How to Screen Capture with Audio on Windows: 3 Methods That Actually Work
Windows includes built-in screen recording tools that many people never notice. Windows 11 offers the Snipping Tool for recording the screen and audio. Windows 10 and 11 also include the Xbox Game Bar. Both can capture system sound, microphone audio, or both together. Besides, a free recording program also covers situations that those tools cannot. So this guide explains three easy methods for Windows 10 and 11.
Which Method Is Right for You?
Before following the full guide, check the table below to pick the right method. Each option is free and can record audio. The main differences are setup time and how much control you need.
Method
Built-in / Free
System Audio
Mic Audio
Best For
Xbox Game Bar
Built-in
Quick clips, gaming, no setup
Snipping Tool
Built-in (Win 11 only)
Simple screen demos
OBS Studio
Free download
Full control, long recordings
Method 1: Xbox Game Bar (Built-in, Works on Windows 10 and 11)
Xbox Game Bar is already installed on Windows 10 and 11 systems. It saves recordings as MP4 files after capture. It is limited to one active app window during recording. It cannot capture the full desktop screen at once.
How to Enable Xbox Game Bar and Audio Permissions?
Before your first recording, confirm two settings in Windows.
  1. Open Settings and navigate to Gaming → Xbox Game Bar.
  1. Toggle “Enable Xbox Game Bar” to On.
  1. Go to Settings → Privacy → Microphone (or Privacy & Security → Microphone on Windows 11).
  1. Enable “Allow apps to access your microphone” and confirm that Xbox Game Bar has individual permission in the list that appears below the global toggle.
Note: If you don’t find the individual permission for the Game Bar, you should check the Game Bar settings. To do that, continue with the next steps.
  1. Go to the Game Bar settings page (Step 1).
  2. Click on the Captures option in the left sidebar menu and scroll to the Recorded audio section.
  1. Toggle on the “Record audio when I record a game” option. Click the checkbox next to Turn mic on by default when I record to enable this option. Also, if you just want to record the game sound, then put a checkmark on “Record game audio only.”
Note: It is recommended that you visit Settings → Gaming → Captures to review your default audio quality setting and confirm the storage folder before you start.
How to Record Your Screen with Audio
  1. Open the application window you want to record. A browser, game, video player, or any compatible app.
  2. Press Win + G to open the Xbox Game Bar overlay.
  1. In the Capture widget, click the microphone icon to toggle mic audio on or off. System audio is captured by default.
  1. Click the Record button to start, or use the keyboard shortcut Win + Alt + R to begin recording without opening the overlay at all.
  1. A small recording indicator appears in the top-right corner of your screen while capture is active.
  2. Press Win + Alt + R again, or click Stop in the status indicator, to end the session.
You can record system audio only, microphone only, or both simultaneously by toggling the microphone icon before you press Record.
Important limitation: Xbox Game Bar will not record the Windows desktop, File Explorer, or most system-level windows. If the Record button appears grayed out, bring a compatible application window into focus before opening the overlay.
Where Recordings Are Saved and Playback Options
All Xbox Game Bar recordings are automatically saved to:
C:\Users\[YourName]\Videos\Captures
Files are stored as MP4, which plays natively in Windows Media Player, the Windows 11 Media Player app, and VLC. You can also access recent clips directly inside the Capture widget by clicking “See my captures.” File sizes range from a few hundred megabytes for short clips to several gigabytes for longer sessions depending on resolution and content.
Method 2: Snipping Tool (Windows 11 Only)
The Snipping Tool gained full-screen recording capability in a Windows 11 update released in late 2022. It offers a cleaner, more straightforward experience than Xbox Game Bar for everyday screen demos. But it is exclusive to Windows 11, so if you are running Windows 10, jump to Method 1 or Method 3 instead.
