How to Upload a Post on TikTok from PC (2 Easy Methods)
Most people discover TikTok on their phones, but if you edit videos on a desktop, you don’t need to transfer files to upload. TikTok fully supports posting directly from a PC — through your browser (via TikTok Studio) or through a Windows desktop app. This guide walks you through both methods step by step, so you can pick the one that fits your workflow and get your video live without the hassle.
How to Upload a Post on TikTok from PC (3 Easy Methods)
What You Need Before You Upload?
Before you start, confirm you have the following in place:
  • A TikTok account logged in on your browser or desktop app
  • A video file in a supported format (MP4 or MOV are the safest choices)
  • A file under 4 GB in size — TikTok will reject anything larger
  • A stable internet connection — large video files need consistent bandwidth to upload without errors
  • Your caption and hashtags drafted (optional, but saves time during upload)
Method 1 — Upload a TikTok Post via the TikTok Website using the TikTok Studio
Uploading through your browser at tiktok.com is the fastest option that requires no downloads. It works on Chrome, Firefox, Edge, and Safari, and gives you access to all the core post settings you need.
  1. Go to tiktok.com and make sure you’re logged in.
  1. Click the Upload button (+ icon) in the top navigation bar. Once done, it will take you to the TikTok Studio interface.
  1. On the upload page, click Select video or drag and drop your video file into the upload area.
  1. Wait for the file to process — a progress bar will appear. Processing time depends on your file size and connection speed.
  1. Once the preview loads, fill in your caption in the text box on the right-hand side.
  1. Add hashtags by typing # followed by a keyword inside the caption box.
  1. Select a cover image using the thumbnail slider below the video preview.
  1. Configure your audience settings — choose between Public, Friends, or Only Me.
  1. Toggle options for Allow Comments.
  1. Click Post to publish immediately, or Drafts to save and post later.
How to Add a Caption, Hashtags, and Cover Image?
The right-hand panel on the upload page holds several settings that creators frequently overlook on desktop:
  • Caption character limit: TikTok allows up to 2,200 characters for captions. Use this space to include a call-to-action and relevant keywords, not just hashtags.
  • Hashtags: Type # directly inside the caption field. TikTok will suggest trending tags as you type. Aim for 3–5 targeted hashtags rather than a long list of generic ones.
  • Cover image: Drag the slider beneath the preview to choose any frame from your video as the thumbnail. A strong cover improves click-through on your profile page.
  • Tag people: Use the mention feature (@username) inside the caption to tag collaborators or brands.
How to Schedule a TikTok Post from PC?
Here’s how you can schedule a post from PC using the TikTok Studio interface through tiktok.com.
  1. Complete all captions, cover, and audience settings as described above.
  2. Under When to post, click the Schedule toggle (instead of Publish now).
  3. A date and time picker will appear — select your target publish date and time.
  4. TikTok schedules in your local timezone by default, so confirm it’s correct before continuing.
  5. Click Schedule to confirm. Your video will appear under Content > Scheduled until it publishes.
Note: Scheduled posts on TikTok Studio must be set at least 15 minutes in advance. You can edit or cancel a scheduled post any time before it goes live.
Method 2 — Upload Using the TikTok Desktop App (Windows)
For users who prefer a native app experience, TikTok offers a Windows desktop application available in the Microsoft Store.
  1. Open the Microsoft Store on your Windows PC and search for TikTok.
  1. Download and install the official TikTok app.
  1. Log in with your TikTok account credentials.
  1. Select Upload (with a “+” icon) and choose your video file from your computer.
  1. Add your caption, hashtags, and cover image using the same settings panel you’d see on tiktok.com.
  1. Click Post to publish.
TikTok Video Requirements for PC Upload
Uploading a file that doesn’t meet TikTok’s technical specifications is one of the most common reasons uploads fail silently or stall. Use this table as a quick reference before you upload.
Spec
Requirement
File Format
MP4, MOV, AVI, WEBM
Max File Size
Up to 4 GB
Recommended Resolution
1080×1920 (vertical, 9:16)
Minimum Resolution
720p
Max Video Length
Up to 10 minutes (standard accounts); up to 60 minutes (select accounts)
Aspect Ratio
9:16 recommended; 1:1 and 16:9 also supported
MP4 with H.264 encoding is the most reliable format for trouble-free uploads. If your export settings allow it, match these specs before exporting from DaVinci Resolve, Premiere Pro, or CapCut desktop.
Quick Tips for a Better TikTok Post from PC
A clean upload is only part of the equation. These small adjustments help your post perform better once it’s live:
  • Use TikTok’s native sound library for background music. If your exported video includes copyrighted tracks, TikTok may mute it automatically. Adding a trending sound directly through the upload page avoids this entirely.
  • Write captions with a CTA. Phrases like “Watch until the end” or “Drop your answer below” drive comments and watch time — both signals TikTok’s algorithm responds to.
  • Choose your cover frame deliberately. Don’t leave the default first frame as your thumbnail. Scroll to a frame with clear text, an expressive moment, or a strong visual hook.
  • Start with strong audio. Recording with a dedicated wireless mic, such as the Hollyland LARK M2, helps keep your audio clear and strong. This lightweight mic (9g) lasts up to 40 hours and is built for vlogging and quick on-the-go shooting, so your sound stays good even before you upload your video.
Why can’t I see the Upload button on TikTok from my PC?
The Upload button only appears when you’re logged in to a TikTok account. If you’re browsing as a guest, it won’t show. Also, check that you’re using a supported browser (Chrome or Edge are the most reliable) and that no browser extensions are blocking the TikTok interface. Refreshing the page or clearing your cache often resolves this.
Can I upload TikTok posts from a PC without the app?
Yes. You don’t need the desktop app to post from a computer. The TikTok Studio (via tiktok.com)  works entirely in your browser with no installation required. Method 1 in this guide covers the browser upload process step by step.
Can I edit a TikTok video after uploading from a PC?
You can edit the caption, hashtags, cover image, privacy settings, and interaction toggles after posting. But you cannot replace or trim the actual video file once it’s live. If the video itself needs changes, you’ll need to delete the post and re-upload the corrected file.
Can I save a TikTok post as a draft on PC?
Drafts are saved to your TikTok Studio account and can be accessed and published later under the Content section.
All three methods work — the right one depends on how you create. Use tiktok.com if you want the fastest path from file to published post. Use the Windows desktop app if you prefer a native interface similar to the mobile experience. Whichever method you choose, the best thing you can do before you hit upload is make sure your video looks and sounds its best.
