Chromebook’s streamlined design cuts out a lot of software clutter, but it also means the familiar voice recorder you might expect isn’t always easy to find. Chrome OS supports several capable recording methods, from a native app to browser tools, extensions, and even full audio editing software. This guide covers all five so you can match the right approach to your recording goal.
Does a Chromebook Have a Built-In Audio Recorder?
Yes. Most Chromebooks running Chrome OS 130 or later include a native Recorder app. If your device is older, school-managed, or enterprise-managed, the app may be absent or restricted.
Note: If you can’t find the Recorder app in your Launcher, your device may be running an older Chrome OS build, or an administrator may have blocked the app. Methods 2 through 4 below work without special permissions and require no installation.
Method 1: Use the Chrome OS Recorder App
The Recorder app is the fastest, most reliable starting point for most Chromebook users. It records directly from your built-in microphone, saves files automatically, and requires no account or internet connection. It works especially well for voice memos, lecture recordings, and quick spoken notes.
Steps:
Click the Launcher button (the circle icon at the bottom-left corner of your screen, or press the Search key).
Type “Recorder” in the search bar.
Select the Recorder app from the results to open it.
Press the red record button to start capturing audio.
Speak clearly at a consistent distance from your Chromebook’s built-in mic.
Press the Stop button when you are done.
Your recording saves automatically. Open the Files app, navigate to My Files, then open the Audio folder to find it.
Important: The Voice Recorder app captures microphone audio only. It cannot record system sounds, music playing in a browser tab, or audio output from your speakers. If you need to capture those, skip ahead to Method 3.
Method 2: Record in Your Browser With a Web-Based Tool
Browser-based recorders are the most universally compatible option. They work on every Chromebook regardless of model, Chrome OS version, or device management status. Nothing is installed, and recordings download directly to your device. The only requirement is an active internet connection.
Option A: Online Voice Recorder (online-voice-recorder.com)
Best for: clean MP3 recordings with basic trimming before download.
Open Chrome and go to online-voice-recorder.com.
Click the large microphone icon in the center of the screen.
When Chrome prompts you, click Allow to grant microphone access.
The recording starts automatically. Speak clearly into your mic.
Click the red stop button when finished.
Drag the trim handles on the waveform to cut unwanted silence at the start or end.
Click Save to download the file as an MP3.
Option B: Vocaroo (vocaroo.com)
Best for: quick recordings when a shareable link is all you need.
Go to vocaroo.com.
Click the Click to Record button.
Allow microphone access when the browser prompts you.
Click the stop button when your recording is complete.
Share via the generated link, or click Download to save the file locally.
Online Voice Recorder is the better pick when you want a downloadable MP3 with basic editing; Vocaroo is faster when you just need a shareable link.
Method 3: Use a Chrome Extension for More Control
Browser extensions are a better option for longer recording sessions. They can record your microphone along with system or browser tab audio. Many also save your recordings automatically, so you do not need to keep a browser tab open.
Chrome Audio Capture is a well-maintained, free extension built for this purpose.
Open the Chrome Web Store and search for Chrome Audio Capture.
Click Add to Chrome and confirm by selecting Add Extension.
Click the puzzle piece icon in your toolbar and pin Chrome Audio Capture for quick access.
Navigate to the tab whose audio you want to capture.
Click the extension icon and select Start Capture.
When done, click the icon again and select Save Capture.
Name the file, choose MP3 or WAV, and it downloads to your Downloads folder.
Chrome extensions are a good option for recording webinars and online classes. They can also combine your microphone and browser tab audio into one recording.
Method 4: Record With an Android App (Play Store)
Chromebooks released in 2017 or later generally support Android apps through the Google Play Store. To confirm your device supports this, go to Settings > Apps > Google Play Store. If the option appears, you can install Android apps.
Open the Google Play Store on your Chromebook.
Search for Easy Voice Recorder or another highly rated voice recorder app.
Tap Install and wait for the download to complete.
Open the app and tap the record button to begin.
Tap stop when finished and save within the app.
To access the file in Chrome OS, open the Files app and look in the Play Files section, or use the app’s share function to export it to My Files.
