How to Export in Premiere Pro with All Audio Tracks (Step-by-Step)
Premiere Pro’s default export behavior flattens every audio track in your timeline into a single stereo mixdown. For editors delivering to clients, sound mixers, or broadcast playout systems, that default is a problem. Whether you recorded a dual-channel interview with a wireless mic system like the Hollyland LARK MAX 2 or built a timeline with separate dialogue, music, and SFX layers, this guide covers every method to export all audio tracks intact.
Why Premiere Doesn’t Export All Tracks by Default
Premiere Pro organizes audio using two separate concepts that are easy to confuse. Audio tracks are the horizontal lanes in your timeline — they keep dialogue, music, and ambient sound visually separated. Audio channels are the discrete output streams written into your exported file. The export engine does not treat tracks and channels as the same thing.
By default, Premiere routes every timeline track through the Master bus and collapses the result into a stereo output. It does this silently, with no warning that your discrete tracks are being merged. Unless you explicitly reconfigure the audio channel mapping.
This becomes a real-world issue any time channel separation matters at delivery. A dual-transmitter wireless setup, for example, captures two independent speakers on separate channels that a sound mixer needs as isolated files, not a blended stereo track. Understanding the tracks-versus-channels distinction is the foundation for every method below.
Method 1 - Use a Multichannel Sequence to Export Discrete Audio Streams
To export multiple audio tracks correctly, move your clips into a multichannel sequence first. Then export them as separate audio channels inside one file. Each channel stays independent after export. For example, one channel may contain English audio. Another may contain Spanish or music only. This is the most direct approach for embedding multiple discrete channels inside a single exported file. Work through these steps in order.
Before you proceed, check your timeline. You will notice that there is only 1 Sequence with your audio tracks.
Phase 1: Create a New Sequence
1. Go to File, hover over New, and select Sequence.
2. Go to the Tracks tab.
You can leave the number of Video tracks as they are and come to the Audio section.
In the Mix dropdown menu, Stereo or Mono should be selected by default. So click and choose Multichannel.
3. Next, change the number of channels. Remember, the Number of Channels will depend on the number of tracks on your timeline.
If you have 4 stereo audio tracks in your original project, and you want each track to be exported separately in a single file, you will need to assign 8 channels because each stereo track requires two channels in the new sequence.
4. Under the Track Name, you can change the name of the track to keep things organized.
You can also add a new track as needed. For instance, if there are 10 tracks in the original project file, you can click the "+" button to add more tracks in your new sequence to equal the numbers.
6. Under the Track Type, choose Standard from the dropdown menu since you have stereo tracks. But if you have mono tracks, then choose Mono instead.
Phase 2: Route the Tracks
7. Next, under the Output Assignments, click the routing/mapping icon for each track to assign an output channel.
8. Now, set each track to your preferred channel. For example, assigning Track 1 to 1-2 output channel and Track 2 to 3-4 channel. Each track will be assigned to a different channel, so make sure to uncheck channels that are already assigned to previous tracks. Once done, click OK.
11. Rename the Sequence to avoid confusion later, and click OK.
The new sequence should now be visible on the timeline with empty tracks.
10. Return to the previous Sequence and copy (Ctrl/Cmd + C) all your tracks from the timeline and paste (Ctrl/Cmd + V) them into the new sequence.
11. Activate all channels’ monitors and preview your timeline to make sure all tracks' audio is perfectly hearable.
Phase 3: Export
12. Go to File > Export > Media
13. In the Settings section, choose QuickTime (MOV) from the dropdown menu as your format.
14. Navigate to the Audio section > Audio Channel Configuration.
15. If you have 4 tracks, and there is only 1 showing up under the Output Channels, click the "+" button to add 3 more.
16. Change the type from Mono to Stereo (If your previous sequence has stereo tracks). After that, you will notice that each track will have its Source Channel assigned.
17. Hit the Export button.
That’s it! Now, whenever you import this sequence, you will get separate audio channels in a single file.
Method 2: Export Each Audio Track as a Separate File (Stems Export)
When the destination requires one file per track rather than a single embedded multi-channel file, stems export is the right approach. This method is slower but gives maximum flexibility at delivery.
  1. Solo the first target track in the timeline by clicking the Solo button (the headphone icon) on that track header. All other tracks will be muted.
  1. Mute any remaining unmuted tracks manually if the Solo button does not fully isolate the track. Confirm on the program monitor audio meters that only the intended track is playing.
  1. Open Export Settings (File > Export > Media or Ctrl+M / Cmd+M).
  1. Set the format. For audio-only stems, use WAV or AIFF for maximum fidelity. If the client needs a video with isolated audio, use MOV or H.264 with the appropriate audio settings.
