How to Record a Google Slides Presentation with Audio (3 Methods That Actually Work)
Recording a Google Slides presentation with audio is possible in at least three different ways, and the right method depends on how much control you need and where you want the final file to live. This article explains each option from start to finish. You can record with Google's built-in tool, browser add-ons like Loom or Screencastify, or screen recording software on Mac and Windows. Pick the method that fits your workflow and get recording in minutes.
Before you open Google Slides and press record, a few quick checks will save you from restarting mid-session.
Recording usually is not the problem. Most issues start when microphone or screen permissions are missing. Check these points before you begin recording.
  • Google Chrome browser: Google Slides’ native recording feature only works in Chrome. Firefox, Safari, and Edge do not support it.
  • A Google account: You need to be signed in to save recordings to Google Drive.
  • A working microphone: Your laptop’s built-in mic will work, but audio quality is often the first thing listeners notice. A dedicated external microphone makes a significant difference. For desk-based recording, a compact wireless clip-on mic like the Hollyland LARK M2 delivers noticeably cleaner narration than a built-in laptop mic, particularly in rooms with background noise or echo.
  • Microphone permissions granted to Chrome: Chrome requires explicit permission to access your mic. You can confirm this in advance by clicking the lock icon in Chrome’s address bar, selecting Site Settings, and verifying that Microphone is set to Allow.
  • A stable internet connection: Required for the built-in Google Slides tool and browser extensions. Not required for desktop screen recorders, but needed to access your Slides deck.
  • Your presentation is open and finalized: Have all slides ready before you hit record to avoid interruptions.
Method 1: Use Google Slides’ Built-In Record Feature (Easiest)
These steps show the entire recording process inside Google Slides. You will also learn how to find, share, and delete recorded presentations. Everything is done with Google Slides' built-in tools only.
Note: Use Google Chrome or Microsoft Edge to record presentations. Recording is available only for eligible work or school accounts (not personal accounts). Each recording must stay under 30 minutes. Revision History does not show recording activity. A full Google Drive blocks new presentation recordings. You also need editing access before starting a new recording.
Phase 1: Recording
  • Open your presentation directly within Google Slides before recording.
  • Select Rec (record button icon on the top-right corner), then choose Record new video from the menu.
  • Give access to the microphone and camera on the browser.
  • Press the red recording button to begin capturing your presentation.
  • Pause recording, then select Re-record to restart from the beginning.
  • Pause recording, then choose Save to Drive for storage.
  • Enable camera blur if you prefer hiding your background.
Phase 2: Finding the Recorded Slides
  • Open Google Slides on your computer to locate recordings.
  • Access the presentation containing your saved presentation recording.
  • Click Rec to display available recordings for presentation.
  • Pick your recording from the displayed recordings list.
Note: Google stores recordings inside the Slides recordings Drive folder.
Phase 3: Sharing
Collaborators can access recordings immediately after successful creation.
  • Open the presentation containing the recording you want shared.
  • Select the recording title from the available recordings list.
  • The recording opens inside the full-screen video player.
  • Click the sharing option located near the top-right corner.
  • Choose recipients, audience, or preferred link visibility settings.
Phase 4: Deleting Recordings
  • Click Rec before removing any presentation recording.
  • Open More (three vertical dots icon), then choose Remove for selected recording.
  • Confirm removal when the verification dialog appears onscreen.
Note: Recording creators may also move the Drive file to Trash. Or else, authorized viewers will still be able to see recordings. But non-creators cannot remove recordings from the creator's Drive.
Method 2: Record with a Browser Extension (Loom or Screencastify)
Browser extensions are a strong alternative when you want an instantly shareable link, built-in viewer analytics, or more flexibility than the native tool provides. Both Loom and Screencastify are free to install and work directly inside Chrome. This method works well for async team updates, client-facing demos, and any situation where sending a URL is more practical than attaching a video file.
Note: These instructions focus on Loom, but Screencastify follows a similar process. Install the extension or app before starting your recording. Then choose to capture your screen, camera, or both together. After the recording ends, the tool creates a link you can share.
  1. Open the Chrome Web Store and search. Click Add to Chrome and follow the installation prompts.
  1. Click the extension icon in your Chrome toolbar and sign in or create a free account.
  1. Click the New Video downward arrow and select the Record a video option.
  1. Click the Video Camera icon, then choose the Window option to view the Screen options.
  1. You can select from the Window, Full Screen, or Current tab options. But since you want to record Slides, you can select the Google Slides tab to only record that specific window. And click Share.
  1. Once you are taken to your Slides tab, a Loom icon will appear on the bottom-left of the screen. Hover over the Loom icon and click on the Record a Loom option.
  1. Select Start Recording.
  2. Loom will start recording the screen.
  1. Once you are done recording Slides, you can share the link. You can also sign in to your Loom account via a browser and check all your recordings in the Library.
Note: The free version of Loom only allows you to record 25 videos, each for 5 minutes.
When to choose this method over Method 1: Use a browser extension when you need viewer tracking, want to avoid managing files in Drive, or are sharing recordings with people outside your Google Workspace.