Android apps run in a sandboxed environment on Chrome OS, so file access between the app and the broader Chrome OS file system sometimes requires a manual export step.
Method 5: Use Audacity via Linux (For Power Users)
Audacity is the right choice if you need multi-track recording, lossless audio formats, or editing tools that no browser app can match. Setup takes 10 to 20 minutes and is not intended for casual users.
Go to Settings > Advanced > Developers and enable the Linux development environment (Beta). Follow the on-screen setup prompts.
Once complete, open the Terminal > penguin.
Run sudo apt-get update to refresh the package list.
Run sudo apt-get install audacity to install the software.
Run exit once the installation is confirmed, and go to the Linux development environment and toggle on the “Allow Linux to access your microphone” option.
Open Audacity from your Launcher.
Before recording, confirm your microphone input in Edit > Preferences > Devices.
How to Get Better Audio Quality When Recording on a Chromebook
The recording method affects what your Chromebook captures. Your recording space and equipment affect the final sound quality. A few simple habits can improve your results with any method.
Find a quiet space: Built-in laptop microphones pick up HVAC fans, street noise, and background conversation easily.
Keep the right distance: Position yourself 6 to 12 inches from your Chromebook’s built-in mic and speak directly toward it.
Reduce CPU load before recording: Close unused tabs and apps. Heavy CPU use can spin the laptop fan up, and that noise bleeds directly into recordings.
Monitor with headphones: Plugging in headphones prevents audio from your speakers from being re-captured by the mic.
The built-in Chromebook microphone is adequate for voice memos and informal notes. For meetings, interviews, content creation, or any recording where audio clarity affects the listener’s experience, an external microphone makes a significant difference. The Hollyland LARK A1 connects via USB-C and is recognized by Chrome OS instantly with no driver installation required. It includes three levels of intelligent noise cancellation, which is especially useful when recording in offices or classrooms where background noise is unavoidable. If you record from multiple locations or while on the move, the Hollyland LARK M2 weighs just 9 grams and delivers up to 40 hours of battery life, pairing wirelessly without any additional adapters.
Can I record both microphone and system audio on a Chromebook at the same time?
Yes, you can record your microphone and system audio together. Open the ChromeOS Screen Capture tool with Ctrl + Shift + Show Windows. Select Screen Record, then turn on Microphone and Chromebook audio in the settings before recording. You can also use a third-party Chrome extension for the same task.
Where are my audio recordings saved on a Chromebook?
The native voice recorder app saves files to its own internal app storage (accessible directly within the Recorder app itself). From the Recorder app, you must use the Export feature to save them to folders like My Files or Downloads. Web-based tools and Chrome extensions download recordings to the Downloads folder by default. Android apps store files in the Play Files section inside the Files app. If you cannot locate a recording, open the Files app and use the search icon to search by file name or format.
What audio format does the Recorder app use?
Your recordings are saved as WAV files in the ChromeOS Recorder app. You can play them in Chrome and most media players. Some apps may ask for an MP3 or another format. If that happens, convert the file with CloudConvert or Convertio. Both tools run directly in your Chrome browser.
Does every Chromebook have a built-in microphone?
Most Chromebook laptops already have a microphone built into them. Chromebox computers usually need a separate microphone instead. Some ChromeOS displays also come without a built-in microphone. In those cases, connect a USB or USB-C microphone before recording.
Can I use an external USB microphone with a Chromebook?
Yes. USB and USB-C microphones are plug-and-play on Chrome OS and require no driver installation. Once connected, Chrome OS detects the microphone and sets it as the default audio input automatically. You can verify the active input device and adjust input levels by going to Settings > Device > Audio.
The best recording option depends on what you plan to do. The ChromeOS Voice Recorder app is great for short recordings. Online recorders are helpful when you want nothing installed. Choose a Chrome extension for longer recordings or system audio. Android recording apps feel similar to recording on a phone. If you need editing tools, Audacity through Linux is a solid choice. Better audio starts with a better microphone, regardless of the app. The Hollyland LARK A1 connects through USB-C and works with ChromeOS immediately.
