That dark video you see after exporting your project is no surprise! Why? Because many editors face this very same problem. There are a couple of reasons behind it. The camera ISO is set too low. The aperture is too tight. Or, the lighting messed up. But with Adobe Premiere Pro, you still have hope, as it offers a few solid tools to fix clips that are too dark without needing to leave the timeline. This guide explains three different ways to brighten your footage. Two of them involve the professional Lumetri Color panel. Whereas the third method uses a simple effect made for beginners. You can choose any of them that makes your job done!
Why Your Video Looks Too Dark in Premiere Pro?
Underexposure usually starts during filming. It can happen when ISO is set incorrectly. A small aperture or weak lighting also causes it. Sometimes, automatic camera modes read the scene wrong and make it too dark. All methods in this guide are non-destructive. You can change settings anytime without harming original files. You can also undo or refine edits freely during the process. But before you continue, remember that these tools only fix exposure levels. Do not expect magic, as they cannot bring back details that were not captured.
Method 1 — Use the Lumetri Color Panel (Best for Most Users)
The Lumetri Color panel is Premiere Pro’s built-in color correction engine and the best starting point for almost any brightness problem. Follow these steps:
Switch to the Color workspace. Go to Window > Workspaces > Color. This docks the Lumetri Color panel and Lumetri Scopes side by side for easy access.
Select your clip in the Timeline. Click the clip you want to correct. The Lumetri Color panel links to it automatically.
Expand the Basic Correction section. Inside the Lumetri Color panel, click the arrow next to Basic Correction to open it.
Raise the Exposure slider. This is the primary brightness lever. Drag it to the right to lift overall luminance. A value somewhere between +0.5 and +1.5 handles most underexposed footage.
Refine with the tone controls. Once Exposure is set, use the remaining sliders to balance the image:
Highlights: Pull left to bring back bright areas that are starting to clip.
Shadows: Push right to open up detail in darker areas.
Whites: Sets the ceiling for the brightest tones in the image.
Blacks: Sets the floor for the darkest tones and preserves shadow depth.
Working through these controls in order produces a natural, balanced result rather than a flat or blown-out image.
Pro Tip: Set Exposure first, then only reach for the individual tone sliders if a specific tonal range looks off. Adjusting all five controls at once tends to introduce more problems than it solves.
How to Read the Waveform Scope While Brightening?
Relying solely on your monitor to judge brightness is risky, especially on an uncalibrated display. To open the Lumetri Scopes panel, go to Window > Lumetri Scopes, then right-click inside the panel and confirm that Waveform (Luma) is checked. The waveform plots every pixel’s luminance from 0 (pure black) at the bottom to 100 IRE (broadcast white) at the top. As you raise Exposure, watch the waveform lift and aim to keep the brightest elements of your shot below 100 IRE to avoid clipping highlights.
Note: If you are delivering for broadcast, keeping highlights at or below 100 IRE is a hard technical requirement, not just a guideline.
Method 2 — Use the Curves Tool for Precision Brightness Control
Still inside Lumetri Color, the Curves section gives you point-based control over specific tonal ranges. This is the better choice when only your midtones need lifting or when the Exposure slider is affecting too broad a range.
Expand the Curves section in the Lumetri Color panel.
Adjust Luma in the RGB Curves. Make sure the "White" color is selected. It is the master curve that is responsible for Luma. It is represented by a straight diagonal line in white. The other three colors (Red, Green, and Blue) help adjust the value of the RGB channels.
Place a midpoint anchor. Click in the center of the line to add a control point that targets the midtones.
Drag the anchor upward. Pull it up and slightly left to lift the midtones without shifting the extremes.
Add a shadow anchor. Click near the lower-left quarter of the curve and leave it close to its original position to prevent the blacks from lifting too much.
Add a highlights anchor. Click near the upper-right quarter and hold it from rising above the top of the graph to cap the highlights and avoid clipping.
This method offers much finer control than the Exposure slider. Choose Curves when you need to lift only the midtones, when the Exposure slider is creating a hazy lifted-black look, or when you need to preserve the specific character of your shadows and highlights at the same time.
