How to Remove Audio from Video in Adobe Express (Step-by-Step)
Need to strip the audio from a video clip before posting it online? Adobe Express makes it possible without installing any software or switching to a more complex editing tool. Whether you’re silencing a noisy background recording or clearing out the original audio to swap in a new track, this guide walks you through every step. You’ll also find out what to do if you hit any plan-related limitations.
Can Adobe Express Remove Audio from a Video?
Yes, Adobe Express supports audio removal directly within its browser-based video editor. You can mute the original audio that came with an imported video clip, which effectively strips the sound without altering the video itself.
It is worth understanding the distinction between two separate audio scenarios. First, there is the audio embedded in the original video file you upload. Second, there is any background music or audio track you manually added to your Adobe Express project timeline. Both can be removed, but the steps are slightly different for each.
On the free plan, basic audio controls including muting a video clip are accessible to most users. However, some advanced features such as higher export resolution or extended video length may be gated behind the Premium plan. For the straightforward task of removing audio, the free tier is generally sufficient.
Quick summary of what Adobe Express can and cannot do:
  • Mute or remove the original audio from an imported video clip
  • Delete a music or audio track added to the project timeline
  • Add a replacement audio track after removing the original
  • Export the silent video as an MP4 file
  • Cannot remove audio from only a specific segment of a clip (partial audio removal is not currently supported in the standard editor)
How to Remove Audio from a Video in Adobe Express
Follow these steps to mute or remove the audio from your video clip inside Adobe Express.
  1. Go to Adobe Express by visiting express.adobe.com and signing in to your account (free or Premium).
  2. Start a new project by clicking “Create something” and selecting “Video” as your project type, or open an existing video project from your dashboard.
  3. Import your video clip by clicking the media upload option and selecting the file from your device. Adobe Express accepts common formats including MP4 and MOV.
  4. Add the clip to the timeline by dragging it from your media panel into the editor timeline at the bottom of the screen.
  5. Select the video clip on the timeline by clicking it. The clip should highlight to show it is active.
  6. Locate the audio control in the properties panel or toolbar that appears. Look for a speaker icon or a volume slider associated with the selected clip.
  7. Mute or remove the audio by dragging the volume slider to zero, or clicking the mute toggle if one is available. This silences the clip’s embedded audio without deleting the video.
  8. Preview your video using the play button to confirm no audio is present.
  9. Export the final video by clicking the “Download” or “Export” button in the upper right corner. Select your preferred file format and quality setting, then save the silent video to your device.
Note: The exact label for the audio control may vary slightly depending on which version of Adobe Express is active in your browser. If you do not see a volume slider immediately, try right-clicking the clip on the timeline to check for audio options in the context menu.
How to Remove Background Music Added in Adobe Express
If you added a music or audio track to your project through Adobe Express’s built-in audio library, removing it follows a slightly different path.
  1. Click the audio track on your project timeline. It will typically appear as a separate colored bar beneath the video track.
  2. Select the track to highlight it and bring up its options.
  3. Click the delete or remove icon that appears in the toolbar or properties panel. This is usually a trash can icon.
  4. Confirm deletion if prompted. The music track will be removed from the timeline entirely.
  5. Preview and Download as normal once the audio track is gone.
What to Do After Removing the Audio
Once the audio is removed, you have a few practical directions to go from here.
  • Use the silent video as-is. If you plan to add captions, use the video as a background loop, or post it to a platform that auto-plays without sound, exporting immediately is the right move.
  • Add a new audio track inside Adobe Express. You can drop in royalty-free music from Adobe Express’s built-in audio library, upload your own music file, or record a voiceover to replace the original sound.
  • Address the source of the problem for future recordings. If you are removing audio because the original recording was filled with background noise, a hardware solution can save you this step entirely. A compact wireless microphone like the Hollyland LARK M2 clips directly to a shirt collar and captures clear close-range audio, cutting out ambient noise before it ever reaches the video file.
What to Do If Adobe Express Doesn’t Have the Feature You Need
If your plan tier restricts certain audio editing controls, or if you need to remove audio from only a portion of a clip, a few free browser-based tools can handle that without requiring a desktop install.
  • Kapwing – A full-featured online video editor with a dedicated mute option and support for clip-level audio editing.
  • Clideo – A straightforward tool with a simple “Mute Video” function that works directly in the browser with no account required.
  • VEED.io – An online editor that supports both full audio removal and segment-level audio adjustments on a free plan.
Is removing audio from video free in Adobe Express?
For most users, yes. Muting an imported video clip is available on Adobe Express’s free plan. Certain export quality settings or extended project lengths may require a Premium subscription, but the core audio muting functionality is not typically locked behind a paywall. Check the current plan comparison page on Adobe’s site for the latest details.
Will removing audio affect the video quality or resolution?
No. Muting or removing the audio track is non-destructive to the video itself. The image quality, frame rate, and resolution of your clip remain unchanged. The final export quality is determined by your plan’s export settings, not by whether audio is present in the file.
Can I remove audio from only part of a video in Adobe Express?
Adobe Express does not currently support splitting a clip to mute only a specific segment. The mute control applies to the entire clip on the timeline. If you need partial audio removal, tools like Kapwing or VEED.io offer more granular timeline controls for that purpose.
Does Adobe Express support all video file formats for audio removal?
Adobe Express works reliably with MP4 and MOV files, which cover the majority of common use cases. Some less common formats may not import correctly. If your file does not upload, converting it to MP4 first using a free tool like Handbrake or an online converter will typically resolve the issue.
Removing audio from a video in Adobe Express is a quick process that works well for most everyday use cases with just a few clicks. Open your project, select the clip, mute the audio track, and export a clean silent file. Ready to go further? Head to Adobe Express to start editing, or explore Adobe’s video tutorials for more ways to build on your project once the audio is handled.
