iPhone Color Space in Premiere Pro: How to Fix and Manage It Correctly
If your iPhone footage looks washed out, blown out, or oddly green after importing into Premiere Pro, you are not dealing with a camera problem. You are dealing with a color space mismatch. iPhone records in several different color profiles depending on your camera settings, and Premiere Pro does not always handle them automatically. This guide walks through each iPhone color format and the exact workflow to correct it in Premiere Pro.
Why iPhone Footage Looks Wrong in Premiere Pro
The iPhone is not a single-format camera. Depending on your settings, it records in Rec. 709, HLG, Dolby Vision, or Apple Log, each with a different gamma curve and color gamut. When you drop that footage into a default Premiere Pro Rec. 709 SDR timeline, the software may not interpret the embedded metadata correctly, and the result looks flat, overexposed, or color-shifted.
The mismatch happens because iPhone HDR formats (HLG and Dolby Vision) encode brightness and color information for displays that can handle wide color volume. A standard SDR timeline in Premiere Pro is not that display. Without a proper conversion, the software renders HDR luminance values into SDR range by clipping or compressing them poorly, which is why highlights blow out and midtones lose saturation.
Apple Log adds a different layer of complexity. It is a flat, logarithmic format designed for maximum dynamic range in post-production. Without a correction LUT applied, Apple Log footage will look desaturated, low-contrast, and noticeably green-tinted in Premiere Pro. Understanding which format you actually recorded is the first step to fixing any of these problems.
iPhone Video Color Profiles Explained
Before applying any correction, you need to identify which color profile your iPhone used. The table below covers every format the iPhone currently produces.
Recording Mode
Color Space
Where to Enable It
Common Use Case
Standard Video
Rec. 709
Settings > Camera > Video > SDR
Everyday shooting, simple delivery
HDR Video (HLG)
Rec. 2020 HLG
Settings > Camera > Video > HDR
HDR content, bright outdoor scenes
Dolby Vision
Rec. 2020 PQ
Default HDR on most iPhones
Automatic HDR, consumer delivery
Apple Log
Apple Log / wide gamut
iPhone 15 Pro+ Log video toggle
Professional flat capture, maximum grading latitude
ProRes (Standard or Log)
Rec. 709 or Apple Log
iPhone 15 Pro+ ProRes setting
High-bitrate professional workflow
You can check which format was recorded by inspecting the clip in Premiere Pro’s Project panel. Right-click the clip, select Properties, and look at the Video Codec and color metadata fields. This confirms what you are working with before touching any settings.
Setting Up Premiere Pro for iPhone Footage
Getting the sequence and color management settings right before you begin editing prevents errors from compounding downstream. There are two setup areas to address.
Sequence Settings: Rec. 709 SDR vs. HDR Timeline
The sequence you create should match your intended delivery format, not your source format. For most editors delivering to social media, YouTube SDR, or broadcast, a Rec. 709 SDR timeline is the correct starting point.
  1. Go to File > New > Sequence.
  2. Choose a preset that matches your frame rate and resolution (for example, AVCHD 1080p30 or a custom setting for HEVC footage).
  3. Click the Settings tab at the top of the New Sequence dialog.
  4. Under Video, confirm the Working Color Space is set to Rec. 709.
  5. If you are delivering HDR content for YouTube HDR or another HDR platform, change the Working Color Space to Rec. 2020 HLG or Rec. 2020 PQ to match your source and output target.
Mismatching the sequence color space and your source footage is the single most common cause of color problems. An HDR clip placed in an SDR timeline will always look wrong until you apply a conversion. It does not correct itself automatically.
Enabling Color Management in Premiere Pro
Premiere Pro allows you to direct color space transforms between your source clips, working timeline, and output. For iPhone footage, the two key controls are the Working Color Space in Sequence Settings and the per-clip Input LUT in the Lumetri Color panel.
  1. Open Sequence > Sequence Settings for your active sequence.
  2. Confirm the Working Color Space field matches your delivery target (Rec. 709 for SDR).
  3. For HDR clips placed in an SDR timeline, select the clip in the timeline and open the Lumetri Color panel.
  4. Under Basic Correction, locate the Input LUT dropdown at the top of the panel.
  5. This is where you will apply color space conversion LUTs for HDR and Apple Log footage in the sections below.
Note: Premiere Pro does not offer fully automatic color space management the way DaVinci Resolve does. You are manually directing the conversion for each clip type, which is why identifying your source format first is essential.
