How to Upload on TikTok: Step-by-Step Guide for Phone and Desktop
Uploading a video on TikTok takes under two minutes once you know where everything is. But many new creators get confused when they reach the settings screen. This guide explains how to upload on both phone and desktop step by step. It also breaks down each option on the publish screen and lists the video requirements that help prevent upload errors. Whether you’re posting your first video or switching to a desktop workflow, you’ll find the exact steps below.
What You Need Before You Upload?
Before you start, make sure you have the following in place:
  • A TikTok account — free to create at tiktok.com or in the app
  • The TikTok app installed (iOS or Android) or a browser open to tiktok.com/tiktokstudio for desktop uploads
  • A video file ready — MP4 or MOV formats work best
  • Acceptable video length — up to 10 minutes for most accounts
  • Stable internet connection — Wi-Fi is recommended for files over 100MB
How to Upload a Video on TikTok from Your Phone?
The mobile app is where most TikTok uploads happen. The steps below apply to both iOS and Android — the interface is nearly identical across both platforms.
Step 1 — Tap the “+” Button at the Bottom of the Screen
Open the TikTok app and make sure you’re logged in to your account. At the center of the bottom navigation bar, you’ll see a “+” (plus) icon — tap it. This opens the TikTok camera screen, which is your starting point for both recording and uploading.
Step 2 — Select “Upload” to Choose a File from Your Gallery
By default, TikTok opens the in-app camera ready to record.
To upload a pre-recorded file, tap the “Upload” button (access to phone’s gallery) in the bottom-right corner of the camera screen. This opens your device’s media library.
From here, you can: - Select a single clip by tapping it once - Select multiple clips by tapping them in sequence — TikTok will arrange them in the order you select
Once you’ve made your selection, tap “Next” to continue.
Step 3 — Trim, Edit, and Add Audio (Optional)
TikTok’s in-app editor gives you a few basic tools before you reach the settings screen:
  • Trim your clip using the timeline at the bottom of the editor
  • Add a sound from TikTok’s audio library by tapping “Add sound” at the top, or keep your original audio as-is. Then, click “Next”
Step 4 — Write Your Caption, Add Hashtags, and Adjust Settings
This is the most important screen before you post. Work through each field:
  • Click on the “Edit cover” option. Select a cover photo by dragging the thumbnail bar to the frame you want as your preview image
  • Caption: Keep it concise and relevant. Include a natural keyword or two that describes the video (e.g., “How I make sourdough at home”). TikTok captions support up to 2,200 characters, but shorter captions often perform better.
  • Hashtags: Tap the “#” icon or type hashtags directly in the caption field. Aim for 3–5 relevant tags rather than a long string of generic ones.
  • Mention: Use “@” to mention other users if relevant.
  • Privacy settings: Choose who can see your video — Everyone, Friends, or Only Me.
  • More options: Turn Allow Duet, Allow Stitch, and Allow Comments on or off based on your preference.
  • Schedule: If you want to publish at a later time, toggle “Schedule” and select a date and time.
Step 5 — Tap “Post” or “Save Draft”
Once your settings are configured, you have two options:
  • Post — Publishes the video immediately. It will appear on your profile and begin reaching viewers.
  • Save Draft — Saves the video locally on your device. Only you can see it, and it won’t be published until you return to Drafts and choose to post.
After tapping “Post,” the video will appear on your profile page within a few seconds.
How to Upload on TikTok from a Computer
If you edit your videos on a PC or Mac using software like Adobe Premiere Pro or DaVinci Resolve, uploading directly from your desktop is more efficient than transferring the file to your phone first. TikTok’s browser-based creator tool — TikTok Studio — supports the full upload and settings workflow.
