Getting sequence settings wrong at the start of a project is one of the most common mistakes in Premiere Pro. The wrong frame rate, resolution, or audio sample rate can cause playback issues, unexpected scaling, and quality problems that no amount of exporting will fix. This guide explains every key setting in the New Sequence dialog, explains what each field actually does, and gives you ready-to-use configurations for the most common project types.
What Are Sequence Settings in Premiere Pro?
A sequence in Premiere Pro is the workspace where you assemble and edit your footage. You can think of a sequence like the canvas of your timeline. These settings control that canvas, including frame rate, screen size, and audio playback during editing.
Sequence settings are different from export settings. But many new editors often mix these two up. Sequence settings control how Premiere Pro processes and previews your footage while you work. Export settings, accessed through Export > Media, control the final output file. You could have a 1080p sequence and export at 4K, or the reverse, though neither is good practice.
Getting these settings right from the start prevents rendering problems, avoids unnecessary transcoding, and ensures your editing environment matches both your footage and your delivery platform.
How to Open and Create a New Sequence?
There are two main ways to create a new sequence in Premiere Pro.
Method 1: File Menu
Open Premiere Pro and load or create a project.
Go to File > New > Sequence.
The New Sequence dialog opens with three tabs: Sequence Presets, Settings, Tracks, and VR Video
Choose a preset or configure settings manually, name your sequence, and click OK.
Method 2: Project Panel
Right-click in an empty area of the Project panel.
Select New Item > Sequence.
The same New Sequence dialog will appear.
You can also click the New Item button (the page icon) at the bottom of the Project panel and select Sequence from the dropdown menu.
Pro Tip: The fastest way to create a sequence that perfectly matches your footage is to drag a clip directly from the Project panel onto the timeline. Premiere Pro will prompt you to either keep your existing sequence settings or match the sequence to the clip. Choosing “Change sequence settings” sets everything automatically with no manual setup needed.
Accessing Settings for an Existing Sequence
To modify a sequence you have already created, go to Sequence > Sequence Settings in the top menu bar.
Select the sequence in the timeline or Project panel.
Go to Sequence > Sequence Settings and make your adjustments.
Note: changing settings mid-project will delete any rendered preview files and may introduce playback inconsistencies. Confirm your sequence settings before you begin editing whenever possible.
The Four Tabs Explained: Sequence Presets, Settings, Tracks, and VR Video
When the New Sequence dialog opens, four tabs appear at the top. Understanding what each one does helps you navigate the dialog without guesswork.
Sequence Presets: A library of pre-built configurations organized by camera format and standard, including AVCHD, DSLR, RED, ProRes, NTSC, and PAL. If your footage matches one of these formats, starting with a preset is the fastest and most reliable approach. Selecting a preset automatically fills in all the values on the Settings tab.
Settings: Where you manually configure or fine-tune every parameter, including editing mode, frame rate, resolution, pixel aspect ratio, preview codec, and audio. Use this tab for mixed-format footage or any format not covered by the presets.
Tracks: Sets the default number and type of video and audio tracks added when the sequence is created. This is a workflow preference and does not affect video or audio quality.
VR Video: The VR Video section inside Sequence Settings prepares your timeline for 360-degree footage and VR projects. It helps stitched clips display correctly inside preview monitors. The settings also add proper spatial data during export. This allows platforms like YouTube and Facebook to recognize VR content correctly.
For most projects, start on the Sequence Presets tab, find the closest match to your footage, then switch to the Settings tab to verify and adjust as needed.
Core Sequence Settings Breakdown
The Settings tab is where the important decisions happen. Here is what each field means and what value to choose.
Editing Mode
Editing mode determines which codecs are available for preview rendering and how Premiere Pro handles footage that does not natively match the sequence. Options include AVCHD, DSLR, RED Cinema, Apple ProRes (on Mac), and others.
For maximum flexibility, set editing mode to Custom. This unlocks all fields on the Settings tab and removes format restrictions. If your primary footage format is listed, such as AVCHD for Sony mirrorless cameras, selecting that mode can improve playback efficiency. Mismatching editing mode to your footage does not break the edit, but it can force unnecessary background transcoding and slower preview rendering.