Method 3: Use a Desktop Screen Recorder for Maximum Control
Desktop screen recorders give you the best audio fidelity, offline recording capability, and the flexibility to edit the video before you publish. This method suits content creators, teachers building course libraries, and anyone who wants to run the final file through an editor. The recording stays on your computer after it finishes. You must upload or share the file yourself afterward.
On Mac: QuickTime Player
QuickTime Player is built into every Mac and handles screen recording cleanly with no installation required.
  1. Close unnecessary apps and browser tabs to minimize distractions and background audio.
  2. Open QuickTime Player from your Applications folder or via Spotlight search.
  3. Go to File > New Screen Recording.
  1. Click the dropdown arrow next to the record button and select your external microphone as the audio source.
  2. Click the record button, then either drag to select your desired screen region or click Start Recording to capture the full display.
  3. Switch to Google Slides and press Cmd+Shift+F5 or click Slideshow > Start from beginning to enter presentation mode.
  4. Narrate through your slides at your own pace.
  5. When finished, press Cmd+Ctrl+Esc or click the stop icon in the menu bar.
  6. Go to File > Export As, choose a resolution (1080p is recommended), and save your file as an MP4.
On Windows: Xbox Game Bar or OBS Studio
Xbox Game Bar is the quickest option on Windows 10 and 11 and requires no installation.
  1. Open your Google Slides deck in Chrome.
  2. Press Win+G to open the Xbox Game Bar overlay.
  3. In the Audio panel, click the microphone icon and confirm the correct input device is selected.
  4. Click Start Recording in the Capture widget, or press Win+Alt+R.
  1. Switch to Google Slides and press F5 to enter presentation mode.
  2. Narrate through your slides.
  3. Press Win+Alt+R again to stop. The file saves automatically as an MP4 to your Videos > Captures folder.
For more control, use OBS Studio. OBS is free, open-source software that lets you configure separate audio tracks for your microphone and system audio, set custom resolutions, and add screen overlays. Setup takes longer than Xbox Game Bar, but it is the right tool if you plan to edit the recording or upload it to YouTube or a learning management system. Download OBS from obsproject.com, add a Screen Capture source and an Audio Input Capture source, then record using the same presentation workflow above.
Tips for Better Audio Quality in Your Recording
Good audio makes a bigger impression than most people expect. These steps apply regardless of which method you use:
  • Record in the quietest room available: Close windows and doors, switch off fans or HVAC if possible, and silence phone notifications before you begin.
  • Use an external microphone: Even an inexpensive clip-on mic outperforms a built-in laptop mic by reducing room reverb and keyboard noise pickup.
  • Check your audio input before you hit record: Open your operating system’s sound settings and confirm the correct microphone is selected as the active input device.
  • Do a 10-second test recording first: Play it back on headphones and listen for hiss, echo, or low volume before committing to a full session.
  • Keep a consistent distance from the mic: Clip-on mics perform best when placed 6 to 8 inches from your mouth, attached to your collar or lapel.
  • Soften hard surfaces near your recording area: A bare desk and bare walls reflect sound and add echo. A bookcase, curtain, or soft furniture behind you absorbs that reflection.
How to Save, Export, and Share Your Recording
Method
Save Location
Share Option
Google Slides native tool
Google Drive (auto-saved)
Shareable Drive link or MP4 download
Loom / Screencastify
Extension’s cloud storage
Auto-generated shareable URL
QuickTime / Xbox Game Bar / OBS
Local storage (MP4)
Upload manually to Drive, YouTube, or share by email
Does Google Slides have a built-in recording feature?
Yes. Google Slides includes a “Record” option in the Slideshow dropdown menu, accessible in Google Chrome. It records your narration, an optional webcam feed, and slide progression, and automatically saves the finished video to Google Drive. The feature is not available in other browsers such as Firefox or Safari.
Can I record a Google Slides presentation with audio on a Mac?
Yes. Open your presentation in Google Chrome and use the built-in Slideshow > Record tool for the simplest workflow. Alternatively, use QuickTime Player (File > New Screen Recording) with your microphone selected as the audio source, then enter presentation mode in Google Slides before recording.
How do I add narration to Google Slides without a screen recorder?
To add audio to one slide, choose Insert and then Audio. Select a saved Google Drive audio file for that slide. This option fits separate voice notes on individual slides easily. For one continuous narration, use Google Slides' built-in Rec button. You can record the presentation directly without another screen recorder.
Why is there no audio in my Google Slides recording?
The most common cause is that Chrome was not granted microphone permission, or the wrong audio input is selected. Click the lock icon in Chrome’s address bar, open Site Settings, and set Microphone to Allow. Then check your operating system’s sound settings to confirm your external mic is set as the default input device.
What is the best microphone for recording a Google Slides presentation?
A dedicated external microphone delivers noticeably cleaner audio than a built-in laptop mic. For a compact, wireless option suited to desk recording, the Hollyland LARK M2 provides professional-grade narration quality without cables. The transmitter clips to your shirt and feeds clean close-range audio to your laptop, cutting out the ambient room noise that laptop mics routinely pick up.
If you want the simplest option, begin with Google's built-in recording tool. It stores the finished presentation directly in your Google Drive. Pick Loom when you need a link to share immediately. Desktop recording software gives you more control during later editing. Test everything with a short presentation before recording the final version. This helps confirm your audio and video are ready.
