How to Use Your Phone as a Microphone (PC, Mac & More)
If you own any of the latest phones, you are already carrying a powerful built-in mic. And guess what? You can use your mobile to send that audio straight to a Windows PC or a Mac. You do not need to buy extra hardware. This guide shows four working methods, including a free Wi-Fi app and Apple’s Continuity Microphone feature. You can choose the best option and get started in just a few minutes.
Why Use Your Phone as a Microphone?
Modern smartphones carry surprisingly capable microphone hardware. Most iPhones and Android devices sample audio at 44.1kHz and handle clear voice pickup across a reasonable range.
If your PC microphone breaks before an important call, you’re traveling without audio gear, or you need a quick input for streaming without spending money, your phone is a practical fallback. It won’t replace a dedicated condenser mic, but for voice calls, gaming chat, and basic recording, it gets the job done.
What You’ll Need Before You Start?
Required for all methods:
Method-specific extras:
  • Wi-Fi app: Both devices on the same Wi-Fi network; WO Mic app installed on phone
  • USB: A USB data cable (not charge-only); Android only for WO Mic USB transport
  • Bluetooth: Bluetooth enabled on both devices
  • Mac Continuity Mic: iPhone XR or later; Mac running macOS Ventura 13.0 or later; same Apple ID signed in on both devices
Method 1 — Use a Wi-Fi App (Best for Most Users)
Wi-Fi is the most flexible method, and the one most users should start with. WO Mic is the recommended app: it’s free, cross-platform, and works with both iOS and Android to Windows and Mac.
Steps:
  1. Install WO Mic on your phone. Search for “WO Mic” in the App Store or Google Play and install it.
  1. Install the WO Mic desktop client and virtual audio driver on your computer. Download both from the WO Mic website. The virtual driver is what allows Windows or Mac to recognize your phone as a real microphone input. Restart your computer if prompted.
  1. Connect both devices to the same Wi-Fi network. The app and client communicate over your local network. If they’re on separate networks, the connection will fail.
  2. Open WO Mic on your phone and select Wi-Fi as the transport mode. The app displays an IP address. Note it down.
  1. Open the WO Mic client on your PC or Mac, enter the IP address, and click Connect. A connected status should appear within a few seconds.
  1. Set WO Mic as your default audio input.
  • Windows: Go to Settings > System > Sound > Recording devices and set WO Mic Device as the default input.
  • Mac: Go to System Settings > Sound > Input and select WO Mic.
  1. Test your audio in Zoom, Teams, or OBS by opening the app’s audio settings and confirming the input meter responds when you speak.
Method 2 — Connect via USB Cable (Lowest Latency)
If you’re streaming, gaming, or on a call where audio delay is noticeable, USB is the better option. It eliminates network variability and delivers the lowest latency of the app-based methods.
Important: WO Mic’s USB transport works on Android only. iPhone users should use Method 1 (Wi-Fi) or Method 4 (Continuity Microphone on Mac).
Steps:
  1. Enable Developer Options on your Android phone.
  • Go to Settings
  • Tap the About Phone option
  • Tap Software information
  • Now, look for the Build Number option and tap on it seven times
  • Enter your PIN (if you have set it on your phone)
  • Allow development settings by tapping “OK” when the permission prompt shows up
Note: These steps are performed on an Android v.15 device. The menu and navigation can be slightly different, depending on your software version and phone brand.
  1. Enable USB Debugging. Go to Settings > Developer Options and toggle USB Debugging on.
  1. Connect your phone to your PC with a USB data cable. A charge-only cable will not work. Use the cable that came with your device or one you know transfers files.
  2. In the WO Mic app, select USB as the transport mode.
  3. In the WO Mic desktop client on your PC, select USB as the connection type and click Connect.
  4. Authorize the connection on your phone if an “Allow USB debugging?” dialog appears. Tap Allow.
  5. Set WO Mic as the default recording device in Windows Sound Settings using the same steps as Method 1, Step 6.
Note: USB audio routing through WO Mic is not supported on iPhone due to Apple’s restrictions on USB audio accessories. iPhone users should use Method 1 or Method 4.
Method 3 — Connect via Bluetooth
Bluetooth requires no cable and no app, but it comes with significant trade-offs. The Bluetooth Hands-Free profile limits microphone audio to 8kHz narrowband quality. That’s acceptable for basic voice calls, but noticeably degraded for recording or streaming.
Steps:
  1. Open Bluetooth settings on both your phone and PC and pair the two devices.
  2. On Windows, go to Settings > Bluetooth and devices > Sound Settings > Recording devices. Your phone will appear as a Hands-Free or Headset device.
  3. Set it as the default input device.
  4. Test in your target app to confirm audio is passing through.
Quality Warning: Bluetooth Hands-Free audio is capped at 16kHz, which is roughly telephone-call quality. Use Method 1 or Method 2 if audio clarity matters for your use case.
Method 4 — Mac Continuity Microphone (iPhone + Mac Only)
Mac Continuity Microphone is the fastest setup available to Apple users. It’s built into macOS Ventura and later and requires no third-party app on either device.
