How to Make Images with Audio for TikTok Videos (3 Easy Methods)
TikTok isn’t just for video clips anymore. One of the most popular formats on the platform right now is the photo slideshow — a series of still images that plays automatically while music or audio runs in the background. If you’ve been wondering how to recreate that format yourself, you’re in the right place. This guide walks you through three methods, from the fastest native option to the most creatively flexible.
What Does “Images with Audio” Mean on TikTok?
A TikTok image slideshow is a post where several photos appear one after another. A music track, trending sound, or voiceover plays in the background, so you do not need to record a normal video. It looks like a carousel but behaves like a video. Creators use this format for:
  • Travel photo recaps set to a trending song
  • “Day in my life” snapshots with a voiceover narration
  • Product reveals or before-and-after comparisons with background music
Method 1 — Use TikTok’s Native Photo Mode (Fastest Way)
TikTok’s built-in Photo Mode is the quickest path to publishing an image slideshow with audio. There’s no third-party app needed, no exporting, and no manual video assembly. TikTok handles the slideshow playback automatically.
Step-by-Step: Post Images with Audio Directly in TikTok
  1. Open TikTok and tap the “+” button at the bottom center of the screen to start a new post.
  1. Select “Photo” to activate photo mode and to ensure you are not on TikTok's video recording screen.
  1. Select “Camera Roll/Gallery” in the bottom-right corner of the camera screen.
  1. Select your images from your camera roll. Tap each one in the order you want them to appear — TikTok will display them in the sequence you select.
  2. Tap “Next” once your images are chosen. You’ll move to the editing screen.
  3. Add audio by tapping the sound icon at the top of the screen. Search TikTok’s sound library or choose a currently trending audio track. Then, tap “Next.”
  1. Optional: Add text, stickers, or Auto Captions as needed for accessibility and engagement.
  2. Write your caption, add hashtags, and tap “Post.”
TikTok will auto-loop the slideshow for viewers, playing your selected audio continuously — exactly like a standard TikTok video.
Pro Tip: Select your images in the exact order you want them displayed before tapping “Next.” Reordering after the fact can be tedious. Laying out your sequence in your phone’s photo gallery first saves time.
Method 2 — Use TikTok’s Built-In Video Editor
If you want more control over timing and layout without leaving the TikTok app, the built-in video editor gives you a few additional options. This method treats each image as its own short clip inside a video timeline.
  1. Tap “+” and tap the “Create” button.
  1. Tap the “New video” tile.
  1. Select the “Photos” tab and choose your images one by one.Then tap “Next.” TikTok will treat each as a brief static clip in the video timeline.
  2. Tap each clip in the editor to trim its display duration. This lets you linger on certain images or keep others short.
  1. Add musicby tapping the Sound icon. Then from the list of options, choose “Add sound,” Sound effect,” or “Voiceover.”To make it easier for you tounderstand, we selected a track from TikTok’s licensed audio library by choosing the “Add sound” option.
Both audio and images will appear on the timeline.
  1. Layer text overlays or stickers over the video timeline as you would with any TikTok video.
  1. Preview, then post.
Note: This method gives you slightly more control over per-image timing than Photo Mode, but it lacks smooth transitions between images and doesn’t support beat-syncing. For those features, CapCut (Method 3) is a better fit.
Method 3 — Use CapCut to Build an Image Slideshow with Audio
CapCut is TikTok’s companion editing app and the go-to tool for creators who want polished, beat-synced slideshows with custom transitions and animated text. If your slideshow is a key piece of content — not just a casual post — this is the method to use.
How to Make a TikTok Slideshow in CapCut
  1. Open CapCut and tap “New video.”
  1. Import your photos from your camera roll. Arrange them in the order you want and tap “Add.”
  1. Set the duration for each image by tapping a clip and adjusting its length on the timeline.
  1. Add transitions between images by tapping the transition icon between clips. Options range from simple cuts to animated wipes and zooms.
  1. Import your audio track. Tap “+ Add audio or Audio” → “Sounds” to search CapCut’s library, or tap “From Device” to use your own music file.
  1. Sync images to beat markers. Use CapCut’s Auto Beat Sync feature to automatically snap image cuts to the rhythm of your track — a major advantage over TikTok’s native tools.
