If you have recorded video and audio separately, you have probably hit the same wall: two files, one take, and no clear way to join them in Premiere Pro. The native Merge Clips feature was built for exactly this situation. This guide covers the full Merge Clips workflow, explains each available sync option, and clarifies when to use Merge Clips versus nesting or simply placing clips sequentially on the timeline.
What “Merge Clips” Actually Means in Premiere Pro
Merge Clips is a Project panel feature, not a timeline operation. It takes one video clip and one or more separate audio files and links them into a single merged clip that you can then edit like any other asset. The original source files are never altered.
This feature exists because of dual-system recording — a workflow where video is captured on one device and audio on another. A camera might record a scratch audio track through its built-in mic while a wireless microphone records a clean, separate .wav file at the same time. When using a mic like the Hollyland LARK MAX 2, which features 32-bit Float Internal Recording as a safety backup track at 48 kHz, that backup .wav file needs to be matched to your camera footage in post. Merge Clips handles that connection precisely and non-destructively.
Two common confusions are worth clearing up before you start. Dragging clips end-to-end on the timeline is not merging — it is sequential placement. Nest Sequence groups existing timeline clips into a sub-sequence, which is also a separate operation with a different purpose.
Quick Reference - What it is: A Project panel command that links a video clip and a separate audio file into one merged clip before you bring it to the timeline. - What it isn’t: A way to join timeline clips end-to-end, or the same as nesting multiple clips into a sub-sequence.
How to Merge Clips in Premiere Pro (Core Method)
Step 1 — Import Your Audio and Video Files into the Project Panel
Both files must be in the Project panel before you can merge them.
Open your Premiere Pro project.
Go to File > Import (or press Ctrl+I on Windows / Cmd+I on Mac).
Select your video file and your separate audio file, such as a .wav or .mp3 recorded on an external device.
Click Import. Both clips will now appear in the Project panel.
Note: Premiere Pro supports most common formats including .mp4, .mov, .wav, .mp3, and .aif. If your audio was recorded at 32-bit Float, Premiere Pro handles the import without any conversion.
Step 2 — Select Both Clips in the Project Panel
Click on the video clip in the Project panel to select it.
Hold Ctrl (Windows) or Cmd (Mac) and click the audio clip to add it to the selection.
Both clips should now be highlighted.
Complete this selection in the Project panel only. If you right-click clips on the timeline, the Merge Clips option will not appear.
Step 3 — Right-Click and Choose “Merge Clips”
With both clips selected, right-click on either one.
Choose Merge Clips from the context menu.
The Merge Clips dialog box opens. From here, you can name the merged clip and select how Premiere Pro should align the audio to the video.
Step 4 — Choose Your Sync Point Method
Premiere Pro gives you four ways to align the audio to the video. Selecting the right one for your situation avoids sync drift and saves troubleshooting time later.
Sync Method |
Best For |
Requirement |
Timecode |
Professional setups with matched timecode across devices |
Both devices must share identical timecode |
Audio |
Run-and-gun shooting and most everyday workflows |
Both clips must contain an audio track for waveform comparison |
In Point |
Manual sync using a set In Point marker |
An In Point must be marked on both clips in advance |
Out Point |
Manual sync using a set Out Point marker |
An Out Point must be marked on both clips in advance |
Numbered Clip Marker |
Advanced multi-take control or complex sync workflows |
Matching numbered markers must exist on both clips |
For most editors working with an external microphone or recorder, Audio sync is the go-to choice. Premiere Pro analyzes the waveforms automatically and aligns them, even when the recording devices were not connected.
Step 5 — Edit with the Merged Clip
Click OK in the Merge Clips dialog. The merged clip appears in your Project panel, usually in the same bin as the source files.
Drag the merged clip onto the timeline just as you would any standard clip.
Open the clip in the Source Monitor to see both the original video track and the synced audio track, ready for editing.
Note: Your original video and audio files remain completely untouched in the Project panel. The merged clip is a new linked reference to those source files. Deleting the merged clip at any point leaves the originals unaffected.
Other Ways to Combine Clips in Premiere Pro
Nesting Sequences (Best for Grouping Timeline Clips)
Nesting is for organizing clips that are already on the timeline. It bundles multiple clips into a sub-sequence that behaves as a single unit, which is useful when you want to apply one effect across several clips or simplify a dense timeline section.
To nest clips:
Select two or more clips on the timeline.
Right-click the selection and choose Nest.
Name the nested sequence and click OK. The selected clips are replaced by a single nested sequence clip.
Nesting does not sync external audio to video. Use it for grouping and effects organization, not for dual-system audio workflows.
Appending or Joining Clips End-to-End on the Timeline
If you simply want clips to play back-to-back, place them sequentially on the same track in the timeline. This is not merging in the Premiere Pro sense, but it addresses a common intent. Use the Insert edit (comma key) or Overwrite edit (period key) to add clips from the Source Monitor to the timeline without gaps.
Merge Clips vs. Nest vs. Join — Which Method Should You Use?
Goal |
Best Method |
Sync a separate audio file with video |
Merge Clips (Project panel) |
Group multiple timeline clips as one unit |
Nest Sequence |
Play clips back-to-back continuously |
Append/join on timeline |
Apply one effect to multiple clips at once |
Nest Sequence |
Troubleshooting Common Merge Clips Issues
“Merge Clips” is greyed out: Only one clip is selected, or both selected clips are the same type (both video or both audio-only). You need at least one video clip and one audio-only file selected in the Project panel simultaneously.
Audio sync is off after merging: You likely chose the wrong sync method. Go back to the original files, run Merge Clips again, and choose Audio to let Premiere Pro match waveforms automatically.
Can’t find the merged clip after creating it: The merged clip appears in the Project panel, not on the timeline. Check the bin where your source files are stored.
Want to undo a merge: Delete the merged clip from the Project panel. Your original video and audio source files are always preserved separately and remain unaffected.
Does merging clips in Premiere Pro delete the original files?
No. Merge Clips creates a new linked clip in the Project panel while leaving your original source files completely intact. The merged clip references the originals rather than replacing or altering them. You can safely delete the merged clip at any time without affecting your source media.
Can I merge more than two clips at once in Premiere Pro?
Yes. You can select one video clip alongside multiple audio clips — for example, if you recorded a dual-channel file or two separate backup tracks. Select all the clips in the Project panel, right-click, choose Merge Clips, and Premiere Pro will link all the audio files to the single video clip.
What is the difference between Merge Clips and Multicam in Premiere Pro?
Merge Clips links one video file with one or more audio tracks into a single synced clip. Multicam sequences are designed for syncing and switching between multiple camera angles during the edit. Multicam is a more advanced, separate workflow and is not intended for simple audio-to-video syncing.
Why is “Merge Clips” greyed out?
The option requires at least one video clip and at least one audio-only file to be selected at the same time in the Project panel. If both selected files are the same media type, or if only one clip is selected, the option will be unavailable. Remember: the selection must happen in the Project panel, not on the timeline.
When you need to sync a separate audio file with camera footage, Merge Clips in the Project panel is the right tool. When you want to group timeline clips into a single unit for effects or organization, use Nest Sequence. When you simply need clips to play one after another, place them sequentially on the timeline. Each method solves a different problem, and knowing which to reach for saves significant editing time.
To build on this workflow, see our guide on How to Sync Audio in Premiere Pro for a deeper look at audio alignment techniques.