Correcting Standard iPhone Footage (Rec. 709)
Standard iPhone video shot in SDR mode is the simplest scenario. The footage is already tagged as Rec. 709, which matches a standard Premiere Pro SDR timeline, so no LUT is required and you can grade directly in Lumetri Color using the standard Exposure, Contrast, and Color Wheels controls.
The main issue you may encounter is inconsistent color between clips shot in different lighting conditions. This is normal exposure variation, not a color space problem, and it responds well to basic Lumetri corrections.
To confirm a clip is being read correctly:
  1. Right-click the clip in the timeline and select Modify > Interpret Footage.
  2. Under Color Space, verify that Premiere Pro has assigned Rec. 709 to the clip.
  3. If it has been incorrectly tagged, override it manually here.
Once confirmed, standard Lumetri grading applies with no additional transforms needed.
Handling HDR iPhone Footage (HLG and Dolby Vision) in a Premiere Pro Timeline
HDR iPhone footage in an SDR timeline is the most common pain point editors report. HLG and Dolby Vision clips encode brightness levels that exceed SDR range, so they appear blown out, washed out, or desaturated when Premiere Pro renders them without a tone mapping conversion. You have two workflow options: convert the HDR footage to SDR for standard delivery, or maintain an HDR timeline for an HDR output.
Converting Dolby Vision / HLG to SDR (Rec. 709 Output)
This is the recommended path if you are delivering for Instagram, YouTube SDR, or any standard web platform.
  1. Place your HDR clip in a Rec. 709 SDR sequence.
  2. Select the clip in the timeline and open the Lumetri Color panel.
  3. At the top of Basic Correction, click the Input LUT dropdown.
  4. Select Browse and load a Rec. 2020 HLG to Rec. 709 or Rec. 2020 PQ to Rec. 709 conversion LUT. Apple and several third-party providers supply these free of charge.
  5. Alternatively, right-click the clip in the timeline and select Modify > Interpret Footage. Under Color Space Override, change the color space assignment to force Premiere Pro to re-interpret the clip correctly.
  6. Once the conversion is applied, the image should appear properly exposed. You can now apply standard Lumetri grading on top.
Pro Tip: Apply the conversion LUT to an adjustment layer placed above all HDR clips rather than adding it clip by clip. This saves significant time on multi-clip sequences and makes it easy to swap the LUT if needed.
Keeping an HDR Timeline (HDR Output)
If you are delivering HDR content for YouTube HDR, Apple TV, or another platform that supports it, keep the sequence in HDR throughout.
Set your sequence Working Color Space to Rec. 2020 HLG to match standard iPhone HDR output. Your iPhone HDR clips will sit in the timeline without needing a conversion LUT. Be aware that if you are editing on an SDR monitor, Premiere Pro tone-maps the preview for display purposes, which may not fully represent the final HDR output. For accurate HDR grading, a calibrated HDR display is strongly recommended.
Apple Log Workflow in Premiere Pro (iPhone 15 Pro and Later)
Apple Log, available on iPhone 15 Pro, Pro Max, and later models, captures the widest dynamic range of any iPhone recording mode. In Premiere Pro, raw Apple Log footage appears flat, very low contrast, and with a visible green cast. This is expected behavior. Apple Log is not a deliverable format. It requires a conversion step before grading.
Applying the Apple Log to Rec. 709 Conversion LUT
Apple provides an official Apple Log to Rec. 709 conversion LUT available as a free download from the Apple support website. This LUT is also commonly bundled with ARRI color tools and third-party LUT packs.
  1. Download the Apple Log to Rec. 709 LUT from Apple’s official support page (search “Apple Log video profile” on support.apple.com to find the current download link).
  2. In Premiere Pro, select your Apple Log clip in the timeline.
  3. Open the Lumetri Color panel.
  4. Under Basic Correction, click the Input LUT dropdown and select Browse.
  5. Navigate to the downloaded LUT file (.cube format) and apply it.
  6. The footage should now display with correct Rec. 709 contrast, saturation, and white balance. The green cast will be resolved.
Note: Always apply the conversion LUT in the Input LUT slot under Basic Correction, not in the Look slot under the Creative tab. Input LUT is the correct placement for a technical color space conversion. The Look slot is for creative grades applied after the conversion is complete.
Color Grading Apple Log Footage After Conversion
Once the Apple Log to Rec. 709 LUT is in place, the footage behaves like any standard Rec. 709 clip in Lumetri Color. You can use Exposure, Contrast, Highlights, Shadows, and Color Wheels to achieve your creative look.
