Your webcam is connected, the video is live, but there is no audio on the call. Whether your webcam physically lacks a built-in microphone or its built-in mic has stopped being detected, this article shows each fix step by step. If the problem is not fixed after troubleshooting, you can switch to an external microphone. This option works with most video calls and recording apps.
Reasons Your Webcam May Have No Working Microphone
Two different issues can appear the same at first glance. One case is a webcam built without a microphone at all. The other case is when the microphone exists but is not detected by the computer. Identifying the correct situation helps you choose the right fix.
The four most common causes are:
No built-in microphone: Many entry-level and older webcam models ship without a microphone capsule entirely.
Mic disabled in Sound settings: Windows can mark microphone devices as disabled, making them invisible to apps until manually re-enabled.
Microphone access blocked by OS permissions: Both Windows and macOS have privacy settings that prevent apps from accessing the microphone unless you explicitly allow it.
Outdated or missing driver: A failed driver update or missing USB audio driver can cause the microphone to disappear from the system even while the camera continues to work.
How to Confirm Whether Your Webcam Has a Built-In Microphone?
Before running through fixes, confirm whether the hardware even includes a mic.
On Windows:
Right-click the Start button and open Device Manager.
Expand Audio inputs and outputs.
Look for a device entry that references your webcam brand or model name. If it appears here, the mic hardware exists, and the problem is software-side.
If nothing webcam-related appears under audio, check the webcam manufacturer’s product page and look for “built-in microphone” in the specifications section.
On macOS:
Click the Apple icon in the top-left corner of the screen, then choose System Settings.
Next, go to Sound and scroll down to the Input section.
Here, if your webcam has a built-in mic, the name would appear in the input section.
If you see names like Webcam Microphone, USB Camera, or similar names, it means that the webcam likely has an integrated mic.
Fix 1: Check Microphone Access Permissions
OS-level microphone permissions are the most frequently overlooked cause of a silent webcam. Both Windows and macOS can block all app access to a microphone without any visible warning, even when the device is functioning correctly.
On Windows 10 / Windows 11:
Open Settings and navigate to Privacy & Security (Windows 11) or Privacy (Windows 10).
Under App permissions, select Microphone.
Confirm that Microphone access is toggled On at the top of the page.
Scroll down and make sure Let apps access your microphone is also toggled On.
Check the individual app list and confirm that Zoom, Microsoft Teams, or any other call app you use shows as On.
Reconnect your webcam after any changes, then test the microphone in your preferred app.
On macOS (Ventura / Sonoma):
Open System Settings and go to Privacy & Security.
Click Microphone in the list.
Toggle on access for every app that needs mic input, including Zoom, Teams, FaceTime, or your browser if you use web-based calls.
If an app you need is not listed, launch it first and then return to this screen. macOS adds apps to the list the first time they request microphone access.
Note: On macOS, if you toggle an app off and then back on, quit and relaunch the app before testing. The permission change does not apply to an already-running app.
Fix 2: Enable the Webcam Microphone in Sound Settings
Even when permissions are correctly configured, a webcam microphone can still be invisible to apps because it is disabled at the Sound control panel level. This is one of the most common reasons a webcam mic appears in Device Manager but never shows up in Zoom or Teams.
On Windows:
Right-click the speaker icon in the system tray and select Sounds, or search “Sound” in the Start menu and open the legacy Sound control panel.
Click the Recording tab.
Right-click anywhere in the blank space within the device list and check both Show Disabled Devices and Show Disconnected Devices.
If your webcam microphone now appears in the list, right-click it and select Enable.
Right-click it again and select Set as Default Device, then also Set as Default Communication Device.
Click Apply, then OK, and test the microphone.
On macOS:
Open System Settings and go to Sound.
Click the Input tab.
If your webcam microphone appears in the input source list, click it to select it.
Move the input volume slider above zero if it has been set to the minimum.
Speak toward the webcam and confirm the input level meter responds.
Fix 3: Update or Reinstall the Webcam Driver
If the microphone still does not appear after addressing permissions and Sound settings, a corrupt or missing webcam driver is the most likely remaining cause.
On Windows:
Press Windows + X and open Device Manager.
Expand Cameras or Imaging Devices and locate your webcam in the list.
Right-click the webcam and select Update driver, then choose Search automatically for drivers.
If Windows reports the driver is already current but the mic is still missing, right-click the webcam again and select Uninstall device. Check the box to delete the driver software if the option is available.
Unplug the webcam from the USB port, wait 10 seconds, then reconnect it. Windows reinstalls the driver automatically on reconnection.
If the microphone still does not appear, visit the webcam manufacturer’s website, download the latest driver package for your exact model, and run the manual installer.
On macOS: macOS handles driver management automatically through system software updates. If your webcam mic is not detected after checking permissions and Sound settings, go to System Settings > General > Software Update and install any pending updates. USB device compatibility patches are frequently included in minor macOS releases.
When Basic Fixes Fail, Use an External Microphone
If all three fixes above have not restored your webcam microphone, or if the webcam simply has no built-in mic, adding an external microphone is an easy way out. Even when the built-in mic works, upgrading still makes sense. Webcam mics are positioned far from your mouth, so they pick up ambient noise. They also catch keyboard sounds and computer fan noise along with your voice.
