How to Go Live on TikTok on PC: 3 Working Methods (Step-by-Step)
Going live on TikTok from a PC isn’t as straightforward as tapping a button on your phone — but it’s absolutely doable, and the experience is often far more stable and professional. Whether you want TikTok’s official desktop app, a full-featured streaming setup with OBS, or a quick browser option, this guide walks you through all three working methods with clear steps, honest caveats, and tips to make your stream actually worth watching.
Before You Start — TikTok Live Requirements on PC
Before trying any method below, confirm your account meets TikTok’s eligibility criteria. If any box is unchecked, the go-live option simply won’t appear — and TikTok rarely explains why.
TikTok Live eligibility checklist:
  • Minimum 1,000 followers — This is a firm threshold. You won’t see the live option until you hit it.
  • Age 18 or older — TikTok enforces this at the account level.
  • Account in good standing — Accounts with recent content violations or bans may have live access restricted or removed.
  • No active strikes or enforcement actions — Even a temporary flag can block the feature.
  • Regional availability — TikTok rolls out and adjusts features by region. Some accounts in certain countries may meet all requirements but still have limited or delayed access.
If your account checks every box and live still isn’t available, wait a few days and check again — regional rollouts can be slow and unannounced.
Method 1 — Use TikTok LIVE Studio (Official Desktop App)
TikTok LIVE Studio is the recommended starting point for most PC users. It’s purpose-built for this exact use case and requires no third-party workarounds.
What Is TikTok LIVE Studio?
TikTok LIVE Studio is TikTok’s free, official desktop application for Windows, designed specifically for live streaming directly to your TikTok account from a PC. It handles everything — scene setup, camera and mic configuration, and the stream connection — all in one place.
How to Download and Set Up TikTok LIVE Studio
  1. Go to livestudio.tiktok.com and click the download button for Windows.
  2. Run the installer and follow the on-screen prompts to complete installation.
  3. Open TikTok LIVE Studio and click Log In.
  4. Scan the QR code with your TikTok mobile app, or log in using your TikTok username and password.
  5. When prompted, grant the app permission to access your camera and microphone. Without these, your stream will have no video or audio.
  6. Complete the initial setup wizard — this walks you through selecting your default video source (webcam) and audio input (microphone or headset).
  7. You’ll land on the Scene Editor. You can add or rearrange sources here: webcam feed, screen capture, images, overlays, and more.
Note: TikTok LIVE Studio is currently available for Windows only. Mac users should skip to Method 2 (OBS Studio).
How to Go Live Using TikTok LIVE Studio
  1. In TikTok LIVE Studio, click Create or open the stream setup panel.
  2. Enter a stream title — keep it specific and attention-grabbing to improve discoverability.
  3. Select a content category (Gaming, Education, Lifestyle, etc.).
  4. Confirm your camera and microphone sources are active in the preview window. Check levels and framing before going live.
  5. Review the scene layout in the preview panel — make sure nothing is cropped or off-screen.
  6. Click Go Live (or Start Stream, depending on your version of the app).
  7. TikTok will show a brief countdown, then your stream goes live to your followers. The interface will display live viewer count, incoming comments, and gift activity.
To end the stream, click End Live and confirm. TikTok LIVE Studio will generate a brief performance summary after the session.
Method 2 — Go Live on TikTok via OBS Studio and Stream Key
OBS Studio is the go-to choice for creators who want more control — multiple camera sources, screen capture, custom overlays, or integration with games. It connects to TikTok through a custom RTMP stream key.
How to Find Your TikTok Stream Key
TikTok does not expose stream keys in the standard mobile app. You’ll find it through one of two routes:
  1. Open TikTok LIVE Studio (you need it installed even if you plan to stream with OBS).
  2. Click on Settings (gear icon) within LIVE Studio.
  3. Navigate to Stream Key & URL or Advanced Settings — the exact label may vary by app version.
  4. Copy the Server URL (RTMP URL) and the Stream Key. Keep both handy — you’ll paste them into OBS.
Alternatively, some creator accounts can find the stream key directly at tiktok.com under Creator Tools > LIVE > Stream PC if the feature is enabled for their region.
Note: Stream keys are account-specific and should be kept private. Treat your stream key like a password — anyone with it can stream to your TikTok account.
How to Connect OBS Studio to TikTok
  1. Open OBS Studio on your PC.
  2. Click Settings in the lower-right corner.
  3. Select the Stream tab on the left.
  4. Set Service to Custom.
  5. Paste the Server URL from TikTok into the Server field.
  6. Paste your Stream Key into the Stream Key field.
  7. Click Apply, then OK.
  8. Back on the OBS main screen, configure your scenes and sources (webcam, game capture, microphone, etc.).
  9. Click Start Streaming in OBS. This pushes your feed to TikTok Live.
You’ll need to check TikTok’s app or a browser to confirm the stream is live and to manage incoming comments. OBS does not display TikTok chat natively unless you use a third-party chat integration plugin.
Method 3 — Go Live on TikTok from a Web Browser
Some eligible TikTok accounts can go live directly from tiktok.com in a desktop browser — no download required. However, this option is inconsistent and not universally available.