  1. Name the file descriptively. In the Output Name field, use a consistent naming convention such as ProjectName_Dialogue_Track1.wav or ProjectName_Music_Track2.wav. Clear names prevent confusion when handing off a folder of stems.
  1. Export, then repeat for each track. Unsolo the first track, solo the next, and repeat steps 2 through 5 until every track has its own exported file.
Note: If you have more than three or four tracks to export as stems, manually repeating this process becomes time-consuming. The Adobe Media Encoder queue described in Method 3 is a faster alternative once you have the individual timeline variants set up.
Method 3: Use Adobe Media Encoder for Batch Audio Export
Adobe Media Encoder (AME) is useful for editors who export multi-track deliverables regularly and want to run all exports in a single pass rather than waiting for each file to finish before starting the next.
Keep in mind that AME does not automate track soloing. You need to prepare separate sequence versions (or duplicate timelines with different tracks active) before sending to the queue. Once those sequences exist, the batch process is straightforward.
  1. Create a duplicate sequence for each stem. In the Project panel, right-click your main sequence and choose Duplicate. Label each copy clearly (e.g., SEQ_Dialogue, SEQ_Music, SEQ_SFX). In each duplicate, solo or mute tracks so only the intended audio is active.
  1. Send each sequence to the AME queue. With a sequence active, go to File > Export > Media, then click the Send to Media Encoder button instead of Export. This sends the item to AME without rendering immediately.
  1. Repeat for each duplicate sequence. Each stem sequence gets its own queue entry.
Which Export Formats Support Multiple Audio Tracks
Not every format can carry discrete multi-channel audio. Using the wrong format is one of the most common reasons a carefully configured channel map fails to survive export.
Format
Multi-Channel Support
Best Use Case
MXF OP1a
Up to 16 discrete channels
Broadcast delivery, archival
MOV (QuickTime)
Strong multi-channel support
Post-production handoff, color grading pipelines
MP4 / H.264
Stereo or 5.1 only; unreliable for discrete tracks
Web / social delivery; not for discrete stems
WAV / AIFF
Single audio stream, maximum fidelity
Individual stems, audio-only delivery
For any project requiring embedded multi-channel audio in a single container, use MXF OP1a for broadcast or MOV for post-production. For isolated per-track files, export to WAV or AIFF.
Common Problems and Quick Fixes
  • One or more tracks are missing from the exported file.Cause: The track is disabled at the sequence level (the track output button is toggled off) or the track is muted. Fix: Check all track headers in the timeline for disabled or muted state before opening Export Settings.
  • Adobe Media Encoder throws a channel count mismatch error.Cause: The sequence’s master audio channel setting (set in Sequence Settings) does not match the channel count specified in the AME export preset. Fix: Go to Sequence > Sequence Settings > Audio and confirm the Master track type matches your intended export channel count.
  • The export has the correct channel count, but audio levels are wrong.Cause: A Master track gain or individual track gain adjustment was applied inside Premiere that does not reflect the intended delivery levels. Fix: Check the Audio Track Mixer for any unintended gain offsets on the Master bus or individual tracks before exporting.
Q: Can I export all audio tracks as separate files in one step in Premiere Pro?
Premiere does not have a native one-click “export all tracks separately” function. The most efficient workaround is creating duplicate sequences with different tracks active, then sending all of them to the Adobe Media Encoder queue and running the batch in one pass. It requires setup, but it avoids sitting through each export manually.
Q: Why is my exported audio only showing two channels even after changing the channel settings?
The sequence itself may be configured for stereo output at the master level. Go to Sequence > Sequence Settings > Audio and check the Master track type. If it is set to Stereo, that means the sequence is not considered a multi-channel sequence.. You cannot change that from Stereo to Multichannel on a sequence that already has edited files. You must create a new sequence and copy/paste the content. The export settings and the sequence settings must agree, or the export will default to the sequence’s constraint.
Q: What is the difference between audio tracks and audio channels in Premiere?
Audio tracks are the vertical rows shown inside the timeline. They help organize clips during editing. Audio channels are separate audio signals, like mono or stereo. These channels control how sound records and exports from the project. You can map channels during export if needed. Still, they usually connect earlier in the editing process. This happens through Modify > Audio Channels or sequence settings. Those settings control audio behavior while editing, not only during export.
If your project requires discrete audio in a single file, use the channel mapping method with QuickTime. If your delivery requires one file per track, use the stems workflow with WAV or AIFF and verify each file in your target playback environment before sending to the client or mixer.