  1. Open Snipping Tool from the Start menu or by searching for it.
  1. Click the video camera icon at the top of the window to switch from screenshot mode to screen recording mode.
  1. Click New, then drag to define the screen region you want to capture.
  1. Before starting, click the microphone icon in the toolbar to enable voice audio. System audio can also be toggled from the same toolbar, depending on your Windows 11 build version.
  2. Click Start to begin. A three-second countdown plays before recording starts.
  1. Click Stop when you are finished.
  2. The recording opens automatically in Snipping Tool’s preview window. Click Save or Save As to choose your preferred file location.
Snipping Tool saves recordings as MP4. Unlike Xbox Game Bar, it lets you capture any region of the screen, including the Windows desktop and File Explorer, which makes it practical for multi-app workflow demos.
Method 3: OBS Studio (Free, Full Control Over Audio)
OBS Studio is the right choice when you need multi-source audio capture, longer uninterrupted recording sessions, or precise control over output bitrate and resolution. It is free, open source, and works on both Windows 10 and 11. The initial setup requires more steps than the built-in tools, but its audio flexibility exceeds both native options by a wide margin.
Download OBS Studio from obsproject.com before starting.
Setting Up Screen Capture and Audio Sources in OBS
  1. Open OBS Studio.
  2. In the Sources panel at the bottom of the screen, click the + (Add) button.
  3. Select Display Capture from the list. Name the source, click OK, choose your display from the dropdown, and click OK again. Your desktop should now appear in the main preview canvas.
  1. Look at the Audio Mixer panel beside Sources. Two channels should already be listed: Desktop Audio (system sounds) and Mic/Aux (microphone input).
  2. Speak aloud and play a system sound. Watch the meters in the Audio Mixer. Both channels should show level activity. If a meter stays completely flat, that source is not being captured and needs configuration.
  1. To assign a missing microphone, click the three vertical dots icon on the Mic/Aux channel, select Properties, and choose your microphone device from the dropdown.
How to Record with System Audio and Microphone Simultaneously
OBS captures both Desktop Audio and Mic/Aux simultaneously by default, which is its primary advantage over Xbox Game Bar’s toggle-based approach.
  1. In the Audio Mixer, balance the two volume sliders so neither source dominates the other. A common problem is mic audio overpowering system sounds. Aim to keep mic peaks in the -6 dB to -12 dB range on the level meter.
  2. Go to Settings → Output → Recording to set your output format. Change Recording Format from MKV to MP4 for broader file compatibility. OBS defaults to MKV because it handles crashes more gracefully during long sessions, so if recording duration and stability are the priority, keeping MKV is a reasonable choice.
  1. Set your preferred recording folder under Settings → Output → Recording Path.
Starting, Stopping, and Locating Your Recording
  1. Click Start Recording in the Controls panel on the right side of OBS.
  2. Recording begins immediately with no countdown.
  1. Click Stop Recording when you are done.
  2. Your file saves to the path defined in Output settings. The default location is:
To open the recordings folder directly, go to File → Show Recordings inside OBS.
Recording System Audio vs. Microphone Audio: What’s the Difference?
These two audio types confuse many first-time recorders, and misunderstanding them is the root cause of most silent-recording problems.
Recording System Audio vs. Microphone Audio — What’s the Difference?
System audio, also called desktop or internal audio, includes every sound your computer plays. This covers streaming music, video sound, game effects, and notification alerts. It is the same audio you hear through speakers or headphones.
Microphone audio is captured from a physical input device, such as your laptop’s built-in mic or an external microphone connected to your system. It records your voice, ambient room noise, and anything else physically audible near the device.
When to use each:
  • System audio only: Software walkthroughs, game recordings, or any session where voice commentary is not needed.
  • Microphone only: Presentations or narrations where system sounds would be distracting to the listener.
  • Both simultaneously: Tutorial videos, game commentary, or remote training recordings where your voice and the on-screen audio both carry meaning.