  1. Open a browser and go to tiktok.com/tiktokstudio
  2. Log in with your TikTok account credentials
  3. Click “Upload” in the left-hand sidebar or the upload button on the dashboard
  1. Click “Select video” and choose your MP4 or MOV file from your computer
  1. While the file uploads, fill in your caption, hashtags, and cover photo
  2. Configure scheduling options under the Settings section
  1. Click “Post” to publish
TikTok Upload Settings Explained
The settings screen stops many creators mid-upload. Here’s a plain-language breakdown of every key option:
Setting
What It Does
Recommended Default for New Creators
Privacy (Everyone)
Makes the video visible to all TikTok users
Everyone — maximizes reach
Privacy (Friends)
Limits visibility to mutual followers
Use when testing content
Privacy (Only Me)
Video is private; only you can see it
Use for drafts or personal archiving
Allow Comments
Lets viewers leave comments on the post
On — encourages engagement
Allow Duet
Permit other users to create side-by-side videos with yours
On — increases content reach
Allow Stitch
Let users clip and respond to a segment of your video
Schedule Post
Sets a future publish date and time
Off unless you have a content calendar
Add to Playlist
Groups the video into a themed collection on your profile
Optional — useful once you have multiple videos
TikTok Video Requirements and Specs
Uploading a video in the wrong format or size is the most common cause of failed uploads. Use this table to check your file before you start:
Spec
Recommended Value
File format
MP4 or MOV
Aspect ratio
9:16 (vertical) — 1:1 also supported
Resolution
1080 × 1920 px (1080p)
Maximum length
10 minutes (most accounts); up to 30 min for select creators
Minimum length
1 second
Max file size (mobile)
287.6 MB
Max file size (desktop)
1 GB
If your video is getting rejected, re-export it as a 1080p MP4 and try again — this resolves the majority of upload errors.
Tips for a Better TikTok Upload
The upload process is mechanical, but these habits will make a real difference in how your videos perform once they’re live:
  • Hook viewers in the first 2–3 seconds. TikTok’s algorithm monitors early watch time closely. Start with motion, a bold statement, or a visual that creates immediate curiosity — don’t open with a logo or silent intro.
  • Keep captions under 100 characters when possible. Short captions are fully visible in the feed without tapping “more,” which keeps the viewer’s attention on the video.
  • Post when your audience is active. Check your TikTok Analytics (available on Pro/Creator accounts) to see when your followers are most online, then schedule accordingly.
  • Use 3–5 focused hashtags. A mix of one niche-specific tag, one mid-size topic tag, and one broad tag (e.g., #breadbaking, #homecooking, #foodtok) tends to outperform stacking 20 generic tags.
  • Prioritize audio quality before you ever reach the upload screen. Phone microphones struggle with wind, distance, and background noise — weaknesses that no amount of in-app editing can fully fix. Creators who shoot on the go often use a compact wireless mic like the Hollyland LARK M2 (9g, button-sized, up to 40-hour battery life), which is purpose-built for TikTok and vlogging and delivers broadcast-clean audio straight to your phone before the footage even hits your gallery.
Q: Why is my TikTok upload failing or stuck?
The most common causes are an unsupported file format, a video that exceeds the size or length limit, or an unstable internet connection.
To fix it: re-export your video as an MP4, confirm the file is under the size limit for your platform (287.6 MB on mobile, 10 GB on desktop), and switch to a Wi-Fi connection before trying again.
Q: Can I upload multiple videos at once on TikTok?
You can select multiple clips from your gallery in a single session, but the TikTok mobile app merges them into one combined post rather than publishing them as separate videos simultaneously. If you need to post multiple standalone videos, you’ll need to go through the upload process for each one individually.
Q: How long can a TikTok video be?
Most accounts can upload videos up to 10 to 60 minutes long, depending on whether you’re recording or importing clips from the camera roll. The minimum length is 15 seconds. If you’re uploading a longer file, desktop upload via TikTok Studio handles larger file sizes more reliably than the mobile app.
Q: What happens to a TikTok draft — does anyone see it?
They are not visible to your followers or anyone else on TikTok until you choose to open the draft and tap “Post.” Note that because drafts are stored on your device, deleting the app or switching phones can cause you to lose saved drafts.
Q: Can I edit a TikTok video after it’s posted?
After posting, you can edit the caption, adjust privacy settings, change the cover photo, and toggle interaction settings like Duet and Stitch. But the video file itself cannot be swapped out or trimmed once it’s live — if you need to change the footage, you’ll need to delete the post and re-upload the corrected version.
Uploading to TikTok is straightforward once you’ve done it once — the “+” button gets you in, the Upload option pulls from your gallery, and the settings screen gives you full control over who sees your content and when. If you regularly edit on a computer, TikTok Studio at tiktok.com/tiktokstudio is worth bookmarking for a faster desktop workflow.