Timebase (Frame Rate)
Timebase is the sequence’s internal clock — the number of frames it divides each second into. Every clip placed on the timeline is interpreted against this clock, which is why matching the timebase to your source footage is essential.
The most commonly used values are:
23.976 fps — The standard for cinematic content, narrative film, and most streaming platforms.
29.97 fps — Broadcast standard for NTSC regions (North America, Japan). Common for YouTube and general web video.
25 fps — Broadcast standard for PAL regions (Europe, Australia, much of Asia).
59.94 / 60 fps — Used for sports, gaming, and high-motion content where smooth playback is a priority.
Always set the timebase to match your primary source footage. Mixing footage with different frame rates on a single timeline is possible, but it requires Premiere Pro to interpret the alternate clips, which can introduce stuttering or duplicated frames if not handled carefully.
Frame Size (Resolution)
Frame size sets the pixel dimensions of the editing canvas. The most common values are:
1920×1080 — Standard 1080p HD, the default for most web, social, and broadcast delivery.
3840×2160 — 4K UHD, for when your camera records in 4K and your output platform supports it.
1080×1920 — Vertical format for TikTok, Instagram Reels, and YouTube Shorts.
Alongside frame size, always check Pixel Aspect Ratio. For virtually all modern digital camera footage, this must be set to Square Pixels (1.0). Any other value will cause your video to appear stretched or squished. Anamorphic lens workflows are the rare exception.
Preview Codec and Renderer
The preview file format and renderer control how Premiere Pro generates preview files when you render sections of the timeline. These settings affect playback smoothness and render speed during editing, not the quality of your final exported video.
In the Video section of the Settings tab, make sure to check the GPU acceleration option. This uses your graphics card to maximize your render quality.
For the preview file format, I-frame codecs such as GoPro CineForm or Apple ProRes (on compatible systems) produce smoother preview playback than compressed long-GOP codecs because every frame is a keyframe. If neither option is available, the default codec for your editing mode will work — just expect more dropped frames on effects-heavy timelines.
Audio Settings
Two audio parameters matter most at the sequence level:
Sample Rate: Set this to 48000 Hz for any video project. This is the broadcast and professional production standard. Use 44100 Hz only for music-only or podcast projects where that rate is conventional.
Display Format: Controls how audio time is displayed in the timeline (audio samples, milliseconds) and is largely a preference setting rather than a quality parameter.
Getting the sample rate right prevents Premiere Pro from resampling your audio on import, which adds processing overhead and can introduce subtle quality loss. If you record with a professional wireless microphone such as the Hollyland LARK MAX 2, which captures audio natively at 48 kHz / 32-bit Float, setting the sequence to 48000 Hz means those files drop straight into the timeline without any conversion, preserving full fidelity.
Summary Reference Table
Setting |
Common Value |
When to Change |
Editing Mode |
Custom |
Match to specific camera format (AVCHD, RED) for optimized playback |
Timebase |
23.976 or 29.97 fps |
Match primary source footage; 25 for PAL, 60 for sports or gaming |
Frame Size |
1920×1080 |
Use 3840×2160 for 4K; 1080×1920 for vertical social content |
Pixel Aspect Ratio |
Square Pixels (1.0) |
Only change for anamorphic or legacy broadcast formats |
Renderer |
GPU Acceleration |
Switch to Software Only if GPU causes instability |
Preview Codec |
GoPro CineForm or ProRes |
Adjust based on system performance and available codecs |
Audio Sample Rate |
48000 Hz |
Use 44100 Hz for music-only or podcast-only projects |
Best Sequence Settings by Project Type
Rather than configuring from scratch each time, use this table as a ready reference for the most common project types.
Project Type |
Frame Size |
Frame Rate |
Audio Sample Rate |
YouTube (HD) |
1920×1080 |
29.97 or 24 |
1.0 |
48000 Hz |
YouTube (4K) |
3840×2160 |
29.97 or 24 |
1.0 |
48000 Hz |
TikTok / Reels |
1080×1920 |
29.97 or 30 |
1.0 |
48000 Hz |
Cinematic Film |
1920×1080 or 4K |
23.976 |
1.0 |
48000 Hz |
Broadcast (PAL) |
1920×1080 |
25 |
1.0 |
48000 Hz |
Gaming / Sports |
1920×1080 or 4K |
59.94 / 60 |
1.0 |
48000 Hz |
Note: Both 24 fps and 29.97 fps are fully supported. Choose based on the aesthetic you want. 24 fps reads as more cinematic; 29.97 fps looks like standard video and works well for talking heads, vlogs, and tutorial content.