For efficiency across multiple Apple Log clips, apply the conversion LUT to an adjustment layer that spans all your Log clips rather than adding it to each clip individually. A second adjustment layer above can carry your creative grade. This two-layer structure keeps technical correction separate from creative choices, making adjustments faster and more organized throughout the edit.
Export Settings to Preserve iPhone Color Accuracy
Correct in-timeline work can still be undermined at export if the color space settings do not match the timeline. Use the table below as a quick reference.
Delivery Target
Export Codec
Color Space Setting
Notes
YouTube SDR / Social Media
H.264 or HEVC
Rec. 709
Standard web delivery; confirm timeline color space matches
YouTube HDR
HEVC (H.265)
Rec. 2020 HLG or PQ
Enable HDR metadata in export settings
Broadcast / Master File
ProRes 422 HQ
Rec. 709
Use for archive or further post work
Client Deliverable (HDR)
ProRes 4444 or HEVC
Rec. 2020 PQ/HLG
Confirm with client display specifications first
To access these settings in Premiere Pro, go to File > Export > Media or send to Adobe Media Encoder. Under the Video tab, locate the Color Space or HDR section to confirm or override the output color space before rendering.
The most common export mistake is leaving the output color space set to Auto when your timeline is HDR. This can produce a file that looks correct on your edit monitor but appears washed out or too dim when uploaded to a platform expecting SDR.
Troubleshooting Common iPhone Color Space Problems in Premiere Pro
Use this as a quick diagnostic reference when something looks wrong in your timeline.
  • Footage looks washed out or flat: Most likely Dolby Vision or Apple Log footage without a color space conversion applied. Apply the appropriate Input LUT or use Color Space Override in Modify > Interpret Footage.
  • Footage is over-bright with blown highlights: An HDR clip (HLG or Dolby Vision) has been placed in an SDR Rec. 709 sequence without tone mapping. Apply a Rec. 2020 to Rec. 709 conversion LUT or switch to an HDR sequence.
  • Color shifts between clips on the same timeline: Mixed color spaces are present. Some clips may be Rec. 709 while others are HLG or Dolby Vision. Apply per-clip Input LUTs or use an adjustment layer to normalize all HDR clips before grading.
  • Colors look correct on your monitor but wrong after export: A mismatch exists between the timeline Working Color Space and the export color space setting. Confirm both match your intended delivery format before rendering.
Q: Does Premiere Pro automatically detect iPhone color space?
Premiere Pro reads embedded metadata from iPhone clips but does not always apply the correct color transform automatically. Dolby Vision and Apple Log footage in particular require manual correction. Automatic interpretation works more reliably for standard Rec. 709 iPhone video. Always verify clip properties and check your preview before assuming the color space is being handled correctly.
Q: Should I shoot iPhone video in Log or HDR for Premiere Pro editing?
Apple Log (iPhone 15 Pro and later) offers the most grading flexibility but requires a conversion LUT and more post-production work. HLG is a practical middle ground for HDR delivery with less complexity. Standard Rec. 709 is the simplest option and works immediately in Premiere Pro with no conversion, though it offers less dynamic range to recover in post.
Q: What color space is iPhone 15 Pro Apple Log?
Apple Log uses a proprietary logarithmic gamma curve mapped to a wide color gamut that exceeds Rec. 709. It is not identical to log formats from other camera manufacturers. Apple provides an official conversion LUT to transform Apple Log footage to Rec. 709 for standard delivery, or to BT.2020 for wide-gamut HDR outputs.
Q: Why does my iPhone footage look green in Premiere Pro?
A green cast on import is the most recognizable symptom of Apple Log footage without a correction LUT applied. The logarithmic encoding and wide-gamut color data creates this appearance in a standard Rec. 709 timeline. Apply Apple’s official Apple Log to Rec. 709 LUT as an Input LUT in the Lumetri Color Basic Correction panel to resolve it immediately.
Q: Can I edit Dolby Vision footage in Premiere Pro?
Yes, but Premiere Pro does not process Dolby Vision metadata through a Dolby-certified pipeline. The recommended approach is to treat Dolby Vision iPhone footage as Rec. 2020 PQ and apply a PQ to Rec. 709 tone-mapping conversion LUT for SDR delivery, or place it in a Rec. 2020 HLG or PQ sequence if you are delivering an HDR output.
Next Steps
Identify your iPhone recording format first, then apply the matching workflow: Rec. 709 needs minimal setup, HLG and Dolby Vision need tone mapping or an HDR sequence, and Apple Log requires a conversion LUT before any grading begins. Getting that first step right solves most color problems before they compound at export.