A wireless clip-on microphone is the ideal category for webcam users who need hands-free, consistent audio without routing a cable across the desk. The transmitter clips to a collar or lapel just a few inches from the mouth, delivering clean, close-proximity audio regardless of how far the camera sits from you.
How to Set Up the Hollyland LARK M2 as Your Webcam Microphone?
The Hollyland LARK M2 is a wireless clip-on microphone system that connects to a Windows or macOS computer through a USB receiver dongle. The computer detects it as a standard audio input device with no driver installation required, so it works immediately in Zoom, Teams, OBS, and any other app that accepts a microphone input.
Setup steps:
Power on the transmitter: Long-press the power button on the LARK M2 transmitter (the clip-on unit) for three seconds until the LED indicator lights up.
Power on the USB receiver: Long-press the power button on the USB receiver dongle until its LED turns on.
Confirm pairing: Out of the box, the transmitter and receiver are pre-paired. The receiver LED displays a solid blue light when the transmitter is connected and actively paired. No additional pairing action is needed on first use.
Connect the receiver to your computer: Insert the USB-C receiver dongle into an open USB port on your laptop or desktop.
You can also attach the camera receiver to your PC using the USB-C cables. It also has a volume / gain knob, which is discussed below in this section.
Verify detection on Windows: Open Settings > System > Sound. Under Input, open the device dropdown and select the LARK M2, which appears as a new USB audio input device.
Verify detection on macOS: Go to System Settings > Sound > Input. The LARK M2 appears as a USB audio device in the input source list. Click it to select it.
Clip the transmitter to your collar or lapel: The transmitter weighs 9 grams and sits flat against fabric without pulling. Placing it near the collar keeps the mic capsule consistently close to your mouth, which directly addresses the distance problem that makes webcam mics sound distant and roomy.
Adjust gain if needed: Rotate the gain knob on the camera receiver to set three gain levels. The LED indicator reflects the current gain setting. Begin with the default gain and adjust only if your voice sounds too quiet or distorted in a test recording.
Route to Zoom: In Zoom, go to Settings > Audio. Open the Microphone dropdown and select LARK M2. Speak and confirm the input level bar responds.
Route to OBS: In OBS, go to Settings > Audio. Under Mic/Auxiliary Audio, open the device dropdown and select LARK M2. Close Settings and confirm the audio meter is active in the mixer panel.
Budget Option: Hollyland LARK A1 for Plug-and-Play Simplicity
For users on a tighter budget or working from a laptop with a single USB-C port, the Hollyland LARK A1 is a practical alternative. The USB-C version uses a direct receiver that plugs straight into the laptop with no separate dongle pairing involved. The computer recognizes it immediately as an audio input device, making setup a one-step process.
Key features at a glance:
Plug-and-play connection: The USB-C receiver connects directly to the laptop; no pairing steps or app setup required
3-Level Intelligent Noise Cancellation: Cycles through three noise reduction settings to reduce background noise common in home offices and shared workspaces
Compact clip-on transmitter: Lightweight design similar to the LARK M2, well-suited for video calls, remote learning, and casual recording
Does every webcam have a built-in microphone?
No. Entry-level and older webcam models frequently ship without a microphone. Check the product specification sheet on the manufacturer’s website before spending time on troubleshooting steps. If “built-in microphone” is not listed in the specs, the hardware does not exist, and an external microphone is the only option.
Why does my webcam show up in Device Manager but the microphone doesn’t?
Some webcams register the camera and the microphone as separate USB devices. The microphone may appear under “Audio inputs and outputs” rather than under “Cameras.” It may also be present but disabled. Follow Fix 2 above to reveal hidden and disabled devices in the Recording tab of Sound settings.
Can I use a wireless microphone with a webcam setup?
Yes. Wireless clip-on microphones like the Hollyland LARK M2 connect through a USB receiver dongle that the computer recognizes as a standard audio input device. No specialized software or audio interface is required. The mic appears in Sound Settings and in every major app’s microphone dropdown exactly like a wired USB microphone would.
Will fixing the webcam microphone improve audio quality on Zoom calls?
Fixing detection restores function but does not upgrade audio quality. Built-in webcam microphones have small capsules positioned several feet from the speaker, which produces thin, roomy sound. An external clip-on microphone placed near the mouth delivers noticeably cleaner, more natural audio regardless of the platform or call app being used.
Does the LARK M2 work with both Windows and macOS without installing drivers?
Yes. The LARK M2 receiver is a class-compliant USB audio device. Windows 10, Windows 11, and macOS (including Ventura and Sonoma) all detect it automatically when the receiver is connected. No driver download or installation is required on either operating system.
If permissions or settings caused the problem, the earlier fixes can usually solve it quickly. When the webcam lacks a microphone or software fixes fail, an external wireless microphone is often the better choice. The Hollyland LARK M2 connects through a USB receiver and runs on Windows and macOS without extra software. It records your voice much closer to the source than a webcam microphone can. If you want a lower-cost USB-C option, the Hollyland LARK A1 is another simple choice to consider.