Method 3 — Apply the Brightness & Contrast Effect
For a faster, less technical approach, the Brightness & Contrast effect works without switching workspaces or opening additional panels.
Open the Effects panel (Window > Effects).
Navigate to Video Effects > Color Correction > Brightness & Contrast.
Drag the effect onto your clip in the Timeline.
Open the Effect Controls panel (Window > Effect Controls) and raise the Brightness value.
Increase Contrast slightly if the image looks flat after brightening.
The main drawback of this effect is that it applies a flat, linear shift across all tonal values. So, raising the brightness value too much causes highlights to clip sharply. There is no smooth rolloff in bright areas. Therefore, use this method for quick fixes only; for footage where tonal accuracy matters, Lumetri Color will give better results.
Use an Adjustment Layer to Brighten Multiple Clips at Once
If your sequence contains many clips shot under similar conditions, applying corrections one clip at a time is inefficient. An Adjustment Layer lets you correct an entire section of the timeline in one pass.
Go to File > New > Adjustment Layer and click OK on the settings dialog.
Before creating an Adjustment Layer, you must select the “Project Panel.” Otherwise, the option will be greyed out.
Once the Adjustment Layer is created in the Project Panel’s Bin, drag the Adjustment Layer from the Project panel to a video track above your clips in the Timeline.
Stretch the layer to span all the clips you want to affect.
Apply your chosen correction (Lumetri Color or Brightness & Contrast) to the Adjustment Layer rather than to the individual clips below it.
Any adjustment applied to the layer cascades down to every clip beneath it. When you need to revise the brightness later, you only update one layer rather than re-adjusting every clip individually.
Quick Comparison — Which Brightening Method Should You Use?
Method |
Best For |
Control Level |
Risk of Clipping |
Lumetri Exposure Slider |
Most corrections, balanced results |
High |
Low with care |
Lumetri Curves |
Targeted midtone/shadow lifting |
Highest |
Low |
Brightness & Contrast Effect |
Quick beginner fix |
Low |
High |
Adjustment Layer |
Multi-clip sequences |
Depends on the method used |
Depends |
Why does my video look washed out after brightening?
Increasing Exposure too much can wash out bright areas. Highlights can lose detail when they get pushed too far. Bring the Highlights and Whites sliders left to recover detail. You can also use Curves to limit the top brightness range. Shadows may start looking faded and soft if pushed too high. This usually happens when Blacks or Shadows are raised too much. Lower those sliders to bring back contrast and depth in the image.
What is the difference between Exposure and Brightness in Premiere Pro?
The Exposure slider in Lumetri Color works using a stop-based system. It also responds to tone mapping, which keeps changes more natural across all brightness levels. Brightness in the older Brightness and Contrast effect works in a simple linear way. It shifts all tones evenly and can cause harsh clipping in bright areas. For most clips, Lumetri Exposure is the safer and more consistent option.
Can I brighten only part of a video clip in Premiere Pro?
Yes, you need to create and apply the mask in the Effect Controls panel. Open the Effect Controls tab first. Then expand the Lumetri Color effect or any color effect like Brightness and Contrast. From there, choose the ellipse, rectangle, or pen tool to draw your mask.
Will brightening a very dark video ruin the quality?
Severely underexposed footage contains noise in the shadow areas, and lifting exposure amplifies that noise visibly. The Denoise slider in Lumetri Color’s HSL Secondary section can help. There is a practical ceiling to how much exposure can be recovered; beyond a certain point, noise and tonal detail loss are unavoidable regardless of the tool used.
For most underexposed footage, begin in Lumetri Color’s Basic Correction panel. Set the Exposure slider first, then balance the image with Highlights and Shadows. Move to the Curves tool when you need more precise control over a specific tonal range, and route corrections through an Adjustment Layer whenever you are working across multiple clips. Once brightness is corrected, the logical next step is creative color grading. Applying LUTs or HSL adjustments to give your footage a polished, consistent look.
