rather than a music track, the quality of your source audio determines the final result. No editor can fully recover a noisy recording after the fact. The Hollyland LARK A1 connects to a smartphone instantly via USB-C or Lightning with no Bluetooth pairing or app setup required, and its 3-Level Intelligent Noise Cancellation filters out background noise at the point of capture. You finish recording, and the file is import-ready with no cleanup needed.
Pro Tip: Record your voiceover as a separate audio file at the highest quality your setup allows, then import it as a dedicated track in your editor. A clean mono voiceover is far easier to work with than audio pulled from a phone’s built-in microphone.
What is the easiest free tool to add audio to a video without a watermark?
CapCut is the fastest option for mobile users, and DaVinci Resolve is the most reliable for desktop. CapCut adds its ending logo to videos by default. You can remove that ending for free with a few taps. Some templates and premium features still require a Pro plan for exports without watermarks. DaVinci Resolve takes a bit longer to learn, but it gives you full control over multiple audio tracks and precise export settings.
Does DaVinci Resolve add a watermark to exported videos?
No. The free version of DaVinci Resolve does not add a watermark to any export. It is one of the only professional-grade video editors that is fully free with no export restrictions, no trial period, and no upgrade required to access a clean output.
Can I add audio to a video online for free without any watermark?
You can add audio to a video with Kapwing at no cost. But videos exported from the free version include a watermark. A paid plan is required to remove it. Free exports are also limited to 720p and shorter video lengths. That quality is still good enough for most social media posts.
How do I add audio to a video on my phone without a watermark?
CapCut lets you add audio from your phone or record a voiceover. Adjust the audio until it matches your video's length. Before exporting, remove the default CapCut ending from the timeline. Also, avoid using any Pro audio or premium assets. Otherwise, you must upgrade to remove the watermark. InShot is another option, but its free version includes more ads and limits.
Editing on a computer? DaVinci Resolve is your best pick if you want watermark-free exports. If you prefer working in a browser, Kapwing is simple to use. But the free version comes with watermarks and other limits. CapCut is the quickest choice on mobile devices. Just avoid Pro templates and premium effects to keep your export free from watermarks.