Fixing Screen Recordings with No Audio
If your recording plays back as silent video, work through this checklist:
  • Audio source not selected before recording started: The most frequent cause. In Xbox Game Bar, confirm the microphone toggle was in the correct state before pressing Record. In OBS, verify both Audio Mixer meters were showing level activity before you started.
  • Microphone permission blocked in Windows privacy settings: Go to Settings → Privacy (or Privacy & Security on Windows 11) → Microphone. Enable the global toggle and confirm that per-app permission is active for your specific recording tool.
  • The application uses exclusive audio mode: Some apps lock audio output to prevent other software from intercepting it. Check the app’s audio settings or switch to system-wide audio capture in OBS rather than application-specific capture.
  • OBS Desktop Audio device set to Disabled: Go to Settings → Audio in OBS and confirm the Desktop Audio device is set to your active output device rather than “Disabled.”
  • Default playback or recording device mismatch in Windows Sound settings: Right-click the speaker icon in the taskbar, open Sound Settings, and confirm the correct output and input devices are set as default. A mismatched default device will cause silent captures even when all permissions are correctly enabled.
Getting Cleaner Microphone Audio in Your Screen Recordings
A laptop’s built-in microphone captures keyboard clicks, fan hum, and room echo alongside your voice. A few adjustments make a noticeable difference:
  • Use a dedicated external microphone rather than the built-in laptop mic.
  • Position it 6 to 12 inches from your mouth, angled slightly off-axis from your lips to reduce plosive sounds.
  • Enable noise suppression in OBS by adding a Noise Suppression filter to the Mic/Aux channel, or activate Windows’ built-in noise cancellation in Sound Settings.
Being a creator, you often need to work on tutorials, commentary, or social media content. The Hollyland LARK M2 wireless mic makes your everyday audio recordings smooth. It weighs just 9g and offers up to 40 hours of battery life. Its USB receiver sends clearer voice audio into Windows recordings without cables.
Can I record my screen with audio on Windows without installing any software?
Yes. Xbox Game Bar is built into both Windows 10 and Windows 11 and supports system audio, microphone audio, or both simultaneously. The Snipping Tool on Windows 11 also records screen and audio natively. Neither requires a download or installation. See Method 1 and Method 2 above for complete walkthrough steps.
How do I record just the internal computer audio, not my microphone?
In Xbox Game Bar, leave the microphone toggle off in the Capture widget before you start recording. In OBS Studio, mute or remove the Mic/Aux channel in the Audio Mixer. In Snipping Tool, leave the microphone icon toggled off. Only desktop audio will be included in the final file.
Does Xbox Game Bar record audio in the background?
No. Xbox Game Bar requires a focused, active application window to function. It cannot record the Windows desktop, File Explorer, or most system-level windows. If the Record button appears grayed out in the overlay, switch to a compatible application such as a browser, game, or media player and try again.
Why does my screen recording have good video but no audio?
The problem usually happens because the audio source was not turned on. Check microphone permissions in Windows Privacy settings before recording. Also confirm the correct audio source is selected and active. Do this before clicking the Record button.
What file format does Windows screen capture save in?
Xbox Game Bar and Snipping Tool both produce MP4 files by default, which are compatible with most media players and platforms. OBS Studio defaults to MKV for stability during long sessions but can be changed to MP4 in Settings → Output → Recording Format.
Does audio sync lag in Windows screen recordings?
Xbox Game Bar clips are generally sync-accurate for short recordings. In OBS Studio, minor sync issues can occur when audio buffer settings are mismatched. To correct this, open the Advanced Audio Settings panel in OBS by clicking the gear icon on the affected audio channel, then adjust the Sync Offset value until audio and video align correctly.
Xbox Game Bar is the best choice for most people getting started. It comes preinstalled and records system and microphone audio together. You can save recordings as MP4 files with a simple keyboard shortcut. Windows 11 users can choose Snipping Tool for selected screen areas. OBS Studio is better for advanced audio controls and longer recordings. Pick the option that matches your Windows version and recording needs.
