Want to stream a prerecorded video through TikTok Live but can’t find the option in the app? You’re not alone. TikTok’s native mobile app doesn’t support this — but with the right desktop tool, it’s straightforward. This guide walks through four working methods, from TikTok’s own free software to OBS Studio and browser-based alternatives, so you can pick the one that fits your setup.
Can You Actually Play a Prerecorded Video on TikTok Live?
The short answer: yes — but not through the TikTok mobile app itself. There’s no “upload a video and go live” button anywhere in the native app. To broadcast prerecorded content as a live stream, you need a desktop streaming tool that pushes video to TikTok via an RTMP connection.
Before you start, confirm you meet TikTok’s baseline requirement: your account needs at least 1,000 followers to access the Live feature on most accounts.
One quick note on TikTok’s guidelines: Streaming prerecorded content is common and usually allowed. Problems can start when the video is presented in a misleading way. For example, saying an edited, planned clip is a real and uncut live stream. Use these methods for replays, demos, automated streams, or events, and you’ll be on solid ground.
Method 1 — TikTok LIVE Studio (Easiest for Beginners)
Priority: Primary
TikTok LIVE Studio is TikTok’s own free desktop app for Windows, and it natively supports adding local video files as media sources. This is the lowest-friction path for creators who don’t want to deal with third-party software.
Download TikTok LIVE Studio from the official TikTok website and install it on your Windows PC.
Open the app and log in with your TikTok account credentials.
On the main dashboard, click “Go Live” and set your stream title and category.
In the scene editor, click “Add Source” in the bottom source panel.
Select “Media File” from the source type list.
Click “Browse” and locate your prerecorded video file on your computer.
Enable the Loop toggle if you want the video to repeat automatically.
Before going live, play back a preview to confirm audio and video are in sync.
Click “Start Live” when you’re ready.
How to Add Your Video File as a Source in LIVE Studio
If you’re unfamiliar with the source panel interface, here’s the specific click path:
In the scene editor, locate the Sources panel at the bottom of the screen.
Click the “+” (Add Source) button.
Choose “Media File” from the dropdown menu.
In the configuration window, click “Browse Local File” and select your MP4 or MOV file.
Check the “Loop” checkbox to enable continuous playback — this keeps your stream running without manual restarts.
Adjust the volume slider in the source settings to match your desired audio level.
Hit “Confirm” and verify the video appears correctly in the preview window before going live.
Pro Tip: Do a full test run in preview mode before hitting “Start Live.” Audio sync problems are much easier to catch before your audience joins.
Method 2 — OBS Studio + TikTok RTMP Stream Key (Most Control)
Priority: Primary
OBS Studio is the go-to choice for creators who want scene switching, overlays, multiple video clips, or full control over stream quality. It’s free, works on Windows and Mac, and connects to TikTok via an RTMP stream key.
Download and install OBS Studio from obsproject.com.
Get your TikTok RTMP URL and stream key (see the section below).
Open OBS and go to Settings → Stream.
Set Service to “Custom” and paste your TikTok RTMP URL into the Server field and your Stream Key into the Stream Key field.
Click OK to save.
In the main OBS window, click the “+” under the Scenes panel to create a new scene (e.g., “Prerecorded Stream”).
With the scene selected, click “+” under the Sources panel and choose “Media Source.”
Check “Local File,” then browse to your prerecorded video file.
Enable the Loop option in the source settings.
Go to Settings → Video and set the base and output resolution to 1080×1920 (9:16 vertical) for TikTok’s format.
Click “Start Streaming” when ready.
Getting Your TikTok RTMP URL and Stream Key
TikTok gates RTMP access to eligible accounts. Here’s where to find your credentials:
Open TikTok LIVE Studio and navigate to Go Live → Stream Settings. Your RTMP URL and Stream Key are listed here.
Alternatively, on eligible creator accounts, open the TikTok app → Creator Tools → LIVE → Go Live Producer to access stream credentials directly.
Copy the RTMP URL (format: rtmp://push.tiktokv.com/live/) and the alphanumeric Stream Key exactly — a single character error will prevent connection.
Stream keys expire after a session ends. Generate a new key each time you start a fresh stream.
Note: Not all accounts have RTMP access immediately. If you don’t see stream key options, try accessing them through TikTok LIVE Studio first, as the official app tends to unlock this for qualifying accounts.
Setting Up the Prerecorded Video as a Scene in OBS
In the Scenes panel, click “+” and name your scene.
In the Sources panel, click “+” and select “Media Source.”
Name the source, then check “Local File” and browse to your video.
Enable “Loop” to keep playback continuous.
For playlists (multiple videos in sequence), add a VLC Video Source instead — this lets you queue multiple files.
Right-click the source in the preview and use “Transform → Fit to Screen” to fill the 1080×1920 canvas.
Confirm the output resolution in Settings → Video matches 1920×1080 base rotated — or set canvas to 1080 width × 1920 height directly for true vertical output.
Method 3 — Browser-Based Streaming Tools (StreamYard / Restream)
Priority: Secondary
If you’re on a managed device, a Mac without admin access, or simply prefer not to install software, browser-based tools like StreamYard and Restream are a practical alternative.
Create a free account on StreamYard or Restream.
