How to Put Text on TikTok Live: 3 Methods That Actually Work
Adding text to a TikTok live stream isn’t as straightforward as it is in the video editor — and that surprises a lot of creators mid-setup. The good news is that it’s absolutely doable. This guide covers three real methods, from quick native app options on your phone to full custom overlays on PC, so you can pick the right approach before you go live.
Why You Can’t Just “Add Text” from the TikTok Live Button
If you’ve gone looking for a text tool inside TikTok’s live interface and come up empty, you’re not missing something obvious — it genuinely isn’t there. Unlike TikTok’s video editor, which gives you a full text tool with fonts, colors, and positioning, the native live screen offers almost none of that. What you see is what your viewers get, with no layer of graphical editing on top.
What the mobile app does offer is a handful of indirect text options: a live title that displays briefly when your stream starts, a Q&A feature that pulls viewer questions onto the screen, and the ability to pin a comment so it stays visible. These are useful, but they’re not the same as placing a custom text overlay wherever you want it.
Understanding this gap before you go live matters. If you need a persistent “Follow for more” banner, a scrolling ticker, or a branded lower-third, you’ll need either TikTok LIVE Studio on a PC or a third-party tool connected via RTMP. Here’s a quick breakdown:
Feature
Native App (Phone)
TikTok LIVE Studio (PC)
OBS via RTMP
Custom text overlay
Live title
Pinned comment
Scrolling text / ticker
Font/color control
Method 1 — Add Text Overlay Using TikTok LIVE Studio (PC)
TikTok LIVE Studio is TikTok’s own free desktop streaming application, and it’s the most accessible way to add real, customizable text overlays to your live stream. It works similarly to OBS but is purpose-built for TikTok, which means a simpler interface and a faster setup for most creators.
Eligibility note: Your account must meet TikTok’s live requirements — typically 1,000 or more followers — before LIVE Studio will authorize your stream.
Step-by-Step: Adding a Text Layer in TikTok LIVE Studio
  1. Download TikTok LIVE Studio from the official TikTok website and install it on your PC.
  2. Log in with your TikTok account and complete the initial setup wizard.
  3. Open the Scenes panel on the left side of the interface. Select an existing scene or create a new one.
  4. Click “Add Source” (the + icon) within your chosen scene.
  5. Select “Text” from the source type menu.
  6. Type your text in the text field — this could be a CTA, your social handle, a stream topic, or any label you want visible on screen.
  7. Customize the appearance — adjust font, size, color, and background/outline settings to match your brand.
  8. Click and drag the text layer in the preview window to position it where you want it on screen.
  9. Lock the source if you don’t want to accidentally move it mid-stream.
  10. Go live using the “Start Live” button when your scene is ready.
You can add multiple text sources, stack them in layers, and toggle their visibility on and off during the broadcast.
Tips for Readable Text Overlays
  • Minimum font size of 28–32px for standard stream resolutions; smaller text becomes unreadable on mobile screens.
  • Use high-contrast color combinations — white text with a dark semi-transparent background is consistently readable against any scene.
  • Add an outline or drop shadow if you’re streaming in front of a busy background; this separates the text from the visual noise.
  • Keep text in the safe zone — avoid placing overlays within the bottom-right corner, where TikTok’s native UI elements (reactions, follow button) can overlap your content.
  • Limit on-screen text to one or two elements at a time; cluttered overlays distract from the stream itself.
Method 2 — Native TikTok App Options (Phone)
If you’re streaming from your phone and don’t have access to a PC, TikTok does give you a few built-in tools that can serve the purpose — just with more limitations. None of these replicate a true freeform text overlay, but for common use cases like announcing a topic, running an AMA, or pinning a call-to-action, they’re functional.
Setting a Live Title Before You Go Live
The live title is set before your stream begins and appears on screen for viewers when they first join.
  1. Tap “LIVE” in the TikTok camera selector.
  2. Before tapping “Go LIVE,” tap the title field near the top of the setup screen.
  3. Enter your title — you have approximately 30 characters, so keep it concise.
  4. Tap confirm, then go live.
The title displays prominently when new viewers land on your stream, making it useful for communicating your topic immediately. It is not a persistent overlay — it fades or moves to a secondary position once the viewer is in the stream.
Using the Q&A Feature to Display Text On Screen
TikTok’s Q&A feature lets viewers submit questions that you can then pull up as a visible on-screen card — making it one of the closest things to a text overlay available on mobile.
To enable it: - Go to Creator Tools → Live → Q&A in your TikTok settings and toggle it on before going live.
Once live, when a viewer submits a question: - Tap the Q&A icon on your live screen. - Select a question to pin it as an on-screen display card.