How to Match Sequence Settings to Your Footage?
When you already have footage imported and want the sequence to reflect it exactly, Premiere Pro’s built-in match feature removes the guesswork.
Import your primary clip into the Project panel.
Right-click the clip.
Select New Sequence From Clip. Premiere Pro creates a new sequence with settings that precisely match the clip’s codec, frame rate, and resolution.
Alternatively, if a sequence already exists:
Drag the clip onto the timeline.
If the clip does not match the sequence, Premiere will display a Clip Mismatch Warning dialog.
Select Change sequence settings to automatically update the sequence to match the clip.
Note: If your project includes multiple footage types, such as 4K A-camera footage alongside 1080p b-roll, match the sequence to your primary camera and let Premiere scale the secondary clips. Similarly, if your delivery requirement is a locked specification, for example, a broadcast spec at 25 fps, keep those settings fixed regardless of which clip types end up in the timeline.
Common Sequence Settings Mistakes to Avoid
Even experienced editors run into these. Here is what to watch for:
Using 30 fps instead of 29.97 fps: True 30 fps and drop-frame 29.97 fps are not interchangeable. Mixing them in a broadcast or long-form project creates audio drift over time. Use 29.97 for NTSC-region video unless you have a specific reason to use whole-number frame rates.
Leaving the renderer on Software Only: If your system has a compatible GPU, Software Only mode wastes processing power and produces a noticeably worse editing experience. Always verify that GPU Acceleration is selected.
Confusing sequence resolution with export resolution: Your sequence can be 1080p while you export to 4K. But this does not add real detail to the image. It only enlarges a lower-quality picture during export. Set sequence resolution to match or exceed the final output.
Wrong pixel aspect ratio: Selecting anything other than Square Pixels (1.0) for standard digital camera footage will distort the image. This is easy to overlook because the canvas may look normal at first glance until you inspect a circular object or a human face closely.
Setting audio to 44100 Hz for a video project: Most cameras, recorders, and professional audio gear operate at 48000 Hz. Using 44100 Hz forces Premiere to resample all incoming audio, adding processing overhead and a small but real risk of quality loss throughout the project.
Q: Should sequence settings match my camera footage?
Yes. Matching the sequence frame rate and resolution to your primary source footage avoids quality loss and unnecessary rendering overhead. Use “New Sequence From Clip” or the drag-to-timeline mismatch dialog for a fast automatic match. You only need to deviate from your source footage specs when delivery requirements dictate a specific format.
Q: Can I change sequence settings after I’ve already edited?
Yes, through Sequence > Sequence Settings, but doing so will delete all rendered preview files and may cause clip scaling or frame rate interpretation issues on clips already in the timeline. It is always better to confirm your sequence settings before you start cutting.
Q: What sequence settings should I use for YouTube 4K?
Set the frame size to 3840×2160, choose 29.97 or 23.976 fps depending on your footage and intended style, keep pixel aspect ratio at 1.0 (Square Pixels), and set the audio sample rate to 48000 Hz. Enable GPU Acceleration in the renderer for smooth 4K preview playback during the edit.
Q: Do sequence settings affect final export quality?
Sequence settings define your editing environment, while export settings via Export > Media control the output file. But if your sequence resolution is lower than your intended export resolution, upscaling at export cannot recover the missing detail because it is hidden. So, when you upscale during export, Premiere Pro recalculates the image. It redraws using original high-resolution pixel data. Therefore, always configure your sequence to match or exceed your delivery specification.
A good sequence setup follows a short checklist. Begin by selecting a preset that fits your footage type. Then review frame rate and resolution in the Settings panel. Set pixel format to Square Pixels with a value of 1.0. Keep audio at 48kHz for proper sync during editing. Also, select GPU Acceleration before starting your project. Checking these at the start helps keep editing stable from beginning to export.