Steps to try the browser method:
  1. Open your browser and go to tiktok.com.
  2. Log in to your TikTok account.
  3. Click the Upload / Create icon (the + button or Create option in the navigation).
  4. Look for a LIVE option alongside the standard video upload options.
  5. If available, click LIVE, configure your title, and click Go Live.
Caveat: Many users — even those who fully meet eligibility requirements — do not see the LIVE option on the web. TikTok has not made browser-based live streaming universally available, and availability shifts by region and account type. If the option doesn’t appear, go back to Method 1. TikTok LIVE Studio is the most reliable path to going live from a PC.
Tips to Improve Your TikTok Live Stream Quality on PC
Getting live is step one. Getting people to stay is another challenge. These practical upgrades make a noticeable difference in stream quality:
  • Use a wired internet connection. Wi-Fi introduces variability that causes buffering and dropped frames mid-stream. Plug in an Ethernet cable whenever possible. Aim for at least 5–10 Mbps stable upload speed.
  • Set the right bitrate. In TikTok LIVE Studio or OBS, keep your video bitrate between 2,000 and 4,000 Kbps for 1080p streaming. Going higher than your upload speed can handle causes lag; going too low hurts visual quality.
  • Frame your webcam properly. Eye level is best — use a stack of books or a dedicated mount to position the camera so you’re looking directly into it, not up from below. Leave some headroom above you in the frame.
  • Sort out your lighting before going live. Natural light from a window in front of you (not behind) works well. A basic ring light or key light removes shadows and makes a dramatic visual difference. Avoid dark, under-lit backgrounds.
  • Upgrade your audio. Built-in PC microphones and webcam mics pick up keyboard noise, room echo, and background hum — all of which undermine your stream’s watchability. A compact wireless mic like the Hollyland LARK M2 is a practical solution: it weighs just 9g, clips discreetly onto clothing, and delivers clean, broadcast-quality audio without adding cable clutter to your desk setup. For creators going live regularly on TikTok, cleaner audio is usually the single highest-impact upgrade you can make.
Troubleshooting — Why Can’t I Go Live on TikTok on PC?
Problem
Likely Cause
Fix
Go Live button is missing in LIVE Studio or browser
Account doesn’t meet eligibility (followers, age, region)
Check the requirements checklist in Section 1; confirm follower count and account standing
Stream key not working in OBS
Wrong server URL, or key has expired
Re-copy both the RTMP Server URL and stream key from LIVE Studio settings; they sometimes rotate
Black screen in TikTok LIVE Studio
Outdated or incompatible webcam driver
Update your webcam driver via Device Manager or the manufacturer’s website
Audio not transmitting during live stream
Microphone permissions blocked at the OS or app level
Check Windows Privacy Settings > Microphone and ensure LIVE Studio or OBS has access
Stream is lagging or buffering
Upload speed too low or bitrate set too high
Run a speed test, switch to wired Ethernet, and lower bitrate to 2,000–2,500 Kbps
TikTok LIVE Studio won’t open or crashes
Outdated app version or missing Visual C++ runtime
Reinstall LIVE Studio from the official site and install any pending Windows updates
Do I need 1,000 followers to go live on TikTok on PC?
Yes. TikTok requires a minimum of 1,000 followers and an account holder aged 18 or older to unlock the live feature on any platform — mobile or PC. These requirements apply across all three methods covered in this guide. There is no official workaround for accounts below the threshold.
Is TikTok LIVE Studio free?
Yes, TikTok LIVE Studio is completely free to download and use. There are no subscription fees or paid tiers. Any eligible TikTok account can install it and go live at no cost. Download it directly from TikTok’s official LIVE Studio page to ensure you’re getting the legitimate version.
Can I go live on TikTok on PC without downloading software?
The browser method at tiktok.com works for some eligible accounts in supported regions, but availability is inconsistent — many users never see the option even with full eligibility. TikTok LIVE Studio is the most reliable option that doesn’t require third-party software.
Can I use streaming software other than OBS with TikTok?
Yes. Any software that supports custom RTMP output — including Streamlabs, XSplit, and vMix — can connect to TikTok using the same stream key and server URL process described in Method 2. The steps are nearly identical across platforms: find the Custom RTMP setting, paste in your server URL and stream key, and start streaming.
Why is my TikTok Live stream lagging on PC?
Lag is most commonly caused by insufficient upload bandwidth or a bitrate setting that exceeds what your connection can handle. Start with a wired Ethernet connection and set your video bitrate to 2,000–4,000 Kbps in your streaming software. If lag persists, run an upload speed test and lower the bitrate until the stream stabilizes.
Ready to Go Live?
Start with TikTok LIVE Studio — it’s the fastest, most reliable path to going live on a PC and requires no extra configuration. If you already use OBS or need advanced scene control, the stream key method gives you full flexibility. The browser option is worth a quick check, but don’t rely on it. Before your first public stream, do a short test go-live to verify your audio, video, and connection are all working as expected.