The selected question appears as a formatted text bubble visible to all viewers — useful for: - AMA (Ask Me Anything) streams - Product demo explanations - Highlighting specific viewer interactions
The limitation is that the format is fixed — you can’t change the visual style, and the content is limited to what viewers actually ask.
Pinning a Comment as a Text Anchor
You can pin any comment — including your own — to keep it at the top of the comment stream where viewers will notice it.
During a live, tap and hold any comment and select “Pin.” The comment stays anchored at the top of the chat. This works well as a lightweight CTA (“Drop a follow if you’re new 👇”) or to display a link or promo code. Keep in mind it looks like a chat comment, not a graphic element — it won’t have the visual weight of a designed overlay.
Method 3 — Stream via OBS or Streamlabs with RTMP (Advanced)
For creators already working inside OBS or Streamlabs, you can route your stream to TikTok using an RTMP connection and gain full control over text overlays — including scrolling tickers, lower-thirds, and animated text sources.
Before you start: This method requires TikTok to provide you with an RTMP server URL and stream key, which is typically available through TikTok LIVE Studio’s settings or the TikTok for Developers portal. Account eligibility requirements apply.
  1. Open TikTok LIVE Studio and navigate to Settings → Stream Key to retrieve your RTMP URL and stream key.
  2. Open OBS or Streamlabs on your PC.
  3. Go to Settings → Stream, select “Custom” as the service, and paste in your TikTok RTMP URL and stream key.
  4. In your OBS scene, click the + icon under Sources and add a “Text (GDI+)” source.
  5. Enter your text and configure font, size, color, and any scroll or animation settings you want.
  6. Position and resize the text layer in the OBS preview canvas.
  7. Click “Start Streaming” in OBS — your stream will go live to TikTok with all overlay layers intact.
This method offers the most design flexibility and is the go-to setup for creators who stream to multiple platforms or need polished, broadcast-quality graphics.
Make Your TikTok Live Look and Sound More Professional
Once your text overlays are in place, a few small production habits make a big difference. A consistent, uncluttered background keeps the focus on you and your content. Stable, front-facing lighting — even a simple ring light — prevents the washed-out or shadowy look that undercuts an otherwise professional stream.
Audio is just as important as visuals. Text overlays improve what viewers read; clear audio determines what they stay for. A compact wireless microphone like the Hollyland LARK M2 (9g, up to 40-hour battery life) keeps you untethered from your setup while delivering clean, studio-quality sound — a natural fit for TikTok creators who move around during their streams.
Q: Can I add text to TikTok live from my phone without a PC?
Yes, but your options are limited to live titles, Q&A overlays, and pinned comments. These are functional for basic use cases, but none of them offer freeform positioning or custom design. For full custom text overlays with font and color control, you’ll need TikTok LIVE Studio on a PC or OBS connected via RTMP.
Q: Does TikTok LIVE Studio cost money?
No. TikTok LIVE Studio is completely free to download and use. However, your TikTok account must meet the platform’s live streaming eligibility requirements — typically 1,000 or more followers — before you can authorize and stream through the application.
Q: Why can’t I find the text option in my TikTok live settings?
The TikTok mobile live interface doesn’t include a freeform text editor — this isn’t a settings issue or an account restriction. On-screen text overlays simply aren’t part of the native mobile live tool. To add custom text, you need TikTok LIVE Studio on a PC or a third-party streaming application connected to TikTok via RTMP.
Q: Can I add scrolling text or a ticker to TikTok live?
Yes, but not through the mobile app. In TikTok LIVE Studio and OBS, you can configure scrolling text sources — ideal for news tickers, donation acknowledgments, or rotating CTAs. This is one of the features that makes desktop streaming software significantly more powerful than the native app for visual customization.
Q: Will text overlays work on TikTok live replays?
Yes. Text added through TikTok LIVE Studio or OBS is embedded directly into the video feed before it’s transmitted — it’s part of the stream signal, not a layer added afterward. If TikTok saves your live as a replay, the text overlays will be visible in the recording exactly as they appeared during the broadcast.
The Right Method for Your Setup
Phone-only creators should start with native options — set a clear live title, enable Q&A for interactive text, and pin a comment as a persistent CTA. Creators who want real text overlays should download TikTok LIVE Studio and add a text source to their scene before going live. Advanced streamers already in OBS or Streamlabs can connect via RTMP for maximum control.
Your next step: Download TikTok LIVE Studio, build your first scene with a text overlay, and run a test broadcast before your next live session — it takes less than 15 minutes to set up and immediately elevates how your stream looks.