In your dashboard, go to Destinations and connect your TikTok account by authorizing via OAuth.
Note: TikTok is not directly available as a destination in StreamYard. You will need to use the “Other platforms” option to stream on TikTok using Custom RTMP. Also, this option is accessible to paid StreamYard accounts only.
Create a new broadcast and enter your stream studio.
To add your prerecorded video: use the “Share Screen” option and play the video full-screen in a media player, or use StreamYard’s built-in “Add Video File” feature (available on paid plans).
Set TikTok as your destination and click “Go Live.”
A few things to keep in mind: - Free plans on both platforms include a watermark on your stream. - Resolution may be capped at 720p on free tiers. - Screen-sharing a video is less stable than a direct file upload — close unnecessary browser tabs to reduce CPU load. - StreamYard’s paid plan ($35.99month) removes watermarks and unlocks higher resolution; Restream offers similar tiered pricing.
For creators who need a quick, no-install solution, this method works well. For anything more complex, OBS gives you significantly more control at no cost.
Mobile Workaround — Can You Do This on a Phone?
Priority: Brief
Honestly, mobile options are limited. The native TikTok app has no mechanism for routing a prerecorded video into a live stream.
Two partial workarounds exist, both with significant drawbacks:
Dual-device method: Play your prerecorded video on one phone and point a second phone’s camera at the screen while running TikTok Live. Quality is poor, and the setup is awkward.
Virtual camera apps: Some third-party apps claim to output a virtual camera feed on mobile, but compatibility is inconsistent across iOS and Android versions, and stream stability is unreliable.
If you’re mobile-only, the dual-device method can work in a pinch — but the quality gap compared to a desktop setup is significant. Desktop methods are the recommended approach for anything you want to look professional.
Tips to Make Your Prerecorded TikTok Live Look Professional
Priority: Secondary
A clean technical setup separates a polished stream from one that looks like an accident. Before you go live:
Export at the right specs: 9:16 aspect ratio, 1080×1920 resolution, MP4 (H.264), AAC audio, 44.1 kHz or 48 kHz sample rate.
Trim silence at the start and end of your video to avoid awkward dead air when the file loops.
Add a lower-third overlay in OBS (e.g., “LIVE Q&A — Drop your questions below”) to signal active presence even when you’re not on camera.
Monitor your stream for the first few minutes — check chat, verify audio is playing, and confirm the video looks correct before stepping away.
Engage your audience. If you’re adding live commentary or answering comments in real time while the video plays, your audio quality matters just as much as the video.
If you plan to talk over your prerecorded content or take live questions from your audience, clear audio makes a real difference. The Hollyland LARK M2 — a 9g wireless clip-on mic with 40-hour battery life — is purpose-built for this kind of TikTok creator setup. It clips on without getting in the way of your stream workflow and delivers clean, wire-free sound so your commentary doesn’t undercut the quality of your video content.
Quick Comparison — Which Method Should You Use?
Method |
Device |
Difficulty |
Cost |
Best For |
TikTok LIVE Studio |
Desktop (Windows) |
Easy |
Free |
Beginners, single video playback |
OBS Studio + RTMP |
Desktop (Win/Mac) |
Medium |
Free |
Full scene control, overlays, playlists |
StreamYard / Restream |
Browser (any device) |
Easy |
Free / Paid |
No software install, managed devices |
Mobile workaround |
Phone |
Hard |
Varies |
Last resort only |
Is it against TikTok’s rules to stream a prerecorded video as live?
TikTok permits pre-produced content in live streams. The main restriction is deceptive misrepresentation — for example, claiming a video is unedited live footage when it isn’t.
Do I need 1,000 followers to go live on TikTok?
Yes. TikTok currently requires a minimum of 1,000 followers to access the Live feature on most accounts. This threshold applies regardless of which streaming method you use — the RTMP connection still goes through TikTok’s live infrastructure.
Can I loop a video on TikTok Live indefinitely?
Yes. Both OBS (via the Media Source loop setting) and TikTok LIVE Studio support looping a local video file continuously. Keep in mind that TikTok may end streams that appear inactive or receive no audience engagement over extended periods, so looping alone doesn’t guarantee the stream will stay up indefinitely.
What video format works best for TikTok Live streaming?
MP4 (H.264) at 9:16 aspect ratio (1080×1920) with AAC audio is the recommended format. Aim for a bitrate between 2,500 and 6,000 kbps for stable streaming quality. Higher bitrates may cause buffering depending on your upload speed, so test before committing to a long stream.
Why is my prerecorded video audio out of sync on TikTok Live?
Audio sync issues in OBS are most often caused by mismatched sample rates. Set both OBS and your video export to 44.1 kHz or 48 kHz consistently. Also check the Audio Monitoring Delay setting in OBS’s Advanced Audio Properties and adjust as needed. Restarting the Media Source can also resolve sync drift that develops mid-stream.
If you’re just getting started, TikTok LIVE Studio is the fastest path — download it, add your video file, and you’re live in minutes. When you’re ready for overlays, scene switching, or more advanced stream control, OBS Studio gives you the flexibility to build out a proper production setup. And if software installation isn’t an option, StreamYard or Restream gets the job done from any browser.