Requirements:
  • iPhone XR or later
  • Mac running macOS Ventura 13.0 or later
  • Both devices signed into the same Apple ID
  • Wi-Fi and Bluetooth enabled on both
  • iPhone unlocked and nearby
Steps:
  1. Bring your iPhone close to your Mac. The devices auto-discover each other over Bluetooth and Wi-Fi without any pairing action on your part.
  2. On your Mac, go to System Settings > Sound > Input. Your iPhone will appear in the list as “iPhone Microphone.”
  3. Select iPhone Microphone as the input device.
  4. Open any app that uses a microphone — Zoom, Teams, FaceTime, QuickTime Player, GarageBand — and it treats the iPhone as a standard system input with no additional configuration required.
  5. To use it consistently across sessions, keep your iPhone nearby and re-select it in System Settings > Sound > Input at the start of each session if it reverts.
Note: Continuity Camera also enables Portrait mode video and a Desk View camera when the iPhone is mounted near your Mac. The mic and camera features work independently, so you can use audio alone without any camera setup.
Method Comparison at a Glance
Method
Setup Effort
Latency
Audio Quality
Platform Support
Cost
Wi-Fi App (WO Mic)
Medium
Low to Medium
Good
Win + Mac / iOS + Android
Free (ads) / Paid
USB Cable (WO Mic)
Medium (Android only)
Very Low
Good
Windows / Android
Free
Bluetooth
Low
High
Poor (8kHz)
Free
Mac Continuity Mic
Very Low
Low
Very Good
Mac + iPhone only
Free (built-in)
Quick pick:
  • Any platform, get started fast: Wi-Fi (WO Mic)
  • Streaming or gaming, need low delay: USB (Android only)
  • Apple devices, zero friction: Mac Continuity Microphone
  • Basic voice call, no setup: Bluetooth
Tips for Better Audio Quality When Using Your Phone as a Mic
Getting the method working is step one. Getting it to sound decent is step two.
  • Position your phone 6 to 12 inches from your mouth. Avoid laying it flat on a desk, which picks up surface reflections and vibration.
  • Set the sample rate to 44,100 Hz in WO Mic settings. This is the standard for voice audio and gives you the best quality the app can produce.
  • Record in a quiet room. Phone mics are omnidirectional and pick up noise from all directions equally.
  • Switch to a 5GHz Wi-Fi band for Method 1. The 2.4GHz band is more congested and can cause intermittent audio dropouts.
  • Enable noise suppression in WO Mic if your environment has steady background noise like fan hum or air conditioning.
  • Know the limits. Phone mics handle voice adequately but have limited dynamic range. They will struggle with music recording or loud acoustic environments.
When you’re ready to go beyond the hassle: If the app-routing process feels too fragile or the audio quality still isn’t cutting it, the Hollyland LARK A1 offers a direct path forward. Its receiver plugs into your phone’s USB-C or Lightning port with no driver or app required, delivers 3-Level Intelligent Noise Cancellation out of the box, and eliminates the entire software chain. One cable, instant input.
Q: Can I use my iPhone as a microphone for a Windows PC?
Yes. Install WO Mic on your iPhone and use the Wi-Fi connection method. Open the WO Mic desktop client on your Windows PC, enter the IP address shown in the app, and connect. Then set WO Mic as the default recording device in Windows Sound Settings. The Mac Continuity Microphone feature is Apple-only and does not work with Windows.
Q: Does using my phone as a mic cause noticeable audio lag?
Delay depends on the method you pick. USB connection gives the lowest delay under 50 milliseconds. Wi-Fi may introduce 50 to 200 milliseconds. Also, the delay in this connection relies on your internet speed. Bluetooth causes the highest lag and is poor for real-time voice chat.
Q: Will my phone microphone show up in Zoom or Microsoft Teams?
Yes. Once your phone is set as the default recording device in Windows Sound Settings or macOS Sound Input, it appears as a standard microphone option in any app, including Zoom, Microsoft Teams, and OBS Studio. You may need to select it manually inside the app’s own audio settings on first use.
Q: Does WO Mic work on both Android and iPhone?
Yes, WO Mic supports both platforms. The USB transport mode is Android-only due to Apple’s USB audio restrictions. iPhone users should use the Wi-Fi transport method instead.
Q: Is there a way to use my phone as a mic without installing any software?
Yes, if you have an iPhone XR or later and a Mac running macOS Ventura 13.0 or later. Apple’s built-in Continuity Microphone connects automatically when both devices share the same Apple ID with Wi-Fi and Bluetooth enabled. No app installation is needed on either device.
For most users, the Wi-Fi app method using WO Mic or Apple’s built-in Continuity Microphone delivers a working phone-as-mic setup in under ten minutes. Match the method to your platform, follow the steps, and set it as your default input once. If you want to skip temporary fixes completely, consider the Hollyland LARK A1. It is an easy plug-and-play option that connects straight to your phone.