  • To find this option, tap the audio track, look for the “Beats” icon at the bottom.
  • Enable the “Auto-generate” toggle by tapping on it.
  1. Add text animations or captions per image for an extra layer of visual storytelling.
  1. Tap “Export” and share directly to TikTok from CapCut’s share menu.
When to choose CapCut over TikTok native: Use CapCut when you want transitions, beat-matched cuts, animated text per image, or when you’re using audio that isn’t in TikTok’s library. Use Photo Mode when you want to publish quickly without leaving the TikTok app.
How to Add a Voiceover or Narration to Your Image Slideshow?
Background music works well for mood-driven content, but narration-style slideshows — where you talk over your images — are increasingly popular for storytelling, tutorials, and personal vlogs. Here’s how to add your own voice.
In TikTok: After assembling your slideshow, tap the “Voiceover” option in the editing screen. Record directly over your images in real time. TikTok will layer your voice over whatever background audio you’ve selected.
In CapCut: Tap “Audio” → “Voiceover” within your project timeline. You can record segment by segment and adjust volume levels between your voice track and background music independently — giving you much cleaner control.
Why audio quality matters more in this format: With static images, there’s no motion to keep viewers watching. Your audio — whether music or voice — carries the entire experience. Poor recording quality (echoey rooms, background noise, wind) causes viewers to scroll away immediately.
For creators who record narration on a smartphone, a small clip-on wireless mic can make a big difference. The Hollyland LARK M2 is a tiny 9-gram wireless mic made for mobile creators. It clips to your collar, connects straight to your phone, and reduces background noise without a complex setup. When your visuals are only still images, and your voice carries the story, clean audio is not optional; it's the main retention factor.
Quick Tips for Better Image + Audio TikToks
  • Use high-resolution images. TikTok displays photos full-screen. Blurry or low-resolution shots are immediately noticeable and reduce perceived quality.
  • Match image cuts to audio moments. Let beat drops, lyric changes, or natural pauses in the audio signal when the next image appears.
  • Enable TikTok Auto Captions. Accessibility features improve watch time, and captions keep viewers engaged even when they’re watching without sound.
  • Keep it between 5 and 15 images. Fewer than 5 feels incomplete; more than 15 starts losing attention unless the content is genuinely compelling throughout.
  • Use trending audio. TikTok’s algorithm actively promotes content that uses popular sounds — check the Sounds tab for what’s rising before you choose your track.
Q: Can I use my own music on TikTok image slideshows?
Yes. In CapCut, you can import any audio file from your device and export the finished slideshow to TikTok as a video. Within TikTok’s native editor and Photo Mode, you’re limited to TikTok’s licensed sound library — you can’t upload personal audio files directly.
Q: How many images can I include in a TikTok photo slideshow?
TikTok Photo Mode currently supports up to 35 images per post. For most content, 5–15 images tend to perform best in terms of engagement, but the technical limit gives you plenty of room for longer sequences.
Q: Why can’t I find the Photo Mode option on TikTok?
Photo Mode only shows in the latest TikTok version. Start by updating the app from your device’s app store. After that, tap the “+” button and choose “Upload.” At the bottom of the screen, find the toggle and switch it from “Video” to “Photo.” It does not show up by default, so it is easy to overlook.
Q: Does the audio play automatically when someone views my slideshow?
Yes. The audio starts automatically when viewers see your photo slideshow in their For You feed, just like regular TikTok videos. Viewers can mute it manually, but it starts playing immediately on scroll.
Q: Can I add text to each individual image in a TikTok slideshow?
Not natively within TikTok’s Photo Mode. The text added there overlays the entire post, not individual images. For per-image text overlays or animated captions that change with each photo, build your slideshow in CapCut first, then export to TikTok.
For most creators, TikTok’s Photo Mode is the right starting point — it’s fast, it’s built in, and it produces a clean result in under five minutes. Once you’re comfortable with the format, CapCut unlocks beat-synced transitions, custom timing, and text animations that can meaningfully elevate your content. If you include narration in your content, set up good audio from the start because it helps keep viewers watching.
Try Photo Mode for your next post. Once you’ve got the workflow down, experiment with CapCut to see how much further you can push the format.
